Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 [88] 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. MK2 Astra 1.4 Carb to C20XE Fuel Probs?
  2. help with boost valve
  3. C18xe and C20xe heads???
  4. Highflow waterpump
  5. Corsa 1.4 8v tuning options
  6. gearbox gen...?
  7. all those with r1 carbs...
  8. xe injectors
  9. quick cam timing question 1.8 ecotec
  10. sorry another exhaust question.
  11. Phase 2 Cav turbo.. EM light now and again?
  12. gear change & engine mounts
  13. c14se astra engine into corsa 1.2 8v
  14. c20let inlet temp?
  15. project 1.8xe1 turbo
  16. Deepening Valve Releifs on Pistons!
  17. turbo transplant
  18. MK3 astra exhaust
  19. need engine mounts
  20. c20xe not giveing enough power high up the revs
  21. can you convert cable gearboxs to hydraulic ??
  22. Corsa xe conversion radiator query
  23. Changing corsa fuel pump
  24. M plate Omega Elite Cambelt Failure
  25. t3/4 turbo for c2olet
  26. Fuel Pump Relay Wires.
  27. corsa powerbox
  28. cometic v's z20let gasket
  29. Hlp needed: Any LET/engine building experts?
  30. boost control valves-z20let???
  31. Few engine change niggles-2.0 8v Corsa
  32. Corsa 1.4 16v Sport Loosing water
  33. gear linkage
  34. quick 20xe corsa b engine mount question!
  35. Improve power on x20xev
  36. End of plug 3 snapped off in engine!
  37. help with digi dash and xe corsa
  38. xe oil presure wires on engine where r they and where do they wire up 2 on a digidash
  39. Spark plugs
  40. Fuel Pump Fault Code
  41. Urgent - 1995 C18xe no spark
  42. Horn Location
  43. Fuel Pump Fuse Location
  44. Twin Turbo Airflow Meter Which One?
  45. how much power ?
  46. best turbo for a c20 let
  47. Superchipped ECU
  48. Solid lifters XE
  49. seatbelt compression?
  50. digidash stops working when side/headlights switched on
  51. twin plate clutch to std Let flywheel how?
  52. Corsa 1.4
  53. c20let oil change
  54. uprated clutch c20let
  55. K&N Forced Air Induction Kit
  56. Which RWD gearboxes will mate with XE?
  57. worth removing the traction control body on c25xe
  58. R1 bike carbs on C20XE
  59. Will a cally exhaust fit a mk3 1.4 astra
  60. Are engine maps readable by different ECU's
  61. itting a X20XEV throttle body to a C20XE
  62. mk4 diesel wont start
  63. XE corsa wiring!!
  64. C25XE throttle body
  65. c20xe into vectra sri
  66. rear wheel drive XE
  67. dog gearbox help required
  68. Bleed Valve Where To Put?? C20 Let
  69. Where To Put Bleed Valve C20let???
  70. gearbox
  71. V6/turbo Brakes
  72. lotus calibra
  73. cutting out c20xe
  74. Car wont start now!
  75. ignition coil
  76. Corsa XE Wiring
  77. Fuel sender resistances
  78. Transfer box question .
  79. Quick reply needed if poss, feed and return into the fuel rail...
  80. vecrta 1.8 fault light, somethings hissing
  81. What quickshift for F20 in a Nova?
  82. Help needed - Engine light on, have ECU codes, what's the problem?
  83. NE engine with SEH ecu...will it pass an emissions test?
  84. Vmax Evo 235 software
  85. What colour plug plugs in to ICV on C20let
  86. back to front head on xe touring car?
  87. 2litre Ecotec rods and pistons..
  88. Amal Valve
  89. What are these chips all about? (ebay link)
  90. xe chatting clicking noise
  91. C20 LET engine looms
  92. Any info? 1.4 GSI Corsa
  93. C20XE: TB's and DTA - wont start
  94. 1.6 turbo
  95. Has my head gasket gone?
  96. Flush Fit Tyre Valves...opinion Please
  97. After how many miles should I change the cam belt in Astra Sport mk3?
  98. corsa 2.0 fuelling problem help please!
  99. 1.6 Corsa tuning
  100. 3.0 24v fuel pressure regulator?
  101. vx220 dials in xe nova??
  102. is this part the driveshaft oil seal?
  103. Amal valve connections .
  104. How to increase BHP on my corsa!???
  105. bottom end for a c20xe ?
  106. Astra GSi trip computer in a corsa LET? Help?
  107. corsa B C20 xe what drive shafts?
  108. What parts are better on a C20ne that on the X20Xev?
  109. Calibra Running Gear and Transmisson
  110. c20ne 296 degrees cam
  111. What turbo ?
  112. 15td isuzu using 1700td isuzu injectors
  113. Cavalier De-Cat pipe
  114. Cavalier De-Cat
  115. dropped my xe afm
  116. Urgent - Is My XE Timing Ok?
  117. Supercharge a 2.0 16v ecotec
  118. Thread size on GSi standard oil coolers.
  119. What are these LET plugs? (pics)
  120. Engine removal
  121. X14XE Immobilisers
  122. XE flywheel onto an Ecotec?
  123. Straight Cut Gears In F28
  124. vectra v6 injector removal
  125. c20let dump valve making engine run ruff
  126. Can You Swap Power To The Rear
  127. help me please
  128. Turboing a 2.0 16v ecotec
  129. Engine mods 2 a 1.2 corsa sxi
  130. Nova 20XE Gear Linkage
  131. corsa clocks change?
  132. torque for the let head
  133. magnaflow sports cat
  134. Cav/Cali turbo camber kit
  135. let-doing headgasket shud i use a z20let gasket?
  136. carbed up sri
  137. stuck on c20xe conversion on corsa B!!
  138. exhaust keeps splitting
  139. Phase 2 or Evo 4? and Std Piston Power question
  140. Nova GSi, fuel hose size - tank to pump ?
  141. i just bought another rover vitesse turbo
  142. CTS sensor
  143. engine conversion in a corsa gsi?? which engine
  144. Cav 1.8 8v Oil Pressure Light
  145. Fuel Computer Switch
  146. Best Proven Cams For XE?
  147. C20LET Thermostat
  148. oil top up light
  149. Wheres my fuel filter and how do i replace it?
  150. c25xe & x25xe same heads?
  151. turbocharging xe dizzy or dispac
  152. supercharging a let nova, can it be done
  153. Squeeky ***in clutch!!!
  154. Power cap
  155. Nova 1.2 Cold Starting Problems
  156. engine conversion
  157. driveshafts
  158. throttle position sensor? reading in ohms.
  159. Oil Cooler
  160. Flywheel question....
  161. Injection to carb
  162. Eibach Cav Turbo Springs, Which way up?
  163. Info on f28 transfer boxes
  164. Astra coupe exhaust system - help
  165. high consumption
  166. Nova exhaust onto corsa
  167. Cat Q...
  168. c20let cutting out
  169. few let conrod questions
  170. turbo pipes
  171. Stiff F28 Calibra turbo
  172. Vectra 2.5V6 Oil leak help please
  173. garret turbo t28???
  174. C20XE stats/info needed
  175. Nova/Corsa MOT cat question
  176. fitting cams worth it?
  177. C16SE compatible A/C compressor
  178. DP nitrous setups on valvers (pics please)
  179. Dump valve on MK4 Astra gsi turbo
  180. C20XE power to Fuel Pump
  181. Reconditioned turbo, what are my options?
  182. eds 3.5 upgrade
  183. where are these sensors on an xe?
  184. mk3 astra let driveshafts?
  185. 1.2 fuel pump relay in 2.0
  186. please help! fuel pump
  187. What engine code is my Zafira?
  188. What gearbox was fitted to 2001 corsa sxi 1.2? and how much to change one?
  189. Making a loom, what sensors?
  190. LET wiring!
  191. worth replacing the radiator? 1litre corsa
  192. Urgent Help Needed!! C20LET
  193. mk3 astra engine conversions
  194. asta gsi turbo mk4 problems
  195. 288mm/308mm Caliper Identification
  196. Mk3 Astra GSi C20LET Conversion + F28
  197. amal valve bypast
  198. engine control module
  199. c20xe problem
  200. doing my head in
  201. Engine managment light intermittently active Vauxhall Nova Gsi
  202. standard c20let hitting 16 psi
  203. Dump Valve
  204. v6 astra....what gearbox?
  205. 1.4 8v mpi thermostat
  206. Torque Settings for C20XE Headbolts?:
  207. what strut brace for xe nova?
  208. transfer box, worth????
  209. 20XE QED DTH Bodies.. Filter Question
  210. What Oil Pressure
  211. fuel consumption?
  212. Help would be SO appreciated....BIG misfire!
  213. astra mk3 misfire
  214. problems with my ecotec
  215. Alternator belt on 2.0XE
  216. Can the ECU on 2000 astra be remaped?
  217. fuel in water
  218. 16V Vectra Engine Problem
  219. what silicone hose kit makes up XE nova kit?
  220. driveshaft removal on f20
  221. Z20LET ARP head bolt kit (stud conv.) torque specs
  222. Help required regarding C20XE not starting...crate of beer for the winner!
  223. Quick cambelt cover question
  224. f20 box ?
  225. aftermarket throttle bodies engine manage
  226. 2.0 8v hHead Studs
  227. xe valve spring help
  228. cav turbo clocks in astra gsi
  229. Looking for a paddle clutch
  230. what Max Oil pressure should a LET/XE be?
  231. 1st post! weird engine sound!
  232. slight oil leak
  233. Cam belt change on a 2.2 Omega
  234. let into mk1 mr2
  235. Astra mk5 2.0 turbo (170) emission light
  236. 2.0 8 valve fuelling question
  237. intercooler
  238. anyone got a c20let corsa? need some help!
  239. Astra exhaust Q.
  240. 20XEJ DIS Conversion
  241. Fitted new head, engine won't start!
  242. What flywheel ???
  243. Mk 3 Astra GSi Engine Removal
  244. C14SE water pump change
  245. Bailey dump valve
  246. XE forged rods and ARP bolts possible bargain.
  247. Carb Problem????? please help!?
  248. XE aiflow meter
  249. c20xe problem
  250. turbo...
