- Greddy Boost Controller
- mk3 astra bulkhead/stearing rack
- HELP with lowering my corsa!
- Quick help plz, Cav SRI drop link nut.
- astra gsi engine loom
- heater matrix fan relay at fault?
- rear turrets? basic dimensions
- Vauxhall Astra mk4 sunroof stopped working????
- HI-SPEC Brake Kits...
- not a vox question i know but....
- polly bushes
- corsa b immobiliser/transponder wiring problem
- airbag light on and horn not working
- Astra MK4 Coupe Turbo - What suspension?
- astra g clocks
- corsa b redtop rev guage needle jumping
- Corsa C speedo keeps cutting out
- replacing mk3 astra top mount?
- How to wire in an air/fuel gauge???
- 1994 frontera swb 2.0 immobilisor prob
- fk coilovers (nova and corsa b)
- cavalier wiring loom on corsa xe
- magnatec 5w30 with 1.4 corsa twinport
- calibra rear brakes
- Couple of faults with vectra b
- Car still not starting
- 5 speed getrag gearbox- speedo connection
- wiring in horn seperatly
- Rear brakes release unevenly
- Sticky window!
- MFD & wiper stalk
- Lotus elise stack dash to xe turbo
- Omega 2.0l estate brake pipes !!!!
- astra 2.0ltr brake disc size?
- how does an alternator work?
- Alternator in nova bay....
- astra g 2.0 brakes on to meriva carrier
- wiring from scratch heated seats
- astra coupe light steering no grip
- is this where the oil filter is located?
- Corsa C Backbox
- Acoustic panel engin ebay
- Solid Top Mounts - Astra Mk 3
- wiring help- fitting a 8v into a 16v gte
- Fitting Oil Breather to C20NE
- vectra handles on cav ????
- astra gte REAR LIGHTS
- URGENT HELP! Paper clip test Corsa B
- VXR brakes on a MK4 Astra G?
- astra g clocks
- astra f c20let speedo query.
- Resetting the "INSP" message on Corsa C?
- wiring central lockin on corsa b 1.2 ls
- limiter on a combo van
- Why do my wheels keep goin out of balance??
- Upgrading FPR on LET?
- need help (engine stops while steering the wheel)
- cav engine in a mk3 astra wiring help
- Rear coilover setup astra mk3
- c20let ignition module ?
- Gen me up on these bolts (GTE Ball joint)
- engine management light
- Finding best road only setup (coilovers)
- Powerbox Fiting Issue X14XE - Urgent!
- Temp gauge is not working on calibra. Any help appreciated.
- What engines for 20XE steel sump?
- 1997 Astra GSi - What Alternator?
- 20SEH brake vacuum hose help...
- wiring help needed please.
- The state of Britains roads the cause of Wish Wash steering?
- custom length clutch/throtle cables????
- need help (electrical)
- no cold air coming from vents
- Corsa B lowering springs
- Chamber setting up on a corsa
- brakes on mk4 astra van
- corsa sxi steering
- what lb springs for 680kg front axel weight?
- Vectra gsi 2.6 calipers...
- suspension tips and set up for 1/4 mile racing. chip and all them help please.
- how much should i lower and best to lower with??
- calibra seats in to nova
- bosch super 4 spark plugs
- changing milage on digi dash
- corsa b ABS
- air con help
- ZC Vectra brakes on Calibra
- Wheels spacers for corsa B. Where from??
- vectra boot lock pre/post facelift
- Testing the spark from a coil
- will calibra 2.0 struts fit a astra mk3
- supernovas suspension
- 2004 Vectra 2.2 SRI Cdti getting hard to start
- Turreting rear suspension: Pro's and cons
- polyflex wishbone bush, corsa b? which one do i get ?
- Cav uprated spring/standard damper question..
- Corsa b Knocking- wishbone bushes?
- mk3 astra struts spacer
- Roof skin on Corsa
- Rear polybush kit
- Fiat coupe brembos?
- Fitting angel eye headlights corsa
- nova elec window switches, where to get/any upgrade ideas
- Tow bar electric
- V6 Conversion - Speedo Problems
- astra vxr brakes on corsa b
- corsa front brakes
- ign live on a corsa-c 1.2 16v 2001?
- corsa c central locking wont open?
- Corsa B C-LET Starting problem
- Urgent help!!! MK3 Astra rear quarterlight
- Bilstein b12 nova kit?
- astravan suspension
- grinding noise when i turn right???
- Hydraulic handbrake
- astra mk3 gsi & astra mk4 1.6 Brake
- Fuel gauge problems
- Position light/tail light goes dim when brake light comes on.
- bonnet wont open on corsa C?
- URGENT, corsa b brake pipe length.
- Battery warning light dimming Corsa XE
- What's this pipe for?
- Tracking stress!!!
- ecu plug earth problem
- Att, people with epc
- what springs are lowest for cavalier?
- Corsa B Horn Wireing Behind Steering Wheel
- battery kill switch
- Calibra rear brakes Upgrade
- 16v Brakes on a corsa B
- corsa sport springs
- imobiliser
- 2.0 ecotec 95 m omega cam timing marks
- is the power steering cooler needed?
- MOT Day
- Help, one and for all annoying noise corsa b
- toad ai606 alarm help
- 2 questions to ask pls
- Battery help
- Eibach Springs - Pro kit
- Power steering column?
- lowering springs on standard shocks
- Nova brakes?
- xe conversion
- suspension upgrade
- Corsa 1.5 TD tunning
- Plasma dial kits
- corsa c20xe engine mount to engine bolts?
- would a driveshaft nut cause the wheel to play if it isnt tightened enough
- Nova hand brake cable?
- cav srings on a mk3 astra?
- suspension torque settings for corsa B 3Dr 1993 shape
- v6 coolant temp sensor ?
- mk3 / mk4 astra springs
- suicide doors
- ecu
- xe corsa suspension
- Double wishbone Q - Technical Discussion
- nova rear disc conversion
- 1.4 sport cold starting
- Simple disc brake question
- Dodgy steering after pothole smack!
- Squealing when turn right
- brakes
- Battery Cut-Off.. where's yours?
- Brake flaring question
- gsi loom
- astravan central locking not working after v6 conversion
- ECU Top-Bottom
- fk coilovers.......
- corsa redtop wheel bearings help
- Mk4 astra sticking wiper problem.....
- Corsa rear Shocks on Cav
- Vectra 2.5 v6 wiring diagrams
- HID kits?
- Corsa B door speakers...wiring?
- What coolant temp does the fan kick in on Z20LET?
- vec c rear brakes on astra
- SRI 140
- Corsa B/c power steering.
- corsa b play in wheel when jacked up, vids to show!
- Nova gsi wiring !
- BMW motronic 55pin - vaux 55pin
- WideBand guages info.
- c20xe hitting 4k then bogging
- 1999 Astra 1.6 Estate Fan on Permanently.
- infinate resistance of amal valve - faulty?!
- Anybody know what these do?
- traction control
- All people with Mk2 GTEs - Part Number required please
- 2005 Corsa 1.2 Twinport MOT failure
- slim line fan fitment
- Cheap brakes false economy?
- vivaro problem
- SARD fuel pressure regulator .
- c20let fuel problems
- calibra help
- power steering
- help reconnecting steering arm ball joint to hub assembly??corsa b
- bent rear axel corsa b, using washers to straigten??
- sensible price wideband
- Really crap washer bottle on Mk3 Astra
- speedo not working
- Corsa VXR rear axle on a Corsa B
- Electrics Fubared On Corsa B
- Help me mount my sideskirt please!
- Brake Vacuum storage..(reservoir)
- Dismantling an Astra GTE Digi Dash
- those of you with sunroofs and a cage (corsa b)
- cv joint help
- Pad wear sensor - same for Mk5 Deisel and Mk4 Turbo coupe??
- Anyone got a car with 256x24 brakes, and a spare 5.5x13 steel?
- 2.0 Corsa with no PAS bu with PAS pump on 2.0 engine...
- mk3 astra van lowering
- corsa springs on a cav mk3
- emerald loom wiring help!
- 2l 16v xev ecotec wiring to corsa
- Replacing side sills on a cav Mk3
- LET loom, icv ks loom 5 wires????
- £1600.00 to get my ASTRA GTE 16v on the road??
- corsa c power steering clicking?
- Engine Oil.
- different ecu letters ??? GF ECT
- astra mk4 wheel bearing
- 20SEH wiring
- Mk4 1999 astra petrol cap/indicator cancel
- Rear Drum Brakes Info?
- vectra suspension
- corsa master cylinder
- fuel pump relay
- corsa electrical problem
- astra mk4 ignition barrel removal
- 5 stud rear disks on a corsa b
- Corsa B Stereo Problem
- Sporty backboxes
- Can some one measure for me please
- Zafira misfire
- Corsa B door speaker wiring...?
- Nova Let issue......
- QuickRack for MK2 Astra GTE 16V
- boost bleed valve
- bulkhead mk3/mk2 astra
- Corsa C EPAS light on and no power steering!
- LET afm fault
- MOT Day Looms astra G 2004 1.6 8v
- where is my pollen filter?
- Wiring Diagrams
- Removed the aircon rad, now have EML on how can I get it off?
- Cavalier lowering springs..
