  1. octane coding plug!!!!!!!
  2. PAS Pulley Question
  3. Seized Brakes!
  4. Heated seats
  5. centrel locking
  6. ABS fault code help
  7. Alternator / Electrical
  8. Fitting an electric aerial to a mk1 nova?
  9. what next??
  10. cav gsi tuning
  11. astra mk3 wings????pls help!!!!
  12. Tbx Problem
  13. Manual to electric wing mirror swap
  14. Steering problem
  15. Will the 16v digi dash work ok on a 8v?
  16. 215/16/40 (ET35) on rears of an Astra mk3
  17. Wiring Help PLEASE
  18. run-in
  19. leak in the boot
  20. Got my V6 rear beam!! Photo
  21. whats not there???
  22. CD player Fuse ?
  23. A wee problem here
  24. 3 small pipes
  25. Fitting front brake pads
  26. car diets
  27. fecking cars
  28. waste gate flutter
  29. vectra noise
  30. TC on v6 cav
  31. Mk4 Astra elec problem
  32. pressure switch
  33. disks
  34. Horses
  35. full house
  36. can you run nos with...
  37. MK3 Dash into MK2 Astra
  38. oh no :(
  39. whining noise from vectra
  40. Vectra SRi alloys - what width? offset?
  41. ABS-next stage.
  42. Cleaning out my new rocker cover....
  43. Lightening and balancing
  44. Total closure on rear windows
  45. Wiring Help Plaese
  46. final checks
  47. mk3 astra zorst
  48. Please help, I need opinions!
  49. Strut Braces?
  50. deep stud kits
  51. Real Deal Or A Load Of ****?
  52. Wierd Wheel Goings On..
  53. ATC's autotronic NOVA - Traction
  54. Best way to cut up a car???
  55. RWD Nova/Corsa any gen??
  56. Cheap insurance
  57. Astra TD's
  58. where to buy new parts cheap
  59. how feasible is this?
  60. abs light
  61. Increased castor angle on Astra/Nova
  62. HELP URGENT icv
  63. How bad is this? (big pic)
  64. changed outer cv joint and....
  65. Brakes
  66. Help, to connect a haltmeter
  67. Airbox drilling yes? no? where?
  68. morettes
  69. digi dash
  70. Will it sound much different?
  71. Fan Wont Work :(
  72. best place for new car parts
  73. White Fluff Around My Thermostat
  74. Question About MOT
  75. 15"-17"
  76. Bleeding brakes
  77. mfd????
  78. Nova terrible handling characteristics, any help?
  79. Vectra Dash
  80. ABS fault code
  81. Corsa starting probs.
  82. GTE 16v Starting Problem
  83. starks
  84. Urgent Help Needed Please
  85. Nova TD Tuning
  86. Update - Total closure, finally!
  87. 6 speed box...
  88. Does Removing Ecu Clear Fault Codes?
  89. nova electric windows
  90. Difference on p/s racks gsi or not?
  91. Polyurethene Paint?
  92. bad mpg on vectras
  93. Ron settings
  94. One Brake Light Not Working!
  95. how long will a cv last with no grease?
  96. Abs
  97. Piston Rings nakered???
  98. Daewoo nexia gen?
  99. more re-assembling questions
  100. Urgent Astra Mk3 Vauxhall Alarm
  101. Astra GSi Spec
  102. Gsi Front Leg
  103. Mk3 Astra Rear Beam Question
  104. Dash Light.
  105. MOT Failure :(
  106. Cavi V6 troubles....
  107. Waste of my damn time - closure!?!
  108. cavalier gsi side skirt removal/sill
  109. noise limits
  110. noise limits
  111. help me spend 150 quid
  112. rear disc
  113. Tappet variations
  114. tick tock
  115. Digi Dash Help
  116. Wiring Problem?
  117. Drainage Plugs
  118. GTE 16v Rad Fan
  119. Big discs
  120. Unsucessfull days moding - maybe. Coolent Questions!?!
  121. Do I need a rebore??
  122. reinforcing inner sills on a convertible
  123. Twin delorto 40's? What else is needed to get them going?
  124. K+F springs?? For nova
  125. performance gains with.....
  126. help needed asap
  127. Timing Question.
  128. has this ever been done !!!
  129. fao simon p or v6 bods
  130. air bag light on a vectra stays on
  131. gsi MOT-advice
  132. 5-Stud GTE 16v???
  133. CO2 fire extinguisher
  134. Dodgy rev gauge connected to the alternator?
  135. LCD dash fuse keeps blowing - MK2 Astra GTE
  136. Removing Locking Wheel nuts
  137. mig tig and oxy-acetylene
  138. SACHS shocks
  139. Brakes, servos and master cylinders
  140. Idle Problems and juddering
  141. How to hook up a tacho on a DIS system
  142. Fitting weber 32/34 - autochoke??
  143. *My GSi sounds like a Imprezza!! Arghh *
  144. Replacing 13" with 14": speedo probs?
  145. Chilling your intake charge.
  146. Fitted Leccy Sunroof, Closure now
  147. Cav 3 and Astra 3 Suspension...
  148. Where can i buy RTV?
  149. vectra gsi info
  150. Part numbers needed please.
  151. Exhusts to fit a Corsa GSi
  152. creaking noise from front
  153. Leccy window problem
  154. stripping paint of bumpers/sideskirts
  155. mintex c-tech range
  156. Mk2 astra 16v rear beam- 5 stud.
  157. External swirl pot
  158. Fault Codes: 62, 93, 113, 116, 117
  159. astra springs
  160. Distributors
  161. Hesitant V6
  162. People with EPC
  163. Knock sensor question.
  164. Vectra Springs
  165. Vectra troubles me again...
  166. Astra Mk3 Seat Subframes
  167. will v6 rear hubs fit mk3 astra
  168. New piston rings
  169. fitting new shocks
  170. digi dash on mk3 astra (help please)
  171. would it fit???????????
  172. Name that noise
  173. EPC Pictures Please
  174. Fan assistance - PLEASE!!
  175. Just been bleeding the brakes, now they seem kinda worse?
  176. Decoding a pinout in to laymens
  177. Any ideas what this is?
  178. Wires, Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  179. urgent arrhhh help
  180. nova brakes onto an astra
  181. Air flow meter
  182. I need help with Tyre wear
  183. uprated handbrake
  184. any 1 with a 1990 astra GTE
  185. purchasing collins dv
  186. Knock, Knock!
  187. Still Have Economy Issue's
  188. Just Shattered a Rotor arm!!!
  189. help needed!
  190. Eibach - Sportline Springs
  191. Handbrake cable.
  192. Making plug leads
  193. Astra Mk2 dash --> Nova
  194. 16v Conversion alarm problem
  195. test
  196. Strut Brace For Nova Sport
  197. digi dash help-urgent!
  198. Mystery 'Clonk' ?
  199. Anyone with EPC to hand
  200. GTE Cab Springs
  201. Corsa Rear disc conversion
  202. Anyone running Lumenition?
  203. Maintenance of Calibra 16V
  204. weber
  205. Calipers
  206. astra gsi idling problems!!!!!!!
  207. central locking on cav conversion boot prob
  208. (Code 45) Oxygen Sensor - Too Rich
  209. Will Vauxhall Change my milage?
  210. what gauges should i have?
  211. Astra GSi flat spots
  212. Vauxhall Straight Six 24v
  213. twin 40 dcoe's on corsa sri
  214. Led's
  215. windows
  216. ok to use a pressure washer ?
  217. Calibra - Heated washer jets???
  218. heated windscreen washer jets...wiring?
  219. rough or fine ?
  220. Rev counter..
  221. fitting i.c. --> Nova 1.5TD
  222. white smeg under bonnet
  223. Part number needed
  224. Phantom boost limit!
  225. ECU removal on a mk3?
  226. EPC gen needed
  227. My fecked battery
  228. Astra GSi foglights
  229. F.ucking V6 problems again.
  230. gsi bonnet vents
  231. Calling all electrical boffins :)
  232. Is this normal???
  233. Building an Amp for Electronic V6 Clocks
  234. Nova body strengthening - is it necessary?
  235. wheels fitment
  236. mk4 astra tc + abs probs
  237. solenoid pressure switch
  238. Very strange problem!
  239. Standard vectra skirts, howd they fit?
  240. Cally T Black Smoke on Acceleration.
  241. which white?.......
  242. Tigra Centre Airvent removal - how :(
  243. Nova GSi - idling @ 2500 rpm !
  244. Bearing...
  245. Board computer for Astra MK4
  246. cool Running
  247. People with EPC - Part number needed.
  248. Bottom End... REFRESH
  249. 2nd hand Weber TBs and Alpha ECU - cost?
  250. steam through air vents
