- c20xe build which crank?
- C20LET vs C20XE tech specs..
- Omega C - Z20LET conversion.
- throttle body woes
- oil in inlet (corsa sport 1.6)
- MVaux 350bhp C20LET Upgrade kit questions
- corsa red top on gsi suspension?
- astra coupe turbo!! please help
- nova conversion (turbo??)
- xe engine clearances
- advice again please - 13s head work
- bottom puley on xe's
- astra mk4 c20let.
- c20xe starter motor problem help plz
- LET Misfire under boost?
- New User looking for some assistance
- Xe idling problems
- Custom Manifolds
- Homemade powercap XE engine?
- Fault codes C20LET
- Sizes of torx & socket for oil change for mk4 Astra dti ?
- Headgasket query ??
- KW Coilover Suspension
- Cam Swapability
- Cricket noise....in auxillary belt area...
- recommended FMIC for cally T
- will a 450kg engine stand hold a let
- xe pistons into ecotec, aye or naw?
- f20 to 2.0 ecotech?
- Removing CAT Myself! HOW TO!?
- carbs are they worth it???
- Real life fuel consumption, Cav SRi
- What is this on the LET...
- Timing Belt Tension 20XE
- Fuel injector cleaning who do you recommend?
- transfer box, cav gsi?
- Vectra GSI V6 Engine water leak?!?
- 8v turbo
- where can i find engine number on 1.6 nova GTE
- corsa c20xe question.
- xe starting problems ,,,
- x16xe query
- What fuel pressure with 440's on phase 2 runnin 15psi constant?
- advice on turbo upgrades please???!!!!
- block skimming in car ???????????
- LET steel headgaskets?
- Is this a standard xe chip?
- Advice on 150cdti engine
- Time to do headgasket...what do i need
- Engine differences between Vectra Sri and Gsi?
- Mk3 Astra 1.4 SPI spitting back from SPI
- Vectra keeps snapping cam belt!!
- 4.0v8 In A Cav 4x4?
- XE Cams
- injector question
- vectra140sri clutch
- How much power can a standard c20let take?
- a bit of let help!!
- fse power boost valve
- C20 LET won't rev
- Fuel pressure question C20 LET
- powercaps! do they do anything??
- Corsa C Z14XE
- courtenay cams for xe
- fuel gauge nova sri
- 4x4 ECU Location
- Advice : C20LET Inlets (450-500bhp)...
- is this adjustable fpr ok to use? its only £18...
- c20 let in mk4 astra
- Throttle bodies and a supercharger
- coupe gearbox
- 93 diesel corsa various problems
- v6 rocker cover gaskets
- digi dash gearbox sender & other questions!
- Corsa B Xe handling issues
- X18XE1 - Bypass EGR ?
- mk3 astra engine swaps
- Oil leak
- Ecotec pipe
- Redtop compression, all 10.5:1?
- redtop & ecotech crank sensors, Interchangable?
- Head porting & throttle bodies inlet manifold
- Machine gun sound in my engine!! Not joking..
- weird xe issue
- top rad hose on xe nova
- oil leak
- what to do? clutch/flywheels decision
- will f28 fit 2.5 v6
- which external pump for v6
- Courtenay High Torque Cams
- Stripping And Rebuilding an F28
- Which 'cat' fits a mk3 astra gsi (c20xe)?
- nova carb
- vx paul's mantzel style inlet
- 1.0 Nova mount's
- wiring for putting xe in mk2 cav
- what exhaust?
- has any1 ever had a next to standard engine tuned? an what was there power gains?
- nitrous???
- What does crankshaft sensor fit?
- Crankshaft
- fuel cut off on corsa gsi
- which gearbox?
- b*stard tw*ting fecking astra gearbox
- XE Idles badly-But Runs fine..
- Fuel and vacuum connectores on C20XE
- xe not running lamda?? how to reverse this
- bonnet lifters
- 8v cams
- my xe idles at 2k? how do i adjust this?
- xe porous mod
- calbra turbo problem
- c20let
- Turbo pressure maps
- vectra b facelift headlights
- deisel dump valve
- Corsa xe struggling to idle
- what phase 2 spark plugs for C20LET ???
- Filters for webbers/throttle bodies ?
- Best cams to get..... (DaveB look in....)
- Which Gearbox for Nova C20XE
- nova throttle cables
- redtop head
- Corsa Loom Problem
- 2.0xe into mk3 astra diesel van
- Gasket cement
- fuel question on cav gsi
- c20let throttle body help
- cleaning airways for egr help
- How long does petrol last for!!!
- grey injectors for let
- Afm On C20let
- Chrome Engine Parts
- B&S Phase chips
- C16se engine ECU question
- corsa 2.0 16v redtop wants to self destruct
- engine help please
- MKIV Astra 1.4 16v X-reg
- missing my crankshaft sensor??
- Samco Hoses Nova c20xe
- balancing throttle bodies
- Converting from N/A to Turbo...
- what do you tb ppl use to hold your coil pack?
- Are coupe turbo and 2.2 hatch rear brakes the same?
- how good do you think.....
- X20XEV help needed
- Ecotec tuning
- Converting Mk2 Astra to Ecotec
- A couple fitting questions (alternator, starter, inlet gasket)
- traction control ecu location
- brake bias valve needed ?
- How do you test the glow plugs on a diesel?
- Mk3 astra estate engine conversion
- c20let conversion help
- Corsa Sport missing and backfiring
- c20let throttle body connections help please
- Buying a 109,000 mile LET Help?
- MK2 Astra Radiator
- fitting electric mirrors to a corsa diesel
- rear turret pics for coilovers
- XE Parts - Std or not?
- seriously good turbo & price
- possible exhaust restriction?
- Cant start ecotec - (RWD Mini ) immobiliser
- which Oil advise please
- gearbox ratios wanted
- my immobiliser key fell out and cut of the fuel
- Batt light staying on - with engine turned off!!
- how can i tell wether my f13 gearbox is close ratio
- fitting air fuel meter in c20let gsi
- Combo fuel pump.
- Cambelt Change
- C20LET Compression test results
- Astra Mk3 Radiator Check
- xe on tb's ignition leads
- How much oil should I put in a 2 litre ecotec?
- c20xe to c20let how hard is it??
- C20XE Grear Selecter rod...
- heres one we've no had in a while - breather mod question
- C20LET inlet cam
- crank case mod???
- HELP!!! Crankshaft sensor...can't seem to get to it...
- nova xe mounting points
- astra gsi gear linkage help please
- Engine building oil?
- mk3 astra clutch cable is it easy to change
- Spanky XE/LET manifold - what do you lot think?
- engine management code 48 20xe
- cams dis and carbs
- let loom into astra sri
- throttle bodies
- 1.8 Cavalier never gets above blue whilst driving
- XE on a standalone management, how much NOS?
- fitting mk3 astra gsi fuel comp to non gsi
- uprated actuator-will it increase my power/torque?
- engine tuning
- Coupe 2.2/ Superchip? Regal Chip
- c20let fuel rail hose split, help!!
- Mk3 Astra Trip Computer says: Oil Lack
- C20XE Machining Mods?
- Corsa 20xe Driveshafts Where Can I Get Them?
- Annoying problem with xe
- astra egr valve
- Gear selection problem
- Starter motor click
- fast road cam
- petrol consumption with vauxhall corsa 1.2
- Trouble with corsa c20xe m-tech short shift...
- Standard compression ratio of a X16XE
- Is it possible to replace the mainshaft of F16...
- LET thermostat...
- Xe'd Corsa Won't Start No Fuel
- injector question
- Headgasket leaking oil?
- con rod broke C20LET
- con rod broken C20LET
- help me with my exhaust decision
- gsi 8 valve
- corsa 2.0ltrxe running rich. help
- Nova camber, caster and toe settings?
- std cally turbo radio...
- throttle bodies ??
- Dizzy pack differences XE and ecotec?
- Fuel flow dampener, do i need it??
- M-Tech corsa driveshaft spacer, why?
- F28 Gear linkage problems
- center exhaust box removal
- Astra 93 Diesel 1.7 water pump
- c20xe cams
- recon driveshafts
- Bosch injector flow rates
- astra 1.4
- Turbo diesel induction kits
- NE/SEH/XE pistons?
- Would you lend me a powercap?
- Engine query
- Coscast Head Or Gm, How U Tell????????
- Our transmission/gearbox woes
- Astra GTE Shaft Conversion
- XE into Nova, what connects to what ? !
- Best exhaust system for Calibra Turbo?
- high lift cams in corsa sport
- Is it possible C20NE with F13 gearbox?
- from 1.6 to 1.8
- cali 4x4 air pressure in system?
- c20xe goin in my corsa,speedo question?
- X16XEL head gasket??
- want to build corsa 4x4 red top turbo
- corsa b with turbo brakes
- does anyone know the difference between the 2.0 8v ecu loom variants
