- fuel tank for xe corsa
- Mk1 Astra c20xe conversion
- What engine?????
- LET missing in 3rd gear
- throttle pedal?
- xe cams interchangeable?
- let conversion
- Where to get 90 degree brake pipe unions?
- c20LET FLASH CODES HELP PLEASE
- Corsa B GSi 16V - which mod - inlet manifold or dibilas TB's?
- tuning a 20seh ???( 2.0 8v 130bhp)
- what part number is the 440cc injectors (green's)
- Is it worth doing resistor mod on PH2 LET?
- all c20let owners please help
- c20let conversion! do i need f28 box?
- EDS phase 1
- xe\let conversion?
- 440cc injectors on C20LET causing error code?
- will i need uprated oil pump on SEH turbo??
- R reg Astra GSI and a LET
- Anyone got a link to diagram of a redtop engine??
- Turbo for x20xev
- x20xev with c20let injectors
- C25XE / 3.0L Cams???
- corsa b exhaust manifold cover
- fuel pump problem
- Sump plug fell off??!!!
- How difficult is changing a cambelt???
- HELP!!! My oil feeder pipes got a split in it
- calibra 2.0 16v ecotec fault codes
- Nova 1.4SR running on - Reasons/cures??
- Injector ticking
- c20let in my (20xe 16v Calibra) electrical problems...
- new tappets but still its tapping
- ive put phase 2 chips in and it runs rubbish!
- Exhaust cam dizzy
- astra coupe 1.8 tuning
- estimated bhp??
- Astra mk3 Ecotec -> 20LET
- Changing Oil Pump - Nova 20XE
- These Chips Any Good???
- Spraying engine parts!
- superchips in a LET, opinions
- What does boost cut sound/ feel like?
- power boost valve
- corsa gsi - no spark
- C20XE injectors
- car smoking inside and engine management
- Nova 2.0l XE ECU warning light not working
- phase 2 actuator setting
- C20XE
- running the radiator fan constantly
- Head Bolts?
- C20XE Corsa Overheating / Not running correct
- Porous head?
- Torque Settings For An Xe ?
- boast valve
- nova flywheels
- 20NE sump gasket on LET with ARP's?
- let with fmic making the pipes!
- C20XE corsa
- Tigra indicators
- AFR lambda readings
- Which sensor is responsible for... (c18xe)
- Problem after Engine Rebuild
- frontera intercooler fitting z20let
- Valve guides
- Calibra V6 Redtop Auto-Manual Conversion
- 1600 mk4 astravan engine conversion
- Which F20 Gearbox Oil?
- Phase 2 Headgasget
- C20LET/XE/XEV crank sensor trigger disk pic needed asap
- what alternator fits on redtop late type bar 70 amp???
- Help Gearbox problems.
- What parts exactly for F28 FWD conversion?
- Oil pressure sender units folks..yay?
- e16se rebuild, parts and - what oil to run in?
- are all c20let air flow meters the same?
- Anyone used these for remaps?
- where is my fuel pump (XE)
- Engine problems - please help (cavalier)
- Let FPR - Cossie Weber
- front fk coilovers on an astra g , problems! clunk
- Turbo Input
- corsa xe oil sensor???
- 1.6 astra engine noise?
- Dis pack on c20let
- 1998 1.4 astra overheating
- let-how can i make more torque?
- Crankchaft pulley
- High lift cams in stock xe?
- Xe cams in a let??
- X16XEL - astra sport engine problem please help
- diesel and turbo's, gen me up please 8)
- 1.7TD Izusu fuel related problems
- Bolt stuck in crankshaft pulley
- X20XER, girdle ???
- Flow rates for 1600 engine and xe
- Diesel Gearbox on a Petrol?
- Diagnostic results for my 2.0 red top..code 93 Phase sensor ..Please advise!
- c20 xe into astra mk3 no spark!
- Turbo Talk. This Kit, Yes or No?!?!?!?!
- xe head
- baffle plate on xe,
- Nova XE Radiator Top Hose
- what will happen to C20 LET First Gear Cable
- F20 gearbox into vectra sri
- Mk3 astra GSI-T uprated fuel pump (044) questions ?????????
- Changing a Lambda sensor on an Astra mk4 (z18xe)
- bad fuel consumption
- MK4 Astra engine electrical problem.
- C25XE Doesn't start BUT in ON without the key
- oil temp wiring help!!
- how many parts in a v6 veccy exhaust stystem?
- PINKING
- 5 stud convertion - i do fancy turbo rimmage
- Grrr Whining Belt Noise With A Grinding Sound And Crazy Revs At Idle
- gearbox problems.....??
- EDS p2 Fuel pressure setting ?????
- apexi induction kit???
- Clutch question
- Corsa 8v SRi TPS & ICV q's...
- clutch for F15?
- TPS sensor readings...
- Calibra turbo and this weather
- EGGS !!!! Fried cooked burnt loom short
- big let problem help please
- fuel reg vacuum and pressure ???
- turbo oil leak on a c20let
- odd c20let problem..just a quickie
- Quick question regarding EGR valve...
- Collets. God damn.
- f20 or f28????
- XE management gains
- Phase sensor problem
- Centre exhaust box on a corsa
- Problem with timint belt... (IMAGE)
- let tuning........ in a boat
- let problem
- V6 Clutches
- Coilover springs
- e16se and c16se - differences?
- noisy f20 gearbox
- ecotec cam pulley pictures?
- Fuelling
- Corsa XE rev counter wiring???
- Nova LET Peeps - Turbo to AFM Pipe
- Anyone been lucky and not had valves say hi to the pistons?
- 2.5 ltr cams question
- on an xe with LET management and k16.....
- Xe Fuel Tank Ventile valve onto LET!
- carbs
- F23 Bellhousing interchangable?
- C20 LET no EM light after cutting out
- Overfuelling calibra turbo?
- Headlight / Taillight Sensor?
- small bore tuning!! 1.2 nova
- Does my timing look ok ? LET (pics)
- Are MK3 astra indicators 581 fitment? (offset)
- Help Me Info On Fitting A 2.5 V6 Engine In Corsa B Please
- cts on a zafira
- samco hoses or simillar
- Decat Pipe
- Which mounts ??? XE into tigra
- c20let dump valve
- ZLET Bottom End Vs ZLEH Bottom End
- Celica losing water and oil (non Vaux)
- txb clutch strength.
- Fuel Mapping
- do you REALLY need a cat to pass an mot?
- list of parts on a let bottom end
- what bhp am i running
- tuned nova 1.4 bhp question
- GSI conversion, loom and ecu... help!
- pinking when engin is cold
- Non Vauxhall Engine conversions
- FPR + Injectors info please
- 350bhp turbo kit
- corsa fuel cut off switch
- blue smoke after re-bulid on c20let
- wot would be best rad for astra turbo
- V6 Noisy and Flat above 4500rpm - cam timing?
- LET Chip identification / 5th injector
- 20xe block and 1.8 block
- LET / Nova won't start !! Help !!
- Best Blow Off / Dump Valve For standard C20LET
- Spark Plugs For XE!?
- F28 Gearbox Conversion?????
- Putting XEV back together
- damaged fuel pipe
- Best Throttle Bodies
- Astra MK3 Gearbox Mount
- oil connector
- Whats the fan diameter for the main rad fan on a Z20 LET?
- speed sensor wire on let loom
- please help people car playing up
- X16XEL into nova
- coscast turbo head on xe, possible?
- just got my c20let running, bit of blue smoke though
- nova cigarette lighter
- Cav GSi fuel leak! Where to look?
- Phase 3 on a standard turbo??
- e16se wiring loom and ecu
- engine rebuild do i need to
- Astra GTE oil filter 16V/8V
- fuel question???
- Wiring engine management light up??
- Oil labelling explained
- bike carbs on 2l 8v
- Fitting Dbilas Intake Manifold to c16xe
- will this work?
- ***live Fuel Rail***
- C20 XE Reving Problem....... ANYONE PLEASE HELP
- XE plugs in a LET???
- gearbox oil level
- 20xev ino corsa. Do i need cally turbo idle sp..
- nova xe engine mounts
- will a mk1 gte 1.8 head fit a cav sri 2.0 block?
- tigra xe cuts out after 20mins of driving (v tuning done conversion)
- head gasket replacement c20let
- Injectors
- changing head gasket on 1.6 8v
- Calibra Turbo 2wd Conversion
- X10XE Annoying ticking noise
- temporary XE fuel pump...
- Calibra Gears/Clutch
- Z20leh Into Vectra B?!
- What should my C18xe be idling @ ?
- c20let, ABS not working! is it just a sensor?
- Sensors - at what engine speed related
- Calibra Turbo Speedo + revs+fuel gueages not working
- C20LET TPS Sensor Bosch number need
- c20let speedo
- Oil cooler pipe trouble
- popping out of second gear help
- Strange Project of 240 bhp c20xe without tb's (photos of custom intake).
- diesal oil
- spark plugs for phase 3.5 LET?
- difference between xe and let block
- New Fuel Tank fitted.. now got fuelling problem
- what boost to run on phase 2 eds
- Mk3 astra engine swap - whats involved?
- 140mph clocks on f28
- corsa sri - engine gbox, what should i have?
- Carlton GSI no start (fuel pump/relay?)
- 2.0 xe wirring diagram ?
- LET help please EM light comes on at 5K rpm
- X25XE Erratic idle problem
- C18XE hunting and stalling
- nova afm
