- 5 sided version of a hex drive, what and where from?
- Rev Counter Problem
- Doe's anybody know the float height's fot the sports T40's
- Astra GTE Digidash
- Nova GTE/GSI clocks
- Astra Wheel Cylinder
- at what point do i need to
- Rear Disks on a Tigra?
- Fan switch question
- FSE balcktop
- MegaSquirt
- standard alarm radio fault
- comedy wire hell :(
- ARGH!!! Not again
- Cav V6 cooling fan
- urgent alarm help needed!
- nut'n'bolt set?
- Ok to use +Live from switched ignition?
- Got theses codes
- FUSE-Rating for interior neons??
- Help With Nova Hazard Switch
- Electric Sunroor motor help
- Help Needed :(
- Magpie's cry for help...
- aftermarket electric windows (fitting)
- 2.0 16v problems
- Best place to buy powerflex bushes
- Tapping noise on 20SEH
- Mileometer trip button query
- corsa floorpan box section...
- electrical problem
- MK4 1800 Sport Idle probs
- Upping the boost on astra TD
- What function does the Resonator perform?
- found something>>??
- cool running thermostat bye bye
- 5 stud rims on a nova
- ECU help!
- corsa problems
- BREAKDOWN COVER! which is good???
- Air Conditioning possibility?
- compression test results
- Tuning time
- My mate's Vectra GSi
- what does bttt mean?
- What Is This Hub Off??? Arghhhhh
- does anyone know
- GM Varajet?
- MY00 Astra Sri Master Cylinder
- Quick question
- actuator bush
- What suspension?
- Nova 2.0 16v - Anti Roll Bar & Bushes...
- Looking for a small part to be machined, any takers?
- megasquirt
- Apexi S-AFC
- Nova 2.0 16v Conversion Parts?
- Hot starting (or not)
- et on alloy
- Light Board Electrics
- taking a cav gsi drivers seat apart!!!!
- Building a 2L 8V Corsa B
- amps and things ect.
- Lowering Mk3 GSI
- actuator can it mkea your car smoke
- rattle near actuator
- multi-function display fitting
- drilled air box?
- Help needed !!! car smoking .
- dead again :( no eng management light?
- Nova - lowered tie bar mounts - how low ?
- ABS problem on corsa gsi
- Nova Front Lower Strut Brace Questions...
- Car Problem...
- Tyre scrubbing problem!
- difficult diffs
- anyone????
- Fault Codes
- Mk3 Astra MFD in a Corsa with pics
- Transplant 16v into 8v cally
- Removal of clocks - mileage Question - mk3 astra
- Whats a J Series
- Astra MK3 TDS help
- Needed...GTE 16v rad length ?
- Best IC fo Cally T - Advice Please!!
- coscast stamp
- Reading Fault Codes
- help
- when does boost die off?
- MIG gas
- brakes
- Vauxhall Corsa no speedometer working
- 60mph in to 1st now fcked
- whats better?
- Vectra lumpy acceleration
- Traction Control On A Nova?
- Big Brake Kit
- Cav 16v brakes help
- GTE Check Control
- help wanted please!!!!!!!
- mk3 heater lights
- Mk3 cav slidey sunroof bit
- Elec prob - Whats this relay?
- Please HELP! MFD, Alarm and interior light stopped working!!
- Knocking when cold...any ideas?
- anyone ever done this?
- Electric sunroof in to a corsa HELP!!!
- metal rollers
- calibra 16v into Astra 8v
- weird starting problem
- Quad Lights
- Total Closure Help
- Astra Enginee Management Light Question
- I need a picture please
- 16v Transplant ( Urgent help needed )
- Chugging problem
- differences between steel and alloy bells on brakes
- Dumb Question
- perfomance, where to start????????
- Electrical bods - Explain this!
- 2l 8v Upgrade
- Brake question
- Getting the right note
- Help, High Voltage.........
- Help!!!
- help needed on cav!!!!!!!please read!!!!!!
- Vectra 2.0di dodgy brakes, any help?
- Help...!!!!!
- what does "CORSA" mean or stand for???
- warning light on dash help !
- cav gsi window switch lights staying on
- need a little help please
- heat wrap
- 156k service
- Is this poss? (electrical prob), not VX.
- My Rolling Road Graph
- 2000 Astra SRi Brakes - Need changing help!
- Problem with holding charge
- Cav rear disc conversion
- Nova TD Alternator
- deadlocks?
- fast corsa gsi
- Knackered Alternator?
- breakdown help
- ticking noise
- Tigra Tuning
- diaphragm damper?
- heat reflector
- Rev counter needle jumping on start up. Why?
- help with starting problems with 2.0 16v nova
- vectra 3.2 gsi brakes
- Help Needed! Ignition problem KO'd car!
- Carlton gsi; cutting out @ 5krpm!
- Todays R/R results
- Wiring Of Guages Help
- help needed wiv hazerd switch
- GTE Hub......What other VX shares the same hub?
- URGENT PLEASE HELP!! Removing and Renewing a CV Joint GTE16v
- How to fool ABS into doing its stuff ?
- Coolant Swirl pot
- brake disks!
- spongy brakes!!
- advice on rotor thickness
- Fault Code Question
- corsa rear anti-roll bar
- What capacity 2.0L GTE
- HOW annoying?
- Autovaux - Thankyou
- boost problems
- Focus Style Uni Side Repeaters
- cav computer "f" thingy
- Bleeding brake saga continues....
- corsa irratic idling
- lights
- 2.5 V6 problem
- alloy pulley
- lingering worry about rebuild
- Sorry for being daft
- Cav 4WD Probs.
- MPG readout
- Anyone Had 288 Brakes Under Cav SRi Rims?
- vehicle speed sensor fault
- anyone got this copy of total vaux?
- Fitting a powerflow
- Urgent Help Needed With Getting A Vectra Alternator Off
- Please help!!!!!!
- Redex 4000 mile treatment (old can)
- what a star
- Front brakes binding themselves?!
- Rear Disk Conversion
- '98 Omega 2.0l starting problem
- NGK Iridiums Or Denso Iridiums?
- Input Shaft bearing
- Weber conversion
- Corsa Gsi
- Straight thru SILENCER, opinions please
- Car still hunting on idle after replacing the infamous ICV
- Rear calipers on astra GSi
- diesal nova conversion 2ltr 8v gte
- Calling all Rover tech types...
- Opel Monza seats...
- TID Problems
- driving with just downpipe
- wheel vibration under braking
- Purple Octane Plug?
- Is this where my paint code is?
- Problem with horn
- Help!!!!
- how to build a 16v nova gsi
- choices, choices....
- Vectra spongy brake problem
- Piston rings
- Your getting rid of your power steering yeah......?
- Setting up Verniers...
- Does any 1 know the O/D of vaux door pins?
- Weber conversion
- astra Mkii 8v / 16v front end
- Gas Shocks
- the never ending nightmare...
- v6 mods?
- My Carltons Died :(
- 15's over v6 brakes
- brake pad warning display
- bike engines
- electric windows
- 2.0 8v into Nova
- actuator
- Vectra GSI/ Touring
- 20NM yeah bolloxs to that!!
- nova heater matrix
- Digi dash test...
- Which outer CVs???
- Help
- 14" wheels and bigger brakes question.
- Broken speedo??
- Choking?
- Cav GLi electric window problem
- help on 2wheel drive switch
- vectra engines
- Best Strut Brace for Corsa B GSI? is it worth it though?
- 6 Speed 'Box
- daewoo/vauxhall
- OMP vs MOMO interchangeable hubs or not?
- black smoke help!!!!!!!!!1
- Part number please
- ** Which 6pt Cage - Sunroofed Corsa?? **
- Can I use super unleaded?
- mk2 astra struts vs. mk3 astra struts
- STILL pulling to the left :(
