- can a laser jammer operate an electric garage door
- Air Fuel ratio
- How do i plumb in an oil cooler?
- help !let poor turbo power?
- The Best Grade & Make Of Oil For C20XE?
- Noisy C18XE
- 1.4 16v into a Nova Sr??
- People who are running an F28 in a nova or have done
- About to buy a recon gearbox, what do you think
- Any1 got a template to make a blanking plate 4 the EGR valve???
- valve stem oil seals
- I need a adjustable FPR...this any good?
- XE block
- astra mk3 exhaust question
- c20let wiring hellllllp
- 3.0 Inlets?
- Engine Light of DOOOOOOOM!
- Whats Missing
- 1.5 thou - is this too much for a Z'let gasket ???
- z20 let troubles
- What oil for my XE??
- XE and NOS
- f18 cluster into f20
- stage 3 hybrid
- C20LET error code 94
- car starving of fuel
- xe/let fpr mod
- Specs for a low 13 second XE.
- f28 box in nova
- help with nitrous oxide in my 2.0 8 valve corsa
- c20xe prob...
- XE/LET crank end oil seal...?
- c20xe redtop workshop manual
- longlife exhaust
- has my clutch gone???
- f28 mod to 2wd how?
- SR20DET Piston for C20LET!?
- f28 noise when engine is running ????
- C20XE Pipe Question
- exhaust hanger problems
- vauxhall astra 1.6 16v gearbox??
- Engine rebuild prices!! Another one!!
- boost without control valve on c20let
- f20 / f18 onto c25xe question
- T.P.S part number for LET
- what car/s does the f20 gearbox come from?
- LET downpipe flange for custom ex elbow
- cam kit
- reasons for pinking.
- uprated fuel pump
- Transfer box testing off the car.
- black plastic moulded pipe rear of block
- 4 Questions about Caudalimeter's & Fuel
- Saber Dump Valve 2nd edition
- BOOOOOOOOST VALVE 1.2i nova
- c20xe into astra 3 1.4 LS info needed
- Rebuilt xe, 2nd problem.
- xe conversion in a corsa
- Vauxhall tigra EMU light came on and engine ticks over lumpy - any ideas?
- cam changing vectra v6
- Vacum in petrol Tank
- changing maps mbe967 + easimap
- c20xe into astra 1.4 LS info needed please
- SBD Tb Question....Water temp sensor V Air temp sensor
- Courier for engine?????
- Running lean C20LET any ideas
- Omega V6 Auto Gearbox ECU
- broken engine bracket
- Non vaux, 1.6Pinto/1.6 Crossflow
- C20XE exhaust header dimensions
- Let Nova F20 G'box/linkage
- Manifold help
- mk3 astra 1.4mpi no gears
- twin 40 carbs flat spot
- corsa B, gear linkage problem with F28 box.
- F25 Gearbox Change...
- Vauxhall corsa 1.4 merit hi torq 1996 - Knocking noise fron engine
- No Water, White smoke, jerky start up - Head fooked??
- Detonation,(Ithink), on new built XE
- c20xe thermostat
- What temperature should oil normally be at when fully run up?
- calibra turbo down compression!! help
- vectra V6 boiling over when hot.....goes very hot!
- what engine codes are the small block 1.8s? z18xe, ...... (fill the blanks)
- engine electronic light
- fuel swirlpot system
- F28 4x4 LSD fitting?
- Running 2x fuel pumps
- Gearbox gone?
- jamie F when can you do my oil sprays?
- part number for xe/let block oil restrictor/non return valve
- astra mk4 turbo upgrade software - HELP
- Calibra turbo running problems
- Cheap ECU chips off ebay, do they actually work??
- LET/XE Removing pistons from bottom?
- C20XE Manifold this standard or not??
- rebuilding the head - tips
- How many different types of frontera intercooler are there?
- Petrol / Diesel Turbochargers
- c16xe crank trigger
- Fast road cam?
- twin 40 on 1400 8v corsa
- can you turbo/supercharge a.....
- How much difference is there between X25 and C25 V6's
- 1.8 Cavvy
- Vauxhall turbos with screamer pipes...
- new life for my retired block
- Cheapests Actuator...
- Vectra 2.5 V6 What Exhaust?
- pro's & con's of going 87mm pistons LET ?
- injectors
- Symptons of FPR failure ? ?
- anyone got any pics of a C20XE inlet manifold off a car,PLEASE HELP
- code 42 on let
- Noble Remaps on Z20LET???
- crank problems,very urgent please help,c20let
- help loseing oil from my z let
- F28 / oil...
- oil sprays . do it in ya garage with a drill ?
- Baffling a sump
- Best plugs for let .
- Dry sump on Nova GSI Engine in a Corsa
- Throttle body???
- astra 1.8 16v 02 plate,
- Astra clutch question
- DTA tuning dials for use doing a live map?
- F28 Speed Vs rpm
- Exhaust gas Temp probe
- V6 supercharging
- How hard is it to change a camshaft?
- Quick q on non adj strut braces
- cosworth inlet manifold on c20let?
- More XE Bottom Pulley Fun !!
- xe leads
- ECU identification
- Do i need a full set of tyres on a 4x4?
- black pipe on lower bulkhead
- Turbo electric clocks help!
- clutch cable
- C20 LET troubles...
- 2.0 8V Go into 1.2 without changein anything???
- c20xe water boiling
- 2.016v ecotec I.V.C.
- Auto gearbox for my astravan mk2 HELP plz
- corsa b c20xe nos
- 2.5" Exhaust connection plates
- let/xe engine removal with gearbox left in car
- corsa b under fueling
- Tapping noise after oil change
- Brake upgrade options, Calibra Turbo
- Astra Mk4 C20let
- possible head gasket problem on C20XE
- fuel pump relay location
- Where can I get some M6x20 bolts from?
- just had the head tested (valve leakage)
- does the let go in from above with head on ?
- corsa gsi...missing/eng light on
- Best Induction Kit Manufacturer?
- head gasket question
- misfire 20xe
- What size clutch does a Tigra/Corsa 1.4 16v have?
- Removing LET sump!??
- XE & LET coils the same ?
- Let Loom - Wtf!!!
- Corsa XE conversions
- Turbo Oil Return
- xe smoking
- xe problems...again!
- XE throttle body
- Quick question about fuel pressure and XE's
- coscast head question
- Water system C20XE?
- oil spray's a must ?
- Ultrasonic cleaning of injectors
- XE V's LET PAS Tank Size?
- XE flywheel on XEV engine?
- are ngk lamba sensor good as bosch for an let
- C20LET Actuator Options
- Accessory belt change question
- BCP7EVX NGK Platinums gap on C20LET Phase 2
- are ecu's different on dizzy/dizzyless c20xe's?
- 1.7 diesel gearbox and clutch fitment advice
- Fixing an F28 gearbox
- location of knock sensor?
- much oil does the f28 take?
- C20XE corsa gsi wiring
- TXB - What oil and level check ??
- 1.4 8v tuning
- Corsa 1.4 8v 1996
- 1.6spi fuel pump enough for a 2.0 seh ?
- Best Plugs for LET ?
- Transmission fluid - F20
- redtop conversion
- C20LET Ecu Question
- Possible exhaust blow problem
- grinding from sump
- ecotec codes will not flash
- fuel pressure regulator blanking plate
- Fitting a 2e3 carb for a 1.8 on a 1.6 cav.. Any probs?
- how to modify the throttle body - X16XE
- Xe to Let Conversion Questions
- Diesel head gasket, or more serious?
- Which Graphite Grease do SBD use ?
- C20LET : Ring groove depth ?
- Under the Rods.
- smoking let
- crap fuel economy
- C20xe Engine Number Location? Do V6 Brakes Fit Easily Onto A Corsa?
- where to get a 3.5 fuel pressure regulator?
- where to get thick gaskets for the x16xe/c16xe???
- Gasket sealant or not?
- Breather drilling or this lark?
- C20XE starting problems!
- Positive Camber
- c20xe runnin on 3
- xe boiling over whats wrong
- Engine conversion - speedo miles out
- Kkk26 Info Needed
- fuel connections c20xe
- converting C20XE lump to turbo
- Polishing inlet manifold
- Cleaning LET AMM
- quick oil question
- 8v Big block Clutch Options
- C20let Injectors ????????
- camber on a cally t
- Changing the waterpump on XE corsa
- 20XE No oil pressure
- 150hp 1.6 16v - what spec
- Flat top pistons from QED
- symptoms of leaking gasket from turbo to head
- Just started corsa xe, few probs
- Cally Turbo exhaust popping
- Superchip installation - pics inside
- xe inlet cam in let with garrett turbo
- nova gsi engine
- Does a dump valve have to be fitted close the throttle body ?
- AFM pinout
- jumping out of gear
- Xe corsa wiring problem
- What throttle cable on corsa XE?
- 20seh ecu em light idle valve?????????
- Nova GTE Engine Managment Problems
- Engine flush made my car cut out, any1 know why??
- Help Please!!!! Gear box Change!
- do i have to swap the injectors over?
- Redex intensive fuel treatment, is it safe to use?
- Oil temperature sender
- astra mk4 1.8 ecotec cooling saga
- C20let blowing oil out.
