: Engines and Transmission
  1. let cooling problem
  2. garret t3 turbo?
  3. V6 Oil pump Question
  4. Powered coating
  5. has anyone got the dbilas throttle bodies on their xe?
  6. c20xe starter motor
  7. Sump bolts - HELP!!!
  8. c16xe continous problems
  9. Gearbox. F13
  10. cam help
  11. Corsa VXR into Corsa C
  12. ecotec 1.8 16v injectors astra coupe
  13. 2.0 XE on R1 bike carbs overfueling
  14. need bit help with oil light
  15. Poor running x12xe - advice appreciated
  16. astra 150 cdti problems
  17. Amal valve wiring
  18. V6 F28 Conversion Spacers
  19. C16XE cutting out and struggling to restart
  20. Fast Frontera?
  21. Mantzel Copy
  22. f28 lsd question
  23. Once the afm goes can it be cleaned??
  24. nova - misfiring, poor/no idle then perfectly fine??
  25. Cool Air Supply
  26. Best plugs for a 20xe on carbs?
  27. V6 Rough Idleing
  28. astra wont select gears properly F20
  29. 1.8 astra coupe drivers side noise at high revs
  30. corsa 1.7d to 1.7 td
  31. C20XE con rods in a X30XE
  32. solid lifters
  33. f13 cwp change,can it be done in the car?
  34. c20xe Rebuilt
  35. t25 hold phase 2 boost?
  36. Can i Turbo a C20xev
  37. 2.2 sri 150
  38. manifolds
  39. what injectors better for c20let
  40. erratic idling and headgasket??? on vectra
  41. tuning a 1.2i spi nova engine?
  42. Twin 40's Brake Vaccum Help.......
  43. VXR 80mm AFM
  44. X20XEV hesitating at low revs + wide open throttle
  45. v6 into ecotec astra
  46. How strong is a 4x4 MT75 Sierra Box
  47. corsa let fuel pump options
  48. 1.6 8v cuts out on low idle?
  49. Suggestions - how to remove this (pics inside)...
  50. Zafira running poorly
  51. c20ne gearbox?
  52. chris astley corsa turbo engine mount
  53. Gasket sealant
  54. Best Place for Chips?
  55. C20XE Fail on Emissions.. BY LOADS! lol
  56. c20xe oil cooler can i put 2 bolts in it to block it off
  57. 1.7td isuzu block and 2L 8v ohc block
  58. gearbox crash boom
  59. corsa 2.0xe help
  60. v6 nova
  61. 1st gear ident c20let
  62. C20xe Turbo ?
  63. Vauxhall 1.9cdti 150 bhp engine
  64. Converting F28 for 5 speed clocks
  65. x30xe heads on the c25XE
  66. Corsa IAT Resistance Mod?
  67. wiring c20let ?
  68. cossie weber fpr
  69. z20let oil pump in c20xe
  70. 10w-40,What does it mean??
  71. Value of this XE and Corsa conversion
  72. Sump loosening off..
  73. 2.2 frontera block fit xe head
  74. Still No Look
  75. cavi gsi exhaust size???
  76. what size fuel lines?
  77. Mk1 Nova C20XE Question!
  78. astra gsi turbo hesitation
  79. mk4 astra which engines easiest to install?
  80. Calibra turbo fuel pressure
  81. MAP sensor for 1.25 bar on standard C20LET management?
  82. swapping corsa engines
  83. what gearbox???
  84. wheel bearings part number
  85. vxr turbo on a z20let gsi astra
  86. Quick help with engine codes please
  87. 0433 Tank vent valve fault code ??? newbie help needed
  88. turbo manifolds
  89. What sort of power gain?
  90. tigra 1.6 stalling problems
  91. 2.0L Forged Crankshaft..........?
  92. Mk4 Astra V6 cutting out
  93. Which Carbs for a V12 - Tripple Setup
  94. help!v6 still got problems
  95. Corsa 20XE wiring problems (sorry)
  96. am i right in thinking??
  97. Boost temp sender problem...
  98. How would a c20let run with out cat
  99. 2l redtop jerking at low revs?
  100. X20XEV Variants
  101. 1.9 CDTI in a Mk4 Astra
  102. 2.0 Xe Flywheels.
  103. c20let help
  104. f28 gear box
  105. z20let head gasket on c20let
  106. Sportex Exhaust, any good?
  107. astra gsi exhaust system question
  108. Failed mot on emmisions please help
  109. astra g noisy and loss of power
  110. c20xe icv
  111. C16XE hesitates under load.
  112. XEV injectors
  113. Corsa Running Probs>>>>>> help
  114. C20LET bottom end ADVICE
  115. XE on carbs?
  116. Metal acid dipping, power coating and polishing.
  117. Removing air-con
  118. Circlip found on F28 drain plug?
  119. astra gsi idling
  120. c20let
  121. C20LET bottom end pic NEEDED
  122. oil for my x16xe, want to try something thicker
  123. What engine do I have?
  124. uprated exhaust manifolds
  125. Corsa Sport conversion
  126. astra coupe w reg tick
  127. C16XE Cutting out when slowing down and applying clutch HELP
  128. C20XE head bolts coscast
  129. Vectra 2L Water pipe problem......
  130. fitting split collets from 16v head
  131. ARP bolt rod settings
  132. Advice on bottom end rebuild
  133. Mounting engine on stand?
  134. urgent!! problem with starting?????
  135. gsi lump
  136. let flywheel
  137. SBD Taper Throttle Kit 208HP
  138. What diesel engine?
  139. Lowering compression for turbo 20xe??
  140. late xe/let square tooth pully diameter
  141. Apexi boost controller in c20let
  142. EML Light Vectra 2.0 DTI
  143. astra g transmission fault flashing heelllpp!!
  144. Transplant Engine on tigra
  145. vectra clutch
  146. ITG JC50 Filter Backplate
  147. what gearbox is in my 1.6 combo?
  148. Crank TDC
  149. LET questions....?
  150. xe late cambelt ????
  151. Piston ring fitting
  152. wideband units?
  153. Idle issue with a Vectra GSI
  154. i dropped one of the cam follower locaters
  155. Xe Cool Running Thermostat
  156. cavalier exhausts
  157. Car Broke down today on the motorway
  158. Frontera Sport fuel sender unit question...
  159. c20xe missin
  160. lp needed
  161. let injectors
  162. HELP - Cracked sump
  163. v6 idling problem
  164. where to get a rolling road tune/setup/power run
  165. genuine vauxhall oil-anygood?
  166. vaccum pipes
  167. wee bit of help/advice
  168. C20LET Distributor Cap Bosch part number?
  169. mantzel style powerbox on x16xel
  170. C20LET Idle Issue once warm
  171. modifying OE pistons
  172. c20xe rev limit problem
  173. engine mount modification 1 litre nova
  174. uprated jubille clamps for let intercooler
  175. vxr injectors whats the story?
  176. fao corsa c20let users
  177. will an x16xel run on a x16xe loom
  178. re map wanted & advice
  179. Calibra 2.0 16v 97 thermostat and fuel relay?
  180. mk4 2.2 sri, needs new engine (which other engines fit?)
  181. Clutch release bearings Nova/Corsa
  182. x16xe compression results wet/dry
  183. Gearbox oil leak? (f28)
  184. Cav Fueling
  185. Astra Induction Kit & Exhaust
  186. Will it need a rebuild?
  187. Guide for fitting F13 LSD
  188. cold start valve
  189. Zafira gsi noise
  190. recommend me a fuel regulator
  191. custom loom
  192. Omega 2.2 missfire
  193. XE running problem (cant work it out )
  194. these any good
  195. c20ne problem pls help!
  196. F20 or F18 c/r?
  197. fuel pump on nova
  198. standalone management on let-????
  199. VECTRA 2.6 V6 Auto problem selecting reverse
  200. c20xe valve springs?
  201. Correct ECU Type
  202. Nova TD, Head warped ... cam seems stiff to turn in housing.
  203. XE conversion
  204. Glow Plug Head Snapped! - Help!
  205. x20xev flywheel
  206. C16XE inlet manifold on a E16SE?
  207. Belt
  208. Corsa B Advice Required
  209. xe to let
  210. Cavalier SRI help/questions
  211. reconditioning hyraulic lifters?
  212. Engine management light staying on in my Mk2 16V
  213. corsa flair no start
  214. Ford Fiesta Engine Management
  215. vxr injector fuel pressure on standard management?
  216. ASTRA 1.6 8v upgrade
  217. c20let upgrade
  218. torque setting for cylinder head needed c20xe
  219. fuel pressure with standard injectors C20LET
  220. Head gasket caused by Electrical fault ?
  221. c20let turbo questions
  222. Will these fit?
  223. Getting 5th gear in a nova after conversion
  224. My corsa Dieing?
  225. early morning puzzeler
  226. v6 mantzel inlet manifold
  227. Corsa XE Conversion help!
  228. 2000 vectra gsi, what mods for more power?
  229. engine builders in herts
  230. c20xe conversion
  231. MAP sensor
  232. vectra 2001 sri 150
  233. Cally turbbo 4x4 fault help
  234. C20XE not starting - help please...
  235. corsa c engine trouble
  236. xe let big end bearings are they different?
  237. F13 Gearbox
  238. Overfueling plus voice is same like missfire
  239. Need some more help citroen ax please
  240. eds phase 2 help
  241. Engine managemen after refuel??
  242. XE Over fueling. Help needed.
  243. Corsa B Head gasket
  244. REDTOP INTO CORSA 1.2 non pas
  245. what is this sensor ?
  246. Does anyone use the megasquirt on your car?
  247. will this fit in place of my 1.2 8v corsa engine
  248. Help Fuel sender Seal
  249. help r1 carbs on a x16xe
  250. xe r1 carbs nova ...
