Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 [79] 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. c20let cam pulleys
  2. C20XE - Misfire/93 Hall Effect Switch
  3. 4x4 v6 anyone?
  4. whats this plug for? pics (LET)
  5. Sudden loss of power while accelerating..
  6. wot size vacume pipe for c20let?????
  7. bmw mini supercharger hasn't got bypass valve! what now? :P
  8. throttle body question: trumpet length vs torque???
  9. detonation
  10. head question
  11. No Oil Holes In New Conrod Shells ???
  12. c20 let cuts out
  13. Corsa 2.0 16v engine conversion: Help
  14. Fit my head gasket for cash
  15. 2 litre cranks
  16. Gearboxes......
  17. finished overbore size - tolerance on new pistons
  18. hot running prob boost issues c20let
  19. Charge Cooler, can it run phase 2
  20. C20let coil type question
  21. CAT out!
  22. help needed with 4x4 alignment results on calibra
  23. 20xe cam oil seal sealing issues
  24. Early XE rollers on later XE?
  25. remapping a corsa 1.2 8v
  26. QED Throttle Bodies / DTA EMS
  27. plz help remap on z20let coupe
  28. mk2 astra v6 / what gearbox ?
  29. quick engine change ????
  30. nova with 16 xe
  31. help meee please - turbo oil feed
  32. Stripping Down a KKK16 Turbo
  33. Astra front pipe turbo with cat
  34. Converting alloy gearbox bellhousings
  35. Cavalier Turbo Fuel Relay?
  36. Daewoo Lanos Sport GSI 16V (c20xe inside) ;)
  37. C20XE Water Hoses
  38. 1.2 Head skim - How much?
  39. what manifold gasket is this?
  40. C20LET No Compression, HELP!!!
  41. Astra cam sprocket removal
  42. Been offered a free turbo!
  43. fitting the f20 plate to convert an f28
  44. How Much???
  45. Will a short shifter help for setting up a tight gear selection range?
  46. c20xe conver kit + TB's
  47. Manifold problems part 2 : c18xe / x18xe - are the manifolds the same ??
  48. X14 SZ problems
  49. weird cranking
  50. No power to clock or stereo
  51. 1.8i cav l reg wiring
  52. which mounts for fitting f28 into a 2wd cav
  53. Vec V6 Oil Cooler
  54. c20 let plug????
  55. need advice on engine swap
  56. Good Rolling Road operator for a c20let?
  57. valve guides *rant****
  58. Anyone Running Avo Coilovers and Rally Design Spherical Bearings On a Nova
  59. Cally Turbo aircon prob part 2
  60. v6..ecotech V redtop v6
  61. Omex 600 or 710??
  62. lucus 75/90 synthetic in f28?
  63. What set up req for a 350 bhp let
  64. Extra injectors for a e16se
  65. astra wont start
  66. XE Runs rich - black smoke and missfire
  67. 92 calibra turbo coil wiring (help)
  68. diesel engine swap - info needed
  69. injectors/fpr setup?????
  70. Why bother with a wheel well mounted fuel cell?
  71. C20LET exhaust downpipe
  72. xe problems help pls
  73. fueling
  74. mk3 astra ecotec problem!!
  75. Engine stalling on a 1.4 16v astra 2000 reg
  76. Quick head gasket Q
  77. oil pressure valve location corsa
  78. Problem LET, might have found something
  79. '92 Cav 1.7TD Clutch Change
  80. 1.4 merit astra to LET with gsi spec...
  81. Turbo and vacum Pipe amal valve pipe ecu pipe
  82. can anyone help with hose positions C20XE
  83. tuning the low blow y17dtl engine
  84. kkk or Garrett?
  85. Hi performance spark plugs
  86. Blue Smoke on a LET.. need help
  87. 4x4 drive trains??
  88. Ebay ECU Chip?
  89. F28 Speedo info please
  90. Calibra turbo aircon help! bizzare problem
  91. Corsa B red top problems
  92. calibra turbo calipers with 4stud disks/help needed
  93. let with a sr20det manifold and which turbo?
  94. help with oil problem L reg fiesta
  95. m vaux afpr
  96. 1.6 xe cam cover
  97. Can anyone advise? '95 cav 2.0i 16v ecotec
  98. what grade oil for f28 gearbox
  99. XE Dizzyless Loom issue
  100. arp head stud kit?
  101. x20xev airbox mod?????
  102. Any way to lengthen stroke on C16 SE?
  103. Engine problem?
  104. c20xe chip what one to get and where to get it from
  105. Which Evo boxes are the most reliable for high power?
  106. dastek unichip wiring
  107. How many amps does a starter solinoid pull ?
  108. Bye bye head gasket!
  109. Astra Gearbox Problem - cant get 2nd or 4th!!!
  110. yet another cracked manifold - help needed !!
  111. Which LET Exhaust Studs? Pics
  112. f28 in corsa 2.0 16v
  113. Help needed Z20LET
  114. Cavalier GSi Header Tank Full Of Treacle!
  115. Engine managemnt light aghh! c20let
  116. Torque figure for camshaft caps on c20let
  117. I know of the breather mod ,but what else is there ?.
  118. Starting 20xe Nova
  119. Nova 20XE exhaust manifold
  120. let boost problem
  121. Optimum Cams For Big BHP LET
  122. Yamaha R1 Throttle Bodies
  123. How much power can a x14xe handle?
  124. what injectors to use.
  125. Nova XE Petrol Tank
  126. LET to NE engine transplant
  127. Fitting an F28 to 2.5 V6
  128. 1.0 Corsa Sting 1997 ECU light - surprise surprise!
  129. are the 1600 16v safe engines (cambelt broken)
  130. head gasket problems? mayo...
  131. astra egr valve
  132. Corsa SRi oil cooler Question,
  133. Please help with dump valve
  134. Manifold Enlarging.
  135. Towing an R5GTT on a trailer using a Corsa XE/LET?
  136. lumination air/fuel meter?
  137. Strange C20LET starting problem.
  138. f20 gearbox synchro issues
  139. car wont move
  140. Theoretical Cav Front Camber Correction
  141. Cav turbo, radiator upgrade?
  142. ecu differences on c20let (imoberliser)
  143. inputshaft oil seal
  144. 1.4SR Engine upgrades (£600 budget)
  145. Xe cam belt covers?
  146. T5 to LET bellhousing?
  147. 1.8 1995 Cav No power, timing belt and head
  148. gte 16v fuel pump wire
  149. C20XE Big End Bearings
  150. f28 front mount
  151. ph2 let. how much boost?
  152. astra gsi engine removal?
  153. what fuel pressure is everyone running on bosch greens for let
  154. fse fuel press re3g is it anygood for an let
  155. removing ABS system completely?
  156. setting let fuel pressure pipe on or off
  157. Omega V6 Manual Gearbox Clutch Plate No.
  158. Nova 1.4SR downpipe
  159. calibra turbo conversion
  160. Z20LET oil pump in C20LET
  161. Gearbox on Nova 2.0SEH
  162. wots the rotor arm mod on a c20let??
  163. installing a oil and water temp guage help???
  164. boost dropped
  165. throttle position sensor fault
  166. 20XE water gallery
  167. C20XE Tigra conversion helllp!!
  168. astra mk3 1.4 misfire/splutter
  169. Auto Gearbox Light Coming On
  170. Differnece between pot & flat flywheel bolts holes?
  171. relocated battary
  172. Petrol and stuff
  173. valve stem pics opinion wanted
  174. Lambda sensors - Zirconia and Titania...
  175. C16XE magazine article
  176. Noisy waterpump
  177. Spark PLug Problems!!
  178. 2.0 redtop conversion!! New Project!! I need help!!
  179. corsa b coolant/lambda sensor question
  180. Nova XE Header Tank
  181. filling gearbox
  182. Driveshaft
  183. Vernier Size Of XE Headbolt Washers?
  184. Question re. uprating the fueling of an engine after supercharging (stock ecu)
  185. Corsa C engine Oil Help,
  186. conversion driveshafts
  187. 3.0 V6 nitrous setup - how much?
  188. quick question on turbo sizes for an LET
  189. exhaust advice
  190. Clutch problem
  191. xe nova airbox
  192. xe loom and ecu
  193. water injection.
  194. 1.6 zafira help!
  195. Anybody Fitted a F28 to a Z20LET/LEL
  196. V6 questions
  197. Astra H dump valve
  198. f28 6 speed on c20xe
  199. z14xe/z16xe
  200. 1.3 with twin 40s need more
  201. enlarged throttle body???
  202. EVO 5 software vs EDS... what do you really need.
  203. fuel ecu?
  204. Will my F23 gearbox work/fit with a C20LET?
  205. Rebuilding a V6 Engine
  206. Cable shift on an F28 ?
  207. Cooler running spark plugs
  208. Cooler running injectors
  209. Which lifters do i need for my c20let?!
  210. Part number for vxr injectors??
  211. Oil in water? help
  212. Couple of c20xe vaccum hose questions...
  213. nos on a x14/16xe
  214. Nova Engine Conversion, 1.6 8v into a 1.2
  215. 2 quick question
  216. Engine stuttering
  217. -=[yellow injectors]=-
  218. FAO Engine tuners/mechanics - Tech info required
  219. LET wont start
  220. saab reds?
  221. Does declaring new engine to DVLA lower insurance
  222. Matheus supplied fuel pressure regs...
  223. bike carbs on c20xe who does this?
  224. C20LET into a vectra. How to do it???
  225. mk 4 sri turbo...
  226. Engine exploded!
  227. C16se which gear box's fit
  228. c20xe tapping
  229. 5th injector
  230. Cally Turbo fuel guage help PLEASE!!
  231. Drive Shafts Low Cwp
  232. new bosch injectors let now holding back
  233. where cab i get an apexi boost solenoid valve
  234. Wheres the cam sensor located on a 2l 16v eco
  235. are all the small blocks the same bar the bore?
  236. Car probs(cut out!) 2l 16v ecotech
  237. Correct torque settings for a K plate astra 1.4?
  238. red top turbo
  239. 1/4 mile times c20let
  240. Can you live map the simtec 70 (71.6 - z18xe) series ecu?
  241. ecu difference?
  242. phase 3.5 with msds
  243. turbo clutch help with xe flywheel
  244. Fitting arp rod bolts to a c20xe
  245. Nova rear spoiler fitting easy to do?????
  246. C16SE same as Z16SE?????
  247. ICV On a ecotec
  248. bosch let injectors 0280 150 558 are they ford
  249. I made a LET plug diagram :)
  250. Stray plug C20LET loom
