- vauxhall have two different sealents for sump/girdle
- 1997 calibra x20xev to c20xe help?
- Vauxhall Nova Idie Problem
- Z20LEH turbo help
- Cavalier 1.8 flywheel, will it fit on xe
- astra gsi 3l v6 lumpy
- f16cr same box as f20???
- Adjustable or Non Adjustable External Wastegate
- Z18xe won't start after fuel pump removal
- Z20LET Clutch and Slave Cylinder
- Anyone had any issues with oil leak from dizzy on xe/let?
- ABS amplifier & pulse converter
- corsa c 53 reg drive shaft help
- C16XE conversion
- Shift Stick for M32 in Astra MK4
- x25xe v6 EGR removal
- innovate wideband help
- f28 into corsa b?
- help on c20xe torque on main bearings , piston arrows
- engine core plugs
- Actuator doubts
- Z16XEP thermostat replacement
- f28 into mk3 astra
- should i relube the arp main cap studs
- corsa gearboxes
- where can i buy the grey arp lube
- c20let getting hot
- Zafira Gsi with Astra VXR conversion wee problem.........
- how laggy is the 86ar gt2871r???
- C20LET timing
- f20 speedo ring?
- Cavalier V6 Sensor
- Zafira fmic advice.
- Glow Plugs?
- VXR M32 6 speed box, Whats the speeds?
- which gearbox for xe engine in rally car
- wide band?
- Frontera 2.2 immobliser problem
- Z18XE Water Pump Replacement
- vectra b mounts for Saab engine & F23?
- heatsink bung for lamba ?
- C20let ecu fault codes
- 1.6 16v ecotec not starting?
- T20SED daewoo/chevy cylinder block
- Post cat O2 sensor heater fault
- Xe spark plugs
- TX Autosport Tubular Turbo Manifold C20LET
- Engine number need to check to get parts
- Engine is not Starting After Auto to Manual Conversion
- HELP!!!!!! Anyone have an x14xe flywheel
- Calibra Turbo clutch 4x4 turbo
- Zafira Gsi Help clutch pedal gone to floor very light
- which is better rtv sealent or sikaflex
- Today's power run! Graph?
- Z20LET Exhaust Manifold Gasket Query
- C20xe camshaft details needed
- Any one offay with VW Passats?
- Anyone still supplying x20xev ecotec exhaust flanges?
- fuel line size
- evo 5 fuel pressure?
- c20let tiny splutter dead on 5000 revs 3rd gear??
- N reg Astra 17 td ecu meter Location wanted please?
- How to make a F20 work with small block engine?
- Z20LEH Corsa C SRI jerky loud boost....HELP
- 16XE valve removal?
- Z12xe Noisy on Tick Over
- Vectra b 2.2 dti P1590 and P0115 fault codes
- 2006 vectra 1.8 vvt cambelt change interval
- help with x18xe1 on carbs
- astra h coolant warning
- small block 1.8 identification
- amal valve
- confused on clutch kit for f23 c20let
- C25xe wiring help needed. No ECU power?
- Wheres the best place to buy 16XE Bearings?
- Coscast the best or is it not...?
- Torco engine assembly lube mpz friction reducer any good
- Vectra equal length driveshaft question?
- Corsa XE Powersteering Pipe work
- Z20LET Light Weight Flywheel.
- Help needed, 51plate 2.2 astra coupe refusing to start.....any advice??
- C20let with vxr turbo?
- Emission woes on v6 gsi. EXPERTS only.
- X16xe aluminium inlet flange
- 2.0 DTI SXI Astra with rattling noise
- 20dth into corsa combo
- corsa 1.4
- do I have an 1800 small block bottom end?
- Has anyone had this happen to a F18 Hydraulic Bearing
- f28 gearbox info needed!!!!
- chevette xe installation help please
- Let fuel pressure... Gauge?
- Lucas 380 or 440cc to C20LET
- Vmax phase 4 chips for C20LET
- x14sz wont start. No spark........?
- quick c20let boost question?
- Saab 9-3 2.2 turbo diesel, vauxhall equivalent?
- corsa b x18xe1 with f13c box
- Zlet corsa smoking
- PLENUM
- converting internal wastegate to external wastegate
- Astra gte 16v running temp and heater issue
- How much oxygen will effect wideband ?
- What size injectors for 450-500BHP C20LET?
- C20let running rich?? Advice please...
- urgent answer needed on this one. Does the f23 Slave Cylinder Fit the F28 if Modded
- VXR turbo on GSi Zaf?
- Cannot open bonnet on vectra c !! Cable is functioning? Does not spring up!
- Whats the minimum clearance between a radiator and a compressor housing?
- Any one running a girdle on an let without did you line bore the block
- F23 gearbox cable or hydraulic?
- Where can i get an oil pump cheap for a z18xe?
- Astra Mk4 SRI Tuning
- c20xe inlet manifold, how to get it off?
- lamba different after new exhaust,
- Z20LET wiring plug question
- cavalier v6 engine into mk4 astra diesel van?
- timing a c20let with a xe inlet cam
- will this clutch fit f23 box with c20let?
- Vectra b (02) old look - clutch hydraulic slave wobbling - no clutch
- C14NZ hesitation on WOT
- X17DTL boost and pump adjustment
- vectra cdti 16v major problem
- kkk16 turbo probs
- Talk to me about omega gearboxes
- C20LEt Corsa clutch?
- corsa c gearbox sump leak (help)
- 16v head freshen up
- astra mk5 gearbox info.
- arp main studs question 2
- Vectra C 1.9 diesel, losing all power
- astra digital dash wiring
- Nova merit plug lead problem
- c20let manifold bolts
- 1999 Astra van 1.7td low blow coolant sensor??
- tigra c20let
- arp bolts in z20let
- chevette c20xe conversion
- x20xev cam in a zlet help
- Astra mk4 saab engine conversion
- 1 dead astra gte 16v,
- corsa c20let problems
- MK4 Astra throttle posisition trouble
- f28 gearbox in to mk2 astra gte 16v
- c20xe conversion
- Z16XE idle control??
- another c20let boost problem
- let mains caps/ shells and lubrication
- is this a genuine or aftermarket water pump
- oil pressure lower with new oil ?
- How to change aux belt on vectra cdti 150??
- fluids help
- Saab red fuel pressure, vernier pulleys
- best spark plugs for c20let?
- what injectors are you using on evo5 chips???
- silly question about fuel
- could this be start of head gasket failure!
- C20let turbo rebuild? eBay? Prices....
- corsa b over fueling
- main bearing bolt help
- c20let giving me a big headache! help please
- f20 clutch
- Astra MK3 / F Engine Management Light (R reg 1997)
- Astra Mk4 C20let to Z20let??
- c20let gearbox??
- confusion with engine looms and ECU's for X/C16XEs
- gearbox very slight oil leak corsa c
- c20xe engine code list?
- corsa c20xe revving problem
- Recommend me someone that will weld drive shafts professionally and balance them.
- v6 lambda sensor and 2.0 8v lambda sensor
- recomend me a eletronic boost controler
- V6 Cambelt Change Kit and Advice needed in midlands X30XE
- c20xe is it worth changing piston rings or just get a new engine?
- vacuum pipes help rebuilding car back up
- coscast double spring retainers
- identifying oval racing/ grass tracking F10 gearbox
- Section on apexi avcr set up im stuck on ?
- help id ing part on vectra v6
- corsa sr1 8v to c16se
- Engine code where is it on c18xe\x18xe?
- for those of you with the f35 gearbox...
- Why no boost on my c20let?
- Are small block flywheels interchangeable?
- cam caps torque settings
- piston rings
- corsa b c20ne
- c20xe valve pockets
- snapped gearbox alignment pin!
- c20xe coilpack engine issue
- baking engine enamel
- Calibra Turbo 4x4 fault code 37
- c20xe to c20let?
- URGENT! c20xe air flow meter is it the same on late and early?
- Fitting F28 to my Mk3 GSi
- Z20LET Air Filter Question
- metal zlet head gasket on c20let
- powder coating an let sump
- c20let with z20let pistons
- corsa c20let breathers
- F28 diff bearings
- suspension help for a corsa xe
- over heating c20xe
- Engine Electronics light comes on for a while in my CDTi 120
- C20let
- Shorter halfshafts for rear diff
- c20let black smoke issue
- C20let fault advice please
- question about uprated fans???
- x14xe cambelt problem plz help
- z20let exhaust flange
- 1.8 vectra mods
- fuel pump for a Corsa B xe
- hi all new here and just got a new project few questions
- Corsa suspension bush ident?
- 1.6 16v engine no power
- F18 differential gasket
- quick question on rear axle
- corsa 2.0xe wont idle
- C20LET Mk3 Astra Lsd... before and after
- twin 40 carbs, jet sizes
- 1st timer bottom end rebuild .
- 51 corsa easytronic advice needed please
- Weird clucth Problem
- Temp switch probs??
- f23 box on a x18xe1?
- F28 electric speed reading
- Corsa C20XE running weird
- just bought a corsa b with a early c20xe and have a couple o Qs
- Problem with mk3 astra gsi c20let
- c20xe alloy oil cap...
- Gains of a remap on a C16xe?????
- traction control light comes on cav v6
- f23 flywheel
- cavalier turbo tx box question- locking kit?
- Vauxhall Nova C20NE - No Spark. HELP!?
- Is it possible to strip down a standard sandwich plate?
- engine mounts
- Wreg Astra SRI 1.8 head gasket probs..
- c18xe rev limit
- Delay in Autobox gear changes...
- 20xe sump
- Vauxhall Corsa SXI, 16v, 1.2L. ---- P0170 Engine fault code
- Corsa B 1.5TD flywheel bolts
- coscast head problem? valve guide
- clutch help for my c25xe van
- 2wd cosworth weber afpr
- 1.6 engine identiy problem
- 1600 16v donor
- 500bhp clet map sensor
