- mk4 astra turbo thrust bearing fault
- Corsa Burning Oil!!!!!
- 1.2I Prob - Hall sensor maybe?
- Nova 16v drive shaft question
- Is Deepening The Valve Pockets Worth It?
- Manifold Problem
- MK4 Astra 2.0 DTI Pinking/knocking Fault
- Idle Control Valve Difference Between XE & LET?
- Cav GSI 4x4 w/o PS fluid Q (eBay link)
- xe conversion parts
- Corsa General trouble Running rough with induction kit????
- engine management light coming on
- sooty exhaust
- c16se lifters
- let ignition fault
- crankshaft pulley thread
- Adams Kkk16 Turbo!!
- LET wiring loom help
- Astra 1.7td Speedo gear on diff change???
- Testing coil
- Definitive answer on xe nova/corsa nose weight
- let fault codes
- Cavalier Turbo - big problem!
- Knocking coming from wheels - corsa xe
- Astra Mk4 Gsi (Z20let) fuel filter
- Which gearbox(/es) will fit my engine
- Vectra headgasket
- rev shift light fitting to xe
- oil temperature gauge for xe, sensor location?
- relocation of oil filter on XE
- which cams & exhaust bore with QED tb'd XE?
- calibra turbo oil light
- exhaust tailpiece
- ffs C16xe idle again
- f20 f28 lsd
- whats the ideal exhaust gas temp on an let
- ginding flywheel
- MK2 Champ let
- Hydraulic lifters
- EDS Chips
- Induction Kits
- Lexmaul Manifolds
- AUDI gearbox help
- oil pressure switch?
- Engine temp gauge not working!
- Crank pulley bolt.
- Bike carb anoraks required.....
- MFD not reading average speed/consumption etc
- ASTRA MK3 1.4i (93) Gearbox help ASAP PLEASE
- C14SE hesitation / Low power
- Calibra V6 Engine steady
- URGENT HELP - coil not sparking after valve replacement
- Jerks in 2nd gear
- what are wasted valve stems
- Diff ratio on Cav/Calibra turbo 4 x 4
- Courtnay Group N vs EDS
- exhaust manifold torque settings
- c20xe cams, can anyone recognise these numbers?
- Under driven bottom pulleys for 20XE's
- Just changed a leaky fuel feed pipe...
- nova gsi cam
- Corsa Diesel Conversion to Power Steering?
- isit safe to wirebrush the crankpulley and flywheel (rusty) or will I unbalance them?
- c20xe fse boost valve?
- cleaning a powder coated rocker
- bosch greens or delphi/racetronix injector for let
- Air temp sensor question
- Mk4 Astra-G Steering Wheel Loom
- what power output?? 2.0 mods?
- Mk 4 Astra Engine Conversion Q's
- Maintenance indicator on saxo
- anyone with regal uprated fuel pumps?
- Vectra, Missing, 2K+ when warm/hot
- C20LET wiring on a diesel.. plug aint their...
- Tuning 2.0 DTi engine
- Vauxhall corsa 1.4 merit hi torq 1996 - Knocking noise fron engine bay! loss of power
- Chipped engine running nitrous
- C20XE Fast Road Cams
- plz help astra coupe turbo engine management
- Hmmm query bout a kkk16 turbo i had purchased...
- bottom end is knocking on let
- c20xe bottom end
- what clutch for F20 LET NOVA?
- Astra GSi Mk3, Weight??
- X18XE Water pump Replacement
- Gearbox for Vectra B
- help! problems with my cavalier turbo 4x4
- FSE boost valve 2ltr ecotec
- LET questions... gudgeon pins, circlips etc...
- Carlton MV6 gearbox quick question
- 1.4 to 2.0 xe astra mk3 transplant help
- std fuel pressure on late 20xe dispak engine
- Battery and engine light came on
- C20let problem can anyone please help
- Corsa +2.0 turbo maybe
- missfire in the mornings c20xe help
- kent cam
- please help... xe nova strut brace
- Struggling to find Walbro 255 pump for Calibra?
- E16SE...cam with standard lifters??
- C16SE forged 81mm pot
- Interesting LET rebuild thread found with plenty pics...
- 3.5bar fpr mod???
- C20LET almost out of engine oil
- Engine Probs Still - Plz Help
- Engine Swap
- holy melted spark plug picture batman
- Fuel pump and relay 2.0 8v
- urgent f28 conversion help needed
- 1.6 8v into corsa?
- oil temp gauge
- C20LET Running really bad please help !!!!!!
- What gearbox is on the corsa gsi?
- cally Turbo steering problem
- ecotec or redtop?
- C18xe faults
- Mk4 astra 1.6 spi on lpg head skimming
- induction
- loom on earl and l8r c20let
- XE solid tappet conversion
- LET Actuator? Which one to buy?
- c20xe distributor
- Camshafts c20xe
- Whats this of a Z20LET
- Engine mount weight
- C20XE Astra GSI Wont Start! :(
- Engine Oil for Diesel Engine
- Corsa C20XE competition mounts
- Best place for injectors on the runners
- calibra c20xe ancillaries ok for a corsaB conv?
- C20XE high idle!
- f20 hydraulic clutch mod
- Switched +ve missing
- Adjustable Fuel Pressure Regulator for LET?
- NOS in an xe nova?
- vauxhall CTS
- How freely should a KKK16 turbo shaft spin?
- X16XE Tuning????
- Urgent help! veccy fuel filter
- What headgasket should I be using for correct CR?
- FAO Chip and any others with gen on fly,bolts and clutch.
- OT, golf mk3 self adjusting clutch cable!!
- 2.0cavvy gearbox, which is best?
- problems with my nova xe please help!
- LET into MK2 astra
- Nova engine bay strengthening - Should I?
- C20 LET
- exhaust query
- Corsa turbo Fuel pump
- Evo5 power switch
- Plugs for 2.1 16v throttle boddied c20xe
- 1.0 12v Idle problems
- Perfromance Modifications (Astra Coupe 1.8 16v)
- problem with gears
- Oil problem
- Best oil for 110k LET
- Can anyone help me do a cambelt change?
- camshaft sensor , plug wont fit
- What to do (with tuning XE)
- Battery Relocation Gen...
- F28 electronic drive into cable drive Astra
- £5 chips on net?
- valve guides c20let/c20xe
- Head gasket at 5000 miles (54 reg Meriva)
- corsa/nova engine mounts
- frontera v6 cambelt
- x16szr cam
- F28 onto 1.8???
- CTS - c14se - and a tube !
- max power on std. c20let pistons
- nova/c20xe inlet man for carbs?
- mounting oil cooler in xe nova???
- petrol consumption
- Performance center section exhaust with standard backbox. Are they compatible?
- 1.6 xe to turbo,,, whats needed?
- are x20xe,x20xev and x18xe rocker covers plastic or metal?
- anyone know about the 1.25 fiestas? small running problem
- Astra GSi 1992 manifold.
- Help with vectra LET
- help! how little to change for power increace?
- can i block my egr valve
- Headlight Wiring....
- inlet manifold trouble. lets crack this! pix included
- whiney Corsa GSI engine
- which 550cc injectors?
- General LET tuning advice needed (fuelling etc)
- Engine swap
- Camshaft sensor plug.
- Oil serging in nova help!!!
- Camshaft sensor
- chipped vs nitrous help?
- Alternater on xe
- causes of pinking on carbed XE
- tick over too high on let.anybody know??
- Smoking from manifold...
- corsa short shift gear linkage issues
- xe'd poor power for the mods
- CLet piston to bore clearance
- engine mount strengthening
- c20let splitting from box????
- Camshafts, C25XE
- F20 onto C18XE
- Fuel Pressure Regulator?
- ECU Coolant Temp Sensor on Astra 1.6
- astra dti tuning box super chip
- Degrees BTDC of missing tooth No1 on a Crank Sensor on a 2.0XE engine
- Headlights on when indicate/hazards
- Corsa Coilover Settings
- No engine light on dash
- C20LET with downpipe no exhaust
- 1.6 astra fault code
- oil light calibra
- 1.6 astra wont rev past 5k
- Dump valve help MK4 astra
- Aluminium con-rods.
- C20LET into Corsa 12v
- LET into corsa/tigra
- XE main bearing bolt torques
- Z20LET Turbo onto C20LET
- C20LET: 235 and 245 bhp chips?
- whats the best zorst c20let
- Timing belt interval - 1.7 TD Isuzu??
- torque figures of standard c20 let engines
- home acid dip or similar - any good products?
- increase power :)
- Z20LET cambelt change????
- vectra gsi gearbox
- 2.5 and 3.0 injectors
- MK3 Astra 1.6 spi problem
- Charging Problem on XE.
- Testing Idle control valve
- C20XE & Megasquirt
- oil cap off when running and lots of pressure blowing out?
- XE spigot bearing
- could this be a sign of turbo failure?
- I need a Cav Turbo asap
- Nova fuel gauge
- mk 3 astra 1.4 mpi or spi?
- At a complete loss
- MK2 Astra 1.4 Carb to C20XE Fuel Probs?
- help with boost valve
- C18xe and C20xe heads???
- Highflow waterpump
- Corsa 1.4 8v tuning options
- gearbox gen...?
- all those with r1 carbs...
- xe injectors
- quick cam timing question 1.8 ecotec
- sorry another exhaust question.
