- Windscreen washers
- C20LET fault code 73 low voltage to afm
- C20let air inlet temp sensor.
- Paper clip ?
- lock stops
- coilovers setting height ?
- brake upgrade astra mk3
- Best gearbox set up for MK3 Astra V6 conversion
- Cav V6 springs onto astra sport
- 308mm V6 brake upgrade question
- C20LET Standard Chips Position? - urgent
- Mk3 Astra Making Noise When Turning Right
- Vectra Air Con Problem
- 284 disc Vs 288 calibers
- astravan rear axle
- bigger brakes v6
- insignia vxr discs and calipers on astra mk4?
- cavalier digital tacho
- Fuel Pressure Reg. positioning
- c20let wont start
- Vauxhall Vectra 1.8 - Alarm keeps going off
- Front fog lights wiring astra g
- brake question
- Biggest discs for 15" alloys
- Window Mechanism
- gaz coilovers
- I'm Thinking of buying this car
- nova steering wheel stuck on!
- C20LET dizzy cap - should there be a shield between it&the dizzy ?
- 284/288 calipers
- Help Needed!!!
- Corsa B Power Steering
- Alternator Ampage
- Relocate radiator
- spax vs. gmax vs. apex
- camber kit
- eds phase 2 chip info for c20let??????
- what did lotus tune, corsa b?
- Size discs for wilwood calipers
- 288 and 308 brake pads
- c20let wiring. drivers footwell
- astra gte shocks, are they ok?
- z20let into astra van fuel pump not working any ideas please
- after market diesel ecu????
- Switched live help.
- corsa / nova sri supension
- vectra leccy sunroof into astra mk3 issues
- Going z20let
- any good >?
- 15x7" ET25 alloys on a mk2 astra?
- wiring in a diagnostic plug,
- Mk3 Astra Gsi Traction Control
- Brake conversion - Removal and refitting Calipers - Advice please :)
- Corsa steering racks
- Cavalier Turbo Voltage Drop
- help rear disc conversion on mk2 belmont
- snapped key
- Replacing Drop links
- mk 4 c20let temp guage???
- ICV Connector
- 1530 a/c fault Help z20let??
- Advice re. poss blocked cooling system & a remedy...
- Nova/Vectra coil overs
- nova gsi digi dash, help
- Battery light not working - 20XE in Mk2 Cavalier
- Vectra Central Locking Problem
- cavalier not starting.
- Tigra 1.4 ECU type confusion .
- Corsa C eps into a Corsa B
- GM CV boots + clips and greese
- Adjusting IRS suspension geometry- redrilling subframe?
- Battery relocation
- Driving on stretched rubber gen please!
- Steering rack/column differences (mk3 Astra)
- c20let wiring
- x16xe Speed Sensor
- Part no. ?
- door switch and window trouble
- Corsa D Headlights
- calibra alarm and immobiliser
- 1999 astra remote central locking stopped working
- corsa b rear discs
- Strange leaky problem on Vectra..
- Veccy 2.2 and Cruise...
- filler cap mod
- ford fiesta radio
- Nova c20xe Exhaust JP
- brake bias issue
- bumper removal
- Bled the brakes and now stop light is always on?
- Strange problems on Se9 V6 Calibra Help Needed
- pin data?
- Astra GTE Suspension Springs Advice
- C20LET EDS Phase 2, How to get more?
- 35w HID ballast on 50w HID bulbs...?
- omex launch control
- fitting electric window kit
- [C20LET] Oil Pressure Gauge
- New keys
- TC and ABS lights on.
- Can't get a brake peddle
- daewoo nexia ignition barrel.. same as mk2 astra??
- mk3 astra gsi scorpion back box
- Tigra 1.4 no fan .
- Engine paint
- Can I connect a stack water temp gauge to thermostat sender?
- intercooler ideas!
- Traffic Master issue
- Calibra - knocking from rear?
- Early Type engine into 1l 12v corsa???
- Corsa B Coolant Fan
- Converting Corsa B To 5 Stud
- astra g suspention
- c20let misfiring
- MK4 astra headlight motors, are they needed?
- What brakes to use? Corsa sport 1.6
- Astra G brake rattle
- Clearing of Vectra C airbag fault codes, please help!
- Vecra B (1999 V) brake caliper bleed screw size?
- cali 10 pin vs 16 pin
- Fitting sfi box on corsa b?
- corsa redtop air flow
- looking for nova e16se colour wiring diagram
- mk4 astra headlight adjustment?
- will front springs off a mark 3 astra fit a mark 4 astra
- APEXI AVCR Boost Controller - Not reading boost
- Any body got a guide or link for c20let loom into diesel van.
- Anti Roll Bar Mounts
- Brake Upgrade
- Rough idle in C20xe: likely locations for vacuum leaks?
- Vectra z18xe starting problems
- Cavalier electric window wiring diagram
- Suspensions question
- suspension kit - nova vs. corsa b
- Pics required - Mk4 Astra Coupe Rear ARB fitting
- hydraulic pas on c12nz corsa b
- Brake Fluid, does it deteriorate in a unopened bottle ??
- Would this exhaust be too loud/illegal for road use?
- Vectra SRI erratic cold running
- Mk3 Astra GSi lowering.
- Removing Runners From Corsa B Seats
- Electrical Schematics
- Heater Panel and Indicators
- Temp gauge on mk3 GSI
- ref Corsa B fan probs
- Vectra V6 ecu Fit Old Cav V6?
- corsa b rev counter
- Smallest slim line fans on the market....
- Bottom ball joint Gaiters & mot
- re:wiring up plasma glow white dials
- HELP! z20net trigger wheel info neede!
- Astra G Vxr brakes and 16" Compomotive MOs
- Wiring a 2nd generation TRW EPAS - diagram
- corsa brake master cyclinder
- Coolent dash lamp
- servo/master cylinder do i need to swop 4 petrol one.
- Weighted rear axle!??
- W plate Astra mk4 fan switch .
- How do you diagnose airbag light?
- richbrook starter button wiring
- 16v calipers etc
- CV Joints & Wheel Bearings
- Constantly annoying rattles, clicks & klonks !!!
- mk3 gsi central locking fault?
- Corsa suspension help
- Airbag Simulator / Removal
- cali fuel trip
- Transducer wiring help
- bosch vp44 diesel pump colour of feed wire
- c16xe immobileiser! How do ya turn off????
- my mk4 astra coupes trip computer and cd player dont switch on why
- coilovers corsa b
- not good not good at all !!!!!
- abs for mark 2 16v gte c20 xe
- dragon dti tuning box how to set the jumpers
- Vectra B MID consumption help.
- HELP cav 2.0 16v ecotec
- digi dash to Ford Type 9
- Window Problem
- pics of intercooler on a vectra b
- angle eye prob
- c20let loom+MS vs MS...
- 55 pin ECUs
- Bigger brakes on a Cav mk3 SRi
- fuel gauge fault
- mk4 astra decat
- central locking problems
- Astra Mk4 Van exhaust system
- Wiring a eml light (c20let)
- Huge problem connecting Rack to hubs Corsa b
- HID fitting help
- can a c20let loom run a c20xe engine?!
- best piggyback c20xe turbo aplication
- Cavalier gsi & nova gsi rear ARB thickness?
- what happens to the CDTI150 engine with no CAN
- eps colunm
- Not getting a spark
- C20XE aftermatket oil pressure gauge question
- quick calibra V6 question
- Top Mounts
- corsa c springs
- f28 Mount
- astra mk4 diesel temp gauge
- oil and volt !!
- please help stereo stopped working
- Wiring From A C20XE to a C20LET
- Front Arb size???
- brake light stuck!
- MK4 astra battery suddenly died?!?!?
- VX Parts list / Diagram Online ?
- weber 40 carb setup on a c20xe
- Corsa B or C PAS (Power Steering Pump)?
- Put on Power Cap and EML Came on:(
- Corsa B 1.0 12v Fault Code reading
- 256mm 2litre 16v Spec Brakes
- Sturt brace for a c20ne corsa b?
- mk2 astra rear beam ????
- Nova rear ARB options
- Central locking problem
- Corsa b 1.0 problem
- Battery Relocation Mk3 Astra GSi
- windscreen wipers re-set...
- Adjusting Odometer On Corsa B
- what amp alternator do i need ?
- corsa b steering problem
- Zafira rear door check straps?
- Parts help/query for disc conversion *NOVA*
- c20let aftermarket temp guage??
- lambda sensor
- morretts.... DOH!
- Water getting inside door
- fuel pump relay voltages
- Cam shaft sensor problem! any ideas?
- in need of rear coil overs
- Choosing an exhaust for my XE
- What steering rack
- MK3 Astra: Seatbelt issues
- gsi speedo
- code readers
- astra van brake upgrade
- EPAS on tigra (astra G mk4 pump)
- c20let loom, where does this plug go??
- Power steering on a C20XE questions
- c16se wiring help needed
- Electric speedo-signal
- Godspeed or Reyland big brake kits
- tigra suspension.
- vectra c indicator fault please help
- Crank sensor wires-positive and negative ??
- Calibra V6 ECU Light
