- Face mask with goggles
- sheet metal?
- anybody built a beavertail recovery truck???
- Astra mk3 chassis rotating jig
- Drawings
- car colour
- I'm looking for awesome paint colors
- DIY car respray advice
- Questions on painting Wilwood 4 pots
- Preping panels
- Painting metal, and fibreglass panels (track car)
- A question on painting & prepping please..
- 240v sigle phase to 415v 3 phase inverter??
- Help purchasing a MIG welder and Air compressor?
- corsa c20xe engine bay problem
- Astra van floor mods for seats
- tig welding tips and advice
- Can't paint to save life / Rustoleum & Rollers / Matte Black
- Welders.. Which to buy?
- Durafix Alloy Welding
- Clarke pro 90 MIG good for general bodywork repairs?
- VXR8 Trashed
- Astra paint code
- Rusty / Slightly Pitted Roof - Dodgy Sill Replacement
- 4 link suspension
- car painting
- Blocking a car
- Does anybody know a mobile welder in Merseyside, or would like to do it themselves?
- NEW blisters on OLD paint, help/advice welcome
- Side Sills on a Cavalier MK3
- Quick Question, Astra SRI Colour ??
- welding TX Autosports pipe, alloy
- prepping textured bumpers (nova)
- Nova floor pan paint???
- v6 cavalier manifolds.
- new to mig welding, good welder tips advice please
- corsa b roof
- CNC machining, need a little something cooked up
- pipe bender and advice needed
- MK2 Cavalier Floor pans
- inner arches work - am i doing it wrong?
- Advice on 2k clear
- Adjusting a stainless manifold?
- Corsa b carbon inner wings
- Tigerseal/Sikaflex on Engine Mounts?
- cavi mk2 floor pans
- Where can i get a quarter panel.
- Corsa C Seam welded?
- Recommend me a good bodyshop in SE
- Mk4 gsi spoiler spraying.. Asap.
- Quote too much for welding & respray?
- cutting pipe with angle grinder
- astra mk3 reiger wide arches- can you use the gsi bumpers
- best prep before powdercoat?
- Tigra rear brace?
- fibreglass basics
- Some of my recent lathe work
- Advise needed: Rust removal / treating products or techniques?
- gas bottles
- Vectra B sill moulding clips
- Hadrian's scrap MK3 Astra 3dr Qtr panel Press!!!
- Bit of a colour change on covers .
- Gunky sealer for panel joins
- respray cost
- saab turbo corsa(what chassis mod to do)
- how to use body filler ?
- welding aluminum with a mig welder ?
- cavalier turbo paint codes and alternative red tones?
- shot blasting a bare block
- Extending inner arch for a widearch kit, use steel or fibreglass??
- may sound stupid but im thinking of making my own show cage ?
- what you think??
- custom inlet
- new to welding metal thickness question
- tidying rear arch lips
- pipe rolling and threaded pipe sleeves
- vectra b front & rear bumper question
- Anyone in the Surrey area that can weld?
- Gaz 1 Sheared stuck stud 0
- never welded before, think i might have to give it a go...!
- powercoating
- engine painting help!
- Exhaust welding ??
- cav / calibra bumper and wheel arch plastic clips
- corsa crossmember plates?
- Custom Paint Sprayers
- Mk3 astra 1/4 panel
- Respraying car bit by bit!
- 1996 combo van
- Spray painting in cold
- paint drying times
- Carb manifold
- fmic pipework z20let??
- Spraying Advice
- what psi do you paint a car at with an air compressor?
- Flairing Ali or ss tube? Advice plz
- replacing chassis rails with box section
- Thinking about buying a plasma cutter
- Masking up-advice needed
- Respray near Chesterfield?
- De-locking Corsa Door
- Protecting inner arches
- Aluminium Welding Thermostat housing
- undersealing
- Problems painting skirts
- tigra front chassis rail
- rust on corsa b rear suspension mounts help !!!
- Rusted Rear Wheel Arches
- fabricating corsa grille
- How do you pull out damage..........?
- Help needed on rollcage backstays!
- advice on corsa strenthing
- corsa b 5dr 98 looking to have respray
- Does anyone have a spare inlet trumpet?
- dent repair
- Corsa b sills
- Some Of My Recent Welding/Fab Work............
- Someone advice On correctly using fade out spray
- corsa inner flitch pannel and bulkhead
- Preparing Bay
- painters - Prepping transit primer?
- Wat too yous???
- exhaust welding
- What's People's Opinion?
- Wheel painting tips
- spoiler hole drilling
- corsa bulkhead
- best place to buy paint?
- mig welder with 50amp lowest setting ?
- Opinions on forwarding rollcage to front struts or not?
- Recommend me a spray gun? Devilbiss!
- arch's and bumper tops on corsa b
- how to fix a broken seat hook bracket
- advice on nova strengthening
- car roller/rotater
- Fabricating/sourcing flat oval aluminium pipe/tube
- boot floor
- spraying plastic how
- cav td intercooler
- vauxhall vectra rust spots
- anyone know any decent painters in the southport area?
- vectra B hatchback
- Replacing a roof on a Corsa B?
- where to get alloys refurbished in ayrshire/glasgow area
- Vaux tigra mk1 sills gone rotten.....
- hammerite underbody sealant advice
- exhaust hangers/brackets
- vectra gsi front doors
- Brake caliper mounts
- How much would it cost me to respray my mk3 full gsi kit ?
- Oxyacetylene advice please
- arch tubbing ??
- pictures of your rear turrets please
- designing and making a rear diffuser
- i am looking for a welder in the shrewsbury area to help with project
- new to welding and looking for advice
- plastic spraying
- Corsa B Exterior Plastics
- Weekend Spraying Mids?
- Tig welding- how easy?
- how much paint will be needed..
- Spraying prices? Midlands...
- Repairing paint chip on wing? Help please
- help needed - car spraying prep?
- I need some custom spigot rings made
- Recommend me a welder
- How much paint to cover my golf?
- weld testing available
- advice onmaking welds look good on exhaust joins
- taking the gunk off the chassis off my car?
- Stripping paint off door mirrors
- metal cleaning acid dip
- help needed aluminium welding north west/northwales
- Painting arches with aerosols
- Genuine vauhall body panels
- need a welder to come do some work for me ??
- Tips and techniques for blending pearl paint
- Paint repair advice?? Corsa b
- Corsa b lower cross member
- paint colour/code
- Undersealing - advice please
- Can u weld stainless with a mig
- bent slam pannel
- Panel beater wanted inthe Kings Lynn area.
- Panel Painting Advice Needed
- anybody fancy a bit of bodywork?????
- nova front panel replacement???
- 2k paint for my corsa gsi
- Has anyone got any experience of Parweld welding equipment?
- drilling f28 turn it from electric to mechanical
- Is this rust repairable?
- were can i get paint?
- Redrilling 5 stud VXR discs to 4x100..
- Liquid polyurethane supplier?
- Removing seam sealant
- Mig 130 vs mig 150...
- Nitromors
- Refurbished 19" snowflakes...
- Anyone arc welded with aluminium rods?
- flush boot
- Painting Dash and Grill
- Newbie Welder
- got a rusty arch can anyone advise
- PROBLEMS trying to get PENETRATION
- full body respray flame red corsa gsi
- Sprayers in Birmingham
- vectra b floor pan
- sheet metal
- advice needed on engine bay smoothing
- mk3 astra gsi resto (ish)
- Acid Dipping
- 95 cav shell
- Shell Had A Front Ender
- Tip to get a good flowing weld
- clear coat
- cavalier floor panels
- vectra c exgaust modifacation
- cheap engine crane
- Sand Blasting - Corsa B Shell
- Painting astra gsi grill
- Underbody tray - MOT fail or not?
- tips for spraying?
- Painting Rear Springs on a Corsa B
- flat backing?
- corsa disc axle
- Repainting Bumpers
- Favorite Panel Suppliers
- recommended online paint suppliers?
- bulk head for corsa b wanted
- Chassis strengthening corsa b
- 2.5 v6 corsa exhaust help needed
- 2.0 8v Bike Carb Manifold. Homebuild.
- anyone in the trade price up some paint please
- cut or rolled arches?
- c20xe/let cam cover... leave it in primer? :) anyone ever done this?
- performance inlet manifold made?
- lather needed, and advice
- Painting rear axel wat paint
- Painting Plastic
- MK3 Astra Van Upper Spring Cups
- Anyone do chrome coating ?
- Saab Exhaust Manifold Flange
- Which welder should i buy for welding car panels on bodyshell
- mk5 red/pink astra question?
- wheel center bores...
- XE 4 Branch to XEV
- after my mk4 van graffiting!!!!
- new fuel tank protection??
- What mask have you used with 2k paint??
- Rocker cover colouring
