- airfilter
- Whiteline kit - Corsa Handling (not suspension)
- airfilter
- astra undeersteering badly! help needed
- Nova Gsi Sunroof Problem!
- removing snapped bolts
- super unleaded? real octane increase?
- Running car in
- Changing Bulbs again (sorry)!
- Cavalier 2.5V6 CDX replacement front discs
- Ignition Selection!!??
- Question about side repeaters
- Shot peening
- astra brakes
- Remote Central locking Problem MK3 Astra
- brake fluid is going down slowley ??advice plz
- Best brake setup?
- Leakage
- Astra GSi
- Mk4 astra leccy windows
- corsa C brakes
- Fao EPC users: 24v Senator front brakes
- Electrical issue with rear lights...HELP!
- help! starting problems.....
- Is super unleaded worth it or....
- Wiring problems
- Vectra Heated Rear Window
- Astra GSi splash sheild?
- Koni adjustables
- Help needed pleeeeeeease.........
- this is seriously p***ing me off now
- Argh! Brakes! Please help..
- MOT soon (AGGGH)
- quick electrical query
- Traction control
- Spongy corsa brakes
- rounded bolts!!! **URGENT**
- PAS help
- restrictor?
- cossa problem
- vectra climate controle problem
- Can having wide tyres be a bad thing?
- fitting 40's to nova gte
- changing a bulb
- fitted new alternator, now what???
- gte clocks (digital)
- lowering the cavvy
- Vectra B V6 Cruise control
- Unusual Vectra Problem
- Pipercross vs K&N
- Grinding Rubbing noise from n/s front wheel area
- miss fire
- calibra suspension
- Abs sensor
- aaaaaahhhhhhh
- Maybe a Stooopid Question
- corsa break problems
- suspenoin kits for calibras why so different
- drilling 284mm disks
- Nova GTE problems
- Astra SRi Advice
- Electric windows, self opeing......
- Vectra - Lost key!
- M7 bolt!
- whats next on the list
- mk3 astra knocking from suspension - possible cause?
- heater control conversion
- Hearted seat switches
- Am i right or wrong thinking this........
- replacing the alternator, help needed
- Serious electrical probs (its all gone kaput!)
- Electrical probs
- Corsa knocking noise
- Calibra 4 stud ---> 5 stud ????
- Leads N Stuff
- Rolled Corsa
- Braided hoses?
- ignition module
- uh oh, broke down again.
- Green Power Steering Fluid??
- miss firing at high speed !!! any ideas ???
- corsa gsi immisions
- suspension prob mayb
- astra gte clocks
- Hints and tips on fitting a Mk3 Astra towbar?
- Heater Matrix on a V6 Cavalier
- Seat Replacment
- Vectra 140Sri 98 S What can be done?
- Corsa MOT
- HT K1 RACING SET from KERR NELSON only in Blue?
- Gte Cutting Out
- Dial Help
- For future reference (Baffle plates)
- can anyone explain this? im lost,again :-(
- Help Me Rid My Raaaassssp?!
- trip computers!
- Fecking anti roll bar bush/drop link
- Alloy wheel Fitment
- wheres the sensor
- strange noise
- i wasted £400 today
- lowering springs
- Electrical fault finding mission....
- boost problem
- calibra 8v to 16v conversion - how to?
- running in
- isuzu or gm
- Corsa ECU light and cutting out
- Multi Funcion Display HELP NEEDED!!
- ignition barrel
- Unsure on a few wires
- More brake Q's
- Vauxhall brakes
- polysport/polyrace bushes?
- Uprated TCA's on nova
- easy or not
- vectra seat angle problem...
- pad swap and stud kit help
- Dual Control Removal
- Excesive Brake peddle travel, (nova)
- mk3 astra springs
- Nova Brakes
- f13???
- what size nut?
- Best panel filter?
- whats this worth?
- Roll cage help please
- Front suspension diagram parts for installing (mk3)
- Sorta quick question.. car heating not working
- Which Fuse??
- Do I.......Dont I
- mk2 astra gte16v alternator swap?
- flat spot
- Clicking sound in front/left angle - Corsa GSi
- mot time again, would it pass
- pssenger air bag
- C O Potentiometer
- zafira-fuse blows when alarm/deadlock activated
- Hall effect sensor
- in need of an answer
- Mk2 Astra quickshift
- MFD Wiring Queries
- Vacuum Gauge Pressure??
- How much will i pay for an f13 cr 'box?
- electric sunroof from cav to mk2 astra?
- How to stop an Astra (without the use of the car in front...)
- Maxrtorq Omega Discs
- What othe Cav's have the same suspension set up as a GSI??
- Ticking noise raising with Revs
- steering pulling advice please
- rev counter stickin
- replacing handbrake cable?
- Running problems
- Clicking noise when braking (Video) help
- electrical probs, low voltage
- Advice needed - suspension kits
- Advice - Modified bearing shells.....
- Mk3 astra gsi owners?
- Fitting gauges to V6
- widest tyre for zaffy gsi wheels
- question? v6 rebore
- corsa conversion
- Superboss Question - Long
- Shock Absorbers...HELP NEEDED TODAY!!
- Making a digital speedo - need info on Corsa (?) speedo sensor - wiring colours etc
- Central Locking... HELP
- new vauxhall shells.
- ecu
- wide arches
- Pi Kits any good???
- anyone help with strut brace fitting??????
- new tyres
- Part Number help
- 288mm disks
- running in..
- Centre consul help
- Will a normal sunroof motor run a one-touch?
- Twin 40s - Weber or Dellorto, Much Difference?
- Seriously @#$(@#$ UP my Dash board clocks - HELP needed!
- Leccy window help needed asap
- Different types of silicon hose's?
- ht lead blowing of!
- Porsche Brakes
- water problem
- Rage Snap Off Boss Kit?
- Maxtorq grooved and drilled discs quality
- Help! judder/knocking feeling
- stats
- how to check if air con is working properly?
- alternater help
- gsi, stuttering, and all sorts!!!
- Spax RSX suspension
- Can someone check something on banana for me
- fitting twin 40's to nova gte
- cav/nova brake lines
- Guages
- astra gte 16v problems
- Knocking from nearside wheel?
- Rear Disc's
- Rev Counter?
- Servicing Query
- Cool Running Thermostat Worries
- Bleeding air from cooling system
- help please speed ratings on cable driven clocks
- Need some gen on the whole lowering thing
- e16se problems
- front calibra fog lamps
- key fobs
- Nova wiring problem..
- how big can i go
- will these later clocks fit my earlier cally
- 7.5 inch wide alloys what tyres?
- corsa gsi 1600 trouble
- G Max Suspension
- Nova wing
- MK3 astra washer bottles ???
- Help please quick
- Result. I love it when diagnosis goes right!
- rev limit on different rod types??
- rear brake help
- Tigra buying Guide...Urgently needed!
- H'brake shoes(lack of)
- Removing dashboard on a calibra
- Nova GTE Shafts
- rebore questions
- URGENT *Help Nedded*
- wheel stud's
- Astra gsi not starting?
- eLECTRICAL FAULT. HELP NEEDED ASAP
- changing brake pads
- what is this? pic
- Omega Air Intake Temp Control Sensor...
- Concerned - MK4 Astra GSi
- brake master cylinders
- ARP bolts
- CV joint gen?
- Astra rear suspension
- loss of compression
- whats the difference
- Cavalier Heater Problem
- Suspension
- Astra g ecu
- Sidelights don't work any more - why?
- steering problem
- Help Needed
- ***ked ecu?
- What can a rolling road do for me?
- knocking noise from front suspension
- ABS sensor. Removal & test? Please help
- Air flow meter
