- Does petrol go off???
- what colour are standard injectors
- c20xe astra missfire
- Redtop swap into a mk3
- Strange gearbox problem (F20)
- Coating the tops of pistons?
- Any Fuel system Peeps with Facet pump on injection
- whats the new restore oil like does it work
- vectra v6 gearbox removal
- C14NZ and strut brace?
- Throttle Bodies
- Piece of exhaust stuck in backbox
- C20XE bad starting when warm
- Throttle body??
- exhaust ports
- Engine Swop...
- two heads are better than one.
- Pistons might be knackered
- anyone had there cam retainers line bored
- HELP: nova c20 xe driveshafts
- Breather and Vacuum pipes on Cavy 1.8i 8v on M reg
- how do i remove the gear knob shaft thing with gaitor...
- 2l 16v exhaust bore?
- Astra Coupe 2.2, Superchip????
- testing a lambda sensor
- head specs
- W reg 2000 Astra Bertone 1.8
- crankshaft sensor
- Urgent help needed with Cav turbo!!
- Increasing rev limit on the X30XE
- Are nova gte exhausts different shape to 1.3
- Oil Catch Tank For Cally T
- Turbo Timer on Cav Turbo?
- best exhaust for the astra mk4 1.6sxi?
- F18+ gearbox with C20LET
- transfer box / power steering, am i being paranoid??
- rev counter in a diesel
- help!!! settin a 1.2 carb from scrach?
- Gearbox problems
- Okk Explain this oil leak miggers...+missing bolts?
- 4x4 Transfer box, 2 breathers?
- splitting a Transfer box from an F28 - HOW?
- F23 onto a LET?
- XE cams on the LET
- cally T overboosting at 4000rpm!!!!
- Omg
- Ported and polished head on ebay...Any good??
- Engine cleaning
- 1.6 SV 8v engine into a nova
- joining a inline fuel guage to fuel rail union sizes...
- Driveshaft problem
- Anyone want to make a few quid by getting my engine to run?
- head specs
- Astra to V6 - F20 or F25?
- Oily on inlet side of turbo.
- uprated gearbox? what to go for?
- Camshaft sensor on an Ecotek
- Astra GSI (ecotec) cambelt kit cost?
- vectra backbox
- astra g headlight adjustment
- c20xe throttle bodies
- Samco Hoses Corsa C20XE?
- Car will roll back when in gear
- can you do teh paper clip test on a 1.0 12 corsa ?
- Recomended retailers...nova exhaust...car wires
- xe cambelt
- Would chroming intercooler/oil cooler effect their performance?
- astra 4 air box modifications - whats this new inlet pipe thingy?
- C20LET Cam Cover
- head skim
- Shall i get a cossie webber FPR ?
- V6 Headgasket change
- power pipe on a z20let- is there a noticable gain in performance
- fitting traction control from a cav v6 on to a let
- Difference in cams on c20xe??
- Ignition Coil
- PAS stopped working on astra mk4
- Oil Cooler Modification
- astra coupe 2.2, more performance?? superchips??
- ALL engine fitters please read ASAP cheers
- "diag" comes up on MFD when engine is turned off?
- electric windows and spoiler....
- siemens crank censor part number
- Coilovers
- Big Turbo Power
- Where should threadlock be used in LET rebuild?
- 1.6 16v Astra G Running Sluggish!
- nova gte head
- Damage to valve cutouts?
- turbo eco
- Vmax chips for C20LET
- bend valves?
- C20LET Boost Problems
- Nova 1.6 16v engine wiring
- Flywheel Bolt Torque
- mk3 astra z20let?
- Astra 1.6 Engine Modz
- wheres the sender for fuel/water temp?
- F20 driveshaft how many teeth on spline?
- Z20LET boosting
- Throttle Bodies or Turbo?
- Henko Racing pumps any good
- What do I get in this headset?
- corsa sri driveshafts?
- head specs 8v
- copper exhaust manifold gasket
- some small issues on the LET
- injector question
- no fuel getting to seh corsa
- What happens when a catalytic converter stops working?
- c20let spark plugs white
- clutch problems
- urgent, headlight problem
- saab reds and standard regulater
- help turbo deisel astra van
- price check please...v6 and turbo bits
- LET oil out of dumpvalve ?
- Nova Fuel Lines
- deisel turbo on a valva redtop
- Nitrous and watercooling
- Astra DTL Injection Problem
- 1.9mm kevlar head gasket
- Tuning the 2.2 in a VX220
- let problems
- creamy oil cap and dipstick
- Snapped Cam
- air feed question on cav sri xe
- Powerbox Inside Volume for 1.6 ?!?
- after fitting a 3.0carlton throttle body....
- Astra mk 4 turbo diesel please help
- 2.0 Ecotec to C20XE (Cavalier)
- C20XE Mis-fire problem, HELP!!!
- 20xe cooling
- Converting Calibra 4x4 to FWD XE...
- head gasket thickness
- throttle position sensor - apexi avc-r on c20let
- Rocketing oil temp!!! HELP :(
- cav eco 16v breather mods? whats best?
- let in a nova
- 1.6 nova turbo conversion
- Converting diesel to LET?!
- 8v heads
- Corsa diesel wont start at all without a squirt of easy start????
- Astra Turbo Exhaust Options
- Fitted Facet fuel pump, but not starting...please help
- bailey or hks (bov)
- corsa b 2l 16v exhaust system
- Help Superchip Problem Astra Gsi16v
- C20LET Fault code 113 + 116
- corsa xe conversion kit
- 1.6 brakes on a 1.0 three pot Corsa
- c20let idle up and down
- Astra 1.7D 1995 (LPT) - Oil leak Rant
- Welding near petrol tank
- c18xe head on x20xev?
- aftermarket ECU choice
- let not starting properly imobiliser?
- c16xe AFM question
- driveshafts
- striped thread my head were spak plug goes! what do i do??
- IS the C20XE Block the same as C20LET?
- Im really stuck with setting up gear linkage on Calibra V6/F28
- alloy fuel tank
- c20 let turbo buying
- carbed XE - 40's or 45s?
- head gasket size
- will a astra gsi manifold fir....
- Atmospheric Dump Valve In Place Of Recirc Dump Valve??
- Quick suspension/coilover question
- spark plugs
- LET inlet manifold question...
- x20xev with xe gearbox
- c20xe head - true or false?
- clutch question
- More XE problems - oil pump?
- Z20LET Transplant
- Corsa Sport Engine idle trouble...
- Corsa fuel warning level light?
- cost of idle control valve.
- fuel problem
- clio snapped cam belt
- carb conversion
- engines and gearboxes are confusing
- xe gearbox query
- what oil is it that k&n use
- Astra F (Mk3) c16se Needs Flushing!?
- MK2 GTE tank to pump feed pipe.
- vehicle speed sensor ecu wire
- Does anybody fancy earning some money? Head Gasket help needs replacing!
- 1.2 fuel pump
- diesel in a petrol
- XE Running Problems
- exhaust peeps
- zaffy gsi radiator(how hard to change)
- F28 Coversion kit
- AStra VXR turbo on to K16 exhuast housing
- let ecu immobilser question
- C20LET fault boot Pressure idle above upper limit
- How do i fit the wrong gearbox then?
- RON coding plug c20ne
- Engine Management Light
- hmmm strange exhaust
- Nova engine swap
- LET Immobilser Question
- Coupe coilovers.... on 18's - 'unstable'
- no spark
- URGENT HELP, think engine guna blow!!!
- How much for a new set of tappets/lifters for early xe?
- Some help please, info needed mk3 Astra
- nova rear coil overs
- cold starting under and over fuelling xe
- tappets
- pic of a frontera oil cooler
- 200sx manifold on the LET
- let bottom end torque settings
- corsa diesel valve adjustment (shims)
- Water in fuel tank...? Fiat Brava question...
- 2 litre turbo 4x4 cav
- best air filter for c20xe
- Ecotec hose adaptor plate
- Oily crankshaft sensor
- Still no ECU Light on the c20xe Corsa conversion...(pic)
- Exhaust manifold studs/nuts
- NOVA Xe - Strutbrace options - what are they?
- Climatecontrol Panel Pixels
- nove gte engine, throttle body mod
- Corsa Gsi Exhaust ? ? ? ? ?
- new engine
- corsa xe
- xe coils
- Astra mk3 radiator fan relay
- my fuel filler cap keeps clicking when filling for fuel
- How easy??
- does anyone have a turbo'd c/x16xe corsa gsi ?
- sebring exhausts?
- ast gsi fuel comp into corsa b?
- valver nova CV's
- how many bolts hold an f28 on?
- How to test an XE Coil????
- gen on sticking tappet/valve??
- 2,0 8 valve questions again
- c20xe gaskets
- Oil Feed for Turbo
- performace air filter
- Homemade Powercap???
- How much boost can i run with...
- pistons
- Bhp
- Nova car loom: GTE vs GSI differences?
- Welding the GM inlet manifold
