- C20XE Idle problem
- Removing off the altenator with a switch, any gains in bhp?
- fitting a turbo
- LET/XE Baffle Plate.....
- Metal tabs in xe/let sump gasket?
- 1998 Corsa 1.0 12v Oil Leak
- quick throttle bodies question
- Hard to get into gear
- Fitting cams to a 1400 16v.. How hard????
- info please about the 1.8e and the 2.0 head
- Corsa 1.4 8v problems starting
- F20 Parts
- Mechanical/Electrical turbo boost gauges???
- what springs?
- removal of driveshaft's from and f20
- help with fuel problem
- fuel mixture
- xw/let ignition modules/coils are they the same?
- How does dump valve work?
- Does a Cavy fuel computer need reprograming or calibrating
- Z16SE 1.6 ?v
- How do you tell a coscast head from a porous one????
- is your bumper & Grille Missing
- Let rebuild advice and ideas?!
- Engine weight
- What FMIC for mk3 Astra?
- c20let turbo
- C20LET blues
- F20 boxes, 3 types?
- velos inlet - ebay link - opinions required
- Nova 1.6 bikes carbs or leave the injection unit on?
- Pipe from SFi box to AFM....
- motorbike carbs
- engine management harnesses
- rear camber kit, info wanted
- best belt tensioner and oil pump
- Urgent Help!! Which Exhaust For C16xe Corsa Gsi???
- red diesel in a bosch pump????????????
- engine management.
- hhead stud kit for SEH??
- xe wiring
- ecotec and xe lifters the same?
- whats the difference betweenearly and late cambelt covers
- C18xe Astra Sport
- Phase 2 people running saab bosch reds...
- FPR blanking plate
- Would a Nova backbox fit a Corsa?
- engine lackin power after head gasket change
- Fault code question c16se
- 2 litre ecotec into a corsa c
- Spax RSX coil overs on Nova. Can't get front wheels on
- calibra turbo engine bay fuse & relay box not present at all.........never was!!!
- throttle bodies which managment
- Cav 1.8 Injection wont start, please help!!
- gearbox ratios query
- x16szr, clutch noise, in astra mk3
- VAUXHALL OMEGA 2.0Lt 16v GLS ENGINE SPECIALIST NEEDED!!!
- x14xe rocker cover gasket torque settings
- X14XE Torque Settings
- Just Bought A Stage 3 Head For My X16XE Engine. But.....
- what size is a coscast head??
- Driveshaft help
- Fuel pressure sender?
- adding xenons to pre facelift omega
- c18xe idle problems
- Z20LET Conversion
- ported head question
- Relocating the battery
- Xe NOS jet fitting
- Dta. how/what fuelling do i need to alter
- Innovate Motorsport LC-1 Wideband Lambda on C20LET
- Bosch Super-4 Spark Plugs
- how can i tell if a Mahle piston is std size??
- What Oil
- Oil leak
- fitting ph2 chips help!!!
- corsa cambelt quick question
- injector prob on X16XEL astra
- corsa fueling and ecu prob
- F20 paired with V6 engine
- Need a place to get valve guides fitted
- C20NE with turbo - prevent from knocking
- x20xev air flow meter
- Help with resetting the service indicator on a Peugeot 106
- Someone help!! Running lean after replacing head??
- Astra 1.4 8v having troubles starting from cold :(
- f16 gearbox 2.0 conversion
- F28 Gearbox help
- More rebuild questions....
- LET fuel filter questions...
- f16 on c20xe?
- f20 gear box with v6 engine
- do you get a plastic petrol tamks for the cav as you do the cally??
- **Vauxhall Tech 1 programmer needed**
- Smoke coming from rocker cover breather pipe when airbox lid is off??
- looking for pic of turbos
- diy turbo oil seals
- just took my old turbo to bits (pics)
- oil cooler
- help with engine mods to a 1.6 16v corsa sport
- xe/xev block aircon set up questions
- Engine whine
- 2.0 8v into mk3 astra diesel van
- ARP Head Studs
- astra mk4 c20let mounts!
- Twin turbo 3.2 v6?
- C20let engine noises..........help
- Engine bay pics?
- Astra 1.7 tdi turbo works when it wants to
- Corsa c 1.2 sxi 02' - Starting noise???
- What injectors for 230bhp xe with nos
- benefits of steel head gasket??
- What Flywheel?
- Unichip or ecu remap for Z20let
- Regal 2L Conversion in a Nova.. What shafts??
- CLUTCH question
- Stem oil seals
- phase 4 fuel pressure
- Dizzy and coil pack
- What Engines The Best??c20xe C20let??
- Help with 16sv engine conversion
- C20LET rocker cover gasket replacement help
- Vectra 1.8 16v starting but not running?
- some small problems with c20let, any help??
- Got my head back!! Plus my 440's have been delivered!! Friday the 13th aint so bad!
- rear diff oil change, cally t
- How Do I Mod My C20let Fuel Reg
- xe sounds like a v6
- astra mk3 1.8 sport 16v ecotec manifold
- Corsa Conversion ??????????
- fuel pump problems for mk1 astra!!!
- turbo water pipes?
- any gen on how to fit starter button to sri?
- Powerflow Exhausts? Astra Coupe 2.2
- c20xe starting problems
- Emissions results for a C20LET
- re-location of battery
- Throttle response
- de cat pipe
- how do u set the timin on 1.6 nova
- Induction or panel filter for VX220 N/A
- ignition amp removal/refitting on c20xe??
- Cylinder Head Bolts
- Crankshaft bolt - which bolt?
- F20 problem
- c20xe what branch to use plz help
- Chevette box/corsa engine q?
- Turbo engine mounts - intruder alert!
- x20xe conversion, fuel pump
- c20xe - x20xe exhaust manifolds
- calibra fuel leak
- 2 ltre xe engine timing belt
- Courtenay cams, are they stamped at all??
- **Throttle body for xe & let,, same or diff??**
- sportex bhp gain
- is the LET fuel pump relay the same as the SEH one?
- quickshift gear box
- engine rebuilds 20xe
- Corsa diesel question..
- Twin 45's on a 2.0l 8Valve
- Missfire! on c16se
- Fuel computer switch
- Cheap and easy mods for C14NZ MPI
- Turbo Stopping Working In A Puddle??? Help...
- changed head gasket an nw nothin works
- auto transmission fluid
- Head gasket changed - now wont start, help please
- f28
- xe oil leak
- f.a.o chip nitrous
- Fuel pressure gauge on Xe / Let .
- C20let Ecu Upgrade
- Help with Nova 1.6 8v twin 40's
- FAO people with EPC, or exhaust catalogue
- Small Block Oil Pump
- redtop quick question
- asta coupe turbo (baileys dump valve
- Removing pas from x16xe
- corsa sri engine stalling juddering
- Sportex exhaust
- Astra G Engine - 1995 16 16V Tigra
- relocating xe icv
- Corsa B C20let Clunking From Front End
- de cat for mk4
- Filter for QED DTH Bodies
- Which clutch to buy for my cav turbo?
- Astra mk2 gte manifold?
- turbo gsi
- where to get nova lowered tie bar brackets/nova f28 linkage???
- pierburg 2e carb
- mk 3 astra gear linkage
- XE fuel pump relay
- corsa b 1.2 merit gearbox question
- Fuel com plug and alarm plug help required on cavy
- Quick v6 timing belt question.
- corsa 1.2 16v fault codes
- Modifying old gear linkage to fit on a 6-speed F28 gearbox
- Is this a locked transfer box?
- corsa 2.0xe throttle bodies and....
- Fuel Problem ?
- Valve Stem Oil Seals on C20XE
- Astra g/mk4 convertible engine numbers
- Let cmashft info needed
- c20let boys quick question
- Dump Valve Before or After IC?
- Oil breather on 20XE on tb's
- what cams???
- qed cam question
- corsa sxi 1.4 help
- Corsa B 1.2 sxi running problem
- xe corsa problem
- 42 - ist gear recognition switch voltage high
- engine truble :-(
- drilling throttle body. house drill or pro?
- differences xe - let
- throttle cables......
- Taking an LET out of a calibra
- Closing elec windows with no power?
- whats white oil mean?
- Frontera Engine problem!
- what problems will a bad cat cause???
- astra coupe 2.2 gearbox upgrade?
- Wanting a better feel to gear stick
- Corsa C sxi 1.2 - Ecotek valves?
- Astra EGR valve
- corsa let prob
- could my ecu be knackered? still no spark
- what are forged pistons???
- c16xe into 8v engine mount (help)
- if you no about v6 cams look in here!
- what gearbox does the omega td use?
- XE problems
- Equal Length Driveshafts = 2ltr XE
- Coscast Head... how can u tell?
- Are the valves in my C18XEL engined Astra sport likely to be sodium filled?
- Any 1 know part no of Amal Valve
- Astra Sport Fuel tank removal.....
- very Quick Fuel pump question
- Pistons and ceramic coating
- clutch problems
- 1996 vectra 2.0 x20xev poor running
- Bailey alloy oil catch tank
- Wide band lambda
- c16se - starting problems
- Q8 Formula 10W50 oil?! any good?!
- Core Plug or Head Gasket Oil Leak? Advice Please
- vw engine (i know it aint a vaux)
- Xe airflow meters
- F28 6 speed into mk3 gsi astra help please
