- Pulling to left badly!!
- Fix one thing, something else breaks! (A/C questions)
- over heats quickly
- Monitoring through ALDL
- -31 actuator
- auto gage A/F ratio meter
- water? hoses?
- Upgrading Brakes On Nova 1.2???
- ATF cooling pipe problems.
- 6pin Air Meter in place of a 4 pin one...
- Chargecooler
- 17" wheels won't fit cauxse of brakes
- Whats needed for a 4 to 5 stud conversion?
- Zafira GSi Parking Sensors
- Urgent advice needed...downpipe probs..
- 1/4 mile questions
- 1996 V6 Starting problem
- wot gbox is in my astra sport?
- Ebay toys.....
- Corsa ECU problem
- calibra power steering
- Which Followers to be Used
- Perished Ventilation Hose? (56k warning)
- Rear disc conversion
- ABS sensor
- 5 stud on a corsa!
- Crazy electrical problem... HELP!
- heater problems!!!!!!!!
- Zafira GSi - Climate Control "whistling"
- 5 studding my gsi
- not vauxhall but...
- Water Loss
- Dial Problem
- chassis design
- Central Locking Problem
- absolutely devastated
- Vectra 2.2 diagnostic codes - help!
- People with EPC - could you check a part No. for me?
- How do i fit this to my trip computer?
- Underbonnet light???
- 5 stud help asap please please please
- Front brakes to rear?
- Fault code = 13 - oxygen sensor. What does it mean?
- mk3 astra - need to know some things
- Arrrrggghhh Parts help needed!!!
- revs surge up and down
- TD rev counter gubbed...
- Chain Rattle
- Idling Fast
- Rev Counter!!!
- Car pulls to one side when accelerating
- does anyone have?
- TWIN 40s on my 8v astra?
- re-programing
- webber 32/34
- Breakdown help please!
- alternator
- Spring bust
- Relay - where is it?
- distributor for weber
- Flat Spots on the V6
- can someone explain....
- Cav 3 Saloon/rear Brace Question
- Dealer inspection...costs?
- No abs!!
- Auxiliary Tensioner
- What boss kit for Cav Mk3?
- Question Calibra
- GM Ecu Diagnostics on PC
- GSI illuminated grab handles????
- Nova Dissy
- RON plug?
- where to put
- did vauxhall make a
- which fan?
- calibra question
- Little bit of info needed.
- air flow meter problem?
- how long does fan run on cav v6?
- air flow meter?
- heater matrix??
- Overboost Issue
- 4WD doesn't work
- Central Locking problem
- sri ecu
- Speedo white dials
- What size are V6 front disks
- Astra G SRi Handbrake sticking
- which antiroll bar for my tigra
- Alternator - removing??
- Central Locking
- Banana request .......
- question on 2.0 8v
- is this possible
- Suspension Questions - Koni
- cav td
- astra mk3 ecu
- external wastegate
- Astra GTE bearing
- H&R vs EIBACH
- Rear demist, fans @ 1 and 2 and heater lights all inop on mk3 Astra
- revtastic cav gsi help please...
- External Temp Sensor
- Some of you might find this interesting - diagnostic stuff
- Corsa C SRi Tunning
- Windowscreen Wash Wiper Problems....
- Omega starting problems.
- Misfiring
- core plug
- 20SEH problem
- Vauxhall breakers
- V6 Vectra Buyers Guide?
- torques
- Clifford alarms and nova central locking?
- Cally Outside Temp sensor - help pls pls pls
- Opel vs Vauxhall....??
- Battery flat, Duff battery or duff Alternator? How do you tell
- Vectra steering wheel on Calibra???
- How I did my custom V6 mount
- Top mounts
- Astra ecu "limp home"
- BMC - CDA's
- brown "baked on" substance in bore
- light on dash...
- AFR Gauge
- wiring my indiglo dials...
- Central locking query (urgent)!
- Bleed nipple thread
- serious oversteer!
- Pinout required
- will 112 pcd fit a vauxhall
- Help - My Passenger Floor Is Soaked
- cally 2.0 8v
- whiring noise
- vectra power steering problem
- cranck position sensor
- Cav V's Astra subframe
- 8 v gte enging transplant to cavalier GL
- Astra SXI's are they any good?
- Qicky about Webers
- calibra problem
- People with EPC, need a part looked up
- Electric sunroof wiring?
- astra struts to cav?
- How low can i go? Corsa Gsi
- Help finishing conversion
- Help, trouble starting GTE
- Cavalier Sri 2.0 16v - lowering question
- getting my nova to pass mot
- chug...chug...chug???????
- help needed quick!!!
- Weird central locking (deadlocking) problem
- Calibra sunroof into Mk3 Astra?
- ECU light & switch wire colour confirmation please!
- astra cluch
- HELP:Problem with wheel fitments
- need 2001 astra tdi info
- rolling road
- URGENT - quick response needed
- FAO astra mk3 V6 owners
- how do i adjust spax adjustables on the rear?
- 2.0 8v carlton auto
- translate to english?
- Manual Boost Controller problem
- Lights playing up?
- M22x1.5 to 1/8 NPT adapter
- silly question
- calibra heated seat switch relay
- Corsa GSI shafts-cav mk2's inner c.v's
- Nova steering racks?
- ecu light
- What's this 'sun-sensor' do?
- master cylinder
- nova scrapes. suspension help please
- quick question bout tigra PAS rack
- How do i turn off ABS????
- Cally Zorst Q
- It failed. ARGHHHH!!!!!!!
- Can it be done?
- Mk3 GSi 'Kangarooing' on low revs & Idle Problem???
- Quick T.C quest!
- Cosmetic Internals
- Rad leaking... I tink..?
- MPI or SPI, how can i tell??
- Wierd wierd problems!!!!!!!
- Power steering pump pulley size!!!!!
- nova koni adjustable kit
- Cav Dash....
- help needed
- did astra gsi come with rubbing strips?
- Koni SSK adj
- Ride Baby, Ride....on What?
- Clifford alarm problems
- has anyone removed abs from a cav?
- Where do I get....
- Changing the pollen filter on MK3 astra
- Cav help........
- Paperclip Test
- TAS lowered tie bar mounts for nova
- trip computer
- whers my coolant going??
- urgent request for info please read
- Calibra ECU issue...
- ECU light
- tramlining :(
- corsa sport
- Instrument Cluster - revs dont work now?
- I got Laaaaaaaaaaaaaag - any ideas!
- corsa gsi speed sensor!!
- Wtf! Electrical problem? Pls help...
- pro's / con's of twin 40's
- Electronics!!!!!!!!!
- Mtech Info display????????
- Lower Strut Brace
- Is this normal????
- Urgent Request For Info
- CAv GSi rad in2 Astra GTE 16v
- vectra sri 4 stud????
- sound
- Front Window Seals
- Hello couple of q's...
- mk3 astra digi dash
- Where Can I Get These Bolts??????
- Calibra Lights
- Please Help Asap!
- V6 modify ****-up
- diameter of a 215 35 19 compared with 205 40 17
- difference between et49 and et40
- calibra power steering plse help
- a bit of help
- Cold start difficulties - what could it be?
- strange idol probblem on astra mk3
- nova gte will not start. wire question?
- Big brakes?
- astra 2.0 16v sport
- Rad Question
- interior light
- Rear Box same on GTE 8V and 16V?
- Got my new universal back box, need help!
- A/F Ratio Measurement / Adjustment
- tyres
- How much coolant for a 2.5 V6
- astra mk3 rear wiper motor
- 8 Sided Wheel Bolts - HELP!
- fed up of this rock hard suspension...
- Vectra 2.0 16v DTi Issues...
- HELP please! dashboard lights on with no ignition:(
- Time to Start Moddin'
- distributor question
- my cars shakin pl,ease help
