  1. Two problems, one serious, the other not so bad.
  2. Braking Problems
  3. My MOT Failure - Wierd!!
  4. Alternator Wiring
  5. Suspension Stiffness Setting
  6. Early signs?
  7. Up is 3rd, down is 4th. Any involuntary sequential box gen?
  8. Cavalier ABS probs
  9. RR Tune..
  10. Quick Question
  11. Mr Poole
  12. Reducing CO for MOT
  13. Removing Dash to Replace Bulb - MK4 Astra
  14. Nova GTE what are the stats?
  15. power steering or quick rack?
  16. airbox mod
  17. kenwood mask key
  18. Are all manual steering racks the same ratio?
  19. 2.0l 16v conversion......
  20. Suspension/handling update.
  21. Fronteras
  22. 2litre corsa
  23. Help, My car's dead!!
  24. Toad alarm
  25. Ta very muchness
  26. Fitting Air Con
  27. Exit, stage LEFT
  28. Smoking?
  29. Alarm + pager...
  30. Confirm my diagnostic?????
  31. strange start in warm weather...
  32. anybody ever had any experience of faulty calibra immobiliser?
  33. Digital Dash For 16v Gte
  34. wheel offset...
  35. For Tom Stickland(polished parts)
  36. Poly Bushes.
  37. help needed, likes of andy k etc
  38. Number plates & registrations..
  39. 2.0 16v nova
  40. Pants pants pants, can't be bothered etc
  41. Clifford G4 C300 alarm, de-install...
  42. Unidentified Connector
  43. ste_a
  44. Tyre Question After Lowering
  45. Buggered Idle Control, PISSING ME OFF!!!!
  46. Urgent question
  47. Clifford alarm help
  48. Cav gsi suspension problem's
  49. Boost droping
  50. Fitting a Peco BB1 onto my Nova this Sat....
  51. Rear wheel bearing on Mk2 Astra
  52. is this normal?
  53. can u fit calibra ABS to a belmont
  54. Steering Wheel push buttons
  55. Wots the standard boost?
  56. Urgent help needed!
  57. Mitsubishi Lancer Evo 5/6
  58. Alarm Help!
  59. code 16 and 31 again
  60. check control system
  61. MK 3 Astra window winders
  62. Where does this pipe go?
  63. One for the cheap parts guys!
  64. adjustable steering
  65. Rear ABS sensors
  66. Mild Steel or Stainless?
  67. trip computer backup?
  68. 2litre 16v nova holding revs
  69. steering column wiring route
  70. what max boost can i run on standard internals
  71. what can it be?
  72. Inside wear on front tyres?
  73. 5 stud conversion
  74. guess wat happened to me today...
  75. failed MOT, good and bad...
  76. Sunroof Removal
  77. leccy windows
  78. cars running wrong?
  79. how do i replace distributor vacum unit ?
  80. Sunroof removal
  81. Sunroof removal
  82. my zorst is gone quite on me
  83. FAO Si P, Andy K, Mark CDX V6 and any other gen generators
  84. lock problem with corsa
  85. Anbother electric Sunrrof Question !
  86. Just a little post because I'm happy....
  87. More conversion questions
  88. 16v rear beam VS 8v rear beam...
  89. Starting/ECU problem
  90. revs drop really slowly
  91. Anyone running their V6 without the resonator box?
  92. Any Jap Crap fans?
  93. wots the torque setting
  94. Part Number gen?
  95. Astra 2.2 Traction Control
  96. prop-shaft removal
  97. slow leccy windows
  98. Frothy Coolant-Anything to worry about?
  99. Yippee!..... Oh bo****ks!!!
  100. Strong Rubber to Metal Adhesive
  101. "lumpy" acceleration/ sluggish response - help!
  102. FAO Andy k + Mark CDX V6 - V6 wiring
  103. is it possible to have a weak lamba sensor
  104. Astra questions
  105. cav t smokey on idle
  106. handling a Nova
  107. ET 42 Alloys on a nova..whats the score?
  108. Just Nearly Flame Grilled My Cally T
  109. cav 3 suspension
  110. Help with these wires on digi dash
  111. mk3 astra brake upgrade
  112. Nova Gsi Rear Chassis Surpports
  113. Making a differential temp meter (Electronics Bods)
  114. Knock sensor
  115. load leveling suspesion........
  116. Cold air feed?
  117. Cooling Fan not cutting in
  118. 100mA = 1A?
  119. Bushes Bushes Bushes
  120. wots the torque setting
  121. Alarm Fitting
  122. Anti Roll Bars
  123. Cav Sri Brakes
  124. Lowering Springs for mk3 Astra
  125. Vacuum pipe things
  126. Hall Effect Sensor
  127. Urgently Need Wiring Diagram!!!
  128. 16v Master Cylinder
  129. brakes advice needed
  130. Annoying Brake Problem!!
  131. Annoying Battery Level Problem - Very Very Urgent
  132. What on earth????
  133. Alarm transferring?
  134. Auto to Manual?
  135. Quick Leccy sunroof question
  136. Bottom End
  137. Astra 8v Question
  138. whats involved?
  139. water wetter is it anygood
  140. ECU dashboard light
  141. What will fit?
  142. Suspension Springs
  143. FAO: Mk3 Astra owners
  144. Omega 3.0 v6 into a cav
  145. Analogue 2 LCD Dash Conv??
  146. Any diagnosis gen please??
  147. To Cemesis or friends if have the same...(APEXI)
  148. Estability... Backside dengeours..
  149. ECU (novice info required)
  150. RBX motorsport
  151. Power Steering Transfer
  152. coolin prob
  153. Couple of Q's!!
  154. rear discs on corsa
  155. Nova Dash Dials
  156. a new project.......
  157. Fixing or repairing sunroof info needed!!
  158. What sort of price range?
  159. ECU's
  160. juddering gsi
  161. power steering problems
  162. Does Argos sell rolling roads?
  163. Failed MOT on CO Readings
  164. KE Jetronic
  165. rear susp
  166. Rear Disk Converson
  167. Doh! Back to the garage then...
  168. best alarm??
  169. air box
  170. FAO Mart
  171. Multi channel thermometers
  172. tick tick tick
  173. Brembo Max or Min?
  174. Astra II 16v mods
  175. differences
  176. Vauxhall Trade Club
  177. Engineer's report...
  178. back again, I think.
  179. how to remove cally electric sunroof?
  180. electric sunroof
  181. Just did the brakes on the car
  182. Is my car about to split in two?
  183. Fault code 31 (no rpm signal)
  184. Bugger, 2 screws left over!
  185. wire problem or perhaps not!!
  186. Multi Function Display / Clock
  187. Vectra WheelBearings
  188. split pipe and fault codes HELP
  189. looking for a good tuners for 2L 8v
  190. My Cally won`t start
  191. Removing Airbag from Mk3 Cav ?
  192. FAN override switch on a GTE
  193. Its Alive!! Muhahwhawawhh :)
  194. Steering rack replacement
  195. Code 114
  196. cav sri ecu
  197. fitting PAS/Power Steering..
  198. Manual steering rack for Corsa?
  199. air box mod
  200. update on smokey joe..
  201. After some bits...
  202. Do my brake discs need replacing?
  203. Boost gauge fitting
  204. Upgrading my actuator
  205. Strange T/B conversion
  206. Urgent help
  207. fan switch
  208. Immobiliser question
  209. elec wins tip
  210. Uprated strut top mounts.
  211. Couple of Leccy sunroof questions
  212. More Suspension Questions.
  213. how easy to fits springs ?
  214. Astra MK2 bottom ball joint
  215. Converting switches to led
  216. Warning Lights in Nova??
  217. do cav111 shafts fit mk11
  218. Adjustable Thermostats
  219. Pefromance loss problem , help please
  220. Soldering help needed
  221. Autojack immobilisor
  222. Strut Brace for Cav Gsi
  223. Is this normal
  224. Help!! I have to do my steering column
  225. Which springs???????
  226. 1994 16V cavalier lsi
  227. Value of TB'd astra
  228. landing panel
  229. Screech, screeeech
  230. Argh!!!!!!!!!!!1
  231. 8v to 16v conversion, help!!
  232. MAF on 16v
  233. Suspension Upgrade Route
  234. Advice and tips wanted for using a dremmal
  235. wiring a switch (vauxhall)
  236. oops inbox full try now
  237. fao andy k
  238. Why do CV joints click when knackered?
  239. speedo
  240. Speedo Cable AGAIN!
  241. Temperture Climbing
  242. Workshop Manual for V6
  243. Power Steering Alternatives?
  244. Coolant temp sensor?
  245. Donor Car For Power Steering Upgrade?
  246. Power steering makes noise should I worry?
  247. cooling prob - help!!!!!!!!!!!!!
  248. "(O)" warning light. Brake problem?
  249. Slight Mk3 Cav Probs.
  250. Annoying problem
