- 720cc injectors......
- Tappety C14NZ
- Weight of steel rods vs stock ones (for Chip and others)
- Corsa Sri Exhaust Manifold, Emissions?
- Corsa Turbo
- 1.0 12v exhaust same as 1.2 16v?????
- x25xe heads same as x30xe?
- C20LET being a TW#T
- calibra turbo problem
- 1996 calibra turbo wont boost
- fitting cruise control on c25xe help?
- is it dying? (X16XE)
- Turbo Cars With Flames?
- vectra x20xev hesitates when accelerating and wont go over 4500 rpm
- Help!! So called friends(electrician) let me down!!
- astra cab or nova/corsa xe???????
- injectors
- Original Spare Wheel Type for cav turbo?
- Saab Red Injector Fuel Pressure, Ph 2??
- Gearbox
- Fuel computer switch part number
- mk2 atsra starter motor
- Engine type
- Dry sump kits on turbo engines
- Mk4 Astra Van 1.7 DT - Y17DT - Cam info needed
- Vectra 1.6 Turbo help
- F20 help
- Anyone know the torque settings for camshaft caps/retainers?
- Astra H 1.7CDTI Vs. Astra mk3 1.6 16v
- Corsa b engine conversion c20xe
- Best place to buy exhaust
- Cambelt fitting costs
- tensioning xe cambelt
- corsa engine mount
- X16SZR Odd noise..
- astra mk3 1.6 8valve, weird sound
- f20 help please
- Gearbox gaskets
- Closing up F28
- X18XE1 surging at 1500 rpm
- Z20Let ECU Error Codes
- gaskets, single or in a set from vaux???
- max boost on standered internals
- 18E valves
- c20xe running issues
- were is revearse gear switch on f28 box?
- how hard is slamming a astra mk3 by 4 on gmax springs??
- Cam choice for x20xev and fitting thermostat
- Dash light identification
- oil smell through air vents??
- Best Gasket?????
- cam belt changing, here's a good idea
- Synthetic Oil???????????
- max boost a xe can take
- Vauxhall Cavalier 1.8 8v 1992 Starting problem
- Astra MK3 1.4 MPI wont start.Crankshaft sensor?
- F20 Which One???
- 2001 Astra Coupe 2.2 Bertone, chain or belt?
- nova xe conversion
- corsa c20xe
- sfi box for power cap, idle props
- crank wire ? ? ? ?
- supercharging c20xe questions (eaton m62)
- 1.4 as 1.6 ecu
- What Is A Bhp???
- oil in cylinders - 20xe
- Just got towed home by AA - Strange Problem. FIXED!
- Resleeving block (non-vaux content warning)
- Diesel 2 Petrol Conversion
- redtop thermostat problem
- Location of diagnostic socket on Corsa B SRi?
- LET Happiness
- X16SZR gear boxes
- How to get more gains bhp
- too much oil
- Clutch change time in Cally T?
- Vernier cam pulley set up
- F28 into a corsa
- Nova GSI engine probs!
- Carbs back to injection? C20XE enquiry
- Vectra GSI - Problem (engine)
- LET max power
- fuel rail pressure after switch off !
- xe upgrades??
- jammed
- hmmm...flat spot in powerband.... CALIBRA!!
- nova fuel problem
- f20 c/r w/r?
- phase 2 with 440's...
- Spark Plugs That Dont Want To Come Out
- Calibra 4x4 problems!
- Xe jolts during acceleration?
- valve compressor
- some corsa starter questions. electrical like
- Induction Kit Costs
- 1.6 8v turbo?
- Oil breather
- Fuel damper valve??
- Right ive had enough now XE on tb's wont start
- clutch adjustment?
- Could this be idle control valve
- apexi avcr onto let
- F28 Final Drive?
- novice needs some help!!!
- head gasket
- c20let ecu fault code
- Gearbox/Clutch Problem. 1996 1.2 8v Corsa
- 4x4 fault codes?
- LET performance, gearbox questions
- c20let 4x4 ques..
- c20xe megasquirt help
- Vectra V6 Idle Control Valve
- LET tips needed
- Turbo's - trim sizes/AR ratio's etc...
- mantzel style inlet
- sri head
- Swapping from late XE to an Early XE
- x25xe & c25xe same plugs?
- fitting arp head studs before or after ?
- Regal Chip For Astracoupe 2.2 ?
- VAUXHALL - oil level on dip stick - how far do i fill it up?
- F15 Gearbox problem
- xe with xev bottom end?
- Wiring a late XE into B Reg Nova 1.0
- Can a coilpack be incorrectly fitted??
- F16 internals into f20 case
- flashing 4x4 light
- fault code 24 on c16se
- xe timing... pics inside
- xe is getting fuel and a spark but still wont start why?
- F20 , F28 - hydraulic clutch?
- v6 into astra, fuel pipe prob.
- c20let to xe,v block conversion
- Low CR Vs High CR (turbo's)
- Double valve springs/ ti caps / retainers
- overheating a diesel engine??
- X20XEV exhaust stud pattern
- 1.6 cav carb dizzy wiring diagram (no spark at coil)
- Nova LET COnversion
- Which gasket set to use??
- Rear main oil seal c20let help!!!!!!
- Nova Xe Top Speed 137?
- Recommendations on low comp pistons and rods please!!
- Xe Chuggin Thick Blu Smoke- Every So Oftern, Help!!
- more power for an XE
- cam sensor
- superchips and inlets..
- Engine management light flashing
- Turbo throttle question (more a pondering than a proper tech question)
- couple of f28 v6 questions
- nova engine mods
- Helix 3 Paddle Clutch - Where ???
- Cambelts + Valves
- no spark on let not switching?
- courtney or regal
- ASTRA COUPE 2.2 what is my engine ref nu??
- shot peening conrods
- Where is my EGR valve??? (1.7 gm td)
- R1 carbs and converting to dizzyless
- courtenay uprated LET clutch
- Stuck cv in gearbox and cant get the beeeeatch out lol
- C20XE X20XEV compatability
- XE Corsa question
- hi ideling on my nova 2.0xe red top
- Stark burst of reality about the f28 4wd system
- CRACKED clutch casing!!!
- Which is the better coilover set?
- Cooked the brakes. Problem now?
- em light on x16xe
- Corsa GSi foglight loom/switches
- astra g 1.4 tran. ratios..
- engine number
- How to remove valve cover?
- Mantzel Inlet Question
- Cam carrier question on LET (pics)
- Xe Corsa Mount Help!!!
- info on redtop with black cover!!!
- c25xe lifters
- What radiator?
- x25xe v6 into calibra
- Cam cover
- xe wont start, fuel gone stale??? help???
- fitting a C20XE into a mk1 nova. advice needed.
- F20 Porblems
- Z20LET seems down on power...
- cheapie mod for 2 litre ecotecs
- Cavalier Ecotec Idle Problem
- which flywheel 4 v6 astra?
- KW and BHP Conversion
- Quick exhaust question
- Redtop with black plug cover?
- nova-xe driveshaft q's
- nova radiator q's
- Nova 4x4 turbo
- superchips
- Xenon HID bulb colours
- fuel pressure guage fitting direct to fuel rail...
- C14se Ecu Help
- Help required nova 1.2i to 1.4sr
- Throttle bodies affecting mpg
- Where I can buy 2.5" 90/45 degree bends in Stainless ??
- Weber Fuel Regulator
- corsa gearbox questions!!
- turboed gsi
- X16XEL Fuel Breather Position?
- C14NZ starting problem
- early/late xe's
- Why more power from the VXR than Z20LET
- Calibra Turbo heaters dont get hot whilst driving?
- X20XEV into Nova
- turbo elbow
- Good C20LET sites
- Wiring The Ecu, (xe Red Top)
- nova c20xe weld engine bay?
- let crank position sensor fault
- 100w headlamp bulbs ok with standard wiring?
- road cams / piston clearance - also : piper or kent???
- 2 ltr turbo
- Adjusting valves on 2.2 DTi
- cam caps
- Astra MK4 Diesel Rear Disc Brakes
- What's the maddest engine I can fit
- map sensor on a x14xw corsa sport
- Engine problem on 2.0 Ecotec Cally
- Store tappets dry or in oil?
- 20xe ideal oil pressure/temp???
- my gasket failure / detonation
- corsa sri bottom end to 1.6 head
- arp head studs ? take a look
- F25 ratio??
- Was i ripped off?? 65 for a chemical dip on a head?
- FAO T.F.S / rob : re your engine
- Head gasket issues !
- 20xe corsa rear mount bolts
- F28 short shift linkage
- Pipercross Viper filter on LET?
- extending let loom
- Cambelt snapped. Please Help.......
- X16XEL Inlet Manifold Code?
- 6th gear transmission
- Best oil for Z20let
- Looms LET & XE
- transfer box seal
- drive shafts
- Lambda sensor split?
- C20LET kkk16 turbo problem - blue smoke
- Speedo wiring on F28 6 speed box help?
- 2.2 coupe remus exhaust
- Flexible exhaust piping???
- Nova 1.2 Luxe - Heater Problem
