- C20XE Tigra conversion guide...
- astra gsi turbo exhaust system(who is best to use for a custom build)
- B&S Chips/PowerMap Chips C20 LET
- 1994 omega 2.5td fuel filter
- C20LET --> Vectra
- Wheres the tach pin on a 1.0 12v corsa?
- Porous head fixed
- Turbo problems .
- Astra Z20 Let Turbo Help Oil Leak
- t40s on an xe?
- coil pack help
- help clutch peddle/spring on astra gsi
- how hard is it to change seals on c20let turbo? HELP
- Radiator fan not working Astra TD MK3
- whats this then ? induction type
- Oil Sprays. Drill Block Or Shell? Discuss Please
- Cheap eBay chips - not a repeat thread
- cant get rad fan to work on xe nova?
- Hydrolic (sp) clutch kit
- Max safe rpm on x14xe?
- High tune XE - 48mm or 45mm carbs?
- help c18xe wont start.
- Help! Problem with a Seat Leon 110BHP TD
- New Engine into a Corsa
- Transfer box running temperature
- c20let ecu wanted!!! (had to do it on here cause im new)
- transfer box bad problem
- got my clutch through - fitted it aswell.
- Help...F20 or F18 ???
- 256 duration cams on 2.0 Ecotec.
- X16XE problems.. help wanted!
- Blue XE Injectors
- Ecotec 2.0 cambelt diagram wanted please...
- Clutch Adjustment
- Nova Ecotec Transplant Problems
- Omega Won't start
- calibra turbo and intercooler
- Oil pressure sensor fitting
- xe into bmw e30 possible?
- vauxhall cavalier oil pump ...info needed
- c20let smoking from exhaust
- 16v digital dash connection to F28 gearbox
- c20let limp mode no eml?
- LET mk3 Astra Rad,Header & Fan
- 2 Litre ecotec problems.
- sooted up spark plugs
- what boost on standard ecu
- engine burning water,not plain to see why help needed
- Why did i bend a valve?
- major oil leak with coupe turbo HELP PLEASE
- Oil pressure relief valve in block...(vauxhall partsman needed)
- can i use the early c20xe head and cams on the later engine?
- XE Manifolds, Difference between models and price they go for?
- has my Kreg calibra redtop got the new or old cam cover?
- Got My Astra GSI Red Top Yesterday!!! + Question on High Lift Cams(Again)
- how to advertise that i want something ( wanted )
- corsa x14xe thermonstat
- speedometer on let conversion
- corsa conversion X16XEL
- vectra diesel spring help.....
- Part 1 of engine build - Block
- bike carbs fuel supply
- How can I get more bhp out of my Cav 1.7td?
- turning fuel pressure down?
- Astra MK3 GSI Gearbox Problem - Help Please!
- omega diesel auto gearbox seal.
- whats the test for valve stem oil seals?
- c20let ecu,turbo+manifold, wanted!!!
- Help please! any1 who knows about 1.6 16v ecos please read.
- head swap
- XE/LET Headstuds - which way up!? (pics)
- Let engine removal
- what is a transponder in a calibra turbo???
- OMEGA 2.5 V6 injectors
- Ideal Exhaust System Bore for Modded LET
- will a viper induction kit fit my car
- Quickshift XE
- TB'd C20XE Vs Z20LET comparison graph
- ford clutch rachet???
- 4 branch for a ecotec
- Shattered - My Engine Spun Bearings! HELP
- Urgent XE/LET question (cams and pulleys)
- Gearbox Question
- Part number for 8v cambelt needed
- f25 driveshafts on f28?
- Loom help
- bhp
- C20Xe Injectors
- Fooking Spark Plugs
- do these pictures of this piston look like Vauxhall C20LET ?
- Twin weber 45 DCOE carburetors
- Cat Bypass Pipe
- Fuel Pump Relay - Please look
- Tb's first time start up problem on xe
- F28 in to Corsa B Question!!!
- xe corsa conversion query - wiring
- Astra 1.6 16v - TURBO conversion!!!
- wot induction kit???
- C20NE Turbo,what camshaft?
- Astra 1.7 Td. Diesel Pump Pulley ??
- Come on then LET into a vectra!
- Where's my powerband gone?
- air filter for c20 let
- f28 making an awful noise
- reccomended air filter for xe nova
- Problem's with vectra let
- Driveshaft at an angle...
- Clutch or Gearbox fault?
- Camshaft sensor
- let v xe sensors whats compatable.
- how easy is it to fit a fuel pump to a corsa gsi
- Clutch release bearing needed for calibra 16v
- Wheres the ECU reader plug on a P Reg 1.2 Corsa
- 1.6xe or 1.6 ecotech!
- LET running rich?
- Some questions about pistons(for experts)
- Easiest way to remove corsa engine?
- faulty afm
- subaru intercooler on c20 let
- Seatbelts
- XE lambda sensor problem.
- Astra S? Turbo diesel model? Bumper fitment
- recommended exhaust system for QED TB'd XE?
- Engine managment light keeps coming on then the engine cuts out
- People using paddle clutches...
- ebay chips ??
- Sump gaskets 8 valve/16 valve
- Can i put vegetable oil in my cavalier td??
- Want to upgrade fog bulbs, and also headlight bulbs!?? What to go for??
- c20let amal valve vacuum hose
- flexible exhaust pipe
- sticky gearshift
- Clutch Kit on Ebay for LET, Any good?
- xe injection relay
- Modded Main and Big End Bearings for LET
- 1.8xe1
- corsa xe rev counter gone mad
- Engine Conversion
- exhaust rubber mounts
- XE/LET Block, Ecotec Head
- Astra G Fuel Filler Flap
- Calibra turbo 4x4 PAS problem
- Which oil in ZLET
- kent cams and vernier pulleys
- Sypmtoms of Faulty FSE valve??
- DSOP downpipe or Regal downpipe *c20let*
- induction piping
- Porous cylinder head mod
- need a bit of help with seh ecu loom please
- f 18 gearbox weak or not
- Manifold studs how to?
- Sump Plug Washers
- oil breather?
- frontera intercooler
- Coilovers???
- 1.4 8v to 1.8 16v
- weird EGR prob???
- that "problem" with my gearbox. guess what it was
- z18xe fuel system
- At a guess how long to refit a head back onto LET
- Need More Power? Engine Transplant?
- Looking for PhaseII soft/chip
- c20let fireing order
- What would u do if ur LET had bent valves..
- More LET rebuild questions... am I doing everything right?
- two simple questions for tps and abs
- c20 let engine number
- C20LET Help Needed!!
- let wont rev past 2k
- slipping clutch or dodgy boost?...
- wiring afr guage into let ?
- Calibra v6 low oil pressure
- x16xe tuning options.
- cav sri engine into nova
- C20XE fault code 13
- 2l 8v rebuild (pistons)
- nova turbo lower tie bars, pics
- 1.8D Escort Van poor starting
- I have searched honest! Head Rebuild
- Astra turbodiesels, Low/High pressure swap?
- Swapping 5th gear for high ratio
- Exhaust question. - well HELP!
- exhaust question (cat)
- 2 X C20 XE available, to whom it may concern
- c20let starting problems
- Porus head repair by-pass link
- Nova brake and fuel pipes??
- wiring an ammeter gauge?
- Which Timing Belt Kit??Plz help
- oil pressure switch on xe... where is it?
- Heavy Clutch Pedal
- Do you HAVE to have an oil cooler on a XE?
- the erratic idle story of the C20LET (HELPPPPP)
- please help me fix my petrol gage!!!!
- Where to get omega pistons???
- Are XE calipers side specific?
- LET big end change
- C20xe from a distributor to coil pack
- URGENT, looking for a inlet pipe after a throttle adaptor conversion
- Silicon Gaskets
- what would cause a hole in a let piston??
- VXR Turbo onto C20LET???
- Anyone know hw much bhp an Irmscher back box would add on?
- Mechanical/electrical Speedo on f28
- Clutch time is coming..
- XE head onto LET
- 1.4 SPI rattle then no compression.
- high lift cams
- let timing belt kit
- Nova Ecotec Transplant Started
- Exhaust fiited can anyone explain some things...
- Which Backbox??
- changing F20 oil seals
- hks turbo timer
- corsa 1.4 16v running hot
- would you say my afm is f***
- Astra GSI LET upgrade
- Smoking 20XE
- whisleing noise on my astra turbo z20let
- Astra Mk3 1.4 LS (HI-T)
- Sports Catalytic Converter for Corsa B 1.2 8v
- Bosch blue injectors
- Whats the torque on phase 3.5
- Nova LET Intercooler, Choices???
- Which Garrett Turbo for a c20let ?
- Can an F20 gearbox fit VW Golf Driver 1.6 H-reg?
- Replacing Starter Wiring Connection Screw
- Engine Under tray
- 20XE into a corsa C
- 16v engine in 1995 Corsa SRI does it exsist?????
- which backbox?
- LET & Induction kit ?
- C20LET overfueling, why????
- Just replacing clutch disc
- Exhaust Choice
- x16xel vacuum hose diagram
- v6 conversion, no fuel :(
- c20let mark3 astra
- 16v head on 8v block...
- Clutch cover plate alignment query (fitted)
- v6 manifold q's
- vectra stainless cat convertor??
- Astra mk4 turbodiesel van - turbo knackered ?
- unichip question
- Red Top 2Ltr 16v wont start when hot
- LET Cam belt - Early or Late?
- Calling All Mk3 Astra Gsi Turbo Owners!!! FMIC Advise
- Motronic M2.8 pin-outs, wiring
