- corsa sxi 2002
- corsa digi dash with f28
- new battery and now it wont start
- digi dash
- knocking / juddering
- mk2 cavalier 8 valve dizzy
- audi a4 wiring
- Heater matrix
- weird washer problem
- vxr brakes Really pissed off urgent help needed
- Rear brake nipples
- weak spark
- rear coilovers?
- structual support bar
- astra mk3 clocks same as cav mk3
- mk3 cav windows in a mk3 astra
- c20let distributorless ignition
- de-cat
- battery light?
- corsa b smoke headlights
- Track rod ends.....
- astra mk 4 gear linkage
- How do you test a Diode?
- Wheel Bearing Nightmare!!!!
- Full beams problem!!!
- Best headlight bulbs - Which? tests
- mk4 astra indicators not working after engine conversion
- Thread and pitch info required for LET / XE oil take off plate (above oil filter)
- Corsa b temp sensor (External) location
- speedo problems mk3 astra 160 clocks
- few questions about new car
- offical vauxhall wiring diagrams
- mk3 astra - no radio or mfd
- nova rear xe brakes
- unbalanced brakes v6
- brake size and clips.
- Anybody using aem thru boost
- Speedo not working, Astra MK4
- x14xe with x16xe ecu???
- Astra mk4 turbo exhaust
- which fuse
- fluid leaked onto rear shoes
- what's the smallest and best ELECTRIC PUMP for a corsa/tigra??
- Rebuilding a ATE Master cylinder
- Corsa b electric power steering help
- rose jointed
- Exhaust, Brakes and Steering driving me insane help!!!!
- astra 1.7 turbo diesal speedo
- ZF steering rack model number?
- how to make astra mk4 rear anti roll bar
- 2.0 Brakes on a Corsa C
- mk4 diesel van pump wire colours ?
- cali ecotec wiring colour help please
- Master cylinder
- Corsa B Front Anti Roll bar
- Cavalier Rear Shock Absorbers
- Astra springs fit a corsa??
- Nova extra rear anti roll bar
- To buy oil pressure sender or not??
- MBE967 ecu vs VDO tacho
- no spark, changed crank sensor today
- removing mk3 astra steering column
- porsche 4 pot brembo calipers
- MBE Knock sensor
- quick spring question
- Wilwood Calipar Identification.
- C20LET gartrac RWD escort wiring issue
- mk3 astra gsi help!!!!
- Astra MK3 handling, best tyre size??
- Brake Problems!
- De-locked car with flat battery HELP!!!!!!!
- Fuel pump relay.
- Fitting Zeitronix or AVCR (Z20LET).
- Fiat Coupe Turbo Brakes on a Corsa B
- which nokia phone fits
- Knocking from rear of Vectra B GSi
- Cause of bulbs burning out
- x16xe transponder
- digi dash. no revs, no speed. help
- astra mk 4 front struts
- c20xe ecu codes?
- Petrol fumes inside cabin.
- rear axle bushes astra mk4?
- Electric mirrors on 1.8 Astra sport
- Astra Mk3 Shock Absorbers
- corsa c poor heaters
- Astra Gte LCD Clocks Transducers Help needed!!
- Tow Bar Electrics?
- looooooooong ht lead
- air/fuel gauge ?
- stripped corsa weight
- C20LET Wiring
- lanos immo. box
- Trailer coupling possible on Facelift Vectra GSi?
- Heating only working on number 4 setting
- C20XE into Corsa wiring
- J Astra GTE 16v with ABS rear brake type
- Meriva steering column part query
- Tie rod spacers VS arb lowering blocks
- feul pump relay
- Brake servo problem
- MK4 Astra Wipers Very slow
- bump steer
- 2.5 v6 gsi popin fuse 28
- Which transducer with digi dash
- calibra shocks on a mk4 astra
- no reverse lights!
- zafira 'A' fuse's
- starting problems
- clock dislplay and cd player no working
- hall sensor - high voltage.
- Driveshaft lengths
- rear coilovers adjusters for zafira gsi WANTED plz!!!
- Reviews - Spax rsx coilovers....
- bigger brakes astra mk4
- brakes
- juddering brakes
- astra gte engine loom diagram needed engine wont fire
- bigger brakes
- Front caliper dust seal?
- CTS low voltage
- tigra fuel guage
- zafira v reg heater matrix advice please
- 35mm piston rear gte caliper
- can you repair a split braided brake line
- Astra MK4 rear suspension
- I found this hanging down, Need Help
- Air wont come out windscreen vent astra mk4
- Fitting Springs Onto Lowered Shocks
- Gartrac c20let rwd escort
- Air/fuel gauge
- Wot size of torx? (Rear Suspension)
- corsa b with c20xe speedo problem
- Handbrake cable
- why the fuse keep going?
- Sick of understeer!
- scary abs problem :O
- astra coupe turbo x plate 2000
- Rear Brake conversion?
- alternator problem
- z20let Brakes & Discs Needed
- MK3 Astra rev counter fitting
- a/c issue, what you all make of this?
- Worn Bushes
- Corsa B brakes
- digital dash into nova
- corsa c20xe speedo
- c20xe electrical fire
- Corsa Juddering
- corsa b rear arb
- Amal valve wires! were does the red/ blue live go? top or bottom pin?
- Fuel return
- Steering wheel slighty off after fitting track rod ends
- C20LET - GTE Digi dash
- corsa b fule gauge wires (what one)
- advantages of new shocks
- astra mrk3 rear beam on corsa b??
- Caliper piston sizes?
- zafira gsi lowering springs!!!!
- Meriva Discs on Cavalier
- Anyone know what this is for?
- NO RPMS after swap
- no speedo in me corsa b (digi dash)
- no spark on XE engine......
- agila clocks stopped working ??????
- top mounts
- noisy spring
- Speed Sensor Frequency Converter Circuit?
- MK3 astra 5 stud question
- Astra Coupe turbo - Which disk and pad upgrade?
- coilovers?
- nova fuel tank ( 4 pipes)
- VW fuel gauge problem
- paperclip test
- battery draining..
- up-rated strut tops for a mk3 Astra
- Wiper Problem. Is it the motor? Help needed...
- Wilwoods
- Clutch size information
- ABS removal help
- C20LET "ECU-Injector Signal" wire colour.
- corsa c 2002 with a c20xe engine and the speedo, revcounter and temp gauge wont work
- not firing on cylinders 1 and 4
- vectra fuel sender dti and petrol
- Brake Disc Retaining Screw, Same Pitch as Studs?
- Astra Mk4 (G) Temp Sensor Guide
- 2ltr Front Hubs
- astra weight
- Airbag Light, What do Vauxhall Need to re-set it ?
- C20LET ignition coil
- Koni shock on Astra Mk3 Front info required
- corsa b speedo not working help needed
- calibra trip computer
- problem wth a wire at back of engine!!!
- C20let wiring diagram
- strange electrics going on..
- f40 gearbox on z20let
- CAN BUS heeeelp!
- Fitting Lowering Springs
- Alternator
- Push button start
- rev limiter
- quick electrical question
- Just a quick corsa c Question
- big brakes!? !?
- Cleaning Discs
- Flat, Drilled Or Grooved?
- can you 5 stud a small-block corsa?
- Astra 2.2 z20let ongoing speedo issues please help
- C20LET RWD escort, wiring
- Pull up resistor? connections?
- corsa power steering rack
- Standard Vauxhall Astra Front Springs.
- lost with wiring
- Custom brake servo vacuum tube
- E36 wishbone bush changing.
- Corsa B strut brace onto nova ??
- Vectra B - Continued electrical problems
- not braking, only slowing
- How to remove astra mk5 front bumper
- Drive shaft help needed
- astra mk 4 multi timer
- Heaters dont blow cold?
- Airbag Question - 58 Plate Astra - How to disarm passenger airbag
- MK4 Fiesta sidelight bulb
- vec b callipers on a tigra a??????
- electrical fault with the corsa sport.???
- cali 2.0 eco wiring problems
- Will a corsa b gsi ecu work on a 1.6 16v sport
- Car stuttering and missing after 12psi of boost heres why>>
- meriva big brakes on 4 stud vauxhall?
- calibra keys lost.. how bad?
- brembos on a vectra v6 ???????
- c20let corsa strut brace?
- C20LET ignition coil upgrade ?
- connecting C20XE wiring to corsas in kick panel
- vauxhall combo rear hub
- problem with calibra afterburners
- Audi A4 2.6 Quattro Brake Problem
- c20ne corsa loom modifications
- What replacement ecu chips and were can i get them from?
- Please which power steering pump for Astra MK3 with T04 turbo ?
- Godspeed Brakes
- Which Brake Discs
- Coolant light staying on
- bigger brakes for corsa c?
- Making spigot rings
- No eml or no starter
- management dash wiring cutting
- astra digital dash
