Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 [91] 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. 1.7TD (Vaux engine) smoking probs
  2. Walbro 255 external fuel pump
  3. z20let engine price???
  4. C20XE Valve Lifters Same as X14XE??
  5. F20 Gearbox Makes a noise
  6. MK4 astra coupe / GSI turbo
  7. C20XE ECU Differences
  8. Question about CNC machining my Throttle body ??
  9. advantages of bigger throttle body?
  10. What is this on my engine? (photo)
  11. Throttle Body butterfly query
  12. Steering capoot Mk3 Astra gsi 2.0xe
  13. LET into mk2 astra. coupla wiring issues
  14. how do you bleed a f28 transfer box?
  15. C20 XE cr*p fuel economy
  16. f28 6 speed
  17. Fuel Pipes
  18. Fuel pump relocation????
  19. C20LET Exhaust Diameter? any ideas???
  20. Lost power and stalled
  21. 3 pin xe and let tps's interchangable
  22. SRI oil relay bihind block help
  23. 2.0 8V flywheel - will it fit x20xev with F18 and standard clutch?
  24. centre exit exhaust
  25. Vectra high oil consumption
  26. pug 306 d turbo wont start
  27. C20XE cat regs
  28. Turbo manifold to cylinder head nuts
  29. Exhaust diameter
  30. What is Omega Pistons?
  31. quickly identify these engine bits
  32. cheap alternatives to sports cats for XEV - any ideas?
  33. c20xe pistons
  34. Random LET water hose question!
  35. Where is ICV on the LET (pics needed)
  36. 1.6inj cav engine into astra?
  37. NOS Experts
  38. Snapped CTS in engine
  39. calling all x14xe owners!
  40. squeeky altenator belt
  41. Brake pedal hard when engine off - spongey when on?
  42. will my xe go into r'lasses corsa c
  43. What models of volvo came with 4 pots?
  44. Corsa Mad Idle And Engine Management Light
  45. Cav 1.8 tuning
  46. Few XE Throttle Body Questions
  47. driveshafts
  48. NGK AFX air fuel monitor
  49. Vectra ecotec, no speedo, error 0500 & 1690?
  50. anyone on here know owt about pug diesels
  51. 2.0 16v running low comp
  52. vectra 2.0dti ecu/engine problems
  53. oil burning and high emission x16xel
  54. what bhp
  55. Years for Flat Flywheel
  56. CAT Replacement Pipes..
  57. C14XE needs head gasket, buy or leave it?
  58. clutch choices...
  59. Can a C16XE ECU be used with an X16XE ?
  60. Nova XE Wiring
  61. 1.6 astra
  62. Fuel pump gsi/joy
  63. Which fuel hose?
  64. 91 astra 1.4 running problems
  65. whats this called? engine pic included
  66. CORSA Performance Mod Chip +20BHP
  67. reasons why my xe will not idle?
  68. 1.8 cav engine problem
  69. Clutch for C18XE Astra...
  70. c20xe running problem
  71. omega wont start
  72. PCD of the cav/cally turbo
  73. what type of gearbox is in a 1.8i 1995 cavalier
  74. Starter help ASAP
  75. inner cv joint on a xe nova
  76. Top your BHP up
  77. corsa c engine conversions help please
  78. What's this turbo? T3? (pic)
  79. advise on results of compression test on red top
  80. What's this turbo? (Pic)
  81. hostyle 350bhp turbo kit
  82. corsa c20xe conversion driveshafts
  83. Corsa B Crank Sensor fault
  84. nova C16xe F15 Short Shift
  85. MK2 Astra Coilover Questions
  86. anybody clued up on f28
  87. c20let hesitating
  88. discussion: backpressure /exhausts ?
  89. Throttle lag with K&N
  90. exhaust info plz
  91. C20XE Rebuild questions...(parts)
  92. c20seh tuning
  93. 20xe revs climbin
  94. nova gsi won't start
  95. Exhaust Wrap
  96. Anyone know what power
  97. What are, if any, the benefits of having an F28 on a corsa c20xe ?
  98. redtop problem
  99. F28 into non ABS Astra G Speedo query
  100. are all xe20 pistons mahle??
  101. Cav Turbo fault reading results .
  102. removing alternator and belt?
  103. How to tell? porous / head gasket?
  104. Engine Code For My Astra???
  105. cams and dizzys
  106. Is this the CTS?
  107. Ten minute Engine Build!! Vid
  108. checking fuel pressure
  109. what shafts do i use for f28
  110. removing head bolts? safe?
  111. turbo hose keeps poping of
  112. clutch clips
  113. cavalier fuel pump question
  114. Let dump valve problem
  115. Info require for converting F28 to 2WD
  116. C20 XE running probs
  117. 8v calibra part same as xe???
  118. If you want technical info
  119. Engine management Question
  120. Help!! Inlet manifold
  121. Help!! Inlet manifold
  122. xe injectors
  123. is it normal to burn a bit of oil after a rebuild?
  124. liquid for diagnosing head gasket failure?
  125. FAO anyone who has done a 1.28v - 1.616v conversion . . .
  126. Let Loom
  127. inner cv on equal length drive shaft
  128. cav 20l 8v turbo
  129. Need Help!redtop Running Lumpy
  130. Carbs
  131. Locating CTS on a corsa B 1.2 8v
  132. turbo not boosting
  133. exhaust rubbing on handbrake cable
  134. mbc ,fuel pressure= bhp's
  135. Paperclip test on corsa
  136. 1.6 gte engine help
  137. Egr valve on a zafira?
  138. Vauxhall Nova, H Plate, 1.4SR, Weird Problem
  139. xe throttle body plates?
  140. xe throttle body plates?
  141. 1.6 corsa GSI HELP lol
  142. C20LET boost
  143. Noise of solid lifters?
  144. ecotec ecu question
  145. Small end bearings..C20LET *NO MORE*
  146. F16 input shaft and clutch question
  147. c20xe redtop ecu question!!!!!
  148. XE & LET sump gaskets - Oh no not again I hear you cry, lol
  149. F18 driveshafts in a F20 'box
  150. rebuilding a C20LET engine
  151. Fitting New Coilovers - What Else Should I Replace?
  152. no power to my fuel computer
  153. Twin Carb's
  154. Engine balancing
  155. Fuel Tank Noise Apparently?
  156. Spark Plug Gap / Torque on Corsa
  157. Best C20LET clutch for sliping start
  158. Leaking Gearbox Oil
  159. C20LET skimming the flywheel...
  160. i need feedback on C20XE SBD
  161. prep block for fitting cyl head
  162. c20xe conversion
  163. 1.6 8V into corsa....... idling to fast tho??
  164. Air/fuel ratio readings
  165. Fuel pressure.
  166. f28 grearbox again
  167. LET ticking over at 1500rpm?
  168. Any kind of improvement for C25XE?
  169. Mk4 Astra Engine Conversion
  170. oil water mixing on xe cav
  171. What to do with my Astra 1.6 sport
  172. Head bolt torqueing procedure 1.4 mpi
  173. Is it worth fitting a diff to a corsa b c20xe?
  174. Instant fuel consumption on X20XEV
  175. help needed-nova fuel pressure
  176. Crankshaft balance weights on X20XEV
  177. can some one get me pics of let engine need to see where all vacum hoses go
  178. where is the iscv located??
  179. C20LET AFM Gen please.
  180. Wheel specifications
  181. Buying an x16xe without an ecu
  182. bike carbs
  183. XE Missfire
  184. running a c20NE on an SEH ecu?????
  185. Omega 2.0 Ecotech question!
  186. corsa b engine conversion (1.6vs1.8vs2.0)
  187. Piston cooling options
  188. Nova GSI - Corsa GSI clutch
  189. XE and XELN Cams
  190. oil warning light has come on!!!!
  191. astra n reg turbo diesel isuzi engine
  192. 1.6 8v into corsa engine conversion, wiring help!!
  193. Engine Management Light On - likely causes?
  194. 3" systems on calibra / cav turbos...
  195. cavalier 1.8 spi engine code
  196. C20LET Block / C20XE Block...
  197. Which F28?
  198. Brief instructions to remove injectors...
  199. Cav 1.6 engine
  200. Astra F with 225/40/16 on 7,5x16 ET35
  201. Corsa B with 205/50/16 on 6x16 ET49?
  202. Astra F with C20LET converting to Corsa B
  203. Corsa 1.4 Sri Overheating
  204. 20xev head on 20xe
  205. Vectra losing all pulling power !!!!!!
  206. my clutch
  207. Help, GearBox problems!
  208. what fuel lines do i need to run a 2.0ltr16v in my nova
  209. bottom pulley removal c16xe?
  210. breather probs, chuggin blue smoke
  211. what tank and pump do i need to run twin carbs on my nova2.0ltr16v
  212. zlet smelling of oil...
  213. xe corsa missing wen rev over 2k
  214. xe inlet on LET without verniers
  215. z20 gasket or cometic?
  216. Timing on a XE with vernier pulleys
  217. 350bhp In A C20let?
  218. Phase 4 specs
  219. Tuning a 2006 Veccy 2.0ltr TURBO
  220. Megasquirt & LET
  221. nova sri head gasket
  222. death and destruction of my corsa c20let
  223. calibre engine removal
  224. oil light question
  225. Those with XE inlet cam in LET...
  226. Leaking injector 1.7td(GM)
  227. Polystyrene vs. Polycarbonate?
  228. astra gsi probs 1.8, heres the codes
  229. universal oxygen/lambda sensors???
  230. can i use castrol gtd oil in a non turbo diesel corsa
  231. smoke coming from exhaust
  232. 440 Cc Injectors What Chips Do People Use
  233. TDI engine power loss
  234. At what amount of nitrous should a 'wet' kit be considered??
  235. Gear Stick Unit.
  236. Will new Vaux gearboxes fit older Cav/Cal 4X4's ???
  237. red top into a nova
  238. Finally got the evo 6 intercooler on!...
  239. coscast/pourus head?
  240. New LET oil pump has no takeoffs for oil cooler?
  241. transfer box help part 2
  242. Nova 1.4 engines
  243. Which engine in a 2.0GLS 16v cavalier?
  244. My Z20let engine overspeed problem fault code
  245. X18xe1(small Block)
  246. Astra Cabrio mk3 Engine Conversion?
  247. Help No Ignition Power Wotsoever
  248. valve?, piston?, gasket?
  249. Cam Belt - Change on C20xe
  250. Chargecooler, Intercooler or both???????
