  1. Mk4 GSI rims for a Mk3?
  2. BIG problems on my Astra GTE **HELP**
  3. trouble starting
  4. Which ratios are closer ..........
  5. Thanks guys :)
  6. Steel Conrod Shortage
  7. Lower Arm Bushes
  8. Spot the diff...
  9. Hall sensor
  10. What speed?
  11. mk3 astra - remote central locking
  12. Speedo reading wrong speed Astra 16v GSI
  13. ABS light
  14. icv cleaned.... idle now at 2000rpm???
  15. Fault code 17? What is it?
  16. vectra alarm
  17. Cavvy gsi rear beam on Astra 2??
  18. power steering question
  19. v6 speedo dead
  20. HH plate kit nova problem (tie bar plate)
  21. Vauxhall Nova Race/Rally Rear Anti-Roll Bar .
  22. wiring digidash into MK3 Astra
  23. tuning a v6 FAO Animal
  24. help please
  25. Rear spring Falling out?
  26. clifford concept 50, siren question
  27. offset
  28. Over HEating Problem..does this sound right
  29. Mk2 astra GTE sill trims
  30. flippin fault codes!!!!!
  31. fault codes???
  32. Astra GSI front arch shields or normal ones?
  33. fault check
  34. Mincer Query
  35. Lotus engined mk3 Astra!!
  36. Will a Gunsons Fault Finder work on.........
  37. Cavalier remote cental locking
  38. Code 17 - what to do?
  39. code 48??????????
  40. Can someone identify these ECUs?
  41. Knock Knock! Who's there? My rear diff?
  42. Performance Upgrade???
  43. Help taking out the front light Astra99
  44. Rear springs dont look right??
  45. fault codes
  46. Mk2 GTE 16v Coolent Light On
  47. vauxhall tilt and slide sunroof
  48. Help Me Please
  49. vectra full closer
  50. Ashtray blues
  51. can it make SOOOO much of a difference?
  52. how much is to recon me tran box
  53. Delocking
  54. chargecooler rad
  55. Fault code 66 and 73
  56. Corsa SRI high idle.....
  57. binding brakes
  58. alternator problem
  59. My internal electrics have gone insane
  60. anyone used hi-spec before??????
  61. Group BUY
  62. Compression test results
  63. 1992 Astra 2.0 Service light
  64. leccy sunroof, leccy rear windows
  65. astra handbrake cable
  66. power stearing fluid
  67. where does this plug go?? (callyT)
  68. Where has my post gone?
  69. Why my steering rack tore itself off (pic)
  70. ECU for Vectra
  71. Big Brake Kits ??
  72. Front spring replacement...?
  73. Ecu
  74. Vectra Central Locking with fob
  75. MBE + Rev counter
  76. stupid question
  77. Empty threaded hole
  78. Nova GTE suspension - different to other Novas?
  79. What 16" alloys ET49?
  80. Twin 45 Pictures
  81. Corsa Bunny Hop
  82. Compression test
  83. Windscreen Scratched
  84. Corsa Speakers
  85. Wassat red light for?
  86. Help code 66 & 93
  87. Apexi AVC-R Boost controller!help and advice
  88. Hall Sensor
  89. 2L nova probs
  90. Read if you have a problem with your alarm
  91. Cavalier Problems
  92. '00 Vectra idle problems. Can u help?
  93. Annoying door lock
  94. Mk1 Astra V6
  95. Car emits blue smoke occasionally when overtaking
  96. Astra Suspension
  97. slow.
  98. remote radio display
  99. Nova bonnet hinge
  100. info on the 1.7 dti 16v
  101. Blaupunkt CAR300 & phone mute
  102. Locking wheel nuts? & wheel bolts question
  103. Digi Dash
  104. Steering
  105. Power Steering Not Working
  106. Brake Upgrade
  107. code 13
  108. I cracked another one off...
  109. Any ideas on how to get this bugger off??
  110. Corsa 2.0 Wiring help
  111. Help Required
  112. GSi Fault Code 36 On Nova GSi
  113. Settle this argument please
  114. 16V Astra Mk3 Airbox
  115. would an evo 5 fit??????????????
  116. Front lower susp arms
  117. Water Loss
  118. K & N
  119. Two problems with my calibra
  120. how much
  121. Golf MK3 2.8 VR6 Specs
  122. Nova Electric windows
  123. Computer Display problem
  124. Display Screens
  125. Strange sound!
  126. Battery question
  127. Calibra Momo G/knob onto GTE 16v ?
  128. Magnecore leads
  129. Shell preping
  130. frontstrut/hub
  131. What would happen if it runs to ritch
  132. CAV V6 - rear hubs / stub axles ........
  133. E16SE running problems
  134. How to clean a piper x cone filter ?
  135. Corsa/Tigra front suspension bolt renewal??!
  136. Diagnostic plug on a Tigra
  137. Cav Sri Playin' up
  138. Time/Date/Temp display
  139. HELP! Advice needed!!
  140. How many turns have the steering rack of the gsi models from lock to lock?
  141. rear springs on cav question
  142. First Performance upgrades On Vectra V6
  143. mk3 to mk2 interchangablitity
  144. emission reg's
  145. Webber Twin 45 Advice
  146. Cavalier GSI
  147. corsa ecu light on
  148. Vectra Fault codes
  149. Can I test an ECU?
  150. New wishbones, now tracking out...
  151. No fan coming on.....
  152. Cooling fans at reasonable cost?
  153. Strange issue
  154. weird rattling
  155. astra gsi
  156. another dodgy ticking noise
  157. quick cav sunvisor question
  158. Play in wastegate?
  159. Corsa C Speedo
  160. Replacement Cav electric arial
  161. Sortin' out Cav sri suspension
  162. V6 Error Codes Help
  163. V6 astra
  164. VX fully synthetic
  165. Silly Question of the week. Is my Arial working?
  166. Electrical Problem
  167. Strange clicking noise
  168. Rev Counter/Speedo Woes
  169. resetting the ecu
  170. smoke out of dipstick tube
  171. Gauges
  172. mk3 astra owners - sound deadening
  173. Wing Removal!
  174. WHY countersink arp rod bolts?
  175. Electric window problem
  176. Best place to get a cooler thermostat
  177. Photos/Info Astra Mk2 Strut Braces Req
  178. Lost Keys
  179. Why does my car Judder?
  180. electric windows
  181. Tyre prices?
  182. frontera front bearing
  183. Rattly Boot lid
  184. Protecting exposed bores
  185. Trip counter not working very well
  186. Lekky Sunroof..
  187. Grab Handles
  188. Springs for Nova
  189. Sparco seat subframes.
  190. TOAD central locking control
  191. A lot of different answers.
  192. insurance
  193. Compression test results.
  194. wiper motor
  195. No performance Mk3 Astra - help me!
  196. Stiffening up my Gsi?
  197. Cabin fan blowing warm even when set to cold
  198. Brake light Switch
  199. How do you read fault codes.
  200. Port runner length and plemnum volume
  201. torque setting for knock sensor
  202. astra gsi mfd what dose this mean?
  203. Fault Code 44 - Oxigen circut low voltage
  204. Diagnostics port on a Astra GTE ?
  205. pic required of back box
  206. intera heater only blows cold.
  207. Calipers
  208. Disc size
  209. break pad help
  210. top mounts
  211. Urgent Please Help
  212. v6 into a cav
  213. Can someone help me with these ECU fault codes please?
  214. Whats the 'L' stand for?
  215. 2.0 8v NE and SEH engines
  216. What have I done!!
  217. diagnostic problem
  218. Stuck WTF
  219. A cunning plan for digi dash
  220. ARP Rod Bolts - Counter sinking? help
  221. Cally broke again !
  222. Rough idling
  223. Clear side repeaters...
  224. lower final drive
  225. do these plugs look ok?
  226. Lowering springs
  227. Fao Rds, Atc
  228. v6
  229. pug offset
  230. speedo cable noisey
  231. running more than 1 LED off a Clifford LED?....
  232. SR dials into 1.2
  233. mk 4 astra
  234. Cost Of Cav Steering Rack???
  235. misfiring
  236. Heated rearscreen
  237. What would you buy with £2k
  238. bust pipe/tube thingy :)
  239. Spec on late Astra Sport and CDX 2ltr?
  240. alternator light????
  241. Bias Pedal Box
  242. Nova Poly Bushes
  243. Hang'in revs
  244. need a spanner
  245. car slowed by immobilisor wiring?
  246. Vented rear discs
  247. Meltdown HELP
  248. Thermostat Quesion
  249. Total Closure leccy windows
  250. Cavalier GSI Rear Brakes
