- External wastegate vacuum
- Which Cam? 20seh + R1 Carbs
- cleaning top of the block for cometic headgasket
- xe breather hose size?
- water hoses c20let corsa b
- z20let stalling
- Vibration from front offside when taking foot off gas
- external wastegate sticking open
- f28 Gear oil
- Diesel Gearboxes........
- Modding a Z20let engine
- astra mk4 1.8 conversion to a c20let ???? i need help please :)
- Walbro pump Clet
- c20xe and c20let clutch & fly wheel
- Z20LET into Mk3 Astra - Throttle
- Head gasket
- Calibra 911 Turbo ?
- Need help with my vectra please
- c20let problems
- wanting to fit fse valve to gte
- Rear lambda sensor Z20LET - how to?
- Coscast head= Porous ?
- Fse
- z20let coupe blue smoke, oil burning smell and noises
- Fault 16 Knock Sensor C20XE
- C20xe air flow meter question
- Need Help! on my corsa 2.0 8v C20NE
- Corsa losing coolant help
- c20let head gasket arp studs
- 1.0 corsa-B poor starting when warm
- vacuum for zlet dump valve
- non vaux gearbox question
- Tial f38 external wastegate
- who is running a cometic head gasket successfully
- Corsa GSi Air mass meter quesiotn. urgent help please
- Accelerator Pedal wiring loom? Z20LET?
- Astra MK4 Z18XE Erratic Idling
- 4.18 or 4.5 cwp for f13
- c20xe and c20let bottom end???
- corsa d fault codes?
- gearbox whine
- Is this a corsa isuzu engine?
- Corsa c20xe alternator muilty rib belt what one to use? Pics to explain
- How much nitrous can an 8v take?
- z20let crank pulley
- 1.7 DTI - Good engines?
- 1.7dti astra estate 2001 (changing fuel pump solenoid)
- twin engine corsa
- +1mm valves on an let advantage or disadvantage
- Camshaft advice z18xe
- should a let head always be skimmed when removed or using cometic
- standard cams .....
- C20LET Question.
- nimonic and 214 stainless steel valves
- C20XE Clutches
- C20NE Problem need help!
- 2.0 8v problem
- Info needed - Foam in Fuel Tanks.....
- High voltage to injector
- Corsa 1.7DT Engine
- 20seh turbo conversion help
- vectra diesel engine light - intermittent
- X16xe engine tuning
- c20xe sagem dispack
- LET MANIFOLD -mazda MX5 OR 200sx ?
- pot type flywheel clutch fitting
- Corsa - gte wiring help!!!!!
- C20XE '96 CORSA B DriveShaft questions
- Z20LET Vacuum lines HELP!
- new vaux engines, no fuel return pipe?
- leaking abs unit
- water and oil leak
- Omega 2.5 V6 misfire
- which is better solud lifters,cams,double springs headwork and xe cams
- Corsa sport overfilling and miss firing now and again
- sick 1.4 twin port
- z20let ticking and missing slightly
- shelling a standard let block
- vauhall astra 1.6 16v head
- nova engine conversion, 2.0 8v or 1.6 16v
- corsa v6 gearbox
- corsa c20xe
- Mid throttle misfire!
- c20let code 13,22
- setting up c20let
- c20xe spluttering on low rpm help needed
- corsa red top need help cutting out and over fuelling
- C20XE wiring into 1.2 16V Corsa B
- engine management light
- coolant hoses long shot
- Drilling Hubs
- astra estate mk4 project
- AfterMarket FPR and Blank C20XE
- Bad Miss when driving on X16XEL
- F16 box
- amal valve?
- i need help identifying the make of my oil pump
- combo van glowplug symbol flashing
- Timing Belt Replacement Problem
- X14XE Rally Engine - Oil Restrictor Mod
- f28 gear selector adjustment weird problem
- Turbos EFR..... exist or not?????
- C20LET on idle what gal/h is displayed on the trip computer???
- Corsa C wont start.
- is zlet and zleh same flywheel bolts pattern?
- corsa redtop brake servo pipe
- These any good?(Oil advice)
- 1.7 td cav putting white smoke through interior vents and abs light on
- saab engine wiring help
- tuning box for 2003 1.7dti installation
- Fuel injector o rings?
- Turbo help.
- Converting a cavalier from c18nz to c20xe (redtop).
- Vauxhall Cam Chain Engines Using Oil
- Remove a/c from x14xe
- Zleh scooby noise (misfire) at 2k revs
- C20XE cam cover inner baffle plate
- let hesd 135.12mm has this been skimmed much
- best performance f28 clutch?
- c20let hunting
- coscast head valve steam seals?
- part number please! - C20XE cam cover mounting female/male fixer
- Vectra 2.6 missfire under load
- supercharged corsa b
- C20LET headgasket gone , pics .
- C20XEL?
- 8v oil squirters?
- Erratic idling
- Dbilas Flowmaster vs 1.9 cdti airbox od? which is better? z20let
- courtney tubular mani leh, any issues?
- f18, f20 clutches? same?
- Mk4 Astra intercooler options
- Corsa - C20XE With F20 - Damaged Gear Linkage
- missfire on half throttle
- engine torque damper
- Front seats Astra 2002
- clicking noise C20 xe and F20
- tx autosport c20xe crank pulley!
- c20xe ecu chipped ???
- z18xe head removal
- Power on a z20let engine
- mk4 astra 1.7td low blow
- 2.0 xe snapped fuel line to fuel rail screw in union....help
- Is a x20xev and c20xe fuel pump the same
- C20let misfiring,overfuelling & cutting out
- Corsa B 1.6 16V Wont Start....
- c20xe with f13 straight cut box ??
- ebay universal turbos
- c20let valve springs
- can i re-use arp head studs bolts ?
- Best engine oil to use?
- Corsa B 1.4 Sport Exhaust hanging too low!!
- c20let in vectra 2.2 150 estate help!!!!!
- Astra G 1.6 8v Misfire in Cylinder 1 - Cause?
- Corsa c20xe problems
- reusing 400 mile mains shells
- advice please c20xe
- Piper or Cat Cams, which to break 200hp in 1.8 vaux
- Gearbox Damage - only 3rd/4th work.
- steering rack vectra b 1.8
- x20xev no ecu feed?
- C20LET Corsa oil pressure
- How long for c20let head removal
- 1.7 dti (astra g estate) flat And hesitates until 2500rpm (turbo kicks in)
- X20xev no spark
- Refitting cambelt after it's snapped...... Finding TDC
- x18xe Cam Belt Failure
- Is water needed for X20XEV throttle body
- Z20let vacuum diagram
- Best spark plugs? Z20leh/z20let corsa turbo
- Head gasket change. . ? (poosibly on a C20XE Corsa, but I've not said.)
- Corsa 20XE/ F16. No drive
- xe corsa with mayo in water
- fuel pressure
- 2001 1.7td has poor accelleration.
- c20XE / C20Let Bolts
- Corsa c16xe low power after engine swap
- What is bend in air intake duct for?
- Corsa C20LET fuel pump feed wire getting hot.
- vectra cdti cambelt damaged idler melted
- 1998 Astra 1.6 8v Terrible running issues. Overfueling?
- sealing the end crank cap on an let
- c20xe miss fire?
- C16XE + Dbilas manifold - will X14XE lower inlet fit the head?
- x10xe head onto a z10xep block
- Astra mk4 Gsi clocks fit?
- mk4 astra 1.7td idle problem......
- z20let/leh stroker kit
- Cavalier/Calibra turbo locked transfer box advices needed
- 2.2 vectra problems starting ECU or CIM ?
- F20 parts on f28?
- can a duff OS affect boost? [C20LET]
- MK3 Astra Gsi phase to ecotec 2 litre replaced with 2.0xe what fuel pump is required?
- f20 box pot flywheel
- Ford Galaxy 2001 1.9 TDi DM flywheel type need to know
- physical differences between early coscast and later coscast head
- C20xe fault codes
- Does this gearbox look useable?
- Driveshalf help?
- Vivaro techshift gearbox
- isuzu 1.7 td conversion
- quick xe question
- c20xev
- x20xev mk3 astra gsi using oil and smokey???
- Z20let running strange
- Astra Vxr judders help??
- 04 zafira gsi problems
- Where does my door stop go ?
- corsa c20xe coolant pipes
- Coil pack XE poor running fault at idle/low revs
- c25xe oil cooler.
- oil cooler on C20LET?
- Astra 1.7cdti cambelt problems
- standard yellow injectors for c20let max BHP?
- c20let - refitted turbo now it wont run properly
- Need help on c20xe corsa conversion
- z20let help, white smoke at idle when hot head tested 3 times shows ok
- Need help!! Gti-r throttle bodies on a 20xe
- 1.8 Vectra timing belt guide
- Holley blue fuel pump
- vectra clutch
- mk4 x20 xev into mk3 astra
- Changing the clutch in a Corsa VXR. Best way to do it?
- Let & f16cr
- 20xe + kkk16 + motronic
- Forged rods and pistons for 500BHP+ LET
- vectra c 2.2 z22se engine question
- random question turbo charger
- Is this standard C20LET turbo scrap?
- Zafira gsi oil leak!
- shocks and hubs calibra 4x4
- Wiring help!?!
- f20 pot flywheel clutch
- astra mk4 c20let MOUNT
- Mk2 Cav sri gearbox
- Eds phase 3.5 and saab reds... What fuel pressure?
- what injectors are these?
- 2.016valve DIESEL conversion?
- CV and driveshaft data anyone?
- dual mass to solid vectra c dti
- Vectra B GSI Short Shift Kit.
- Corsa B GSI F15 gearbox short final drive
- X18XE1 Nova. Immobiliser trouble.
- nova redtop project again
- Friction Plate Thickness
- 95 astra 1.7td just turning, wont fire up.
- C20XE Rebuild
- The 2 year misfire :(
- who does custom inlets?
