- c20xe fuel relay!
- How to take out 2 gearbox bolts?
- Movano big problem .
- Mk2 Astra Digi Dash Problem.......
- 2 year garaged Nova - 1986 advice/tips?
- from the battery to the c20let wiring?????
- lowered?
- c20xe coolant temp sensor problem
- V6 Corsa Runs for 2 secs then dies any 1 any ideas?
- Advice Astra mk3 suspension for tarmac rally
- Power steering on c20xe tigra
- Mk3 springs on mk4???
- heater control panel unit problem
- Removing TC on CAV C25XE
- corsa b rear disc conversion plz help peeps
- will vectra sxi suspention fit my cavalier
- Cavalier/Calibra Shock absorbers
- drivers mount dimensions
- astra mk4 caliper to corsa b
- meriva c20let wiring. corsa C c20let/хе owners, need help from you
- Bolts to mount caliper
- drilled and grooved discs
- Tighten hub nut, wheels get stiff?
- mbe management conectors
- rear brakes help asap
- Corsa C steering splines
- were to get mounts from
- Fitting EPAS rack only
- Coil not sparking
- Air con & coolant rads
- 1 wrong braided hose in kit??
- Mk4 Astra suspension???
- mounts for astra mk4 c20let conversion
- vectra power steering makes a sucking sound, pipes been extended
- Lost Front Brakes
- nead help with my etc on my mk 3 astra
- agila, gearbox replaced, no speedo
- Mk4 Astra clocks???
- battery in boot
- Corsa C central locking fault
- ePAS differences
- weird ignition question
- stainless steel pipe can i use mig with co2 for a spot weld
- What are these? (blocks inside Corsa lower arms)
- inner cv movement 2wd f28conversion
- Does anyone have a wiring diagram for Cav/Cali trip computer plug?
- Corsa / Nova adjustable rear spring platforms...
- Astra H rear beam onto a Corsa C
- Red/black thin wire near XE starter motor
- Can anyone confirm this alternator wiring is ok (diagram)
- Astra mk3 N reg central locking fault
- 2ltr corsa b springs?
- need help with wiring up fan
- ATE CALIPER DUST SEALS - DRIVING ME F*CKIN MAD... Any Tips?
- No spark, fuel pump relay?
- engine management light
- Igition barrel
- astra mk3 rear brake question issue??
- Rev counter not working on my c20xe nova merit
- Corsa B wiper arms
- need vectra air con compressor pipe seals
- Corsa b blue/red wire vehicle speed sensor
- flexible water hose
- hi spec brake pad replacements?
- MK1 / 2 astra leccy window help
- Astra g to VXR CANBUS
- Converting mk4 astra van from 4 stud to 5 stud
- corsa b c-let, steering rack change
- can a multi v alternator pulley be swapped to a v pulley
- Corsa B 1.4 16v and fan switch
- corsa coilovers
- astra coupe clocks to fit v6 astra van
- v6 electric clocks
- Changing radius arm on combo van
- corsa b, blower thingy that blows air into exhaust manifold when engien is cold.
- fitting c20xe ecu in corsa b kickpanel area
- help !!!
- Will a standard Corsa B backbox fit to this... (pic)?
- corsa b camber
- Washed my enginebay 2day and I've now got em light on! Help
- asrta g stopping
- unichip for v6 c25xe
- Thick red wire in Corsa footwell
- Rusted Rear Subframe Bolts, need some advice
- gsi engine bay fuses help!
- Coilovers with softstars on a corsa B
- Whats the Best glue to use for carpet to metal????
- vxr calipers on my astra g
- Corsa conversion front hubs...
- Byke´s ITB or MTB
- rev counter signal
- z20let aircon fuse blown
- Which other rear brake calipers will fit my cav turbo?
- corsa throttle potentiometer
- My ECU is locked - Attempted remapping
- nova hub nut
- Adjusting Koni dampers
- c20let wont start
- mk5 astra sri tuning?
- 288 mm brakes on corsa b
- Urgent - X-reg Saab 9-3 SE turbo - what front brakes will it have?
- Weber Alpha ECU
- C20 LET Vec , oil level sensor .
- leaking cav!
- Air con retrofit
- How to install essentric top mounts
- Brakes, upgrading and braided hoses.
- vectra front mount intercooler, fan problem
- Vectra B shock absorber differences
- cd player wont work and no dash lights
- Small problem with my Opcom unit
- Hid lights pulse off/on when lights turned off for about 2 mins !! Any ideas??
- rear break conversion
- cruise control module
- Taking ABS off
- rev counter is mk astra van
- Fan switch!!
- Key
- correct speed on digi dash
- brake pedal play
- tx autosport tophat clearance issues on corsa b.
- Apple USB Cable
- engine managment light
- Tigra Rear shock absorbers
- rear brake conversion using astra g parts please help
- breaks?
- c20xe conv (nova)
- what lbs springs too buy(gaz golds)
- buzzin steerin coloum
- Going from baileys dv26 twin piston to baileys dv30 or forge 007p diverter valve
- AEM wideband calibrating? help
- speedo drive
- click noise when braking
- Mk4 Astra Air Con Compressor what to do
- mbe loom
- Central locking
- after market management systems
- milling down hubs
- VW intermittent wiper relay terminal diagram?
- pain in the ass vectra
- c20xe (dizzy type not coil)
- whats this mysterious black box?
- radio antenna cable
- Redtop high idle
- how to fit corsa b lower front strut brace
- Overheating 1 litre Corsa B
- vectra to corsa brakes
- wrong rpm reading after conversion??
- Nova c16xe loom: What plugs are these?
- central locking no longer working on tailgate
- Corsa b Driver side window issueq
- I want to upgrade the brakes on my corsa b
- Board Computer
- Calibra Brakes help.
- corsa b 1.6 16v
- C20XE Airflow Meter BIG PROBLEM
- corsa b independent rear suspension
- electric windows
- Brake proportional valve info please
- 1996 Vectra (B) Electrical issues
- help with my locks
- crankshaft sensor on x10xe?????
- chevette brake budget upgrades???
- cavalier rear lines, female M10x1 at both ends?
- Corsa b rear disc
- 53 Zafira Rear Brake Callipers
- Cracked front spring
- rev counter help
- Will it fit????????
- Vectra B - Electrical problems resolved
- rewire my mk4 astra c20let
- Astra GTE Mk2 Power Steering + C20LET
- no power at deignostics plug
- Brakes Juddering when warm/hot
- Why is my suspension doing this??
- Spax rear shockers
- Car Wiring Looms - Who knows?
- Horn trouble.
- C20let slim fans
- wideband, what and where from??
- X20xev bike carb manifold
- Corsa VXR Lowering Springs
- V6 Brakes
- Wiring in a start button
- Astra gsi mfd
- C20LET wiring, help please.
- multi function display works on dta ecu ?
- chipping a ECU for 8v turbo
- c16xe help please
- Wideband or Narrow (pic included)
- X20XEV ECU and loom query
- Emerald K3 ECU and LC1 wideband controller
- Econoseal connectors female
- corsa b speedo
- corsa b suspension upgrades
- 20xe Alternator Grounding
- vectra b steering
- help with choosing coilover kit
- rough idle/temp sender
- TID to MID in Astra mk3
- x30xe lightweight fly & clutch
- Brake pedal goes to the floor after changing front brake pads!
- Corsa b 1.2 8v Sportex Race Tube
- Wiring new Astra GSi loom into ECU side loom (driver's footwell)
- Taking Off door card on mk3 astra
- which is the best engine fan?
- pissed off with LET...temp gauge not working and oil leak from head?!
- vectra C door warning lights
- c20xe tps problem!!
- Astra mk3 Adjustible top mounts idea
- Brake lights flash with indicators - where is the earth?
- Calibra BC- Doesn't fully work
- spot lights wiring
- Corsa B (99) Powering the Electric Windows
- battery drain any ideas???
- vectra b air con hissing through vents
- z20let turn off traction control
- anyone know anything about KMS engine management?
- c16xe wiring to nova
- c16xe wiring to nOV
- Corsa B handling ?
- Corsa b C20XE suspension??
- Corsa c washer jets, boot locked!
- Tigra and Corsa B share the same rear axle?
- 1.0 12v wiring to c20xe
- Cheapest Place To Buy Wishbones
- help
- wiring in electric windows on a mk3 merit
- imobliser
- will cavlier rear hub fit mk3 astra
- who is using dta e48 ona ac20let
- coolant temp problems
- o/s/r Coil Spring Top
- Strange steering problem .
- Air/fuel ratio gauge Sensor wire on a c20xe nova
- Brakes keep warping
- Corsa B Headlights won't flash
- mfd display help and rev counter
- vectra brake lines
- Anyone does cheap welding down near london?
- corsa spring on a mk3 astra
- c/l and ew
- FAO folk with mk4 astra Gsi
- c20xe tps dizzy pack
- 1.7 cdti dtuk tuning box
- 1.0 12v - c20xe
- battery in boot
- F28 Weight
- c20xe swap with 1.2 rad
