- c20xe problems
- c20xe
- problem with vectra diesel help needed
- Let one way valve between rocker cover and throttle body
- 1.4 8v/ 1.4 16 v question
- X20xev Help !!!!!!
- LET - Nova wiring, little bit of help needed !
- c20let-z20let bottom end?
- corsa 1.4 8v oil pump??????
- GOLF VR6 AMM onto C20LET !
- 1.0 12v Corsa ECU light; Airflow metre fault?
- 1.6 200hp turbocharged - please spec me
- Couple of quick easy LET questions!
- X20XEV fluctuating revs
- aquamist 1s system fitting?
- f20 box in a corsa
- EDS motorsport Germany
- XE on 45s HELP NEEDED!!!
- Regal Enlarged LET Tophat
- Nova fuel lines question for 2.0 16v conversion
- What oil for F28 ?
- De-seaming con rods?
- 1.8 Astra H Sri( sports hatch) help needed
- who makes custom turbo manifolds? contact details please.
- electrical clocks with c20xe corsa B
- Where is the 4x4 ecu located on a cav turbo?
- gearbox numbers????
- full cylinder head service (flowerd ports, valves, seats, new guides) in w.midlands??
- x20xev & z20let head: any differences?
- overheating why?
- gearing trouble
- does a turbo pump fit in a corsa tank
- Corsa C20xe conversion
- FMIC for Cav Turbo
- C20XE Coil / Ignition Problem (Corsa Conversion)
- K16 Hybrids...
- Corsa C20LET overheating
- c20xe redtop not running right?
- Info Needed!!! F16CR Boxes
- Exhaust manafold cover broken (pics included)
- help regarding piston rings c20let 86mm
- turbo mods for a astra 2.0 dti actuator
- engine nutters plz view this!
- Is this right? Thermostat test pics....
- what block for turbo?
- Urgent Help Starter Motor
- dull question...manifold related
- fitting a f13 on a c20xe
- Electrical problem with the lights / headlight switch?
- corsa 1.4 engine
- "coolant level" and "oil lack"
- Power Loss
- anyone going high power from a super charger
- X20XEV verniers
- C20LET piston to bore clearence
- 2 types of Courtenay cams for C20LET...
- Nova/Corsa gearbox mount question...
- Injector sizing, flow and mapping
- Fuel Pump Power Problem
- Engine ID and adding electrical goodies
- v6 crank
- stage A blydenstein head
- F23 or F25 internals into F20
- C20LET rebuild Q's...
- Astra G,1.7DTI isuzu,Fault P1125,Turbo wastegate
- XE Fuel Starvation at High Revs?
- eds 8.1 intercooler fitting on cav turbo!
- help with sensors and to tell what engine it is please
- For All u Turbo Nuts
- Which vauxhall has the biggest oil cooler ???
- LET throttle butterfly valve how big ?
- which cars will a red top engine and f20 box fit straight into?
- xe fuel pressure regulator on let
- c20ne 296 degrees cam idle rpm problem
- breather pipe on rocker box cover
- Oil pump problem c20xe
- A very real reminder of Vx's crappy 4x4...
- no oil pressure-----HELP
- Engine not quite right, Ineed some advice.
- Gte 2.0 8v - No POWER???
- Bike Carbs/TB's
- Mk 4 Engine mounts for C20XE
- Let cambelt trouble
- What clutch for f28-let Suggestion's
- LET Front pipe ?
- Oil on outside of I/C
- my new block is now bored :-)
- Carlton Boxes and XEs
- URGENT!!! HELP!!! where does the C20XE cam sensor get its reading URGENT! HELP!!!!!!
- 2.0 XE hessitation
- Ecotek camshaft sensor retaining screw
- where can i find information on engine and gearbox weights
- Main and big end bearings
- troubles with coolant pressure!
- Fuel pump bracket rubbers?
- Nova GSi engine E16SE - HELP!
- fuel pump to run R1 carbs?
- Crank Seal Gone
- Engine Conversion
- Can I use c20let injectors on a c20xe?
- Engine oil - difference between Diesel and Petrol?
- Gen Questions Re: Rebuilding engine
- How to check fuel pressure on std XE
- What gearbox? (R reg Tigra 1.4 16v)
- C20 LET head or valve problems
- LET Head fitting advice
- c20let ecu fault code 117 (wastegate voltage low) what does that mean???
- Oil in Water 1.7 Diesel
- Turbo hose problems!
- blank x14xe ecu where from?
- if my amal valve has gone,what will happen?
- X18XE1 Swap
- f28/f20 gearlinkage questions
- water manifold ????
- Mission Impossible????? Supercharging C16XE
- Ecotec manifold bolt torque settings.
- How is the ecu mapped after a turbo kit is installed?
- LET Actuator - which way to wind it ??
- K26 Turbo
- engine knocking !!!!!!!!!!
- Anyone help identify some wires ? Calibra Turbo clocks
- has your samco hoses discloured overtime?
- turbo timer fitting?
- cav turbo electric window question?
- Fuel guzzling astra 1.8 16v
- Corsa B Overfuelling
- How much to recondition KKK16 turbo?
- what things to do to avoid melting a let?
- Whirring noise on Astra G 1.8 16V
- turbo technics hybrid k16
- can anyone recommend a good injector cleaner?
- position of cambs in relation to tdc???
- F28 Lightweight flywheels
- z20LET gasget on a LET
- Best way to wreck an engine using household materials?
- Tappet noise on freshly built engine
- Polyurethane engine mounts?
- f28 bearings
- Where do the astra diesel breather pipes go?
- Block skimmed - piston to head clearance question
- f28 clutch advice
- ASTRA G bosche rear calipers
- C20LET injectors on a C20XE
- fuel filters
- Power handling of a e16se block?
- Forged pistons... What?
- oil non return valve in non 16v blocks
- Changing the clutch on a 94 Tigra
- XE upeer Alt bracket Q...
- c20xe corsa feels slow
- opinion on these pistons
- dome volume of 87.5 omega pistons
- bigger bore in an xe
- manifold question
- what colours is the wires on the first gear boost plug???
- C20XE Performance Air Filter
- fault code 95 on my c20let.
- Calibra Tinny Exhaust
- omega fuel pump rellay?
- long shot - but does anyone know anythin about 1.25 zetec fiestas?
- LET/XE Coil ??
- C20LET blue smoke on idle when hot? Why?
- whats the best way to remove carbon from pistons
- best way to tune c20seh???
- I removed the Boost valve
- I found usefull bosch-nipon denso injector catalogue
- weakling sound 1.2i
- oil breather on c20xe
- Omega gearlinkage question
- Has anyone ever measued the 14nv camshaft?
- X16SZR astra engine C16SE question
- c16se not starting first time
- why is my dump valve so quiet on my let?
- phase three questions
- Injector duty cycle
- where is the carbon canister on my c20let
- Gearbox choices
- help with kronenburg engine management
- coils
- Checking an LET b4 buying
- How hard to do a cam sensor on an X20XEV?
- Camshaft Sensor Fault
- carbon canister question
- gearbox help
- astra gsi phase1 and 2 differences?
- calibra turbo front susspension arms
- Weird engine management light
- how do i bypass the amal valve on a c20let..please help.
- 1st gear boost limiter
- fse power boost valve's
- gap less rings came today, there weird
- XE dizzy pack help
- what bearing shells for z18xe? are they the same as the 16xes? and where can I get um
- c20xe corsa strut brace
- nova group a exhaust system
- KKK oil feed
- Astra GTE 16V engine tuning
- Corsa turbo problem
- ECU Map Question
- X20XEV Breather Pipe..
- corsa 2016v exhaust
- Info for Vauxhall Magnum Engine
- corsa cammed????(gsi)
- Corsa engine converion help,,
- which TB's for a 2.1 16v redtop?
- name me a clutch to buy for a phase 2 let
- fuel pressure, injectors, afr.
- fuel pressure regulator question
- big engine nova chassis splitting???
- combustion chamber cc xe engine
- FYI - injector fuel pump replacement in essex
- power problem
- 10.39 volts at fuel pump is this enough.
- 1.8 SPi Cav missing?
- not many kkk turbo's about !
- No Boost and Glowing turbo
- cally turbo & v6 drive shafts, the same??
- X16XE Need more power
- On the back of the block..........
- corsa gearbox problems??
- Cav 1.8 Single Point Injector
- Hydrualic Clutch conversion - Quick question
- Vauxhall Astra mk3 1.4 ECU Problems
- New car, new gearbox problems!!
- solid lifters
- turbo water return pipe split, how to change it?
- corsa xe problems
- how good or bad are charge coolers?
- quick fuel pressure question
- FAO: Anyone who has fitted FK Highsport Coilovers
- xe pulley bolt failures
- Does anyone have a basemap for XE ignition?
- Does anyone have an XE/LET head they can measure for me
- C20LET and F28 removal...
- Im thinking of building an uprated C20LET and need some advice/suggestions :D
- c20xe uprated Fuel pressure regulator & injectors
- Turbo with a SFI box?
- 20seh crank shaft
- F28 Clutch Buying
- Ecotech Crank Sensor
- SEH 8v Oil pressure warning when engine warm.
- Cone Filter / Induction Kit / Drilled box & Good panel filter
- Switching the TC off on a coupe turbo...
- oily smell
- C20let start up and tick over problems
- Help!! DIS Oil Leak Causing Misfiring
- can anyone tell me what mm size the c20let gudgeon pin is?
- gearbox with lse
- can a laser jammer operate an electric garage door
- Air Fuel ratio
