- Blocking the hole for the secondary Air Injection
- corsa indicators dont work???
- C20LET rebuild questions..
- 1.4i 8v tuning
- ECU 0202 misfire problem
- redtop cams what are they?
- V-Max Evo 2 chip..
- Huge BHP sideshafts for a let.
- Oil and/or oil filter change
- lambda compatability
- crankshaft pulley splined bolts...
- fk coilovers
- Astra 1.6 spi .
- xe red top engine age ?????????
- Glo plug change,but engine hot!!
- where can i get C20LET parts
- C20XE Crankshaft sprocket.....reverse thread ? :S
- Annoying LET boost problem...
- Fitting Bailey Dumpvalve on Z20LET
- 20xe nova, lots of smoke after hard corners
- Removing EGR improves performance?
- Pics of my pistons and crank...
- c20let wtf runnig problems
- cavalier exhaust
- Contol Indicator Light
- astra gsi c20xe over heating problems
- XE instead of XEV?
- cavy shifter in nova - it feels worse than the standard linkage. why??
- rebuilding a 16xe price of parts and info on running on carbs...
- x20xev-z20let
- XE ectotec adaptor??
- auto on / off of headlights??
- red top cutting out
- what gearboxes fit what vectra???
- Charge Air Cooler covered in oil?? Help
- Feckin' engine! (fuelling prob on LET)
- corsa c20 xe conversion, help with engine mounts
- re-built engine,, how many k miles to run in???
- anyone used yamaha R1 carbs on their 2.0
- Fault code EGR valve
- mk2 gte 1800 8v wiring to a 20 xe?????
- m vaux turbo problems
- cat box okay?
- Changing sump gasket C20NE
- 1.2 16v sxi corsa
- Engine number
- ecu chips how to check/dismantle???
- Oil temperature sensore in X16XE
- corsa gsi bhp?????
- Advice required on T3 Turbo please
- Turbo problem backing off in 6th...
- can oil pressure be accurately measured from a gallery in the head?
- XE in to GTE 8v
- V6 engine photo/similar needed
- LET/XE dizzy: how do I get rotor arm off?
- turbo rear hub removal, help please
- x1.4xe running poor help!
- dangers of running nitrous
- Standard C20LET Rebuild Parts
- wot oils best ???
- miltec exhaust
- Fuel pump not working!!!! (Help)
- C20XE What size/type of bolts to plug up oil cooler pipes?
- blocking EGR valve on Z20LET
- Cav Turbo & gsi tranfer boxes same??
- high temp resin/putty i can block a hole with?
- 4x4 problem!!!
- X16XE ECU In A Nova
- 1.0 corsa back box how much? easy to fit?
- cav egr bodge needed! also mot queery
- nova 1.4 sr parts list
- when using carbs...
- Nova + XE + Fuelling = HELP!!!!
- water leaking from near bulkhead
- C20LET carbon canister... info needed
- Corsa B C20let Engine Codes
- Had the head off now theres a light on?
- XE rev limiter question
- Headlights, dip/dim relay etc
- fault code help c20let
- 8V Sump to 16V block
- LET: Oil pressure releif valve part number?
- X25XE engine loom onto a C25XE engine?
- Cav T down on power ?
- corsa 1.2 16v running like ****
- V6 question here, pistons?
- Phase chips and acturators
- Let engine numbers
- 1.4sri stuttering
- 1.4sri stuttering
- another quickie
- water in oil... 20XE
- salad cream in crank case breather
- LET missfire on idle
- Need to replace standard LET pistons any suggestions?
- c20let steel h gasket
- Exhaust
- amal valve
- Decent LET pics
- engine management light cums on when using a different ecu! why?
- Diesel engines for astra Mk4 help!
- will the engine be stright swap??
- help im pised off with my turbo
- oil cooler c20xe
- Nova gear box issue help please
- HELP - dump valve postioning
- carb xe fuel pump wiring
- astra van c20let anyone done this b4
- Small block to F20 g/box
- fuel pump relay
- Turbo spin up / boost on standstill
- Cav GSI non-starter
- kkk turbo not boostin over 11 psi--fooked wastegate?--
- Astra 1.6i 16v SXi Misfiring Problem
- cylinder balance test on car with box-type coil?
- 1.4 Astra airbox into a 2.0 MKIII GSI?
- mk3 astra fuel pump
- X16Xe, oil pressure and electrical
- GTE 16V loom into a Corsa
- xe fuel pump wires
- Classic: F28 into a corsa c20let dummies guide?
- z20 let engine mount
- help with a diesel
- C20LET ignition problem on 2-3 cylinder
- oil lights wount go out on my corsa b!
- varley red top batteries
- ngk spark plugs
- XE fuel rail fuel direction!!!
- Blitz chips for C20LET? *problem*
- fuel wont pass the FSE
- Oil pressure warning light on throttle bodied 2.0 XE
- Cav v6 (Transponder ECU or NOT)
- Most Powerful Z20LET?
- Astra SRi.... Which Gearbox?
- C25XE second water pump/belt question
- HELP!!! Vauxhall Corsa 1.2 Semi-Automatic
- Engine swop - ecotec to redtop
- Dropped 5th gear on a F20
- astra boosting problem...please help..
- Kent 1601 profile cams
- calibra turbo problem at 4500-5000rpm
- Vaccum leak at throttle body
- boost problems
- Astra Turbo Z20LET Oil Pressure Switch
- superchip
- Are there certain cat convertors to suit certain engines?
- fuel pump/ immobiliser
- c20xe
- F28 2-wheel drive conversion kit
- F28 Electric speedo-mechanical speedo?
- f28 2wd conversion - how important is the small bush?
- HELP! - Waterpump on a Senator
- XE breather mod help
- what are the benefits of a 3" exhaust system on a c20let?
- Dip stick on an XE !!?? (oh and a sunroof prob)
- anyone know the name of this driveshaft related part:
- LET Running problems
- Question for time-served LET owners/repairers
- 285deg cam on a 12nz(1.2i,lol)
- c16se turbo head gasket ? where
- fitting a set of lifters.how hard?
- 16v Injectors on 8v what eles can be changed!?
- Sensor located on front of sump (C20XE)
- Vectra V6 fuel pressure regulator
- c20xe high reving
- Online Clutch Quote
- Engine conversion on a nova
- Calibra Turbo Springs Fit A Calibra Red Top???
- Fitting New Cambelt (C20LET)
- astra turbo conversion ??????
- splicing ecotec and redtop exhaust manifolds - where has that thread gone?
- How are ecu's programed in turbo cars?
- Zorst Manifolds (turbo)
- e16se turbo
- corsa b c25xe conversion
- KKK Recon - Price
- Let Alt belt on a nova
- Where is fuel pump relay??
- Which cat convertor for c20xe corsa?
- Amal valve.....
- exhaust manifold gasket replacement.......HELP
- fuel pump not working!!!
- x16xe turbo cost !
- Which Clutch?
- Manta XE engine mounts
- zlet dump valve position?
- fault code 55 motronic 2.5
- Astra 1.4 spi backfire through throttle body
- What FPR??
- X10XE air leak question
- Possible XE/LET lifter/cam problem... pic!
- Cigarette lighter
- F13 selector turret on F16 - Possible?
- Corsa XE perm live??
- oil leak on oil pressure senors
- engine ticking ?
- Headbolt Question
- V6 308mm brakes on Calibra Turbo
- c20 XE astra conversion
- darn slow cranking
- xe distributor
- My Z20 LET has started randomly cutting out
- xe engine loom
- is the z20let turbo manifold stud pattern same as x20xev?
- How do I connect tachometer in XE Corsa?
- astra mk4 exhaust to mk3?
- Can someone post pictures of the X16XE engine?
- Spark Plug for Corsa 1.4 Twinport
- What To Do Before Fitting C20LET
- 20xe dizzy/coil wireing urgent please help!!!
- LET fuel pressure?
- cant swap red top 4 ecotech
- Corsa XE Lives??
- EDS Phase 2 Installation HELP
- Wot Adjustable Fuel Pressure Reg??
- inlet manifold for 20SEH single weber carb?
- Pilburg Valve
- XE inlet manifolds, all the same?
- Converting F28 from Electrical to Mechanical
- Head Gasket second failure advice please
- Which engine to install in my MK3 cavalier
- 1.0L corsa help
- wot is the best engine to put in my gte and wot is involved and needed to fit?
- which clutch?
- Astra Mk3 1.8 Sport to XE
- X20XER question
- dbilas intake 20XE
- changed 1.2 corsas head gasket and then....
- vectra V6 2.5, s-reg. Timing belt job anyone?
- My Nova GSI's loosing oil pressure & my oil lights on, anyone got any clues??
- what Gearbox does a M reg 1.4 Tigra have ?
- changing gearbox f28 help me please :(
- X20XEV block and oil spray piston cooling
- deblias inlet manifol.
- "Play" in Turbo Shaft
- Fitting a X16XE exhaust cam on X14XE
- Re-using ZLET head gasket (not been started yet)
- Opinion wanted on cambelt change
- X16XE slow when heated up
- Lowering 5th gear ratio on 2000 astra
- EDS phase 2
- Nova & LET, quick Q on tank vent valve / carbon canister connections
- irmscher manifolds??
- 306DTurbo problem... Tathan done a bad thing...
- nova xe hosing with no heater matrix, how?
- C20XE Major Lack Of Power
- Calibra Turbo Suspension Help
- c20let dizzy cap and rotor arm quickie
- Anyone identify this plug ? LET wiring loom
- what gearbox is in a cav sri 8v 'L' reg
