- Smelly aircon (pheewewwwww)
- Nova Brake Question ?
- Spin off at Combe; tracking out, or something more serious?
- Ignition key problems.
- Kangerooing at 1500rpm
- hall sensor on 16v gsi cav
- help me
- Its gettin hot in here?
- scrap yard modding
- can a rear unbalanced wheel cause vibrations
- Remote central locking help
- Plugs leads wich ones?
- Cav gsi performance disapointing
- mk3 cav ignition barrel in mk 2 astra
- strange feeling/sound at steering coloumn
- rear phono output on radio?
- electronic spedo trouble
- Anyone know wot this thing does then?
- playing with factory ecus
- 2ltr 8v conversion for a corsa
- urgent 4 ne1 with epc
- Some pic's
- diagnostic plug linked to pc?
- where the hell has this come from??
- Where can I get???
- Leccy Windows Nova - Nova
- ABS Question
- Central Door locking question.
- strange noise when idle
- frontera judder
- Compomotive MO
- Help!
- Ever had a mod escalate out of control?
- URGENT!! - Std Vauxhall immobiliser problems.
- Code 66
- Corsa Problems Starting
- MK3 Rear Springs
- reshell???
- Some photos.
- CAV break light bulb
- Dizzy?
- wiring diagram
- input shaft extraction tool.......
- just finshe d 16 v conversin and no rev counter
- Nova Troubles Help!!!!
- Capacity of a Cav PAS reservoir tank?
- Low charging system
- tunig
- wiring?
- Castle Combe gremlins have struck
- How much for power steering pump.
- Fix It Again Tommorow
- which colour wire for swithched lightes
- Mirror Switch Wiring Query - Advice Needed
- Tracking on lowered Astra mk2
- Brake Problem
- mk3 astra
- DIagnosing a problem...
- nova suspension??
- (Non vaux)Escort Cosworth problems!
- Adjusting my boost?
- HELP!! Clifford Concept 300 Problems Part 2
- just a quick one peeps...v6?
- Inspection (service due) warning on Astra MK4
- Rethreading a wheel hub
- Kangaroo'ing
- Orange Warning Light Permanantly On
- Astra GTE battery charging?
- Help Please..... Rear Disks Conversion
- Revving up
- PLEASE HELP ME!!!!!!! and my Cav!
- Radio code
- Disabling Airbag on MK4 Astra
- Big brake upgrade
- confused.
- Cruise Control failing to work!
- Tyre Pressures!!!
- 25 thou is a lot!
- FAO: 0ddball / Tom Stickland
- Bored of knocky/clunky sound
- Ignition live
- traction control
- whats the pcd of 5 stud vaux wheels?
- Anti Roll Bar Hell
- astra brakes onto nova??
- hows does this sound?
- where can i get rear susp spring mounting plates
- dodgy tick over :(
- Speedo/rev counter illumination lights gone kaput
- Clonking on the steering.
- wiring for leccy windows
- Tonight I did a Paul Daniels on my sunroof.
- non-vaux - Punto rear suspension
- here`s a quickie....
- fuse blows immediatly
- FAO AndyK
- ECU Info Please
- nova nosedive!!!
- brake upgrade
- Is no spare wheel an mot fail?
- leccy windows
- fault codes i've got... now what?
- MK3 Central Locking ??
- Decisions Decisions.
- Airbag Steering Wheel
- ANyone fitted a 120amp alternator?
- Glue
- Rear side light out
- Help Please!
- rear suspension help/advice
- Traction Control Problem
- floor pan
- omega v6 struts
- brakes
- astra g 5 stud wheel fitment???
- Airbag Warning light.
- tick over
- Today I arve been mostly polishing Miles' rod...
- watch out, here comes the dremel
- wheel bearing
- airbag
- Mk2 astra forward foglamp switch
- Vauxhalls are weak!! Surely not
- Calibra V6 ecotek owners - help please!!
- Nova 2.0 16v wiring
- Can someone clear something for me?
- IRS on Kadett/Astra E
- Astra Mk3 Rusty Points With Photos
- I think my car is dying...help please!
- Please discuss...
- HELP Meeeeeeeeeeeee! please
- Urgent One Lads
- Group A, N etc
- Cih
- AN0030 keyless entry system **HELP**
- V Tuning contact details?
- Brake servo testing
- wider tyres
- interior neons wiring on nova...
- fitted bilstein kit today
- Anyone got a wiring diagram for a Toad 201TC alarm
- Sometimes the simple things are the best
- annoying rattle!!!!!!!!!!!!!!!!!
- problem with heater - Calibra - Help!
- exhust question
- dizzy cap
- quick!!!!! and a few questions for ya
- Help needed....mk2 nova dash conversion
- Spluttering and flatspots.......
- what do i need
- v6 advice
- URGENT Alarm Help Please....
- any one use qh parts
- Mk3 Astra Outside Temp Display
- Blowing bulbs!!
- Vectra Problem
- Cav GSi dodgy idle...
- Am I Normal!
- Probs with my 52 reg Astra 1.7 Dti...
- Not Vaux...But need help
- Heater Matrix: how do I know it's dying?
- Nova GSi ECU Plug
- 1.5 td too 1.7 td whos done it?
- Clocking a digi-dash
- Lowering
- 3 pipe mod for Vectra V6
- sprrdo problem
- Handbrake not working!
- Calibra 4wd
- 1st post, Q's about 8 to 16v conversion etc
- Whats this??
- Corsa creaky rooflining
- Help! I can't disconnect the battery without the alarm going off.
- Mk3 Astra sport diagnostics *URGENT*
- 1998 R-Plate 2.0L 16V Sport
- v5
- Lights 'on' warning buzzer on a Nova?
- 16V convertion
- Rear beam and stub axles
- Heater fan blower question
- Thermostat question
- From Understeering to oversteering!
- Handbrake adjustment
- help sorting my leccy mirrors
- nova wheel bearings
- why won't my car start?
- another 8v gte question
- fecking stupid v6.. andy k u may be the man once again..
- wheres the thread on boost levels at different stages
- top strut assemblies
- 2.0 8v question
- V V T I Engines?
- MOT Faliure - Rear Axle Mounting Bushes Worn
- cav gsi fan blower problem
- PVD Kit for 2.0l
- is boost also limited in 2nd
- Clifford Concept 300 Piece of Cr*p!!!
- Steering wheels on the MK3 Cav.
- O dear...........
- Reducing road noise
- overheating gte
- Astra GSi Buying Guide
- Interior Lights...........
- manafold
- pdf manual
- m3 Mirror Wiring
- Cruise control on a cable driven speedo.
- dizzy ?
- Veccy Handles On A Cav
- No ecu light ???
- juddering
- boost gauge -ve readings??
- twin 45s
- Suspension Types
- calipers
- fautly ecu????
- ** Urgent **
- Weight Loss overkill
- mintex M1155's PADS on Track car
- RON plugs
- Fuse keeps blowing
- kangarooing V6??
- weber 32/34 as standard?
- a couple of rebuild questions
- how much is this gonna cost me!
- Air Conditioning Question
- Which wire???
- Is my suspension sitting right? (pics)
- Wiring for digital dash dimmer
- Electrics fried
- 02 Sensors Again
- Handling Query
- Rev counter inop
- Cavalier GSi electric window question
- Speedo and cable problems...
- Interesting results
- 1.7 is now in!!!!!
- rising rate pressure regulators...?
- Wolf3d advice Needed
- ABS Light
- Handbrake question
- trying to understand the physics of it
- How much performance may I loose?
- Swapping rear drums for disks
- Electric Power Steering Conversions ???
- Replacement seats
- Stainless steel system
- f18 cav box
