- brake problem?
- 160mph clock conversion, plug missing ?
- Aahh heck! eBay, new wheel bearings!!
- Cheapest place for eibach springs?
- astra mk3 gsi
- EPAS removal
- x14xe keeps cutting out!!??
- Ecotec Coilpack on C20XE
- sbd ignition only kit
- fse power boost valve
- XE Nova, Anti roll bar or not?
- Fault codes - hell!
- belmont fuel gauge and blower
- Brake upgrade
- Help! Ordering Nova Polybushes
- fitting a steering rack
- need help in a radiator
- brakes problems
- goodridge brake lines
- wiring for rear fog light
- Hard wiring my satnav.
- how many relays on c20xe conversion?
- Changing hubs - Cav GSi
- Flashing eml light on corsa b
- C20let weird problem
- Handling the Torque steer.
- help needed engine light/cutting out/speedo
- HELP!! astra mk3 master cylinder connections
- Buying a digi dash without a transducer
- suspenion problems
- combo A axle flip, any ideas?
- Astra mk3 - Total electrical failure!
- gt3071 race spec turbo
- ebay turbo
- astra Fuel pump wiring
- battery light
- Astra gte clocks need bulbs
- possible cause inner tyre wall wear( not camber)
- mk3 astra estate V's van shocks....
- Spax suspension failure
- wipers
- corasa arb lowering blocks
- Caibra decat help wich side is wich?
- heater trouble
- Let Corsa b diagnostic plug
- c20let loom tidy!
- De Catting the Astra
- 50amp Alternator. Enough?
- How to set clock?
- What brakes, 256mm red dot setup or std 288mm?
- coscast do they have larger valves +1mm and guides as standard
- astra mk 4 susspension top mount bearings
- Will this exhaust be too loud???
- identifying mk4 astra model from radiator part number?
- Dim dip switch trouble..?
- pas on a corsa
- Took Digi Clock out of my corsa how do i rewire normal clock
- mk3 cav suspension
- Mk4 Astra Lowering
- nova sri cutting out ?
- corsa 1.4 clocks in a 1.6 corsa????
- zafira 1.6 can i do the paper clip test..?
- Need some 9164475 ECU help
- anyone know anything about HID headlights?
- sport clocks
- astra g mfd (trip computer version)
- Astra Coupe Headlamps
- saxo (sorry) brake problems
- c20ne ecu loom in mk3 petrol van shell with phase 2 dash loom
- Air bag light!
- RHD steering pump on LHD astra G
- corsa engine light contantly flashing
- c20let map sensor info
- Zafira Heater Vent Problem
- cav gsi help my rad fan will not work put a new rad switch on still no luck
- alarm going off
- wishbone and powerflex video & pic inside
- Suspension
- front spotlights astra sxi
- astravan dash loom (z20let conversion)
- Astra Mk2 rear dampers
- wipers dont park, they just stop
- changing power steering rack advice needed
- Brake upgrade for Nova 2 Litre Turbo
- 206 gti heator problems PLEASE HELP
- help needed
- astra mk 4 brakes
- Air-con removal
- weird electrical problem astra mk4 gsi
- Calibra cavalier decat the same?
- Vectra Mk1 HID's - CDX into SRi
- C20let Air Flow Meter (AFM) resistance. How to test the air flow meter?
- Vectra B Which Steering Rack
- Can anyone please tell me what this part is called....
- Nova/Corsa B suspension on Astra
- Converting a narrowband afr gague to read as fuel
- Better to have a low front end or low back end?
- ceramic coating
- Astra g bilstein b14, strut top bearing std?
- astra mk3 cab roof probs!
- Where does this go???
- corsa/tigra 16v rad fans size
- C20let/Corsa B GSI wiring issues!Please help!!
- Vent controls
- Strange photo request
- cav/cali rear suspension
- nova gsi wiring??
- Standard C20LET Chips?
- air/fuel ratio gauge, help needed
- Vectra Abs Lights On
- Useless blower in my astra coupe
- c20xe into my nova, wiring??
- Vectra OPC rear suspenion is knocking..
- Ron Switch? a?b?
- need a new plug...
- Narrowband Setup?
- radiator fan for c20xe corsa
- best castor setup for road
- Rear stub axle and bearing Astra GTE
- People who know Bias Pedal Boxes. Please help.
- Nova tie bars question. Advice needed
- Best bulb upgrade for cali angel eye lights
- Battery light glowing yet alternator giving 13.8v
- Manta front hub - how many bearings?
- NO reversing lights on my Astra coupe any ideas??
- ABS Sensor Bracket Mk3 Astra
- Hub nut too tight???
- mk4 Heater controls bulb
- paperclip test shows CTS (high voltage)
- Brake Upgrade
- Problem wiring electric speedo to 2.0 8v.
- sppedo problems
- powerflex engine mount
- speedo problem
- Spax shocker issue on mk3 Astra
- c20ne tbīs
- Diagnostic Tool for my Tigra. Help
- c20let loom icv and knock sensor
- Newer style steering on tigra mk1
- Calibra turbo rear calipers....
- Need help I can't see!
- wiper speed
- MK4 Astravan power steering?
- engine mount, 1.6 astra g
- Valve spring tool -1.2 16v
- astra mk3 heater
- Fault code unknown to mechanic
- combo van springs?
- Corsa home diagnostics
- Corsa B Coilovers
- Bloody frontera fuel relay.
- astra mk3 bushes advice
- Nova SR/GTE clocks swap
- Is anyone using a lightweight battery? Or know of one?
- Best camber angle for grip and tyre wear on 4x4
- electric windows
- rewiring lamda plug
- Tigra Brakes - Front and Rear C20LET
- Caliper specifications
- 'Stack' Dash Help
- Master cylinder size? Help.
- Nova engine mount bracket
- what brake pads for willwood 4pots!!!!
- 284mm cali turbo 5stud brakes on a 4 stud corsa
- Question about rear cross member bushes
- Help - Which Engine Mounts for Ecotec into Nova
- Battery/ Charging Fault on Cav GSi
- new wing bolts/screws and recievers?
- zafira gsi dash loom
- Astra Brakes
- Calibra superchips
- Astra H heater fan problems!!
- Need help with wiring please!!!
- Wiring looms
- Ecu classifications gy, gq etc what do they mean?
- dizzy coil wiring
- oil pressure gauge problems
- Windows Steaming Up...?
- MID question?
- Corsa 2.0l rear brake conversion
- Fuse Box
- battery to boot need help on conector
- C20xe speedo help
- Do i need lambas for it as its a j plate?
- Switched live wire
- vectra v6 knocking from rear? ?
- quick gearbox question
- mk4 astra heater prob?
- whats this ecu from ?
- 2.0l brakes?
- morrette headdlight problem
- C20xe chip - group n
- blowing fuses
- Vectra-C Backseat Won't lock in place
- Vectra B ABS pump leaking
- 14xe/16xe looms, interchangeable?
- Fitting V6 Brakes
- recomend me some comfortable -60mm suspension kit :)
- Silicone brake fluid
- nova ignition modual
- Nova Corsa steering rack differences
- P reg Corsa, Electric window fitting options
- C20XE problems...
- Fuel pump, issues, please help.
- ECU light keeps coming on
- Cavalier Rear Axel
- V6 Vectra MAF works??
- Omega Brake Lines
- No spark
- my MATE has lost his vectra key
- 4 unknown relays
- do i keep this relay?
- astra mk3 c20let dash tacho not working
- Vectra B C20XE problems... please help
- Astra gsi turbo mk4 exhaust manifold
- rev limiter help
- Meriva brakes question
- 4 stud 288mm discs
- power steering c20xe corsa
- Urgent help!!!
- Squeeky Brakes !
- Another corsa b speedo/epas question please HELP!
- Sealed optima battery refusing to charge... advice please
- Corsa c20xe conversion - Wiring
- Exhaust / Manifold Heat Wrap
- astra mk3 gsi exhaust systems??
- LET corsa ecu mounting
- astra mk3 steering column
- Cavailier suspension on mk4 astra
- What wheel bearings?
- c20let throttle position sensor explained
- old type tigra - cabin temperatue dial relay "clicks" on cold
- astra brake lines
- brake pipe question
- Bordcomputer in nova
- MK3 astra running rich
- Do those leads fit the above coil?
- Corsa B 15" Alloys Rubbing Arches - Wider Arches or Uprated Suspenstion?
- astra g - suspension mount bearing replacement
- Headlight Beam Aim!
- spare plug and wire
- Calibra V6 alternator swap?
- Difficulty sourcing Corsa B Poly rack mounts
- Corsa b not sparking
- Air Conditioning Not Working
- Corsa 1.4 Sport Rear brake load valve
- Problem fitting rear V-Maxx coilovers Corsa b
- calibra rear subframe bush??
- ford keyfob
- Quick question about fitting rear suspension corsa b
