- Help with nova SRI wiring
- Immobiliser over ride for 95 gsi ecu
- ABS sensor for 5stud conversion
- Vectra C Heater/Fan blowup!
- really wierd electrical problem mk 4 astra
- starting problem
- brake lights wont go off when main lights are on?please help
- Anyone know what bulbs are in these headlights (astra Mk4)?
- vectra rear bushes
- 2.0 hubs for swap. "-s" or "t-"
- ID of springs on nova avo coilovers?
- extra bhp for 1.8 16v
- Double the guages!
- corsa x16xe question
- pulling to the right and general wandering?
- Car hard to start after oil change???
- Gauges from calibra to cavalier
- c20xe no spark stressing out now..
- corsa b strengthening ?
- corsa rear disks
- coilover springs for nova c20let
- Need some 2002 renault clio advice - screenwash pump
- how do you adjust the aim on mk1 vectra headlights?
- Horn
- ABS pump after engine conversion
- Rear Wiper Centre Position
- astra G handbrake sticking
- 5 stud drums???
- vectra b ellectric windows not working....
- Hot start valve ??
- Removing mk3 astra wishbone
- Corsa b coilovers???
- Whats involved in lowering a Vectra C ?
- blitz turbo timer confusion :(
- Mk3 astra adjustable steering column
- Brake issue, doing my head in!!
- Bleeding Brakes
- Best way of removing stubborn bolts
- Springs , what do they fit .
- cavalier gsi
- decent suspension (Nova)
- Part number
- M.O.T blunder, please help!!!
- mk3 sport problem (warning long thread)
- Can't open Corsa C bonnet
- Help! what size thread on corsa b track rod ends
- Window Settings after new battery
- Magnex Mainifold - power steering pipes and rad
- VX220 Dials in a MK3 Astra
- engine crossmember?
- oil sensor level
- Wilwood kit for Cavalier SRI plus brake disc queery.
- astra battery light on
- lowering kit for corsa B
- astra electric windows?
- lecy window switch ?
- WHere can I get hose kits for C20XE Corsa B/C??
- paper clip test
- c20xe problem
- Mk3 Astra Deisel Estate to a 2.5 V6 Petrol
- Mk3 Astra MFD just stopped working?
- 2.0 16v corsa
- couple of things
- handbrake back plates on a calibra
- corsa sprint/ trackday car
- fault code reading
- c20xe rev problem
- vectra electric seats no worky
- Gauges
- Vectra B Intermittent Wiper Fault
- spark problem few checks
- vectra total closure
- another corsa turbo problem
- Corsa C20xe speedo drive??
- reverse lights
- Making own loom.
- xe/let airflow meter (telling the difference)
- corsa abs fault, help please Gen required.
- Corsa 1.2 lx jerky engine
- rear caliper bore size??
- Corsa 1.0 12v
- c20xe loom questions
- Lumenition ECU?
- slam panel ???
- vectra b heater blower system fault
- Rear Fog Light
- diesel to petrol wiring looms change
- replacing a corsa standard radiator?
- Big Brake conversion.
- corsa brakes
- Picture request.... heater matrix pipes c20let
- chip identificaton help.
- 2.0 8v help
- fitted adjustable fpr and pump died
- nova gsi clocks, fuel gauge and oil [ressure switch
- I have for some time had a clunk comming form the front passenger side.
- Rear Disc Conversion
- cav gsi/turbo headlamp wipers and parts fitted to another model cav
- is it worth it?
- who knows about isuzu diesel alternators
- Mk3 astra estate odd starting?
- Code 94 Hall effect swich
- battery light is on but its not the alternator! HELP
- Lowering mk4 astravan
- astra/cav springs
- Help on Resetting Dashboard
- Cavalier loweringsprings - TÜV
- Flashed out the ecu codes and am now confuzzled
- nova lights
- 2 speed rad fan on cali only working on slow speed??
- rear breaks calibra what are bigger
- C20XE Temp Gauge Fault
- vectra v6 rear bushes
- corsa b rear anti roll bar ???
- speedo on 96 vectra diesel playing up?
- fluffy steering
- vectra, flat battery now wont start
- Coincidence or not ?
- x20xev - c20xe wiring Help please!!!
- 2.0 diesel fuel pump fault
- Nova rear inner arches
- ABS Light on dash
- c20xe crank sensor
- vectra b brakes
- corsa b rear disc guide ?????
- C20XE Wires
- lotus carlton rear brake judder
- ECU codes won't flash out
- 1.7 td cavalier isuzu starter
- Code Reader
- 308mm brakes from vectra b (irmscher or vaux GSI)
- Nova wheel bolts (chrome/stainless), best place to get..
- Car won't start!!!!
- EPC 3
- Simple electrics question please.
- Dash Queries
- Corsa B EPAS - will it fit?
- Handbrake light switch, where is it?
- Wheres the ALDL ABS plug on corsa gsi?
- Manta B2 GTE - Brake upgrade, suspension and rear diff
- Corsa manual rack on Tigra with powersteering? and hubs?
- Astra V6 brake upgrade with poor pedal HELP PLEASE!
- mk3 power steering
- Digi dash and other electrical faults
- My Interior heater/fan issue
- lossing brake fluid
- Rear disc spacers ( HELP) ???
- Help needed ASAP
- Knackered Alternator???
- Headlight Allignment
- Brake sizes
- Electrical Problem
- Do mk3 rear brakes go on a GTE?
- Astra MK2 GTE front brakes
- Need to Order a couple of Proxies
- 0 gauge fittings
- brake upgrades nova
- brake pads
- Noise coming from my mk4 van - what could it be
- Bolt in Nova bonnet slam panel mod???
- where to get intercooler/oilcooler cores
- another MOT question - race harness
- Vectra C Rear Shocks
- **** braking after changing discs!!
- vectra gsi intersting abs/tc issue....?
- MOT fail or not - front arches
- c20xe cam sensor how to change
- fuel cut off???
- my shockers rubing on my wheel on drives side help
- seats
- ecu coding
- MK4 Astra SRi 2.2 wiring
- M-Tec Phase 2 Vs EDS Phase 2?
- Juddering issue, just found my crank sensor lead wrecked!!
- KYB dampers any good?
- What are these fuses for?
- Zafira electrics don't work
- can you put a petrol battery on a diesel?
- asta digi dash
- c20 xe conversion no spark??? please help
- front top mounts for nova.
- were is my ecu
- no spark
- Small alternator for XE, Autograss car
- 288mm up grade but not happy ?
- Powerflex Poly Bush Query..
- Omega Irmscher Exhaust
- Cruise control
- Cav V6 Rear Anti Roll Bars
- Fuse info needed
- Nova alloy top mounts, help needed
- Corsa B rear demister not working
- bigger slave cylinder for bigger brakes
- Corsa and polycarbonate window fitment?
- Custom Wiring...
- Power Steering
- Vectra B V6 ECU, chips etc
- ASTRA GTE 8v no sparky warky
- Help please another wiring problem
- corsa c epas on corsa b
- let not sparking
- sheared engine mount bolt
- electric windows!
- astra mk3 gsi turbo c20let power steering fluid
- se22 spark plugs
- Which 15/16" vauxhall alloys fit Over 280mm Wilwood 4pots?
- push botton start in a corsa
- multi plug problem please help
- Rear disc spacer plates ?????
- wiring in footwell near the ecu!!
- found the wires on the camshaft sensor broken can anyone tell me which wire goes wher
- Omega wiper stalk upgrade into mk3 astra
- Non working heated leather :(
- Quickie: MK3 Astra Wishbone Bush (which way?)
- 1.6 8v SPI
- Cam cover bolt thread size
- 2.0l Nova Hub shattered help??
- ?? inch wheels over V6 Calipers
- ABS light
- Astra mk4 1.6 running problems
- rust treatment
- Need a steering rack...but which one?
- ??? Headlights too dim...1996 Omega 2.0 16v ???
- fault code 16 twice!
- part number needed please
- found out why i nearly crashed on the m25
- Plugs left over
- Help! Cally Bonnet won't open!
- Astr G Speedo
- Koni adjustables
- eds phase 2
- Astra GSi Brakes
- Haywire Cav Mk2 Dashboard
- Vectra GSI 2.6 308mm brake kit on cav turbo..
- The Best Place to Wire a Boot Popper Too??
- 256mm brakes
- corsa mfd not keep its settings
- Brakes Under Alloys
- battery relocation
- fog light help please
- rose jointed gear linkages
- xe conversion spare plug
- ECU & immobiliser petrol to diesel query?
- bigger brakes but odd bleed nipples ?????
- vectra c cdti sxi mpg.....where is it shown on the dash???
- Astra G coupe seats into corsa B?
- Speedo cable where does it connect?
- need major help electrical problems on a vectra
- 20xe ecu
- XE air/fuel gauge compatability
