: Engines and Transmission
  1. Still got an idle issue on LET with Lambda connected
  2. courtenay cams for 3.0 v6
  3. Checking for ARPs
  4. 1.8 block 2.0 head crankshaft sensor
  5. Jet Sizes Needed
  6. Ok to reuse hg, if head undisturbed ? 2.0 8v
  7. external wastegate
  8. How to make an astra mk4 faster?
  9. C20XE Explosion
  10. Coil Testing with multimeter?
  11. Old Smokey!!
  12. what afr's are best?
  13. 2.2 conversion C20XE
  14. Loose front wheel bearings?
  15. flywheel bolts?
  16. Any one ever fitted an ashley manifold and system to a nova
  17. Part Number for LET Tophat gasket?
  18. Reading ECU fault codes
  19. Motronic 2.7 vs 2.8 - how similar?
  20. redtop problems
  21. Corsa x14xe 1503 immobiliser wrong signal
  22. Cally turbo clocks into Corsa B
  23. turbo and injector choice help
  24. 1400 8valve on twin 40's, jetting??
  25. astra vrx engine into corsa c??
  26. f25 on a xe
  27. Sleeving std nova front hub to fit 2.0l bearings?
  28. cleaing the icv/throttle body on a c20ne
  29. does anyone know where to get cheap clutch for f16
  30. Compression Test result
  31. power boost valve
  32. Saxo (sorry) 1.4 misfire...... HELP!
  33. Strugglin to decide c20let or c20xe
  34. 2.5 v6 on lpg is fine but...
  35. c20let boost down to 0,6bar
  36. 2 Questions , Ox and Oil Pump .
  37. where can i get a set of wossner rings??
  38. Radiator For 16v Nova
  39. Running Diesel with Veg Oil/Diesel Mix
  40. Re-Circ dump valve on Z20LET
  41. Blue Smoke From Exhaust
  42. Lost 5th gear
  43. F13 and F15 Gear Ratios !!!!!!!!!
  44. Turbo Kit for 1.6 Nova?
  45. SB engine
  46. C20XE Hot start problem
  47. x14xe into a Corsa Body Type One
  48. what would cause the engine to flood on cold start?
  49. fault code reading
  50. V6 conversion help
  51. which fan for nova let
  52. Vectra B Rear Engine Mount
  53. RRFPR Fitting
  54. bleed valves - z20let
  55. What does this sensor do?
  56. turbo astra
  57. Readings on a Nova SRi Dispack..
  58. Xe into Mk4 van
  59. Nova SRi stay original or 2.0?
  60. V6 Auxhilary belt
  61. 2.0XE camshaft oil seal replacement
  62. sandwich plate help?
  63. C20LET Spark plugs NKG-Iridium
  64. Advice needed setting pre load on diff
  65. Really hard to get into gear
  66. c20let dizzy cap - best place/cheapest/bosch??
  67. chris astley oil pumps any good 4 c20let?
  68. C20XE DIS pack TPS voltages
  69. c18nz block for 86 piston
  70. astra mk4 c20let
  71. C20XE into MK4 Astra?
  72. corsa failed emmissions
  73. what do u think about this c20xe manifold.....?
  74. C20XE mini - new problem :/
  75. c 20xe ecu codes
  76. seeking to buy an turbo kit for oprta 2006 1.6L the engine code is E-Tech F16D3
  77. XE inlet & TB gasket price from Vaux?
  78. C20XE idle control valve vs throttle plate
  79. where can i get a modified oil pick up to run a z20let oil pump on a c20let?
  80. Does this sound like crank sensor?
  81. C20XE in a classic mini - ECU codes and no fuel
  82. How do you fit phase 2 chips on a c20let
  83. vetcra 3.0 conversion !?!
  84. Knock sensor position?
  85. z20let into nova does it work
  86. 1.8 ecotec hall effect switch?
  87. Astra SRi Decat Question HELP
  88. c20xe revving higher and higher after conversion
  89. Splitting boards on LET ecu ??
  90. Gear box mod's for accelleration??
  91. remove exaust vlaves am i missing something?
  92. LET using oil, only when hammered+++
  93. hesitation
  94. Noise when i press the clutch in?
  95. what will be corsa B c20xe weight?
  96. corsa let f28 box what linkage do i use?
  97. t reg astra 1.7dti advice
  98. C20LET Nova Air Filter
  99. Lambda Sensor Question
  100. C20LET Vacuum Hose & T-Pieces - Where to get?
  101. no oil pressure in my let! help please
  102. Help need a ecu for a old astra gte 8v engine
  103. c20let + f20
  104. Astra GSI Mk3 1.8 16v - How tunable?
  105. c20let corsa knocking! HELP
  106. Corsa fuel pump Q...
  107. is the X18XE head same as the X20XEV?
  108. F18 Gearbox on Redtop Gsi?
  109. Interesting Oil Facts #3
  110. Z20let boost controller
  111. Z20let upgrades
  112. X14XE Tapping
  113. Z20let air intake mod to turbo
  114. turbo v6 engine
  115. Cavalier 2.0GLS Surging Engine Problem
  116. LET COSCAST Head
  117. Redtop Flywheel type?
  118. 2nd to 1st ooops lol
  119. KKK16 Hybrid
  120. convert xe to let or just get a let???
  121. Plug and Play Megasquirt
  122. help needed !!!!!!!!!!!!!!!!!!!!!!!
  123. Fitting Corsa C heater Matrix
  124. White smoke
  125. Bastuck exhaust
  126. vauxhall combo 1.7di
  127. Could a Vectra 2.2 run on Methanol?
  128. Z18XE MOT Failure.
  129. white smoke!
  130. millteck system and front pipe
  131. 1.4 engine consumption on idle?
  132. z20let conversion
  133. Putting a Nova GSI Engine in a 1.2 Nova
  134. RWD q's
  135. bored now
  136. Power on a budget?
  137. Astra mk4 1.7 diesel 03 plate bad mpg
  138. astra 1.7td isuzu engine
  139. POT flywheel
  140. Z20LET Clutch Choice
  141. cav v6 queries
  142. How to install Regal FMIC?
  143. Omega Z22XE power steering pump change
  144. Lsd, Boost Controller, Flywheel
  145. X25XE Throttle air leak
  146. modified oil pick up
  147. corsa c20xe wheel bearings
  148. Astra G Gsi Intercooler advice
  149. Modified ECU for MAP sensor engines
  150. zafira limp mode problem
  151. Removal of c20let in a astra
  152. C20XE Big End Bearings
  153. Omega X20XEV ECUs
  154. v6 into nova saloon
  155. X12XE Coolant Temperature Sensor
  156. MGTF broken.....
  157. nova v6
  158. xe inlet cam on c20let!
  159. f28 check
  160. C20LET ECU differences
  161. Transfer Box does it have synchronizers?
  162. Genuine GM Pump .
  163. How to remove a Corsa engine
  164. What is the standard XE piston size??
  165. engine mounts
  166. HELP fitting tran x diff
  167. F20 problems
  168. Help need a source for Corsa 1.2 16v engine (second hand)
  169. dose anyone think this piston will fit.
  170. Loose Gear Shift
  171. vectra gsi MSD engine, whats it worth?
  172. C20let leaking oil
  173. 1.4 16v sport problems
  174. XE Pistons
  175. [C20LET] High-rev valve springs
  176. spacer getrag 265
  177. Corsa 1.2 16v Club Running Bad
  178. c20let which oil pump?
  179. Corsa 1.2 16V idle air control valve faulty?
  180. C20NE Tuning.
  181. what clutch for xe
  182. Mantzel for x14-x16
  183. Replace corsa x16xe with Astra 1.6lt SOHC
  184. xe cam on a let
  185. t reg astra mk4 1.6 8v engine swap any known probs?
  186. x14xe into 1.2 8v corsa
  187. Would like your advice please??
  188. fuel pump
  189. coscast eco?
  190. VXR turbo on Z20 LET
  191. fuel system
  192. z20let oil pump on c20let! direct replacement?
  193. uprated c20xe manifold.....can any body point 2 the right one for best results
  194. Anyone know the F no on a gearbox from 97 astra TD???
  195. DTA management, cam sensor map?
  196. need some info abot some motors
  197. sri cavalier
  198. C20XE Lightened flywheel
  199. Simtec pinouts
  200. X14XE Throttle Bodies
  201. Anyone know Amal valve part No. ?
  202. what is the difference between x16xe and x16xel
  203. anyone mapped an omex 600 on here help needed
  204. fault code
  205. engine numbers
  206. Wife's rover 25 HGF - Help!
  207. Is this a pourus head?
  208. Car Jerky when Aircon Switched on
  209. KKK16 inlet side size?
  210. gm pump
  211. S/Hand K16
  212. your thoughts on iridium's
  213. 1400cc to 1640cc. Dangerously overbored?
  214. Nova XE Needs HELP ASAP!!
  215. what size socket for hub nut? quick answer needed
  216. Astra G 1.7 CDTI van, Gearbox problems
  217. Anyone know ford diesel engines?
  218. C20LET boost probs
  219. equal lenght shafts
  220. F16 on X20XEV???
  221. Nissan Primera... exhaust valves?
  222. vacuum or coolant!!!!
  223. Renault Clio 1.2 8v P reg - Is this engine 'safe'?
  224. How can i tell if i have a limited slip diff in my car
  225. Aftermarket Idle Control valves
  226. How can i Turbo my Corsa B 1.2 8v......?
  227. Water In Inlet! Help!
  228. Corsa XE fault codes.
  229. Xe throttle cable problem.....corsa
  230. schema for x16xe & c20xe
  231. Engine upgrade opinions
  232. Isuzu 1.7d Gearbox
  233. VXR TURBO
  234. Simtec 56 Differances?
  235. Air Temp Sensor...is it needed.
  236. Turbo Death?
  237. new engine needed
  238. removing driveshafts from gearbox
  239. t25 water pipe query?
  240. engine mapping courses
  241. racing on a budget
  242. 95 ecotec into 1999 mk4 astra
  243. what vauxhalls have a f17 gearbox
  244. C20XE with NOS+Progessive Controller
  245. Astra Mk4 Symptoms
  246. calibra rear diff question
  247. LET, Solid lifters and shims!
  248. epc part number
  249. Oil Cooler Fitting
  250. Standard XE with straight through system?
