- Vectra Xev into my Cav
- Buying an intercooler - what to look for?
- Crank sensors
- Mk3 GSi Turbo conversion help...
- What's this chip (C20LET ECU)
- C20xe Oil cooler
- courtenay sport corsa xe springs
- Torque settings on 20xe
- correct part no for let rotor arm?
- will turbo shocks fit a xe calibra??
- F28 in to corsa B AGAIN!!!!!!!!!!!!!
- Stainless exhaust parts suppliers??
- HELP!! C20XE conversion problems.
- anyone willing to come fit engine conversion (take a look)
- Injectors for GSi-T
- Transfer Box Oil Temp Gauge
- Isuzu 1.7 TD, Inlet manifold removal (pictures)
- Let question.
- asrta mk 4 engine code
- Mk 3 astra 2.0 SRI cams
- xe running trouble
- Cambelt on Ecotec
- Oil changes on modern cars....
- Diesel Omega B
- nova, rear gearbox mount?
- C20LET dump valve prob
- Easy LET dizy rotor question.
- C20xe superchip ? ? ? ?
- Lambda fault
- Emergancy!!! PV06 and engine has just let go HELP!!
- c20 let shells and rings
- Dbilas turbo kit, with stock injectors?
- engine wont run
- ignition short? help!!! astra mk4 turbo
- Help !! My Diesel 106 won't start !!!
- Cavalier 2.0 16v ecotech ECU problem
- Place turbo in my Vauxhall 1.2 carburator? Its possible???
- C20XE corsa engine mount
- Forged Pistons
- Ecotec Coolant pressure?
- Repairing Carbon...
- What fuse etc for Interior light and Cigarette lighter?
- Z20LET Oil Temperature Gauge
- Engine just cuts????
- C20let distributor cap & rotor arm replacement
- melting pistons c20let HELP!
- Another let engine holding back thread!
- let bosch green injectors what fuel pressure is best
- another oil gauge question
- Bit random, LET fault code 13...
- follow on from 8v cam follower probs
- Solution to my engine cutting back???...
- Crankshaft Bolt
- Astra headlamp adjustment
- XEV altenator onto Early type LET?
- Fault codes on Vectra diesel 1998
- Ecotec to Redtop.......How Easy???
- modified 1400xe down on power, any ideas?
- Phase 2 Chips C20LET
- 1st gear switch, LET, F20 Please help
- 1.7 TD engine into nova
- Inlet manifolds
- another problem with my turbo?
- drive shaft lengths mk4 mk3 astra
- F28 reverse light switch?
- EGR Valve
- Crankshaft Sensor - How do i route the wire so it doesn't melt?
- Timing Belt
- Would you please help C20LET FAULT CODE 114 AND other problem
- Have i forgot anythin? C20let rebuild
- Early crank and flywheel any gains (c20xe)
- Transfer box oil
- Redtop and ecotec compatibility
- caming corsa
- lambda sensor thread size
- Wanted Redtop Air Flow Meter!! Help!!!!
- Changing a C20XE corsa to a LET?
- Turbo overhaul - Who?
- good oil for freshly rebuilt turbo lump
- XE/LET block mount the same?
- Quick Q about the C20SE(?)
- Astra H z18xe question????????
- c20let starting..
- V6 + F25 - will it go into a Nova
- GT3071R on c20let??
- tappet noise after new lifters
- Is this a Williams engine or the normal 1.8 16v?
- C20XE Tuning Advice needed!!
- vectra manifold
- does the mk3 astra have a fuel filter?
- can u get chip copies for diesels...
- Vectra 2.0 Diesel 1998
- Baffled sump design
- single piston recirc on let
- Still No boost, LET corsa????
- red top starting problem
- Z20LET gasket Vs C20LET gasket Vs Cometic
- 3.0 Inlet?
- Where to get nova xe engine mounts ?
- Arp rod bolts/throttle bodies question
- CAlibra Redtop Airflow meter needed DESPIRATELY
- let xe engine looms
- traction on leted astra mk2
- 1L 12V corsa to XE conversion wiring
- Watching Your EGT's
- how to get crank oil seal out?
- Cav turbo inner CV joints?
- tuning a power boost valve
- Fuel Filter connector
- nova sri fueling need help[ asap
- Cam Belt on a mk3 astra
- wrong oil
- Mk2 Astra V6 Gearbox + 4x4
- How do i reset ECU on astra gsi Mk3 redtop
- broken drive shaft . help needed
- injectors
- bailey dv30 info needed
- Zafira GSi - Poor Performance?
- nova c16xe
- gsi fuel prob
- c20xe ECU Chip
- What do i need.... C20LET question
- MK3 astra let. Which radiator?
- Injector cleaning
- Corsa XE wiring
- ***GUESS THE C20LET BIT*** lol oops...
- x20xev corsa
- What Variable Fuel Pressure Regulator for P3.5 LET?
- Clutch freaked? Gearbox or linkage/Adjustment
- max boost/hp on a let with forged pistons and deseamed/peened rods? what have u run?
- IC options for let astra gsi!
- Early c20xe crankshaft (cost)
- c20xe Calibra not start when warm.
- Crank Sensor help
- Corsa C20LET Reccomendations
- in a paralel biturbo set up, if you have 2 18psi turbos in2 1 inlet, do u hav 36psi?
- Irmscher Sprint Injection System
- kkk compressor housing quick question
- Can I Make My 1.2 Nova Any Faster ? ? ?
- electrical issues sensors 4x4...
- C16XE in a nova questions
- Pipercross Induction Kit question - Astra Coupe
- Astra Mk4 V6 + F28??
- corsa c20let, phase 2 or 3.5? which injectors?
- when skimming a head.... *pic inside*
- advice needed on changing EGR valve please - vaux tigra
- What do these screws on the carb do? *pic*
- f28 electronic clocks/ abs ecu
- c16xe ........ what to do ?
- c20let questions
- xe fuel pump
- gsi cav fuel prob
- astra mk4 c20let wiring
- throttlebodies
- uprated oil pump
- crank sensor
- Burning Oil
- Vectra - Headlights no worko
- Which Calibra turbo (1995) were 240bhp
- c20xe nova anti roll bar
- gsi fuel prob
- ECU/chip question
- xe fuel pump
- Knock when engaging clutch etc.
- Individual coil packs - testing?
- injector cleaning
- what colour is the clip on idle control valve
- Question on LET in-tank pump...
- C20LET *Engine Management light* code 12...
- Z20LET gasket on a C20LET head...why drill out rivets?
- Angel Eye Headlights Help needed!!!
- Angel eye headlights
- Anyone knows the psi range of the MAP on a X14XE?
- uprated fuel pump
- who uses the TAS mount on their f28 in a nova?
- Carb Fuelling
- Tightening torques for ARP stud conversion on a LET
- still cant get engine running
- Pipercross Induction Kits
- eds ph1 and 2 switchable question!!
- ashley exhausts vs peco exhausts?
- Boost problem? LET
- 20xe fuel plug
- Nova rear beam strengthening due to coilovers
- Let still not boosting over 16psi
- LET still running badly, HELP
- c20xe supercharged
- Bailey Dumpvalve not working
- 'leccy window wiring loom
- Cally turbo farting
- calibra turbo spark plugs
- xe inlet cam not fitting
- peco exhausts?
- fitting xe into corsa b emmbarrasing problem
- Which strut brace on Nova LET?
- size of LET clutch please?
- injectors
- c20 xe won't start!!!!!
- 8v cam followers
- how do i find out the engine model on my vectra
- corsa XE clocks
- Engine Management Light
- any 1 needin power in an nova
- Fitting new manifold section (Help !!)
- idle control valve
- LET Exhaust Studs
- 1600 engine question
- c20let owners
- changing gear cluster (F20)
- CV joint 'collar' out of gearbox/diff area? vectra V6....
- Are coupe Turbo 308's that same fitting as astra mk3's
- difference between xe and let exhaust cam
- T8 LEH project....(56k beware)
- ashley manifold any good
- Aftermarket tach on c16se help?
- is let and xe fan the same
- 4x4 problem???
- How does a 5th injector work?
- how to mix toluene and fuel
- Transfer box temp sender, 10 - 18mm Adapter, where from?
- astra g engine swap
- Corsa let conversion question
- Running Evo5, Which Injectors
- z14xe from corsa c into corsa b?
- let engine parts
- DTA maps for c20xe on throttles
- Injectors
- how much work to convert C20XE to turbo
- anybody using a 200sx manifold on an let?
- vectra V6, inner driveshaft/differential problem
- problem with redtop, missfire?
- Need Engine Rebuild Advise (C20LET)
- Nova engine into a rwd chevette
- No spark
- poorly engine :(
- cool running plugs for c20let
- Can you tell me how much power...
- Induction kit on astra gsi turbo ?
- Clutch Adjustment on Tigra?.
- LET ECU Codes...
- Help with Cat/exhaust on 93' MK3 Cavalier 8V 2.0l
- C20 XE and C16 WE flywheel sizes?
- exhausted
- 4WD Let Astra GTE....Is it possible?
- nova xe
- DIY-TURBO.COM - Chips..
- Changing rear wiper on Astra GSi with spoiler!?
- Looking for Phase 2 chips!!!
- Astra mk3 Sport Superchip
