- EDS phase 2
- Nova & LET, quick Q on tank vent valve / carbon canister connections
- irmscher manifolds??
- 306DTurbo problem... Tathan done a bad thing...
- nova xe hosing with no heater matrix, how?
- C20XE Major Lack Of Power
- Calibra Turbo Suspension Help
- c20let dizzy cap and rotor arm quickie
- Anyone identify this plug ? LET wiring loom
- what gearbox is in a cav sri 8v 'L' reg
- Ecotec Oil Consumption
- clutch probem, or just my stupidity!
- corsa xe driveshafts?
- Garett -31 actuators
- How much timing SHOULD i be able to give my XE?
- starter motor problems. c20xe
- C20Xe Service
- Astra G - Install resistor - Gain XXhp - Ebay scam
- Calibra turbo CDTI conversion cost?
- Calibra frount drive shafts?
- fuel filter question???
- need an idea for an engine conversion
- What Car Is This Rubber Engine Mount Off?
- Sportex Exhausts?
- what flywheel to fit a f13 to a c20ne?
- Conversion advice needed!
- f20 gear box --- have i broken it?
- what astras will a ecotec/F18 drop straight into?
- What Hapens When Ignition Is Retarded On An Let
- Info needed on Schrick cams
- EGR Blanking (VX PAUL inlet)
- LET not sparking!
- LET wire colours!
- X14xe intake replacement, tech question
- ECU remap chips on eBay? Has anyone here used these? NOT the crap 'resistor' type!
- F20 Gearbox into a 2.5 V6 Calibra
- f28 into nova - whats the thread to drill n tap into box for rear mount?
- skidding, then engine cuts out
- manta gearbox
- bosch fuel pumps
- Vectra Gsi: Grade of oil??
- Need my XE ported and polished.
- 98 1.4 Corsa Mods
- F20 gearbox help
- C20let Spluttering and Cutting Out.
- Block Differences
- Exhaust
- C20 LET Valve lifters checking
- Electrics light coming on
- increasing fuel pressure gte 16valve
- v-max evo2 chips
- Just Bought a C20LET.. A few troubles
- is the z20let basically an Xe block with an ecotec head and a turbo bolted on?
- 1.3 nova 32/34 dmtl -best jets and hose locations
- corsa c20xe cv joints
- 2 only JE pistons where from ?
- quick question re fitting cold cathodes
- F25 gearbox advice needed asap
- Question about LET downpipe/exhaust elbow
- How does the clutch cable connect to pedal?
- Help Starter Motor? asap
- X20XEV Pinking/ Running Lean
- £100 of fuel and only 520miles...
- Corsa Engine Probs
- Engine cuts out / poss ignition? Confused my mechanic :)
- c20let oil in boost pipes
- camshaft locking tool???
- my turbos broken down.....
- LET fuel pump hose size issue.
- Mk1 Cavalier C20XE
- Anyone got, LET coolant pipe diagram ?
- c20xe starter motor and corsa cvs
- how to isolate HSV (Hot Start Valve)
- Z20LET Fuel Preasure Regulator?
- F20 driveshaft seals
- XE with F28.... flat or pot flywheel ?
- Nova 16v driveshafts
- corsa XE gear linkage
- Help c02let boost ?????????
- Stripped 20SE Engine parts
- F28 getrag vs F28 GM
- Automatic corsa XE conversion..
- Nova Fuel Pump
- CORSA C Exhaust advice please.
- C20 Let Ecu
- calibra oil pressure switch fault
- URGENT- Redtop emissions
- fuel pump relay
- Flow rate for yellow LET injectors?
- Wrong oil???
- Carlton 3.0 Throttlebody on an 8v ?
- 3 quick questions corsa c20xe
- no spark :(
- Oil Leak On 20xe???
- Using Mk3 Manual fuel pump on Mk4 Astra Diesel
- Cavalier turbo
- ecotech cutting out
- cutting out c20xe
- nova head
- Stuttering red top
- Corsa LET inlet pipe Turbo-afm
- corsa b c20 xe conversion help fuel pump question
- ECOTEK Valve
- crankshaft sensor
- any quick ways of puttin a perfromance cam kit on?
- 2 litre equal length driveshafts on corsa
- Have a clook at this C20LET running Escort cossie turbo
- Won't go in gear.... Clutch or box?
- corsa gsi inlet
- Z20LET O/E Dump Valve?
- C20LET & C20XE dizzys same?
- LET Rebuild..
- c20xe into rwd sierra??
- Actuator for EDS phase 2
- Corsa B F28 gearbox mount
- Changing the turbo on a zlet
- performance cams
- Engine Swap,pig Of A Job
- alloy rad? (nova let)
- 1.7 td head gasket change. difficult?
- corsa b c20xe conversion driveshaft advice needed
- Zaust help C20XE
- ECOTEC juddering
- xe tensioners q's
- Blimey, duno where to start. Smoking Z20LET
- Nova XE Wiring Quick question
- How many lambda sensors on 20NE (bosch motronic 1.5)
- crankshaft/oil pump seal - how to remove with the oil pump on the engine - any tips??
- how many cav auto boxes are there ??
- corsa sport 1.4 16v susp probs
- Astra Gsi Radiator Fan not working
- multi-throttle vs tapered
- F28 Input shaft question..... help asap!
- Corsa performance exhaust manifold advice needed!!!!!
- head gasket
- High oil consumption
- Timing on 1.6 Cav
- Clutch release bearing? (Non-vaux)
- let conversion q's
- f20 transfer box
- differnt gearboxes on c20xe for acceleration?
- DV problems
- GEARBOX choices,choices
- replacing rocker cover gasket on 1.6 16v ecotec
- Power stearing
- X10XE high idle please help
- Which Is Easier?
- Quick corsa b xe exhaust/cat question
- manifold gasket power loss??
- corsa gsi engine problem
- 2.0 8 valve exhaust query.
- pls help! quick egr info needed
- engine stand help
- big block black plastic water pipe??
- Custom manifold
- Help needed x14xe ecotec head
- Where's the ecu on an astra mk4 1.6?
- Question about turreted Nova & coilovers
- Who was it looking for a Garrett T3 Before The Mig Thread Melt Down??
- Wiring the Oil pressure gauge on a V6 Calibra
- TDC Z16XE
- Fan override thread, does it apply to cav turbos too?
- anyone know were i can get throttle bodies from?
- what mods should i get?
- Water leak mystery on C20LET - inlet manifold?
- Electric Windows but no loom! :(
- 1995 N reg Astra 1.6 16v GLS cambelt gone?
- Help needed! 4x4 Brake Bleeding
- From 'V' to multi 'V' high AMP alternator fitting
- Changing injectors
- let kevlar or steel headgasket
- corsa c20xe wiring
- remapping?
- clutch peddle spring on mk3 astra help
- overfueling astra. what could it be?
- Diffrences in the 1.6 16v engines
- HELP! snapped avo coilover spring
- dta / qed experts
- fueling on my gsi
- Nova - DIY short shift gear linkage
- Help me identifying a Lexmaul manifold 1.8 same as 2.0?
- Backbox
- equal length shafts onto let corsa
- Intercooler size for a Evo... one?
- X20XEV immobiliser...
- where is the fuel filter located
- let turbo charger
- noise at 3.5k revs in all gears
- high performance cambelts
- what do i need.......bike carbs/throttle bodies
- sudden loss of power
- samco help
- Injectors for +220bhp XE
- oil pressure reading c20 let
- 1.416v 1.616v rods
- Let Engine Management Light But No Code
- where to go to get exhaust system built ?
- crunchy gears
- How much torque can a straight cut F20 take?
- 2.0 16v feels underpowered
- Clean spots on let pistons
- Need help finding a DSOP...
- F16 or F20?
- Weight & dimentions of a red top?!!!!
- What type of ignition has a 20seh and c20ne got
- head gasket or fan ?
- XE Manifold Variations
- Migweb JE pistons question
- Phase 2 + Apexi avc-r + 22psi ?!?!
- 2.0 XE lamba HElp neede asap
- 1.4 engine with 1.6 gearbox?!
- Xe/let Bottom Pulley On A Nova
- Wire colours +/- on fuel pump.
- Gear Box advice
- Any SU carb experts?
- Corsa 2ltr 8v gearchange problem.
- carbs onto xe
- quick fuel pump question
- astra gsi 1.8 16v - 2.0 16v, is the set up the same
- Funny Fuel Guage
- corsa 1.4 8v
- Corsa help needed on fuel injection?????
- what carbs or TB's for V6 ?
- head gasket
- 82 degrees thermostat
- redtop/eco enginemounts (mounting point on block) - car specific - dif on vec/astra?
- Corsa C20LET-XE owners?
- new to red top novas
- Jammed cally sun roof
- Pic of inlet manifold pipework / vac hoses - can you help?
- will a old cav gsi ecu work on the newer DIS engine?
- F13 gearbox used in the USA?
- URGENT: Valve diameters
- Clutch change / fly wheels replacment...
- 2.6 V6 Vectra AFM compatabilty question
- Mk4 Astra - X16XE to C20XE
- 1.7 TD (Isuzu) fuel problems?
- LET Nova
- Turbo Recon
- X14xe dual tract intake manifold question
- RE: 2.0 8v corsa driveshafts
- C20XE Air Flow Meter
- Vectra DTi turbo
- Pressure testing a porous head.....
- bike throttle bodies
- GM part numbers required please for any with EPC installed
- Vectra DTi Turbo lag
- Finally getting engine sorted..............
- Amalvalve pipe
- custom-made exhaust for c20let
