- corsa fuel hose internal diameter n reg sri
- Early 20xe coscast head - valve seals
- c20ne 3 angle valves
- Corsa engine light on
- Unplug the amal valve on your LET and what happens?
- LET oil pressure low?
- fuel gauge - how accurate?
- late dizzyless c20xe not runing, code; 19
- : XE Valve Spring -- ' Installed Height ' ??
- 2.0 16v red top in to 2.0 8v
- Megasquirt on a 14XE
- skimming c20xe head
- Transfer box temp sender connector locaton??
- r1 carbs/gsxr carbs
- Dented fuel tank
- Can the fuel pressure regulator increase pressure?
- corsa gsi/td drive shafts
- Cavalier Turbo running temp (water/coolant)
- where is the EGR valve on X16XE Vaux Tigra
- mk 4 astra engine prob
- Fuel cap motor
- Exhaust downpipe
- Just got a turbo through the post - how much play is normal ?
- measuring a oil pump
- Ecotec 2l into what was a turbo cally
- C20LET Inlet and Exhaust Camshaft number !
- Help Over Fueling X16xe Corsa Gsi
- Will a Cav SRI cat work on a Nova GSI?
- Is there a fuse in?? help needed asap
- how do i spot a vacuum leak please?
- Help!! Still Got Oil Leak!!
- have i fitted my catch tank correctly
- Fuel Signal 18e engine
- strange problem cally turbo
- do i need a new gear box
- corsa gsi power problem
- what size thread is the let act sensor?
- Radiator for turbo conversion
- C20XE ECU Question.
- Calibra Redtop Fuel Pump Where Is It??help
- exhaust query, need quick answer, thanx
- what state did your head come back to you in?
- Any1 know if different cat coverters will fit a Nova GSI?
- z20let owners please help!!!!
- Astra 1.6 SXi - the kangaroo machine !
- Astra GTE mk1 engine in a nova?
- Anyone know about RS turbo timing setup?
- Nova SR fuel pressure
- Stiff 1 Gear In Cally F18 Gearbox
- amal valve bleed pipe
- When Was The Z16xe Engine Installed In The Astra Mk4?
- what size pistons c16xe
- 2.0 8 valve into a corsa
- Wossner Pistons
- Gain Low-End Torque from a LET...
- wiring a oil pressure gauge
- f28 lsd? which would you get and where?
- Quick question on running reds on standard chips...
- Z20LET downipe connector
- Non-rev counter and rev counter clocks for a diesel Mk4 Astra
- LET dizzy cap rotar arm etc...
- astra g 2.0l di clutch
- matheus turbo kits, c20let
- c20let- kkk16 dead????
- re-using head bolts
- Identifying Aftermarket CAms
- better corsa b gearbox
- CO emmissions on c20let what should they be?
- Pics of LET/XE dizzy in pieces
- Nova Samco hoses
- nova xe
- Vectra radiator leak
- dta management with vaux coil pack, help needed!
- 16v gte tappets
- C20let sump plug...
- Engine mount thread stripped
- Overfueling x16xe
- fitting oil non return to block drill size ?
- Problems with the wiring loom of a C20XE
- What size r the bolts that hold the down pipe to cat....
- HELP (cams)
- Vacumm hose on Nova GSi engine, where to?
- Has my exhaust got a flange
- Downpipes for Astra X20XEV with Cat.
- let engine prob :(
- Astra Diesel CDTI 1.7
- Stock GM plugs on LET/EDS phase 2... what gapping?
- LET Head bolt torque settings please
- Head gasket set
- autronic sm2 dizzy mod on an let? urgent help!
- Oil pressure...
- clutch
- help cav exhaust
- ZLET dump valve!
- can any one identify these inlet manifolds?
- Calibra 2L 16v engine problems
- Question about x16xe
- R1 Carbs Shopping List
- Omega indicator fault
- Adjusting clutch the right way to fix my problem...
- How do i find out whats wrong with my 4x4?
- Nova c20let conversion
- Am I missing something??
- c20xe branch maniifold
- Boost Levels On Phase 3 LET
- Best bonnet vent(s) for a Nova LET?
- x20xe ecu on a x18xe
- Heeelp!!! Diesel Vectra won't start!!
- X20XEV double valve springs
- 4x4 switch guide?
- F25 gearbox prob
- Best camber correction kit supplier??
- let-fitting mbc in between which pipe?
- Let and conditioned air ??
- throttle boby
- 3.0 throttle body
- Omex management on c20let
- Replaced Cambelt on 1.8 16v and now not running right
- qucik, help plz ;)how does an xe ecu split apart?
- Engine fitting in west yorkshire
- Add powersteering to Corsa ?
- Dizzyless C20Xe
- F13 - Filling with oil...
- 1.6 gte engine trouble....
- astra mk5 1.8sri tuning! Help!!!
- Advice on C20XE
- 16v gte tappets
- How do you remove a calibra turbo dash?
- C20NE/XE/LET dipsticks all the same?
- spark plug pics is my let running ok
- are msd injectors godd for phase 3.5 let
- Are the mot tested emissions different on 1.4 and 1.8 engines?
- sump's
- F28 gearbox, problems!
- c20let in to v6 vectra help
- help with injectors
- how do you know if your gearbox is on its way out?
- z20let - X20xev
- EDS Phase2 Chips??
- Optimax in a zlet
- Dead engine?
- Phase 2 on C20LET
- astra coupe 1.8 brakes to turbo brakes
- milltek front pipe and sports cat
- Car won't start from cold.
- oil in boost pipes?????
- XE Turbo Kit - Ebay -
- engine rebuild info
- Can someone ID a calibra turbo loom wire please
- why the hell would i have so much crankcase pressure???
- Fitting a air/fuel gauge to a let
- C20Xe going flat bottom and top of revs???
- Cav GSI 4x4, In a bad way, plz help!
- URGENT corsa xe driveshafts
- Nova GTE Fuel Pressure Regulator
- What the *** is wrong with my engine!? let holding back...
- Cally T rear toe /camber angles??
- lowering my 4x4 cally T
- Good advice for XE owners
- Astra 1.4 > C20XE ?
- sbd TB trumpets
- Trouble starting T45 20XE
- nova xe
- f20 diff
- Nova GSi wiring loome
- anyone here buy the XE turbo conversion from Matteaus on here?
- Lack of power
- putting a c20let into a mk4 astra diesel ?
- c20let problem......possible airleak?
- c20let boost
- carb trumpets and airfilters
- scorpian full exhaust on mk2 GTE (16v)
- Brake Upgrade for Cavalier Turbo
- how to stop rear crank main seal leaking
- SBD TB's
- v6 into a ecotec calibra
- induction kit
- what Temperature
- any suggestion let upgrade
- oil cooler position on nova let
- Engine taking ages to warm up?
- should engine warning light come on ????
- glow plug relay location
- coil wiring help please
- Astra G gearbox fault
- Corsa 1.4 16V Trouble
- Nitrous on c20let
- Astra turbo gone pop!!!
- quick nova wiring queery - oil gauge
- Do you use EGR on your performance intake?
- C20XE/LET crankshaft sensors
- Wiring loom
- Z20LET gasket and runnig problems on a C20LET
- Driveshafts, same or different??
- MAP sensor with DCOE inlet manifold
- Z20LET Oil Cooler location?
- F28 Speedo Drive Conversion Question
- let ecu question
- FUEL pump on corse c20xe???
- electric power steering on c20xe corsa???
- need a favour 1st gear boost wiring
- Omega 2.5 v6 Gearbox bolts?????
- Pot Flywheel
- Timing up the C'let
- engine conversion question
- Diesel To Petrol Swirl Pot Help
- Lining up bottom crank on XE
- Sump gasket Q
- swapping cams early and late xe
- any1 rebuilt an f28?
- cossie -31 coversion for let q's...
- Supercharging a X14XE
- Removing F28 from Calibra
- fitting a pressure gauge to the rear of fuel rail help!
- Cylinder Head Cleaning
- Sparks/Ignition timing
- fitting headlight buzzer - 97 corsa breeze
- what oil should i put in a f20 gear box?
- let in to astra gsi mk3?
- Is it my actuator? (c20let EDS2)
- Corsa combo gearbox
- FAO people running bike carbs
- F28 mechanical speedo conversion?
- making a Let on a diesel mk3 astra
- anyone with a xe live near kilmarnock? air flow meter prob...
- 1999 astra 2.0 sri gearbox help, please!
- 2000 16V Turbo - Conrod Problem - HELP !
- stuck in gear???
- Astra Turbo Z20LET using too much fuel?
- Rev counter wire on XE coil.
- what cams? - corsa gsi
- Z20let Blowing Manifold Gasket
- Draper Camshaft locking tool
- 20xe water flow diagram
- Competition Engine mounts for Mk3 Astra
- Gearbox.
- water injection jets
- fse boost value on C20XE
- Silicone hose kit for Cavalier Turbo, Where from?
- Valve seal on coscast head.
- small block 8v mpi heads
- Camber Issues Calibra Turbo ( With Pics )
- Can I use an F23 with a v6 engine?
- header tank pipes c20xe
- electric clock on f16 how do u wire sender in???
- quick questions on 1.6 16valve nova. . .
- gearbox trouble
- Help please astra fan belt
- Changing valve stem oil seals
