- does anyone know the difference between the 2.0 8v ecu loom variants
- hhas anyone ever come across a vtuning-porous fixed head thats became porous again?
- Xe To Let
- 1.6 sport astra...how can i make it faster!!!
- Nova 1.0L starter motor
- all nova driveshafts............
- Head Gasket question
- vectra misfired then cutout
- links for injector info / sales
- Astra mk4 TURBO????
- will a red top fit the 4x4 box of sri cavalier
- 4x4 corsa or nova
- sticking valves?
- 2ltr 4x4 corsa
- C20Let Valve Pic What Valve Is It
- Very obscure fault after engine rebuild.
- C20XE Corsa Overheating
- x16xe dieing
- c20xe corsa running problem
- Changing seals with head on
- Omega ECU Chip Number?
- Aftermarket HID Xenon Kits....
- cat off, straight thru on :-)
- Removing heater on LET Mk2 Astra track car - good/bad idea?
- crank sensor no sig
- Astra Mk4 Sri exhaust
- oil leak, i think.
- nitrous
- LET (Yellows) Injector Question
- C20XE heating up
- XE wont rev over 4000
- LET crank dimensions
- would this turbo be worth putting on 300bhp let...
- g-max kit,cav 4x4?
- transfer box,speed hump?
- Any GOOD Dyno Tuners in/around Leeds?
- Transfer box temp sender, swapping from 2 to 1 wire?
- calibra exhaust
- Problem with my C20 LET
- 4x4 tracking
- Corsa b combo van gear box...
- c20xe coil wiring
- corsa xe problem eps and speedo
- Fueling question/ internal tank
- Nova gsi loom wiring
- coilover fitting
- Engine code fuel pump relay help
- c20xe wiring into nova gsi loom help
- Nova LET problems
- How much boost can i run on my Phase 2 Cav turbo??
- Does ITB's and Lambda Sensor go together?
- Seriously erratic Idle - XE
- Help 2l nova driveshafts
- Let oil spray nozzles
- My new sbd type C manifold nikel! (pics)
- Removing and fitting of a f20
- Which strut brace for a c20xe nova with the sfi box still on
- Help.....central locking not working(spark)
- Heavy duty con-rod bearings for 2L 8v
- BHP Of Astra Sport 1.8 16v
- Heater Probelm Calibra Turbo '96
- changed oil using vaux 10/40 now it taps
- Egg in me Rad,fixed Rad,How do I get egg out?
- What Spark Plugs
- Fitting/filling new lifters of 20XE
- Drilled Air Boxes? Are They Worth It?
- let fuelling problem fixed
- converting astra mk3 x16xel into c20xe red top
- coil lead sparking, injectors firing and icv clicking when ignition turned on
- ecotec piping question
- f20 gripper diff.will it fit the f28 like the atb does?
- Fuel pressure? General Query.
- ebay remote engine start any good?
- v6 engine pics wanted
- c20let into astra gsi urgent help please
- Regal nova c20xe silicone hose kit
- c20xe....no spark?
- Engine Mount Bolts F28/F20 Turbo/GSi
- map sensor
- * E16SE into 1.2 8v Corsa B...What fuel pump?
- C16SE pistons diam and bore size
- higher fpr
- Motronic 2.5 or 2.8???
- Walbro 255 Fuel pump - WHAT KIT???
- C20LET lumpy idling and cutting out
- Suspension for c20xe corsa? Koni?
- If I was to build an LET from scratch...
- mk 3 astra heater relay location?
- C20LET injectors
- c20let imobiliser
- Induction Kits On 1.0 12v Corsa
- f28 into mk2 astra?
- Uprated oil pump question
- cav td seat belt tensioner
- 190lph sytec fuel pump ok for 300bhp?
- changing rocker cover gaskets on Mk3 Astra help needed...
- X16XEL Tuning?
- Red Top Corsa GSI Running Problems!
- which oil for vaux Tigra? 10-40 or 15-40?
- Are let / xe crank sensors the same?
- c20let fault code 71 ats
- GTE exhaust. Which box is cat?
- Oxygen/Lambda... problem
- Calibra turbo...................THE END
- corsa x16xe (no performance)
- gearbox sender
- High idle on my ecotec
- Astra VXR turbo part no and eng' code
- Superchips for C20LET..........help
- Fitting Walbro 225 Pump Cav Turbo
- rear gearbox mounting astraf
- c20let into a automatic calibra?
- 20XE How To Regain Lost Power
- why does 4x4 keep switching off when warming up?
- do 1.4 single point injection astras have throttle bodies
- Engine mount trouble
- 20xe mods
- why the differences between the X14xe?
- Nitrous Question
- New corsa SRi 1.8 tuning...
- Misfire running rich MOT failure
- 3.0 ECU Map
- calling all 20xe owners (in nova), need abit of help.
- FSE power boost valve fitting!!!
- ARP head and conrod bolts
- LET rings that won't make me skint?
- Vectra Head Gasket replacement
- astra gsi turbo having problems help needed
- Difficulties & Disadvantages of F28 in nova?
- ecotec troubles
- Corsa 20XE wont start!
- Engine Transplant Astra SXi
- Is it possible to put fuel lines on wrong way round?
- Fuel Computer For Vectra P Reg
- Cigarette lighter
- Lightened Flywheel ; Whos Got one? Your Thoughts?
- LET CONVERSION ON A TIGRA (help)
- Fuel pipe how to remove?
- Transmission refill location C20XE F20
- All Parts Required For Let ??
- What uprated fuel pump for the LET
- X16XEL flywheel locking tool
- astra F LET intercooler size
- Astra mk4 SRi Turbo question
- intercooler for mk2 astra??
- correct main cap bolt for c20let
- LET Tophat
- octane plug for race fuel
- engine trouble
- power steering nova
- 1995 corsa sri 16v engine dose wot it wants :s
- gsi/ xe sri cat the same?
- which turbo do i go for c20let
- how do u convert an f16 for a veccy
- Quick exhaust question
- What plugs 180bhp 1.6 16v
- my t,b xe is playing up again
- Cavalier SRi sometimes won't start
- calibra v6 trouble with engine cutting out
- let fueling
- leaky sump gasket
- regal, courtney or superchip????
- Rover 820 misfire - any gen?
- F16 Or F20 Gearbox On Xe
- The tester nozell on the fuel rail...
- severe oil leak form torque convertor....
- full throttle going lean
- Overheating 1.4 8v
- C14SE cylinder head onto C14NZ
- Quick F20 question
- 1.4 spi - 1.6 spi
- Question for all you C20 let boys
- CV Joints for LET
- c20let-Throttle position sensor
- EGR Valve where is it ?
- Veccy backbox on Astra GSi
- spark plug 2 run with nitrous
- cv joint 1.616v sxi mk4 astra
- c20let info please.
- air filter
- Weber carb or manifold.
- Speedo on C20LET: not correct!
- v6 throttle body (cavalier)
- What mileage do C16SEL and X16XEL need timing belts changed
- engine cuts out!!!
- turbo clocks in gsi
- Fuelling issue
- z20let turbo schematic?
- digital dash problem
- Nova GSI engine probs continued! :(
- sump plug
- x20xev turbo
- Help Required Asap
- How to service a 20XE ??
- Conversion help c20xe into corsa (nearly finished)
- XE wont stop tapping. Rebuilt coscast head
- Astra engine codes and modifying
- ffs error code 38 lambda sensor voltage high what do i do??
- Solid Nova engine mounts...
- Oil way plug
- can you clean a lambda sensor?
- 2.0l xe pistons
- X20xve Temperature
- Nova GTE/GSI inlet plenum on C16XE
- XE Radiator into Calibra Turbo
- injector ques
- x14xe crank pulley hits t/belt tensioner bolt- help?
- EDS Phase 1 spark plugs
- c20xe exhaust help please.
- oil pump compatibility 2.0 8v/ 2.0 16v
- Need help, want to fit a t3 turbo
- oil in water
- spark plug leads at the right place?
- Keeping a carb tank on Nova XE
- vaccum pipe locating
- disconecting egr to fit a mantzel style box
- only one headlight works
- thottle bodies on c16xe
- Cav Turbo And Astra Gsi Seats
- tps wireing
- f18 gearbox vectra easyiest way to replace??????
- Cav turbo starting prob's
- f28 speedo drive
- water/metanol injection
- should i be able to see through the cat?
- Charge Cooler
- changing turbo on calibra C20LET??
- Idle Control Valve ICV
- nova turbo diesel
- super chip question
- dump valve
- What size valve guides are required for a cascast head please?#
- turbo or not turbo
- New icv Car still trys to stall
- c20let rebuild
- strut braces corsa xe
- r1 carbs on a xe
- late xe clutch and xev clutch the same?
- 1.4 cams, ecu, injectors to 1.6 items
- con rods needed
- fuel inj return line
- Clutch Cable Woes ; F18, XE
- QED direct to head throttles map (dta)
- swaping rear axel
- C20LET alternator does it again
- phase 4 problem
- Corsa LET silicone hoses
- can a LET block be bored out............
- Corsa Engine Swaping Help,
- eds phase 3 ecu codes
