- Calibra V6 ECU Light
- Remote locking problem - driver side wont open
- Installing electric windows to one without enough pins
- Corsa wiring - rear window heater
- 4 pot upgrade
- Calibra SE9 V6 Tracking Issue
- C20XE into Cavalier TD
- Corsa B EPAS - Steering wheel options
- Braided brake lines
- 1.8 Zafira - Possible MAF fault
- c20xe help aux belt
- corsa b can't open hatch with key
- Ignition live - Corsa
- xe loom
- brake upgrade help
- Meriva Insp reset help
- aftermarket engine management on a z20leh?
- T/C switch does nothing on calibra v6 SE9
- Will a scorpion s/s exhaust from 8v fit a V6 calibra
- Isuzu not charging - replaced alternator
- Drive belt tensioner
- late redtop into corsa b sxi 1.2 16v
- Sunroof problem
- corsa b big brakes
- c16xe fault codes
- Ebay keys/fobs worth the money?
- zafira self destruct
- late dispak c20xe wiring
- PAS into a Belmont
- Corsa Knock sensor wiring - engine loom
- combo van rear suspension?
- Astra coupe fuel pump relay (Z18XE)
- Corsa 1.5d to xe
- Rogue wire to rear of spotlight switch
- Astra G and Zafira A use the same box?
- remapping
- mk1 gte brake hose fit mk2 gte????
- Urgent help requried on servo removal please on mk3 Astra
- Thanks for nothing
- slight tap on c20let
- Help needed!
- Lower ARB Corsa B
- 160 elecro clocks
- help with vauxhall frontera
- Quick sensor question
- Astra H OPC wiring
- Corsa B handling issues...
- What size bolt? - Nova steering column to bracket
- depo headlights
- Corsa B gsi/sport Std ride height.
- how to disable parking sensors on zafira gsi
- Zafira Central Locking - Question.
- how big off job is astra gte dash into my corsa b
- corsa c seat belt removal VERY STUCK!
- Which hubs? - 20xe Corsa
- where does this lead connect to?
- 5 stud rear drums for a corsa b?
- 04 astra G indicator dying :(
- vectra 2.2 dti gearlinkage overhaul
- Broken rear wiper arm on an astra G/Mk4
- Nova brake bias pedal box
- Are Cambelts directional?
- HELP! I think there is a gremlin in my electrics!
- Speedo on my corsa xe.
- HD ECU on LET, differences from pj pk?
- wiring queries??
- head light prob
- New wishbone is stiff?
- Corsa c eps torque sensor adjustment *** ahhh ffs ***
- Cunifer Brake Pipe
- Astra 55 plate not all controls on the cd player working
- corsa b bonnet liner.
- mk3 astra electric windows wont work
- Hel Brake Line Kits for Astra H 4 or 6 Hoses?
- non start startor motor clicking when trying to start
- Multiple fuses blown?
- Bleeding Wilwood calipers
- corsa steering wheel removal
- Lotus Carlton rear suspension problem
- mileage query
- 85 nova knuckles same as corsa?
- astra mk4 R/C/L help?!
- Corsa 1.7D Utility 2000 thermostat
- MK3 Astra van 5 stud brakes!
- poor brake pedal astra h
- x20xev vectra wiring into a mk4 astra
- HELP
- suspension query
- Bolt thread for caliper
- changing bulbs in dash on a calibra?
- which mount do i need for F28?
- Corsa B lowering problem
- Boot lock help
- Axle flip on a combo.. need help!
- speedo not working??
- 60mm+ drop on Astra-G
- Vectra B Erratic speedometer
- Hopefully an easy corsa B question :)
- 1994 cavalier gls td c/locking probs
- urgent ecotec ecu
- c20xe into 1.2 16v corsa wiring problems?
- What aircon rads will fit my coupe turbo??
- suspension
- thermostat on mark3 astra gsi
- Radiator fan / effective cooling ??
- software?
- System exhasut nova c20xe
- Vauxhall tigra wiper switch blowing fuses.
- management light
- Astra Coupe Towing Electrics
- AfterMarket Stereo Wont Work In Vectra?
- corsa gsi springs
- erratic idle/stalling help!
- key and ecu?
- Zafira - Speedo and mileomiter not working
- Slight grinding noice when accelerating....??
- astra gsi mk3 and vectra do they have the same pillar pods
- Astra 1994, Time , Date , Temp * HELP *
- Powerflex ARB bushes - how much compression?
- horn relay
- zafira ofside caliper?
- redtop braking
- astra 1.4 ignition advance tuning
- fuse blowing
- Iratic idling
- Quick Drive Shaft question.. Vectra
- Corsa B Clock
- OPEL OBD
- Suspension Question
- Drivers side door electrics
- wiper wiring
- L.E.D bulb problem!
- brake caliper
- air flow meter are they same for vec 2.0dti and 2.2 dti
- Any " Change Driveshaft Guides " On here?? Vectra 1995
- corsa c no hazard or indicators
- Astra g petrol smell
- Corsa c Brakes
- mk3 gsi mfd,temp shows "f" ?
- gsi trip computer mk3
- mk4 hid fitting help???
- How do i use Eezibleed?
- 1.2 16v loom help needee for conversion..
- Tigra rear brake conversion
- help and advice on brake upgrade please.
- Heater blower switch packed upBlower
- Astra gsi compbrake concentric mounts
- Wiring up management light with no speedo?
- Power steering
- X18XE1 Fault codes p0100 and p0110
- Astra mk4 power steering steering rack in mk3
- Z18XE Still not Running Right running out of ideas
- Corsa B with Cavelier Hub
- urgent help needed pls guys!!!
- new sensors for aftermarket loom
- Z18XE/X18XE1 help
- Astra mk4 gsi Alarm and starting problems help?
- Jamex suspension kits, any good?
- ecu earth?
- weight of a power steering rack?
- gte brake servo knackered
- Corsa B electric windows
- no brakes corsa
- Clearance Issues F28 vs Tie bar
- Corsa b/Tigra A XE Strut brace
- corsa rear discs
- Astra TD brake servo
- Vectra electric window
- Heated Seat wiring?
- tyre size and make for let corsa
- ebay sellers .
- Mk4 Speedo Over reading
- rear discs
- what do i need to put the mk2 astra gte digi clocks on my astra mk3 ?
- Replacing dash bulbs with leds in digi dash
- Corsa Clocks
- can i test my brake servo
- car locked and wont open ?!
- V6 auto wiring loom
- mk5 suspension on mk4 astra?
- wiring diagram
- creaking noise from front of astra mk4
- balljoints!!!
- replacement hub, need help
- rear bike shocks on cars?
- Corsa B big brake upgrade advice.
- Toyo R1R'S
- What is this?
- Brake Info needed - websites?
- Coilovers for a Corsa b 2.0l
- bad problem with my corsa b rear lights /wireing
- Adjustable Spring Platforms.
- can a power steering rack be fitted to a 1.2 1997 sohc engine
- changing struts and brakes?!
- Hub sizes?
- Astra G rear discs
- Astra mk3 abs problem
- Corsa B 1.4 16v how to clear fault codes
- Astra v6 rev counter help pls
- Please help need to wire up 1.216v corsa to c20xe
- OPCOM - where to buy?
- Hi spec 285mm disc on 256 calipers kit fitting instructions?
- quick ecu question ** URGENT**
- Digi dash in corsa b with xe
- veccy b to calibra
- 1.8 SRi traction control?
- HIDs effect radio
- Tigra ignition barrel
- rear anti roll bar on corsa b
- 308mm brakes and 16inch mos??
- mk4 astra speedo problem
- corsa B digi dash
- Will a Vectra B towbar fit a Cavalier as well?
- Brakes and Suspension advice
- exhaust question
- how to flash out DTC's 2005 astra van euro4
- corsa c speedo??????
- 2ltr ecotec wiring
- Coilovers on Corsa B - HELP!! :-(
- vauxhall 4 stud 'big' brakes
- LET ECU mapping
- Tial 44mm wastegate to ebc
- wiring redtop corsa
- electic windows
- Fitting oil pressure sender help
- Clunking from drivers wheel area
- corsa gsi starting problems and battery light
- Vented and drilled brake discs
- cavalier turbo diesel clutch
- Astra-G heater controls
- wiring help corsa redtop
- Astra G steering issue...
- Stripping interior
- Mk3 Astra GSi Air Purge Tank, Fuel Line qu??
- will these be any good
- Mk5 rear beam on mk4 astra?
- C20xe F20 speedo probelms
- Vacume pipe
- astra g dash lights
- corsa b relocate heater controls
- tec question
- cavalier lowering
- DTA S60 pro
- Wheel Wobble :|
- Nova rear chassis leg rotten
- ronal turbo wheels will they?
- astra mark 4 window wipers
- suspension ideas
- Vauxhall sxi code
- speedo on off fault?? help please
