- Nova 1.2 Luxe - Heater Problem
- Head Porting
- Sump plug size on c16xe?
- what can i do to make my 1.6 sxi (03) go faster???????help
- Z20let Help
- Cav GSi bonnet catch
- Nova XE - Running standard Air Box?
- Exhaust MOT question
- C20xe wiring, multiple plugs in car problem.
- 1.6 16v ecotec 1996
- Calibra Turbo Gear Selector Help???
- let one way valves cause of smoke?
- Exhaust Reducer Sections?
- Crushing a Fpr .
- C20XE rebuild
- brake servo pipe on engine conversion
- Cam belt snapped 2nd time in 2 months!!
- hmmm spesso head gasket blown
- unusual smoke on idle,c20 let
- what gearbox is best in mkIII turbo
- Crank Wheel Compatability
- c20let corsa prob
- corsa let prob
- Cav GSI shell + C25xe = ???
- bike TBs on astra G x20xev
- Question on LET head studs
- changing let
- TB's C20Xe inlet trumpet jenvey problems
- Oil level sender unit for x14xe.
- twin 40s and turbo?
- throttle bodies on C20XE
- C16XE Running Problems
- x16xe Vs x16xel
- 120mph tops out of c20xe
- What turbos best and where from??
- LET Double valve springs
- anyone doen a valver corsa how to yet?
- Bonkers rev counter GTE TURBO HELP!!!!
- c20xe in to nova 1.2?
- top bhp out ov my v6 gte ???
- de-cats?
- SBD TB inlet help needed
- Z20Let Conversion
- 1996 V6 Calibra Ecotech ..... C25EX or X25XE?
- where can i get 440cc injectors for the let
- c20xe nova driveshafts
- were is the crankshaft sensor on a x20xev ecotec?
- Boost going crazy on C20LET
- Cambelt/roller options for the LET (uprated?)
- Vectra Diesel Battery Light On
- nova turbo diesel
- 2 head gaskets for turbo conversion
- astra gearbox
- anyone kno what redtop ecu has the code FP??
- whats the difference between xe and let
- wiring loom problem
- quickkie - 20let 20xe inlet manifold - are they different??
- quick question, c20xe lambda sensor fit c20let?
- compressin test results bad or good?
- don't know how to change a clutch!
- let help????
- astra mk3 gsi f20 removal
- C20let Help
- Any rover coupe turbo owners on here?
- installing a chip
- Do valves etc have to be removed for a shot blast?
- injection fuel tank on carb nova...
- turbo compressor housing
- F28 gearbox oil
- uprated injector colour
- Cunning plan maybe?
- plugs for 300+bhp LET
- xe oil pump
- Whats the max BHP/Torque a standard LET can handle?
- accumulator calibra 4x4
- astra 1.4 not starting
- Heavy clutch - making more than squeaky noises
- People How Can I Make My 1.2 Faster ! ! ! !
- xe keeps eating belts
- Z20LET gauges (or is it guages..?!) fitting...
- Corsa Let???
- nova engine
- heavy clutch
- really odd one, wipers control headunit?
- power out of a 1.7td gm engine
- X16XEL Astra Engine Swap
- lets talk gearbox's
- Oil pressure/Voltage gauge removal
- Engine refusing to start after top end rebuild????
- ecotec idling problems
- Best gearbox fluid for over-stressed F23?
- 16valve Rear Brake Discs
- NGK Iridium plugs
- my astra turbo z20let is pinking at high boost under load
- Plug Covers
- 8v heads
- fuel pressure on xe
- 1988 ascona c20ne problem
- Diesel and lpg? WTF?
- 1.8 - 2L eco-tec conversion
- c20xe gauges ?? Help required !!
- SNOW might have given me a clue to my problem (c20xe corsa)??
- hesitation on c20let
- 1.6 parts on a 1.2?
- corsa 1.4 ecotec auto replacing engine help!
- C20xe 20xe c20let - inlet and turbo ecu question
- Calibra turbo Power steering 4x4 help!!!
- c16se Head on x16szr
- C20LET or C20XE ????????
- x20xer head worth it?
- 1.8 ecotec engine into corsa sri
- Corsa C 1.2 16v Cutting Out
- turbo brakes on corsa
- Cally T Transfer box problem????
- What damage does turbo stall do?
- Corsa 20XE Wiring Help needed - With pics!!! (sorry quite big)
- red top mass air flow sensor
- Is there an AutoChoke on the X14NZ Multec CFi engine??
- Clutch
- C20XE ecu
- c16xe help
- C20LET -- Coolant temp sensor -- code 15
- Help needed with astra turbo diesel
- What fuel lines to use
- c20xe power dies at 6000rpm experts plz help
- Black smoke coming out (not a diesel)
- xe in astra td van
- ICV Location
- nova 1.3 engine
- cavalier gear linkage
- Boost going up with gears .
- 94 Cavalier SRI redtop large wiring plug connections?
- Were is best place for LET dump valve
- water jacket on direct to head throttles
- let nova wont start possible wiring problem?
- [Doubt] Vauxhall Corsa 1.5TD Vs Astra 1.7TD (Flywheel)
- APFR install in C16XE engine
- Nova headlamp question....
- engine number question
- Exhaust recommendations
- phase 3.5 boost cut?
- cav fuel computer wiring help needed
- 20XE with F13 gearbox??
- servicing hydraulic valve lifters????
- 20XE Alternator Adjustment Bolts
- 20XE idle trouble
- help with quickshift on f20
- should i change fuel tank
- Z20 LET Fuelling
- cream flow on oil top
- z14xep exhaust manifold!
- C20LET ECU chips
- More (separate) gearbox gen required...
- fuel filter
- carbs in a corsa
- af22 Autogearbox oil question
- X16XE engine problem with video
- gearbox question
- Astra C14NZ Gearbox
- F28 into corsa ?
- Oil Pressure light on Corsa B C20xe
- Coupe Turbo Lowereing Springs
- Where can I get a decent induction kit like this?
- XE Problems - Help me read fault codes...
- quick question... misfires?
- Gear box
- what turbo do these use 17 gm/15 uzuzi
- sensors on a c20let
- C20XE D.I.S coil + twin 45s.
- cav td bhp
- c20xe
- let inlet temp sensor and gauge?
- coolant/radiator dash light
- VXR Turbo (Z20LEH) unit on Astra Z20LET..more power???
- whats the diff between a brain an a coil?
- 1st gear
- Technical engine question
- X16SZR Engine
- Cambelt Cover
- C20XE Fuel pump Relay
- C20 LET wiring question
- Irmscher Exhaust fitting clamps different..
- crankshaft nut torque setting on a bike
- let smoke at idle
- gear box mechanism!!!
- c20xe astra intermitintly smoking?
- v6 light flywheel
- GTE astra Chip, anyone heard of this one??
- Changing turbo inlet, compressor, housing between models.
- weber adjusable FPR! WHERE FROM??
- cams?
- the best xe
- best xe
- does a powercap make any difference?
- P+P head?
- which wire is the indicator one?
- XE Nova Trouble
- Oil Temp Gauge fitting c16xe Nova
- xe gearbox options?
- xe wont start.....
- X20XEV into Daewoo Nexia: any advice? :)
- Let Tb
- gasflowd inlet manifold XE
- v6 ecu chip
- Got my new turbo today for the LET (pics)
- Modifying Heater Matrix Pipe On XE Nova
- arp head stud tork settings on c20let
- Oil light
- urgent chip fitting!where does boden and deckal chips go
- Breather Question and Spark plugs
- urgent help needed car wont start !!!
- B**tard. could have engine prob
- Astra Coupe 2.2 What Exhaust????
- looking 4 cut away diagram/exploded view of KKK16 turbo
- 8v heads
- 2l 8v engine swap
- Coil Over Suspension???
- Anyone had to set the pre load on Y17DT Cams before?
- cavalier mk3 1.6 HT leads ?
- Help! RS Turbo engine problem
- Hydraulic Tappets - How to test
- 20xe alternator
- Gear Linkage removal.F18. vectra 20sri 1995
- Breather hose modification
- Reducing play in the gear stick
- clicking noise front 1.8 sport
- oil burning astra
- Where is the PCV valve in astra 1.7DTL
- Nova 1.6T40 - Just breathed ALOT of oil
- cav turbo brakes / pads
- another 1.2 question!
- How much bhp
- air filter cav sri
- v6 tappets
- Cav turbo oil light.
- Matheus's turbo conversions
- just got car back(x14xe corsa)
- how do i adjust gear linkage on c orsa 1.5 diesel
- Oil
- lambda signal wire
- anyone using a webber type fpr?
- Camber Adjustment Astra Mk3
- Fuel pump troubles still, please help
- ecotec fault codes help
- How to clear engine management ?
- Need Advise for fit a shorter Gearbox!
- crank sensor
- Inlet manifold for tapered throttle bodies
- Radiator fan senders
- fuel pump not coming on with xe on tb's
