- increasing low end torque
- GSi reae wheel bearings
- Wiring Problem
- Quick 12V question
- Leccie Sunroof
- who reckns the know it all then...
- Clearing the ECU of a fault code?
- Alarm Help
- peugeot 405 grtd help anyone
- powering laptops from the car +12v.
- Corsa heaters
- Inner wing
- Spluttering
- Strut Braces
- brass band section apply here..... (photo's)
- late Omega V6 into Mk3 Cav Sri
- Cav 3 hatch won't open
- mk2 cavalier
- Urgent Advice Needed
- sussed it!!!
- How much for HT leads? (slaps the ickle vaux man)
- i broke my rev counter?
- Dont Buy Apex
- Urgent help required
- Can u buy...
- Rollcage specs
- My latest rolling road results
- 16V calipers
- electric window help?
- ste_sa or any other 16v nova gurus
- got my car back from the auto electricians...
- Help Help Please Mk2 Astra Electrics
- Ahhh help me ASAP!!!
- Any ideas?
- ABS on Nova
- here
- Wiring help again, last one I promise!
- TEMP DISPLAY READS --.-c
- On, Off, On, Off, On, Off...HELP!
- Battery light like blackpool illuminations
- Gagelight Kit
- My new toy...help me out with the wiring...
- Help !!!! electrical problems!!!!!
- RWD Knocking
- bonnet stuck - fitting new cable?
- mk3 astra suspension same as my cav?
- startup after rebuild, fao builders etc..
- answer needed quick
- NoS injected astra mrk2 gte 8v
- Fitting a push button start
- problem brakes
- Astra brakes
- erm....take a look and help
- Cally bonnet alarm switch - help needed
- astra/belmont,,,,,its died again
- Any Pipercross Viper Gen
- Drilling Discs
- Astra/Belmont mk2 Dash
- erratic idle...help
- Fao Oddball
- leccy sunroof in nova guide. where??
- Astra GTE 16V - difficult starting when part warm
- Fitting an Irmscher Grille to a Vectra
- Uprated brakes
- caliper paint colour
- Best place for ECU
- Final wiring - Help
- Nice little Gauges
- GTE 16v Suspension
- Help - Any ideas??
- Cally T pissing coolant for fun
- 5 stud conversion
- MOT and suspension.
- Leads!!!!!!
- FAO Wallace P
- coding plugs
- What You recomend !
- Water Temp
- traction control
- problems with running of me car
- Water ingress.....again
- My corsa keeps on juddering then staling
- Back brakes service
- Nova Antiroll Bars
- New Distributor Cost?
- Door handles / locks??
- Auto-Vaux parts numbers help
- loose handbrake...
- compression test results
- PU Bushes
- Suspension Kits
- Argh! Springs...
- Window Washers.
- Slow Vectra Sri140
- Where can you get TB's for the V6?
- FAO monkey_boy
- Any bigger brake gen for a cav gsi?
- Static running pressure?
- Astra 16v brakes on Nova
- Nova electric windows
- any one help with major electrical problem
- Springs
- What Dash?
- 1 more thing
- ok i am fed up please read and help me
- Astra mk2 top mounts
- Fogs 'n' full beam light
- Lights/Fogs Problem
- HELP - Brake Fittings
- Alarm Identifiaction
- Astra Shifter Question
- ideas needed urgently please!
- Anyone know where i can get.....
- bigger trumpets.....
- another choke question
- Front electric window motors... in the rear?
- Who`s Car does...........
- Nova rear anti-roll bars
- 16v into a nova
- How do i convert Bar to psi?
- Jetex panel filter - £18.99 *new* should I get it?
- My sunroof is not well....
- -60mm on Mk3 Cav SRi?
- Deadlock Problems
- is there an 8v gte astra on a j plate??
- Car won't idle
- id this part
- whats the first step to improving my performance??
- corsa 1.4 16v heating problems
- gasflow gsi
- Astra mk2 Anti - roll - bar question.
- Rear arches on Mk 2 Astra
- ingnition wires ? help
- Cutting Out with Pipercross Filter
- knowledge needed
- Sticking Brake Calipers?
- Springs and Shocks
- Any one got a puma suspension kit?
- Squeel on startup
- Rolling Roads, whats the deal
- water leak - nova
- UPDATE: 13 hour 34 minute problem
- Lowering Non-GTE Mk2 Astra
- Blue LED for dashboard
- ECU light
- Hmmm, dodgy or not dodgy???
- wot do i need?
- I have 13 hours 34 Minutes to solve this LARGE problem HELP!
- Why does this light stay on??????
- Fecked Corsa
- Any electrical minded people?
- nova runnin too cold
- Front shock nut... - HELP!
- FAO Cris Rose
- Alternator
- Sudden pulling...
- My car has gone in for work today...
- How easy is it to..............
- Car still sits to high at the back!
- lowering help!
- brakes
- Adjusting the alarm
- 16v astra rear brakes
- super unleaded
- standard vaux stereo
- need a new alarm
- Gas struts on MK4 Astra Bonnet
- Countdown to March 9th. Rolling road gen-eral banter.
- Starting Astra 16V GTE
- Calibra rear mod! HOT or NOT?
- AP-22 and AC-22?
- Wheel Arches Pt2
- Compression Test Results
- Changing colour of Digi Dash
- Fuse 19 - can you?
- mk2 astra dash light queery
- for any one interested
- Faulty Rear Wiper
- Rear Wiper Acting Funny
- Speedo/clocks
- My charts from the rolling road
- Wheel Arches
- FAO - G898 BLY please reply or email.
- wire colours for corsa mk1
- revs up and down
- Wiring Fog Lights
- Tyre Knowledge.
- Calculating Tyre Pressures
- Rear Wheel Bearings
- Nova running problems
- How much are bigger brakes?
- Astra handling problem
- mk3 astra brake hoses same as mine?
- What tailpipe?
- wheel / speedo relationship
- Big brakes
- Custom Dash
- Disconnecting Speedo Cable (Weird?)
- dangerouse problem!
- Nova DIY Central Door Locking
- nova 16v
- Greddy Boost Gauge
- Quickshift kit for Omega?
- Rear windscreen
- Replacing control arms
- Speedo Reading
- Astra Gsi trip computer
- How ?
- Aluminium Polishing
- Still losing water
- urgent help
- Wet carpets but dash area dry?
- FAO anyone from Northampton
- alarm/ remote locking
- Had my car rollered today
- wee bit of help please
- Yearly service
- FAO Anyone with a lowered IRS Cav.
- What's the best way to get the steering wheel off?
- Carlton boot solanoid
- Astra GTE Question?? Help
- mk2 astra suspension
- Not starting
- 2litre 16v twin 48 problems/hassles
- 2.0 8v Bottom End Comparison
- Ferrit killing season is upon us!
- Is it worth it?
- What size?
- 2.0 16V Nova installation.
- Apex 60mm or Gmax 60mm?
- Is this correct?
- Alarm recomendations
- You need it... I got it !!
- Gt 136 Wiring Diagram Wanted
- FAO anyone with a Koni suspension kit
- Have a break! Kill a KAT?
- help any 1 got a mk3 astra sri
- does any one no?
- Cavalier Handbrake - Drums
- My first post and question!
- Another question about Astra GTE's.
- What is it?? Can I get rid of it??
- What do you reckon? Twin 45s?
- spax suspension settings
- mk1 gte stalks
- Work this one out please ANY BRAKE EXPERT
- What a flickin day!
- How do you increase rev limit?
- Yippeee Mk3 Strut Tops
- fao 0ddball
