- caliper bushes
- Corsa 20xe fuel relay noise????
- Swapping lock and ecu for astra van
- Astra GTE Digi Dash
- Vxr front brakes upgrade
- electric steering
- Vectra C Workshop manual
- Corsa B Gsi radiator fan stopped working (c20let conversion) motor/wiring fault?
- Is this a C20LET 1st gear switch fault ???
- HID's on 05 plate veccy 1.8
- gte digi dash films
- electrical probz
- fuel pump not running
- accelaration trouble
- No cruise control light
- astra g looses power steering but belt and fluid ok
- crank shaft sensor problems :@
- One touch electric windows on mk3 Astra
- Anyone good with Renault Electrics? (Non Runner)
- ECU light / EGR valve
- help please, corsa c20xe :(
- Vectra central locking problem
- elec windows and mirrors
- Vectra electrical gremlins
- Speedometer and odometer not working?
- xenon lights
- z20let brakes seizing
- corsa c driver side floor wet through
- brake light sticking on and brakes sticking
- wet drivers side floor carpet
- Gte stub axel help !!!!!
- v6 ecu/immobiliser
- water injection
- need help with wiring.
- mk4 astra dash packed in
- Any Fly by wire info out there?
- x25xe aftermarket clocks for dummies
- mk4 astra slam panel corsa b !!!
- corsa 5 stud conversion
- Rad fan not kicking in c20xe!
- calibra
- X25xe wiring
- help with corsa gsi fuel tank!
- Car cd player problem
- Calibra electric windows only work when drivers door open??
- corsa rear beam
- How to remove astra mk4 doors
- mk4 astra c20xe how to get temp gauge
- Advice on changing Corsa B master cylinder
- Fan Comes on with ignition
- Brake pedal touching floor!
- Steering rack corsa b
- v6 cav ecu wiring to mk3 astra wiring
- Help please astra sri 2.0 2000 fires but wont start
- suspention calibra on to astra gte 16v
- Diagnostics
- suspention 'Q' corsa B on 2 nova??
- Top strut mounts 4 nova
- Fauly Code 0771 on manual box
- nova xe not starting
- heater control panel button problem
- Brembo Calipers
- SWAP CORSA B.... 20XE or 25XE??
- Corsa gsi brakes
- what do i need to do to wire 2 rad fans up?????
- Best Radiator for a corsa XE?
- Brake Pads...do they degrade ?
- no pulse signal
- What to do about emissions?
- immobiliser/alarm
- ht leads
- Corsa b manual steering rack question
- astra mk3 gsi mfd
- Astra mk3 alloy rack mounts
- is it okay to run a yellow top battery on a c20let?
- Wireing in an aftermarket rev counter??
- Trip Computer???
- calibra soaking wet passenger footwell
- tappy redtop when cold
- carlton digi dash conversion?????
- c20let fault codes not flashing up on ecu light
- Corsa B Loom Advice
- Braided brake hoses for 1993 calibra turbo?
- astra gte 16v petrol tank issue
- Good pads and disc for wilwoods
- Tow-bar Wiring
- Comedy Corsa Coilover Suspension
- Altenator connections? (pic)
- redtop wireing to a corsa???
- Omega air-con?
- digi dash
- Retro-fitting Cruise Control to Zafira B 1.7CDTieF 10 plate
- stops fueling after initial startup,WHY?
- would the hall sensor cause this problem?
- '02 Vectra GSI Fuel gauge warning light fault
- 20seh wiring
- CV help!!
- c20xe need help wiring
- Vectra intermittant wiper in an Astra H
- diagnostic plug
- Vauxhall Nova Wheel Bearing Problem???
- tps traction control c20xe
- Red top brakes help
- Help!! astra gte 16v temp gauge problems
- problems with temp gauge and window water squiters
- where to buy nova chasis strengthining kit
- Brake servo leaking brake fluid?!
- c20xe f16 ??????? help
- starts and cuts out any ideas why?
- Where can I get stalk connectors from?
- c25xe airflow part numbers
- Corsa C rear axle onto Corsa B
- 2.5 v6 fuel/injector problems.wont fire
- Corsa B rear shoes
- help, split CV boot
- corsa speedo not working!
- tow bar bent, what should i do ? (pics)
- vectra rear bushes can i get uprated poly bushes
- exhaust manifold
- Too much anti-roll?
- Astra 2.2 coupe alarm help
- What car battery and where from?
- Astravan 1.7td driveshafts - small one end, big the other???
- corsa rear beam on a nova ?
- Corsa b Coilovers
- c16xe crank sensor
- dodgy alarm astra mk4
- Speedo 5mph out ???
- c18xe limit at 4500rpm HELP please
- c20let interferance with spark
- Gte digi dash in mk 3 gsi
- corsa b c20let speedo
- Intermittant key fob...
- cav t suspension
- 256mm 16v pad recomendations (track/road)
- which hoses?
- What bolt should i use?
- help pls corsa gsi c20xe
- immobilser problem
- Help wanted with some minor wiring :)
- Part number required - help
- Brake pad caliper retaining clips
- What is correct brake bleeding caliper sequence on calibra
- Corsa xe Kerb weight??
- Vivaro sat nav
- where to get roose c20xe induction hose
- Does this sound like brake servo leak???
- Good AutoElectrician
- lowering spring
- Vectra Steering Wheel Controls Don't Light Up Anymore
- whats the best management for a let?
- Where is best to tap into for remote central locking sidelight flash function??
- Mk 3 astra chassis
- 2.2 astra ?
- vec gsi electrical help needed
- Corsa c20xe help
- Front Camber on Calibra?
- Astra Mk2 ARB size 2.0 8v?
- Corsa b W REG 3 door, electric window conversion help needed!
- what suspension for mid engined nova?
- will an an apexi avcr work with an external wategate
- pics of mk3 astra v6 with strutbraces please :)
- kkk turbo
- Windscreen fitter needed, west sussex
- corsa c steering column into astra 3
- cuts out when i plug ec t sensor in
- recomended turbo re-build companys
- 3 pin round plug in Corsa engine bay...?
- c20xe into corsa b 1.0 12v
- corsa b 1.2 twist help.
- live wire from ecu to ignition?????
- Mk3 Astra/Cav etc indicator wiring
- Corsa Sport 1.6 - Rack End Removal
- PAS bracket and support
- corsa c
- zafira consol\lock fault
- c20xe to corsa wiring
- Ignition problem with Corsa 1.6 GSI
- mounting master cylinders in engine bay
- Brakes clicking
- cav turbo wheels and big brakes
- 256mm 166 pads size
- corsa 1.0 12v 2000 engine wiring diagram
- corsa 20XE still running crap,could it be this?
- tigra key problem
- Timer delay relay?
- Fuel pump astra mk3
- Tech2 enabling of Cruise Control
- mk4 astra van goes flat and then power comes back iny ideas?
- Wiring up a redtop dizzy in place of a blacktop dizzy on a nova
- Omex Rev limiter help please(20xe)
- battery relocation, what wire?
- 20XE in 1.0 Corsa; fuelling problem
- Petrol engines into Diesel Astra MK4
- ECU Fixed but still more fault codes!!
- Astra 05 Electrical Problem?
- 1.4 sport into 1.0 corsa b, wiring the electric steering??
- Bush Removal Tool - Glos Area
- heeeeellllllpppppppp
- Cosra C 1.2 gear selection problem - linkage issue
- Corsa 1.2 problems
- how do i wire a 5 pin relay for my corsa steering
- Any Mechanical or race engineers here?
- engine loom,old for new.
- Whats the lightest 5 stud Vaux wheel possible?
- Windscreen supplier?
- diffrence between 3and6 pin tps please
- Corsa B Uprated Brake Master Cylinder
- fitting corsa b hubs & carriers on a mk1 nova
- Adjustable intermittant on corsa
- c20xe wiring loom
- help! corsa driveshaft xe problem
- fitin 5th injector on coras 1.4 16v turbo
- Astra GTE Tailgate Glass - is it bonded in?
- Please help! corsa b xe vauxhall alarm problem URGENT!
- Corsa C Rev Counter
- Tigra Let power steering
- Cavalier electric window problems
- Which wire is live please on F20 g/box speedo sensor?
- No Temp gauge - How to test it?
- Not sparking
- uprated top mounts (may be solid). astra G/meriva/corsa C/vectra B
- vectra b 2.2 dti no more torque after 3000 revs
- Headlight Modification
- Air Ride Suspension
- Need an electrition in the south west urgent
- blitz fatt dc4 turbo timer manual
- What size rear A.R.B. on '95 Calibra 16v Ecotec?
- Anyone recommend a good quality straight edge
- Calibra Shocks
- Bad wheel wobble
- Whats the best type of brake bleeding kit? DIY?
- 2.5 ecu help
- epas conversion
- lowering springs
- Air Con Compressor Astra GSi Turbo Mk4
- Corsa C20XE conversion help asap please!!!!
- Corsa LET conversion - final hurdle electrics please help!
- need help on my astra coup 2.6 v6 wiring loom
- Help, x10xe Corsa ECU light pin Test?
- Stripped Corsa Wiring?
- lowering a vauxhall combo
- C20LET Loom, Turbo & Coil Conundrums MK2 GTE
- c20xe icv/knock sensor plugs?
- corsa bigger master cylinder
- need help on cavalier suspension tweaks for better roadholding ?
- v6 front springs vs turbo ones
- SAAB 900 turbo pin data needed
- Convert Corsa B From PAS to Manual Rack
- corsa b coil over issue, a big one
