: Engines and Transmission
  1. Nova C20NE Not Sparking
  2. supercharge Chevette?
  3. To water cool or not water cool??
  4. cable or electronic gearbox?
  5. Pot type flywheel and F16 clutch change
  6. Corsa C 1.4i
  7. X14Xe X16Xe cam profiles and other oddities
  8. Fuel and Ignition Maps C20XE
  9. vivaro re- mapping any good or con?
  10. Vxr Injectors
  11. boost gauge installation (vivaro) help!!
  12. Corsa GSi Help
  13. Tigra Aux belt Question
  14. hall effect checking??
  15. Another CAM CHAIN issue
  16. F28/LET Clutch...
  17. c20let oil pump wanting to fit z20let pump
  18. Setting up phase 3
  19. What spark plugs and oil for Zafira GSi?
  20. f23 for a 2000 vectra gsi
  21. C14SE fuel problem
  22. vectra issues again
  23. C20let frontera intercooler max bhp?
  24. do i use sealant wen fitting new oil pump??
  25. Vivaro 1.9 6 Speed Rattling when clutch pressed
  26. Carlton 2.4 engine. Gen me up!
  27. cavalier sri130 engine , needs injector info
  28. EDS Phase3 Power Wheel - how many 'clicks'?
  29. Lupo GTI gearbox problem! Help!
  30. what engine code and gear box??
  31. Nova 13s engine problems
  32. Pedal Test - Fault Code Reading Instructions
  33. XE Cams in a Z20LET
  34. Megasquirt set up please any info?
  35. combo 1.3 cdti ecm and dpf fault...code 1901...help!
  36. z10xep head on x10xe block/pistons
  37. 20xe in corsab boggin/missfireing when warm.
  38. Fitting a 2.3mm cometic headgasket
  39. anyone have chris reay email or contact number
  40. Cam cover under pressure help !
  41. Fitting arp bolts
  42. 02 1.7 combo with the y17dt - replaced head now it wont start
  43. 1.6 Ecotec bent valves - C20XE Conversion?
  44. kkk16 - upgrading exhaust wheel
  45. vec b 2.2. diesel driveshaft question
  46. Vectra Diesel Engine spluttering/loosing power
  47. c20let splutter help anyone
  48. z16xep loosing oil
  49. Difference between C20LET and XE head gasket .
  50. X14xe help!
  51. C20LET, No oil to inlet cam
  52. Cav V6 wont start when hot
  53. C20let problems HELP PLEASE
  54. Vectra C engine conversion
  55. smoke froma c20let
  56. which turbo for C20LET?
  57. vxr turbo
  58. c20let piston rings
  59. alloy rad for c20xe corsa
  60. camshaft timing y17dt
  61. What is this on a MK3 Cavvy 1.7TD?
  62. Z16xep tuning?
  63. flywheel bolts
  64. C20xe getting HOT
  65. whats this flange? t34?
  66. 8v or 16v ?
  67. Mil light
  68. C20let and f26... Diesel box??
  69. gunk in the expantion tank
  70. (98) vec gsi 2.5 Air/vacuum leak
  71. Cam cover colours?
  72. Z20LET oil pump potential near faliure
  73. combo timing, nothing locked in place
  74. what engines fit mk3 astra
  75. problems with mk3 astra
  76. Ashley 4-2-1 exhaust manifold on eBay (c20xe)
  77. C20LET recirc valve leak air?
  78. car wont turn off properly
  79. Vectra B gearstick into mk3 Astra
  80. C20let boost?
  81. ebay chips
  82. Nova Turbo - Driveshaft question
  83. Turbo manifold corsa c
  84. c20xe oil breather question...
  85. let and 8v sump gasket
  86. Astra GSI Z20LEH Turbo
  87. C20LET Turbo rebuild
  88. PS23 and Pro-long
  89. MV6 High idle and poor fuel economy issue
  90. Wat fuel pressure evo5 chips bosch greens????
  91. F28 onto X20XE / C18XE?.
  92. C20LET fuelling problem i think? Please read and help
  93. which antifreeze for C20XE
  94. HELP where have the garrett boys got their injectors???
  95. C20LET coil .
  96. Zafira 1.6 2004 - WONT START
  97. expansion tank boiling over? c20xe nova
  98. Corsa C 1.2 SXI convert to z18xe....help !
  99. F25 final drive
  100. f23 gearbox final drive question ???
  101. c20let head gasket/ kkk16 oil seals
  102. f28 leaking
  103. 03 zaff gsi cross over
  104. C20LET using too much fuel ? :(
  105. lexmaul manifold..
  106. M32 six speed gearbox question
  107. Degrees before TCD astra mk2?
  108. corsa b conversion driveshafts and hubs
  109. 1.8 16v x18xe problem help please
  110. C20xe header tank overflowing when revd..
  111. corsa b f18 fitting
  112. glow plug order? (wiring)
  113. rad and fan fpr redtop nova
  114. 1998 Calibra 2.0 16v Ecotech low power issues
  115. wanting to build a hybrid k04 turbo? anyone know were to but the parts from?
  116. Vectra Engine Removal
  117. C20XE coolant hoses
  118. weird start up...x18xe1 astra mk4
  119. z20let idle (sorry peeps)
  120. bearing code mk4 astra diff
  121. What engine is this ?
  122. Manifold cat or cat
  123. Building a LET... from scratch!???
  124. best place to buy sensors for C20XE
  125. Standard Intercooler
  126. Are all Vauxhall speedo cables the same?
  127. X16XEL throttle bodies kit advice needed
  128. HELP C20XE throttle bodies R1
  129. zafira 1.8 engine problem
  130. c20let oil pump help!!!!!
  131. drive shafts C20XE Nova (probably)
  132. possible diff rumble
  133. Decat on 56 astra 1.6 3 door sport hatch
  134. coolant emp sensor problems when plugged in
  135. 2004 - Corsa - 1.4 Twinport Engine Management Light?
  136. Lexmaul inlet manifold on C20LET
  137. c18xe limited to 4.5k rpm and other issues
  138. under piston oil squirter part number
  139. snapped drive shaft
  140. Removing C20xe from MK3 astra
  141. checking arp mains and rods torque settings
  142. c20xe gudgeon pins....? where from?
  143. astra mk3 many questions! c20let
  144. C14SE Vacuum pipery - where's this go? where's that go?
  145. frontera A timing help
  146. F18 Gearbox oil?
  147. XE Cams
  148. mk3 astra engine change
  149. astra mk3 c20let driving issues
  150. c20xe cold running problem
  151. xe fault code 013 & 019
  152. Newbie with a gearbox question
  153. 2.0 8v with v6 throttle body
  154. 1.0l to 2.0l conversion
  155. Calibra 8v (c20ne) fuel leak???
  156. 1.4 8v timing
  157. OIl pressure Gauge problem
  158. are z16xe inlet manifolds the same as z18xe ??????
  159. Astra mk3 1.4 MPi - no fuel / wiring trouble
  160. F20 box with 2 different splines ??
  161. Size crankshaft bush for a redtop
  162. F20 driveshaft size
  163. Belt advice Astra mk4 + XE
  164. newly built c20let oil grade options
  165. Best cams for a let?
  166. corsa 1.5 td isuzu problems
  167. Calibra 8v Auto - Snow light constantly on...
  168. c20xe mot and insurance problem
  169. F20 Gearbox Bolt size please
  170. arp main studs question
  171. Which rear water pipe do you use when redtopping a mk4 Astra?
  172. F23 with Corsa XE question
  173. changing my engine
  174. smallblock oil pressure switch thread size?
  175. vectra 2.2 d glow plug light
  176. c20xe mounts
  177. regal exhaust manifold
  178. c20let/f20 clutch set ups.
  179. Slipping clutch, Sending me over the edge....
  180. Suitable clutch/fly assemblies for 450+ ft/lb of torque on a Z20LET ?
  181. F18 gearbox differences between Vetra and mk3 Astra
  182. open circuit on vectra V6 EGR valve
  183. Inlet Manifold Nuts
  184. Help on Replacement Valves for X18XE1
  185. kadett c
  186. ECU Faults 15 and 73 on Astra Mk3 GSI 1.8 16V
  187. Vauxhall Astra 1.6 8v MK4 Gearbox.
  188. C20LET no boost
  189. z20let thermostat
  190. x25xe won't start
  191. f25 gearbox strip
  192. Supercharger guru's.....
  193. Are Corsa balljoints the same diameter as astra mk4 ones??
  194. GT3076R hole on turbine cartridge?
  195. Astra coupe Decat Exhaust and Sports Cat Insallation
  196. does a wideband lambda just replace my existing one ?
  197. zafira a gsi (i want to fit a 6 speed box)
  198. c20let running lumpy/spluttering since fitting 3" exhaust
  199. corsa x14xe oil pump gasket??
  200. astra mk3 gsi c20let
  201. 400hp on OEM ECU?
  202. Boost Pressure
  203. C20LET Ecu..is it the immobilised kind or not?
  204. T34 Big turbo
  205. Re-routing throttle cables on XE's
  206. coscast head
  207. c20let exhaust gasket ???
  208. x20xev cams in a z20let
  209. Corsa Redtop Driveshaft/CV Help
  210. smoke
  211. Help needed removing v6
  212. adjustable fpr on a v6?
  213. new turbo but boosting higher...??
  214. Adding an adjustable fuel pressure regulator...
  215. C20LET timing components
  216. Intercooler options
  217. mk3 astra 1.6 16v engine change. immob problems
  218. f28 in a nova
  219. fuel presser reg for c25xe
  220. fitting oil squirters to z20let
  221. Question about Z20LEH fuel rail and regulator.
  222. vectra 1.8 stuttering, is it my maf
  223. What's the power difference between Mantzel and ITB in c/x16xe engine
  224. Fitting v6 brakes to mk3 astra van?
  225. astra 1.6 1997 .... c20let conversion
  226. Corsa 1.3 Fault Code
  227. coupe turbo aircon and rad removal advice
  228. Let Smoking on Idle
  229. engine managment light comes on and off
  230. Phase 3 c20let
  231. Electrical Connection to Injectors - Removing
  232. The last c20let sump bolt
  233. how much piston movement in a new built engine
  234. c20let revs going on and off on its own :S
  235. hoseing idle control valve
  236. best mods to do on a 14 16v corsa sport?
  237. x20xev egr blanking
  238. Exhaust Manifold Removal X18XE1
  239. Cam cover removal - X18XE1 Vectra V Reg
  240. Help dropped speedo gear inside f28
  241. megajolt 20seh
  242. removing gearbox from engine problem!
  243. Coilpack wiring issue on Z18XE with Gotech Pro ECU..
  244. oil cooler jic fittings ???what size or type do i order
  245. fuel pressure regulator
  246. Corsa B error p0505 and 1405
  247. Corsa - No Compression in Cylinder 3
  248. wiring speedo transducer
  249. What's ph chip is safe on a let?
  250. TWINPORT Flaps
