  1. big end bolts
  2. Alternator Bracket
  3. Running Temperature
  4. I do believe my Trip Computer has gone **** up!
  5. air flow meter
  6. mk3 astra gsi water leak?
  7. -40mm or - 60mm
  8. Is This Too Expensive?
  9. Radio display lighting problem
  10. Volume
  11. Bish Bash. . .
  12. misting astra mk3
  13. TOAD A101 CL wiring diagram
  14. Help!!
  15. Is this normal???
  16. FAO cemesis
  17. 1600 16v nova water hose
  18. Compression of a 14NV
  19. How much?
  20. GSi shocks.....
  21. Whats Leaking??
  22. Nova Dash Change
  23. Brakes Question
  24. jamie_f
  25. alternator Q?
  26. Oh shite
  27. D/Shafts?
  28. Work in progress (pics)
  29. top speed
  30. Will a...
  31. Dash LED Problems (AndyK/PhilAstraSport?)
  32. Brake Fluid Level
  33. car doesn't go straight!
  34. soaking carpet
  35. 5 stud hub conversion
  36. Centre Console on Mk2 Astra GTE 16v
  37. Airbags !!! Wots the story !!!
  38. Dead battery
  39. Bloody Wipers!
  40. Anyone ever changed a dashboard?
  41. astra gsi + momo boss question
  42. 1.7 in a nova ???
  43. Instant Start-up
  44. opening ecu
  45. flat spot - grrrrrr
  46. Corsa possible fault
  47. Revs dropping too much
  48. Nova 1.5 Td
  49. help with cally
  50. Veccy Door Handle ??
  51. E/w
  52. manual rack on mk3 cav
  53. which is better for GSI standard wheels??
  54. Ok a Rover question not a vaux one........
  55. Mk 2 nova speakers
  56. Crap Brakes!!!
  57. Eproms
  58. Lazy git switches on leccy windows (AndyK/Markcdx?)
  59. getting a grip
  60. Nova blowing off.....
  61. fitting a strut brace
  62. bigger brakes on a nova, what master cylinder
  63. Are 1.2 16v SXi corsas reliable? What should you look out for when buying?
  64. How hard can it be to remove a steering wheel!? Someone help for gods sake!
  65. Bid Digi dash problems
  66. Do corsa's have one touch windows?
  67. How do I set up a 2 stage rad fan?
  68. adjusting airflow meter
  69. Mk3 Astra Dials Enquiry?
  70. What Car Should I Get
  71. Corsa Window Motors connectors, Help!!
  72. which is better optimax or super unleaded
  73. Dials (white)
  74. water comming ion through rear clusters
  75. Knock Knock
  76. Thanxxxx
  77. Anyone know if renault wheels fit vauxhall??
  78. ICV's
  79. 160 mph clocks
  80. Lcd Dash Clocks
  81. Immobilizer ?
  82. Heated rear window doesn't work.
  83. rolling roads
  84. Alarm/Astra MkIV
  85. Under bonnet light on a cav where does it plug in?
  86. Its Alive, Running and Upsetting people!
  87. temp monitor solution?
  88. Diff swopping...
  89. Number 19 fuse?
  90. Cav Gsi dampers
  91. Digi dash sender? 8v, 16v
  92. overcharging trouble
  93. Max safe boost?
  94. 5 Stud conversion
  95. electric sunroof
  96. where can i buy some custom brake discs?
  97. Carlton 2.0 auto cuts out when warm
  98. FAO all you "Gen'd" up peeps
  99. Thieving bastards! Choosing an alarm+immobilizer
  100. what paint for calipers..
  101. Cavalier Offset
  102. Question About Astra GTE's...
  103. will cav 5 stud fit bmw 5 stud
  104. what suspension kit ?
  105. running problem
  106. reserve tank
  107. MK3 astra advice needed
  108. Help (I need a main live)
  109. Removing steering wheel (none airbag)
  110. Outside Temp Gauge (Incar)
  111. Too much air. Is it possible ?
  112. How do i reset the ecu in my corsa?
  113. What would happen if...
  114. Wich Pads and discs to use
  115. big brakes on astra
  116. rubbing on nova
  117. the results are in...
  118. How do I fix this ?!!!!
  119. Cavalier GSi handling upgrades
  120. Mbe/dta
  121. ecu cutting boost
  122. project nova 2003. handling questions
  123. removal of astra gte front bumper??
  124. Omega Electric Sunroofs
  125. High Temp.
  126. code 44
  127. how do work these bloody cliffords...
  128. What spec golf gti 16v ?
  129. vauxhall nova quickracks
  130. vauxhall nova gsi sunroof
  131. Spring Help Needed
  132. steering rack where from fitted ?
  133. Nova brake pedal travel
  134. White blobs.
  135. I can't hear myself think...!
  136. T/Box Rebuild
  137. Lowering
  138. Buzzing noise on digi dash!!!
  139. SPA Gauge Fitting
  140. nova wiring - HELP
  141. Help
  142. when i start my car......
  143. V6 rev counter in astra gsi HELP!!!
  144. some advise please
  145. Distributorless ignition
  146. fault code 24
  147. Gunk!!
  148. Ok we know whats wrong...
  149. speedo cable.(noisy)
  150. Leaky boot?
  151. Fixing on doorcards?
  152. sluggish and hesitant just after starting from cold!!
  153. How can i tell if my leads are knackered?
  154. Whacking big brakes on a Calibra Cheap!
  155. digi dash acting strange
  156. Wow Oh My God This Is Amazing!!!!
  157. A couple of wiring questions
  158. fault codes
  159. Ne1 with a nova haynes manual handy?
  160. ABS for or against
  161. How good is.........
  162. Glue?
  163. abs
  164. Blue Lights
  165. Just wonderin?
  166. FAO AndyK/Animal, TB Wiring
  167. how do i drain power steering fluid and change
  168. Meaning of Versions..
  169. Digi dash- plugged it all in and...MORE FECKIN PROBLEMS!!!
  170. what bulbs are in my mk2 astra??
  171. can some1 please convince me that...
  172. Smoke
  173. Spinning bolt on undertray
  174. Do I.....
  175. Weird Electrics!!!
  176. Digi Dash- most of wiring done just got 2 left over???
  177. *Urgent*NOVA tie bar
  178. Fitting bump stops
  179. Converting a 2wd GSi to 4WD??
  180. Aerodynamics
  181. 16v brakes - will they fit?
  182. Digi dash question!! Help!!!
  183. Gmax/bilstien/spax.???
  184. Thermostat switch
  185. Traction Control on Cav GSi
  186. Traction Control Switch
  187. Cold Air Intakes info
  188. Calibra Question
  189. Clifford alarm help..
  190. I did 0-60mph test with my car, i need tips for get better
  191. Strange noise
  192. Blydenstein air box mods in TV.
  193. Wiring Fog Lights In Corsa
  194. ecu question
  195. Abs!!!
  196. managment light!!!!!!!
  197. Faulty ECU?
  198. Corsa GSi vs. Corsa Sport 16v
  199. Actuators
  200. Piston rings/low compression
  201. Cavalier Central locking gone crazy?!
  202. electric windows
  203. what a lovely feeling
  204. Boost Level adjustment
  205. Raising the Final Drive Ratio: Gen needed
  206. Laminar flow
  207. light leveller switch and motor wiring
  208. rev counter on go slow
  209. 1,8 eco
  210. Astra gsi
  211. Fault code
  212. Digi dash not working
  213. Engineering prices?
  214. U know u wanna help.....
  215. MIG or TIG
  216. sticking leccy window
  217. Ford dealers, surprise surprise!!
  218. solenoid push button doors
  219. Cheap HID conversion
  220. Bit of a dilemma?
  221. Heated window relay on Cav GSI
  222. starting
  223. Part Prices
  224. astra hubs on corsa
  225. rough running when cold
  226. Serpi Star GR420 (Alarm)
  227. new torque wrench
  228. Tyre Depth....whats legal?
  229. Electric Window Conversion - 3 door 98 Corsa
  230. Astra gsi (mint)
  231. Airbox mod
  232. tie rod ends which is right which is left
  233. My Thermostat has gone... where is it?
  234. hmm... somthing dosent feel right...
  235. sidelight bulbs
  236. Tech1 ecu
  237. Renault 19 help?
  238. Is there any point getting a full system?
  239. Mitsubishi 300 or Supra !!!
  240. differences of 8v models from 16v cav models on the front.
  241. power steering pump
  242. Hud
  243. Have Wallace Performance done bust/Ceased trading
  244. A CAV GSI with a mind of it's own!
  245. Changing CV joints
  246. Ok... Its getting silly now
  247. Again: quick rack on cav
  248. sri nova, help
  249. Help needed, digi dash instalation in nova!
  250. Etc And Abs Problems Help Needed
