- Corroded sump
- engine code, 1.8 vectra arctic
- Help getting door open................
- Cold start mechanism on 1.4 spi astra
- argh!! let headgasket?
- rear discs on cav turbo
- Turbo Conversion questions
- Head skimming/refacing, how much power gain if any?
- msd 550ccc injectors
- valves hitting each other
- 1.6 Corsa GSI Air Hoses Problem
- After a bit of info
- C20Let Smoke Opinions Needed
- corsa power(please help)
- changing cam belt
- MK4 astra what gearbox?
- cav/cally turbo clocks
- nova 1.2i gearbox
- how do you identify low comp pistons
- Cav Turbo Owners, Fuel Question.
- question about let injectors
- 2.0 8v Engines, Which came in Astra GTE and cav SRI??
- Corsa B SRI Gearstick Excess play?
- 1.8 16v vectra engine loom
- LET Turbo - Airflow meter uprated hose?
- clutch on f16 - how to get the 12 splined cap off
- 1.8 astra coupe HELP!
- z18xe fault codes
- crank main cap sealer
- power caps
- LET Turbo amal valve advice
- induction kit question
- clutch arm
- Clunky clutch!
- Corsa 1.2 Engine problems
- What next??corsa c20let!
- is there any way to distinguish a kent cam?
- exhaust recomendations.!
- Ford Mondeo 1.8 - Clutch change
- induction- z20 let forced/induction kit?
- z20 let- actuator adjustment?
- Engine overheated on way home
- mk3 astra turbo hose kit?
- cav de-cat onto calibra?both xe
- let-fitting a cossie actuator!!!!
- Astra 16V F20 Gearbox Help required
- Nova XE Engine Wiring
- How secure are Polycarb windows?
- calibra turbo ecu
- dizzy to dispac 2.0 XE?HELP
- What size power cable, Battery to Starter / Alternator ?
- Cam differences, 16xe & 20xe
- How long does a clutch last?
- Big Power LET Valves? 1 piece steel??
- 1.7D Astra starter motor help
- oil level sensor on cav turbo??
- Standard platforms and Double springs
- Oil pickup pipe bracket (C20XE)
- Engine code
- Head Gasket ?
- Looking for a turbo manifold thread
- What driveshafts do i need?
- XE info needed
- Help Cylinder Head bolt won't open
- powerbox
- valver red top
- LET Oil Pressure and temp Senders.
- coupe turbo creaks- aaaarrrrrrrgggghhhhh
- where can i get good ignition leads for my let
- Anyone got a cam for a c14se?
- nova wont start
- HELP! 2.0 TD Vectra not starting...
- Converting GM oil cooler to run braided lines
- c20xe into 1991 cavalier sri
- xev block questions
- quick xe inlet cam Q
- Mercedes Diesel Alternator Issues
- f20 to electric clocks
- manual adjustable fuel regulator
- nova xe to c20let options/ideas
- can't get into second gear ?
- Flexi Exhaust Joint
- Corsa 1.8 SRI
- bearing xe
- xe cam cover metal type?
- Alternator for C20XE
- calibra turbo 4x4 question
- Quick Calibra Engine out Question
- what chip?
- Where can I buy 8mm bonded fuel lines?
- Custom Turbo Manifold Questions.
- Fixed rate FPR
- Straight Cut, Seq, In F28 Housing?
- which manifold and turbo to buy...help
- Phantom xe clutch
- C20XE Oil Cooler/Sandwich Plate
- f13 gearbox problem.
- mph per 1000rpm on an F28
- Corsa TD - Throttle Response Problems ?
- XE Inlet Cam on LET
- what to recon on co2let engine, any ideas people?
- Sorted my poor visibility from nova headlights1
- New engine in my 1.2i nova which one??
- F28 question
- Throttle bodies / engine management
- phase 3.5 ,injectors
- redtop tappet noise
- f23 speedo
- Do you "Run" your engine in when you've replaced the head gasket?
- corsa b 1.2 16v to xe some thoughts..... HELP!
- urgent!! - x20xev - dispack 3 or 4 pin??? thanks
- C20 Let upgrade q's?
- c20xe idle probs
- part number for racetronix 440cc injectors
- c14se
- Aftermarket chips on Turbo .
- Astra g Engine Management Codes
- nova c20let clutch cable???
- Pre-Turbo Water Injection - Works!!!
- Coscast head identification
- Jerky XE
- cheap ways to improve your engine.~(Help)
- V6 airflow meter hot film type on c20xe
- Please help - doing my head in .
- removing chip from gsi
- Recomend Me A Company For A Gsi Manifold
- corsa turbo electrical faults???
- ecu fault light on xe
- Fitting Corsa Sump to Nova GSi Racecar
- turbos
- pics needed of xe in nova
- differnces on xe and let components
- RWD Converting an XE
- astra head
- fitting 1.4 sri engine to my nova 1.2i k reg
- Ecotec CB26 valve
- loom differences
- Diesel Cold Start Problems
- c20 let cylinder heads
- Does anyone have a picture of a corsa 1.6 16v engine?
- Ecotec LET, Does this exist???
- £180 head gasket for let are they this expensive
- Gas flowed head and webers 8vGTE
- big 288 brakes and xe brake questions.
- F28 in Corsa/Tigra
- LET crank pulley small bolt size
- 1600 nova won't start
- oil pressure sender location on astra gte
- phase 3.5 let only revs upto 5000 revs
- fuel pressure
- xe high idle
- Astra g Lambda Sensor
- Spark PLug Q
- corsa c 1.8 sri inlet manifold??
- HELP!! Calibra wont start
- How much pressure on txb ??
- Making a Turbo Calibra
- Need a bit of info RE: Leaky fuel pipe
- Corsa X10Xe idling problem ?
- 2.0 Conversion for a Tigra
- gsi turbo air filter
- misfiring xe
- diesal turbo on petrol 1.4 astra
- Nova - starter wiring/what do do with green pipe?
- help nova 1.4
- engine question
- Bought my x16xe today - Whats missing ? Pics . . .
- Odd Looking Transfer 4x4 Box ?????
- TPS differences? are they interchangeable?
- Astra/Corsa starter motor question.
- Conrod XE and LET identical?
- Crank question???
- Xe to LET Nova
- Cavalier and Vectra Gear linkages, are they inter-changeble?
- let rebuild help?
- MisFire on Recent Conversion C20XE Redtop
- Water Pressurising C20LET Calibra
- TB's for a 1.8 Corsa C
- What is the diameter on OE IC Z20LET
- Bump stops, best location?
- 3.0 Omega Throttle Cable ?
- Fitting phase 2 chips .
- XE - water piper or oil pipe - show it look like this? (pic)
- c10xe corsa B starter motor - how to remove ?
- injectors, wots the crack?
- Engine warning light? Seperated from dash?
- Astra gsi do i need a cat for MOT???
- 2wd f28 shafts?
- egr valve location
- All C20Xe Nova Drivers In Cheshire Area
- throttle body ID
- c20xe dizzy housing same as c20let?
- corsa 1.4 8v
- Exhaust, Mild or Stainless ?
- what injectors for my xe?
- Bracket for SBD trigger wheel?
- bike injection and ignition - cheaper power?
- kkk k27 - few questions
- fitting new clutch in 2.0i frontera
- corsa gearbox mount
- Astra 1.6 16v problem - jerky/kangaroo when accelerating
- big block into corsa c
- When should the fuel filter be replaced?
- LET oil concerns
- fuel pipes
- 1.7 td gm engine cambelts
- c20ne supercharger
- Cts
- Rad Fan Not working on XE
- Expansion tank c20let part number?
- FAQ for those running Phase 2 on LET KKK Turbo
- Let wiring issues!
- for all you petrol heads- what is this valve on my let?
- Shocked Valver Nova
- c20xe sump *urgent help needed plase*
- help with XE'd corsa
- steel layered head gaskets for c20let
- Non original dash and troublecodes? And Oil level?
- top end knock on c20xe
- Have I damaged my engine?
- PDF manuals C25Xe and cavalier (mk3)
- C20NE - Fireblade carbs
- let/xe cam cap torque?
- New Air Filter
- Sandwich two gaskets together?
- XE Oil light on at startup from Cold
- crank pulley bolt on automatic
- Sump Bolt
- What actuator on phase 3 LET??
- Misfiring X20XEV
- F28 speedo
- X16XE Throttle Bodies
- x20xev to dizzy conversion - can it be done?
- cyl head question
- oil breather mod
- mid engine f20 gear linkage help???
- Astra GSI TURBO conversion (Help needed urgently)
- c16xe - help/info on bike bodies
- which gearbox. calibra 16v
- gearbox
- STD LET MAP Sensor
- Calibra Turbo Lambda/oxygen sensor Q's
- F28 6 Speed
- engine management light
- Spark Plug Colour???????
- building a nova xe ?
- what do you think 2.....
- saab red injectors
- 1.7TD (Vaux engine) smoking probs
- Walbro 255 external fuel pump
