Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. Think the AFM on my Z20 LET has gone agian.
  2. corsa c engine mounts and conversions - someone help me please
  3. xe wont idle
  4. driveshafts on my nova
  5. xe lazy lifters
  6. fitting a turbo engine into a corsa
  7. c20let coils
  8. ECU Light (C20XE)
  9. clutch problems
  10. X16XE - 1.6 16V Ecotec Engine - Knowledge Needed.
  11. Off Topic - Clio Cam Belt quick q
  12. Astra mk4 sri 2.0 or 1.8
  13. any1 done a rwd cav or v6 4x4?
  14. GT4 gearbox/transfer would fit LET :-)
  15. vectra Z22SE ENGINE
  16. Induction kit for my astra
  17. Problem with sump nut
  18. Idle CO high (cat)
  19. 2.0 8v missing badly ! ???
  20. Eco Turbo
  21. Regal Have a New Phase 4 friendly turbo coming
  22. oil dissapearing
  23. turbo brakes on nova
  24. Transfer box technical discussion
  25. Throttle Position Sensor
  26. F18 cr onto a C25XE
  27. anybody running koni coilovers on corsa or nova?
  28. astra coupe turbo
  29. 2 litre Manta engine into Chevette...
  30. PAS on corsa sport 1.4?
  31. More LET problems
  32. Corsa 1.2 16v CDX - power problem??
  33. z20let into 1.6 8v mk4 astra van
  34. amal valve replaced with electronic?
  35. 3litre 24v Senator gearbox - will it fit a XE
  36. opened up the let..coscast !
  37. Adjustable Fuel Pressure Regulator
  38. C20XE on Carbs
  39. Oil burning 20SEH
  40. vectra petrol consumption sensor????
  41. Just put deposit on 2004 Astra GSI Turbo
  42. C20xe - 2.1 with TB's, question
  43. astra 1.6 sport 1998
  44. Regal tophats...
  45. Connecting EBC - with/without amal valve...
  46. Help How Can I Get Extra 20bhp???????
  47. Astra Mk3 Turbo conversion
  48. Flashing EM codes on a Vectra diesel?
  49. need help with 2.5v6 redtop
  50. Vectra Headlight adjustment
  51. reccommended AFR for c20let
  52. cam lift of c20let engine
  53. calibra turbo clocks in to nova wiring diagram
  54. c20xe in astra
  55. F28 gears for Corsa
  56. Motronic 2.8 immo, possible?
  57. corsa f28
  58. gearbox in 1.6 16v vectra
  59. Power Cap or ECOTEC air inlet hose?
  60. 1.4 8v to 1.6 16v
  61. Play in gear stick (Calibra Turbo) can you rebuild them ?
  62. Std 20xe conrods, How much rpm's can rev safely?
  63. engine management light in renault megane
  64. which head gasket for cooling mod
  65. cigarette lighter fitting
  66. how do you remove a throttle cable?
  67. Why would LET MPG be poor?
  68. steel conrods
  69. T35 on a LET.
  70. xe clutches
  71. Courtenay Sport deflector plate... Cav Turbo
  72. C20LET Turbo Question
  73. XEV RWD Conversion
  74. 2.0 clutches
  75. prepared headstock c20xe
  76. Calibra V6/TURBO alloys on MK3 Astra GSI - Help Please!
  77. What do you think about electric supercharger
  78. Fitting C20LET & F28 into Astra 3
  79. Gearchange issues
  80. quick c20xe oil question
  81. Different valves on c20xe / c20let heads...
  82. Head studs and ARP rod bolts.....
  83. Turbo to Elbow flange on DSOP seperated wastegate downpipe
  84. MBC / Suit which chip?..
  85. fse power boost valves
  86. LET very fast to heat up in traffic
  87. C20XE - Auto Choke???
  88. Little F in the fuel computer window?
  89. fuel light
  90. C20LET Boost problem???
  91. smell of petrol on start up
  92. help help help, crankshaft sensor
  93. ecogash misfire, ecu recall/remap?
  94. C20LET and XEV 120amp alternators the same? (pics)
  95. SBD group A exhaust manifold
  96. XE Exhaust Manifold
  97. HELP !!!!!! Ignition problem (Cav 1.8i '95)
  98. Please HELP Serious mod on cav gsi engine
  99. Quick question, how much gearbox oil for f28?
  100. Done wet and dry test now on cylinders...
  101. Is it safe to drill the gearbox?!!!
  102. check/adjust fuel pressure
  103. G20LET metal headgasket...
  104. what make is this manifold?
  105. Mk 4 Astra Dti 16v F17 Gearbox Problem
  106. is it safe to take the water pipes off my turbo for a short trip?
  107. What gearbox in c18xe Astra Sport mk3
  108. Nova 20XE fuelling
  109. x20xevs in astra or vectra - where are the mounting points
  110. Engine c20xe turbo
  111. f28 clutch plate
  112. corsa b tuning, 1400 16valve sport
  113. turbo or supercharger?
  114. Lowering compression ratio (Z20LET)
  115. Astra GSI Fuel Pump
  116. Hydraulic tappets question...
  117. c20let clutch
  118. F-28 Gearbox Tuning Question
  119. 04 Reg Corsa 1.2 16v
  120. calibra oil pressure
  121. head height c16xe
  122. nhra obtain 1500hp c20xe
  123. engine manegement
  124. corsa xe CV problems
  125. corsa c20xe mount kit??
  126. Coupe turbo oil leak...? smells when idling
  127. engine c20xe
  128. corsa de-cat
  129. pas fluid out of transfer box breather
  130. 1.6 Vectra Running problems
  131. c20xe
  132. coil wiring quick question
  133. my new turbo question.
  134. Transfer Box????
  135. did the timing belt change on the 8v engines like it did on the 16v engines?
  136. XE Corsa Questions
  137. how to re prog mk2 fuel computer
  138. Nova GSi Engine Management Light
  139. unichip questions
  140. in general, how much do decat pipes go for?
  141. corsa 1.0 12v to 1.6 16v
  142. oil pump
  143. xe pistons
  144. strange engine question
  145. Webber fixed rate fuel regulators
  146. Z18XE engine trouble!!!
  147. Nova hydrolic clutch? Vectra setup?
  148. Let and V6 (C25XE) Flywheel Fitting ?
  149. HKS SSQV BOV making car stall on idle, anyone else using on on a LET?
  150. How many LET-ers run a chargecooler?
  151. c20x
  152. arp bolt torques
  153. Xe corsa blows heater pipe and now the rad??
  154. Gear Selection
  155. Isuzu Engine Astra MK3
  156. C20LET Baffle plate
  157. C20LET Oil Pumps
  158. c20let code 117
  159. f18 replacing f20?
  160. help with a 1.4 8v induction kit
  161. f28 in astra mk4 help
  162. who can rebuild my let?
  163. My cat doesnt smell, should it?
  164. 2x c16xe rolling road test ?opinions?
  165. whats the standard SEH clutch rated at?
  166. running a engine in!!
  167. Whats Best??
  168. Vac pipes Vectra 20XE ecotec
  169. Calibra Clutch change?
  170. cav gsi strugling in all gears about 1500rpm to 2000rpm
  171. Nova 20XE Coolant hoses
  172. cam sensor
  173. Recommended Plug for C16SE
  174. dump valve not working
  175. oil leak advice please
  176. Redtop experts in here please.
  177. Corsa (B) Sport, turns over but won't start !
  178. Misfire 400-5500 rpm
  179. Xe smoking...
  180. Loss of power through an induction kit?
  181. what strut brace for nova xe
  182. engine swap in a nova
  183. ecu to ignore lamnda xe
  184. removing cat from exhast
  185. c20xe.........no spark
  186. Corsa B Sump Plug
  187. cavalier gsi redtop runing troubles
  188. Engine Painting & XE Sump
  189. Turreting a nova rear for coilovers?
  190. any OMEX experts? need help with tps........
  191. diesel running back to tank?
  192. Lightweight Flywheel
  193. Sports air-filter in a donkey diesel?
  194. bleed valve on a diesel
  195. Bollox!! think my heads gone porous.
  196. Astra F 1.6 8v
  197. what plugs for eds c20let phase 3?
  198. Nova conversion (3 part driveshafts)
  199. Astra Gsi Mk3 Gear Linkage Nightmare
  200. Astra Phase 1 and 2
  201. Temperature sender location on X20XEV(2000 opel omega)
  202. C16SE Air Intake Diameter?
  203. IF I wanted to tweak the Z20LET?
  204. Nova Radiators
  205. Clutch recommendations for a C20LET
  206. z20let iridium plugs
  207. copper exhaust wrap
  208. another 2.0 8v loom change. different loom again. whats this plug?
  209. Is there ANY PICS or info on where all my hoses go on my C20LET ?
  210. oil sump compatibility
  211. Headlight Lifter Motors - Problem
  212. c20let,smoking occasionaly and oil leak from intercooler
  213. Cavalier SRi Ecotec Help required
  214. astra mk3 1.4 spi idle probs
  215. taking XE out of GSi with gearbox still in....
  216. EGR Blanking
  217. corsa 1.4 sport R reg
  218. Would this digital dash fit my cav turbo?
  219. what does insp mean on my clocks when i start my engine?
  220. Quick fuel pump question...STP220
  221. Wierd noise after fitting exhaust
  222. V6 Calibra.. coil pack problems?
  223. Nova engine mount
  224. induction noise...
  225. Dummies Guide to fitting the " Mvaux 350bhp Turbo "
  226. What is the engine?
  227. Wanna fit my oil pressure indiglow gauge now...
  228. EDS Phase 1 C20LET
  229. best brakes for claibra turbo?
  230. cav v6 driveshafts?
  231. 1997 2.0 Ecotec tapping and oil light
  232. oil sump gasket problem
  233. Need Help about fitting Large Throttle on a C20XE.
  234. Loss of Power
  235. Replacement turbo
  236. Carbs, fuel filters and flow rates...
  237. F25 to a 4 cil.
  238. Changing Mk2 Astra fuel pump?
  239. fuel filter
  240. things you find in your exhaust...
  241. Corsa B Type 2 Offside Chassis mount and Engine mount question
  242. Fitting gearbox to V6
  243. let dropping onto 3 cylinders
  244. Engine Loses Power After 5 Mins
  245. Astra 3 Van d engine conversion, V6 or 16v?
  246. Fuchs Oil - Portuguese needs opinions!
  247. c25xe upgrading??expected power??
  248. C20xe fitment into corsa
  249. Headlight Wiring / Relay Upgrade
  250. Is there a difference between these 2 Blocks
