- 3.0 v6 turbo
- SBD Headbolts website needed
- C20LET into a C20xe calibra
- Diesel wont start (pics)
- 1997 astra, x16xe
- Aftermarket Turbo Dump Pipe + Where To Buy Flange?
- What turbo do courtney use?
- exhaust system ??
- Fronter oil filter
- broken spark plug, help!
- Amazing Ebay turbo, I have Questions !!
- info on coilovers for corsa gsi
- c20xe temp sensor wirring?engine change
- corsa Let - Boost problems
- Quick Cav exhaust Q...
- gearbox and mounts for XE/LET in corsa C
- Need Local Garage (Cambs)
- C20LET Ecu Pinouts
- Dispak c20xe fault code problem
- LET cuting off
- pre cat
- baffling a smallblock 8v sump
- Head bolts!!!??
- alternator belt on red top with t'bs
- what gear box?
- - Cometic - Head Gasket - Part No: ?
- Oops me hybrid kkk pipe tis leaking...
- spark gaps
- xe rebuild problem
- turbocharging a 1.8 8v?
- equal length driveshafts on mk4 astra?
- e16se gearbox- please look
- GT35 82R Turbo - info needed
- stroked 1.616v(ECU question)
- c20ex in corsa problems
- C20let Poping Exhaust
- Help V6 in but won't start
- c20let dizzy problem (broke plastic bit that goes in to the cam)
- FWD F28, offside CV has play....is it normal?
- Oil feed captive nut on LET turbo?
- Injector Flow Calculation
- Nova Let Conversion Guide?
- quick crank wheel question
- afm sensor
- Hall Sensor Question (C20XE)
- Struggling with X16XE timing belt
- corsa b coilovers - where
- x16xe into a Corsa B 1.4 16v
- C20 LET Cam followers
- Miss-Fire - c20let
- Custom exhaust
- 1.6xe head-1.8xe1 head
- engine mounts
- is it ok to shot blast the cam cover
- Have to reset computer to start c16se
- nissan skyline r33 gts non turbo
- 20l8v/20l16v flywheel.SAME???????
- XE Injector Colours ???
- 400 bhp what boost
- f20/f28 gear linkage?
- 100amp alternator on a LET?
- What rad for Astra GSI C20LET?
- engine conversion
- diagnostic plug location, astra 4
- Iridium Plugs on C20LET Phase 3
- Driveshaft retaining nut help! ASPA
- Coilover Setup??
- Breather mod on 2.0 16v
- removing xe head, whats best to replace?
- Turbo breather required ?
- ** Fuel Pressure - Nova E16SE engine conversion
- C20XE timing cover and lambda question.
- Std LET running with no water cooling to turbo?
- Running std LET without Oil Cooler?
- Stripping XE Head Help needed please!
- Quick double valve spring question
- Cold water into hot engine .
- R d - Valve Springs "submerged" or "sprayed" with oil ?
- mk4 astra gsi turbo engine into corsa b ne ideas
- Oil pressure too high
- Cav mk3 1.8 SPI engine?
- wanna make a turbo corsa help please
- let-fitted fmic and dump valves not as loud?!!!
- which clutch do i need? help
- Redtop miss fire?
- XE on carbs...
- Check Out Wot Regal Have Told Me 'let Tuning'
- Carbs
- Calibra turbo coolant reservoir
- Vauxhall arena engine code? Or cam belt pages from autodata :)
- corsa gsi c16xe idle problem
- Intercooler!
- head bolt problem
- cav turbo ecu....... hose connection???
- Frontera FMIC on Cally T
- C14NZ misfire at idle
- Corsa Turbo conversion
- accidentally put petrol into a vectra diesel now it wont start
- Is a 2 litre 8v inlet manifold water cooled?
- knackered Head, replace or repair
- coolant pipes - 1.4 8v - 1.6 8v are they the same?
- breather filter
- Anyone with engine changeing knowledge?
- F15 Gear box Help
- cav 4x4 transfer noise
- Turbocharging A V6
- c20xe starter motor! help
- nova 2l 16v gear linkage !!!!!!!!
- equal length manifolds on lets
- flat fly on xe, when?
- Will Calibra Turbo Suss Fit A Calibra Red Top???
- astra coupe turbo suspension
- what ignition leads & spark plugs?
- *** Twin Carb Dissy / Coil Setup for 20XE ***
- Cav fuel Consumption
- Help with XE fuel lines
- starter motor
- Exhaust Re circulation Valve Corsa Gsi
- xe crank pulley bolt
- x14xe conversion
- C20XE converted to LET oil return?
- heat shield bolt
- Who sells - 'Solid Lifters' ?
- Variable vane turbo? Explain!
- f28 speedo cable
- Which Gearbox???
- LET Help!!!! Again!
- LET rebuild, quick question
- Reconditioning an F28 6speed gearbox
- wot symptoms would a dead let airflow meter cause
- 400 bhp let waht size injectors
- Roosemotorsport Silicone Hoses.
- mk4 astra 1.6 problem.... help
- Engine Management Light
- brand new C20Let looms
- xe ICV problem
- Corsa 1.2 starting problem
- C20let Overfueling+ Missfireing Please Help!!
- Corsa 1.0 engine conversion to 1.6!
- Oil change on 2.2 vecta (2001)
- engine troubles
- Clutch pedal feels weird
- Injector Question
- HELP! F28 gone bang, lost loads of oil but still all gears??
- C20LET and Z20LET tuning
- gettin more power out of my cav
- phase 3 fuel pressure regulator
- phase 3 adjustable boost controll not working?
- cally turbo tyres, quick question
- let boost problems do you think this will cause it?
- any one know best setting for avo coilovers on a xe nova
- 400 bhp let
- head gasket c20let????
- air/fuel gauge Q
- Wiring clutz needs advice...
- Petrol gauge fecked .
- Running a MBC but I want overboost too!
- Oil cooler size recommendations?
- LET cutting out just after start up
- E16SE Parts & Tuning?- lightend flywheel etc..
- The good old cam snaped
- astra gsi loom removal?
- hydrolic clutch adjusting help
- Urgent Turbo Replacment Help!!!! again
- reboring an inlet manifold
- Calibra F20 in a Corsa B?
- XE Starter troubles
- Corsa 1987 1.0L ECU light
- eds phase 3 question
- Blocking off dump valve aperature?
- Corsa C XE/LET???
- Fitting instructions for Pace dry sump tank
- Will it damage my C20XE using magnetec full syn oil?
- Water pump knackered?
- wont start sri 16v red top
- is it ok to use z20let injectors on a standard c20let
- Simple Xe Mods
- XE/LET flywheel on X20XEV
- 1.8 SPi to MPi
- Supertouring Engine Swap
- Supercharging a LET
- Fuel tank
- Failed Emissions: Calibra Turbo
- SBD LET Cam fitting adivce
- Diesel INjector Pump on 99 Astra Turbo Diesel
- f28 linkage mount urgent help
- Very leaky F16 gearbox
- c20let lifters
- LET & F16 - What clutch/fly setup?
- hesitation under boost and cutting out let
- Exhaust Flanges..
- checking cam profiles
- has a cav turbo got a fuel pump relay?
- what size thread on spark plugs
- Anyone got a pic of the nut on the turbos oil inlet?
- loosing power
- Carbs
- cav gsi fuel pump earth
- bloody astra turbo
- intercooler question
- Cam spec'ing
- head swap ?
- YB Cosworth fuel press reg part No.Required
- gsi cav fuel relay
- more power. 2.5 v6 omega?
- Not Vauxhall but engine related.
- Fault Codes - 22, 33, 35. New head just been put on.
- How much boost can i run with...?
- EGR VALVE
- Big Oil Leek 1.4 Sport
- Corsa C Gear Linkage repair kit
- Twin 45s on 20XE in a Nova - What linkage to use?
- How do i remove a EGR valve from a corsa GSi
- The reasons synthetic oils are better
- C20LET Starting Problem
- XE into Corsa questions
- Where do this go in a C20XE
- cams - which ones
- 1.4 nova sri head onto 1.2 8v corsa
- Air Con Refill LOW/P Valve .??
- C20let Thermostat
- T34 turbo fitment into mk3 astra
- Air Inlet Temperature Gauges?
- help my gsi fuel pump plz
- c20xe power cap question
- Calibra De Cat Pipe... ?
- nova cam
- Mugel Fuel Pressure Regulators Are They Good For The Let
- what does a std xe fly wegh, both pot and flat types please
- Nova C16XE - Exhaust bore size?
- Gearboxconvert (help)
- Corsa 1.0l 1997 ECU light problem - ongoing
- copper fuel line & mot problem
- ecotec cally running probs.
- 1.6i 8v SPI ENGINE CODE PLEASE?
- Carbon Canister
- evo5 chip
- Are x20xev & c20let crank sensors the same?
- Astra sport 1.8 16v questions
- Need help clarifying a fault on calibra Turbo!
- LET Head with XE Bottom End
- anyone dropped an x20xev into an 8v corsab???
- Vectra V6 3.0 with F28 6 speed box.. advice please!
- how to tell if my head has been skimmed
- Why would an alarm be connected to the ground actuation for an injector?
- LET to Nova Wiring - Just wanna check!
- corsa xe starting problems help!!
- calibra lifters
- whats my fuel pressure??c25xe
- poor running evo 5 let
