  1. innovate wideband questions
  2. c20ne! wont start. help!
  3. deactivating my passenger airbag?
  4. unknown start problem
  5. Where is the cat on a Vectra B 1.8 16v?
  6. throttle cable x20xev
  7. 03 corsa 1.2 sxi dash electrical fault
  8. 20seh conversion wiring
  9. V6 ecu chips
  10. Hi-Spec Billet 4s?
  11. pas pump or rack??
  12. Corsa Bs with aircon....Which ones?
  13. Widst 14 inch wheel in vauxhalll range?
  14. mk2 5 stud conversion
  15. brake upgrade
  16. corsa B top mount split (uprated?)
  17. Dome Fuse / Interior Light Fuses - Vectra B
  18. Corsa speedo/milometer
  19. Will vauxhall 5 stud fit volvo 5 stud
  20. volt gauge readings when system loaded( is mine ok?)
  21. Air Filter
  22. Could someone recommend a Terminal Removal Kit ?
  23. C20XE Alternator Relay
  24. Immobiliser poser?
  25. mk3 gsi 16v electrical probs
  26. will vectra c calipers fit my vec b gsi
  27. Digi Dash - dead
  28. corsa b loseing back end on roundbouts at 15 mph
  29. ARB Position/Angle
  30. 4-pot caliper question (with pic)
  31. Astra Mk3 head lamps
  32. Roof rack removal
  33. anyone want to wire my corsa let up cash waiting
  34. LEDs
  35. nova front bottom arm polybushes help
  36. Wiring in indiglo dials
  37. Corsa b keyless entry problem pop doors
  38. Avo Adjustable rear shocks
  39. Mk3 Astra MFD need re programming?
  40. Mark 3 suspension question
  41. tech1 reprogramming for opel / vx
  42. Corsa B EPAS into Nova
  43. Corsa B Steering Problem
  44. Mechanical Speedo to Electric??
  45. astra mk3 interior light??
  46. Electronic speedo drive Astra mk3
  47. Corsa B HELP!!
  48. mk4 astra coilovers onto mk3 gsi?
  49. C20xe plug connector query
  50. Corsa Hydraulic power steering
  51. Vectra B electric windows!! :mad:
  52. Steering column on Mk3 astra / cavalier etc
  53. Power steering issue
  54. steering shakes violently at 70+ mph
  55. 2.0 8v turbo c20ne
  56. BRAKES (nova)
  57. What does this switch do
  58. Vectra ignition and starting
  59. Subframe bolts query...
  60. c20let loom
  61. Air Horn
  62. offside lights not working corsa c
  63. Fault code 74- MAF Sensor,Please Help!!!
  64. Head light bulb access
  65. Subuaru Legacy problems .
  66. Car shakes horribly at 50+...?
  67. Play in wheel
  68. vectra gsi , new stereo but keep display
  69. Corsa B electric windows??
  70. Battery out of they key fob
  71. Astra Mk3 top mount, help
  72. C20xe crankshaft sensor ? wont start
  73. astra mk3 leccy windows!
  74. what size drill bit needed to drill rear f28 mount
  75. mk4 sri astra steering play
  76. custom exhaust
  77. Is there an effective way to clean the icv ?
  78. "Sanity check" on this please
  79. mk3 cavalier rear screen relay?
  80. Xe emerald jenvey wiring diagram ?
  81. corsa not reving
  82. Installing power steering in a 1995 corsa b sri
  83. Astra Gte 2.0 16v Wiring diagram
  84. Zafira Brakes
  85. coilovers rubbing on tyres
  86. digi dash transducer plug wire colour? help please
  87. Bad camber on C20xe Corsa
  88. Spring identification
  89. Rear Disk Conversion
  90. Brake line unions seized, as per usual
  91. Astra VXR 321mm discs
  92. back turrets
  93. rev counter not working
  94. rev needle moving all over the place
  95. Early xe wiring colours??
  96. rear bearings mk4 astra
  97. Corsa B speedo not working??
  98. corsa b front strut nut removal.
  99. Shudder
  100. vectra loom into mk3 astra?????
  101. vectra b strut brace?
  102. Will this run for a c20xe of bike carbs?
  103. ecu,loom,hoses etc
  104. bilstein help
  105. digi cloocks for corsa
  106. faulty corsa c wiper park...
  107. mk3 astra bonnet release cable snapped
  108. V6 Vectra front noise
  109. adjusting corsa b castor
  110. Engine fan on constantly
  111. Mk3 Astra Fan Switch Problem
  112. c20let loom question....
  113. Washer jets.
  114. 12v aux power socket
  115. astra gsi fails to start
  116. Water pump
  117. Astra mk2 GTE ARB's
  118. Amplifier Problem
  119. mk2/3 astra rear strut top position
  120. 2002 Combo DI, Changing ECU Etc
  121. astra g 1.6 8v gearbox oil question
  122. calibra rear brace?
  123. 160MPH electronic clocks speedo signal input
  124. retro fitting cruise control and aircon.
  125. Water coming in mk3 astra van/estate
  126. Angel Eye Led's?
  127. calipers
  128. How do i upgrade the fuel pump wire?
  129. disc conversion problems
  130. water coming in near pedals mk2 gte 16valve
  131. cavalier front camber Q
  132. Vectra SRi non-start
  133. corsa xe OBD fault reading
  134. Corsa C coilover suspension?
  135. Corsa C big brake setup?
  136. Coilover Height
  137. replacement key
  138. secondary air pump relay wiring
  139. Brakes
  140. brake creep ?
  141. Astra G central locking controller?
  142. astra gsi 2003 front anti roll bar fitting
  143. zaffy gsi loom
  144. Help corsa speedo not working
  145. Nova fuel gauge sender wiring
  146. putting a mfd into a astra
  147. cally leathers heated seat in a corsa
  148. corsa race/rally car interior pics wanted!!
  149. more problems with the gsi traction control ????
  150. eccentric and concentric mounts
  151. c18xe wiring loom
  152. mk 4 suspension mounts
  153. Engine Mount
  154. 1st gear switch? now on f20!
  155. mk3 astra front fog wiring help
  156. Removing heater and wiring
  157. Fan Blade
  158. HELP
  159. Gearbox Bushes code
  160. Where has this come from?
  161. My cavalier GSi has an erratic starting problem...
  162. Corsa B bonnet wont release
  163. Alloys
  164. boost has gone and im getting loud sound from car after 2000rpm
  165. Rear Disc Help
  166. Corsa B SPAX RSX Full coilover setup
  167. battery move to boot?
  168. EDS phase 3
  169. Electric power steering question
  170. Astra speedo not working mk4
  171. Wiring
  172. calibra turbo calipers question
  173. Best top mounts?
  174. ECU trans and chip
  175. Vectra front wheel bearing...
  176. Vectra x20xev ecu work on cav x20xev
  177. Annoying Suspension & Road Noise and general whining!
  178. drop links or top mount??
  179. Airbag light on Vectra B... what to check?
  180. Z20LET coolant temperature sender?
  181. Corsa b sxi leccy window question!
  182. wilwood brake caliper
  183. C20XE - Moving crank angle sensor closer in
  184. Wheel alignment question
  185. Brake Calipers 2ltr 16v Astra
  186. Calibra Turbo Subframe into Astra mk3
  187. Vectra GSI (2000), Full Dash failure ?
  188. Wheelbearing
  189. digi dash
  190. What suspension bushes and tie rod ends?
  191. water temp gauge not working?
  192. c20xe cts sensor resistance versus temperature
  193. are 288mm and 308mm discs the same width?
  194. fuel pressure on phase 2 c20let ?
  195. c20let wiring
  196. faulty fuel gauge corsa B 1.2 sxi
  197. Fitting Cruise Control
  198. corsa b sport cutting out
  199. Calibra Rubbing?
  200. (mk1 nova) fitting GTE dials with a rev gauge
  201. Vectra GSI Brakes Issue.
  202. astra mk3 indcators not working!
  203. Vauxhall Carlton - Dials to Digital
  204. digi dash in mk 3 astra sport
  205. Spare key for a vectra C
  206. Cranking power needed for a corsa sport 1.4
  207. New front suspension for Corsa redtop needed!!
  208. Need help on doing a 5 stud coversion corsa b
  209. Brakes judder 02 corsa
  210. x20xev torque settings
  211. corsa indicator problem.
  212. De baffling the exhaust
  213. 1997 corsa sport speedo not working
  214. Vectra V6 Relay
  215. Nova wheel bearings
  216. Replacing The Standard Suspension Help (Vectra C)
  217. Powersteering Corsa Let
  218. rear disc convertion
  219. Reconditioned brake calipers
  220. how do i change the cv joint???
  221. vectra b gsi brakes onto a calibra 16v
  222. ABS sensers
  223. bigger rear brakes on vauxhall cav!
  224. seh fuel problems have i missed something?
  225. installing turbo timer on z20let?
  226. corsa b hanbrake (!) light not working
  227. Corsa c brake discs to corsa b?
  228. corsa suspension
  229. Welding Nova XE .
  230. Tech 2
  231. Electric window illumination relays?
  232. cav mk3 rear axle anti roll bar size
  233. Cruise Control on Combo 1.7 CDTI 08
  234. CV Joint
  235. Fitting ecu on x20xev
  236. flamer kit ignition modules...where from??
  237. astra mk3 footwell yellow plug wirring
  238. corsa wheel spacing
  239. just put a 1.6 in my corsa and it dont work
  240. Gearbox synchros of F20, F20 4WD, F16, F18
  241. fuel pump
  242. Converting LHD Zafira 06> OEM Xenon Headlights to RHD
  243. servo conversion
  244. HOW TO - fit front fogs using a relay
  245. Corsa B Steering issue
  246. cruise control doesnt work?
  247. whats this hose for?
  248. Newbie with a spring part number query
  249. Electrical Problem with Interior Lights.
  250. corsa c brake upgrade
