Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. Recommendations for a QUIET performance exhaust?
  2. Any info on doing a V6 conversion into a corsa
  3. corsa/tigra uprated engine mounts
  4. let can smell fuel when putting my foot down
  5. Latest style Bosch wiring connectors
  6. Crankshaft sensors
  7. nova gte engine into a corsa
  8. K16 Turbo Query
  9. c20let - advice
  10. X10XE - Mixture too rich? Please help!
  11. Clutch on astra
  12. Vectra diesel r reg, clunking noise
  13. Radiator fan resistor
  14. Cally 16v Clutch problem
  15. Wanting Phase 3 or Evo 5
  16. blue smoke from my astra coupe turbo
  17. Another LET Holding Back
  18. Fuel pump damper?
  19. help with redtop late alt bracket fitting
  20. To Buy Or Not To Buy A C20LET Engine?
  21. Nova LET, Boost problems ?
  22. Best intercooler's for c20let phase 2 eds set up
  23. LET fuel relay..same as other vauxhalls?
  24. Which Intercooler for STD C20LET
  25. 1.8 SRi vectra engine in a corsa???
  26. Best way to kill a clutch?
  27. Camber kit problem calibra turbo (cav-16)
  28. what rwd gearboxes will bolt straight onto a xe bigblock or xe smallblock. thanks!
  29. Attention anyone building or recently built a C20LET or C20XE...
  30. need to lock my transfer box!?
  31. random "tink tink" noise x20xev
  32. Vac pipe - where does it go???
  33. What Happens When A Piston Hits The Head
  34. leaky xe sump
  35. Which engine in 1.6 astra gls auto? x16xe? quick response needed!
  36. c20let seems to have to much pressure building up?
  37. LET and F20 Clutch
  38. Clutch slipping when pulling away
  39. is it dangerous to drive with my fuel vacuum pipe off
  40. Smoke from my Corsa GSi C20XE
  41. crushed fpr still reading 2 bar
  42. Engine management light?
  43. 16xe wiring - in a mini
  44. Questions about a diesel Cavalier
  45. Cam Belt Interval??
  46. lost 1st and 2nd gear (corsa c yreg)
  47. Should the clutch release bearing be loose?
  48. C20XE HG1 type block
  49. corsa, f28 question
  50. Petrol flap wont open!??
  51. vectra gsi 2.5 v6 hesitating and reving like its missing...
  52. crazy positive camber!!!
  53. Why is this happening ?? LET probs
  54. help! CANT GET ENGINE MOUNT BOLT OFF!
  55. let service
  56. C20LET What oil pressure?
  57. injector issue
  58. Resistance curve of 1.4 1.6 16v engines
  59. LET Not Boosting
  60. c20xe hoses
  61. LET sump removal..
  62. Fuel tank vs fuel cell
  63. Bad Smell Of Petrol
  64. Gearbox differences
  65. surely someone on here can make a inlet plenum
  66. Mystery Air Leak - C20XE - Correct diagnosis gets beer....or summit...
  67. Aerodynamics vs Gear Ratios
  68. x14xe and x16xel heads the same?
  69. fao astra mk3 turbo c20let owners
  70. Dump valve between turbo and I/C?? Discuss
  71. Garrett GT2540r -Opinions please!!!
  72. XE underdriven single V alloy belt pully?
  73. GTE 16v fuel pump relay questions....
  74. Knackered clutch cable?
  75. problem getting 5th gear in my F20
  76. Phase 3.5
  77. Help! Which hydraulic tappets should I use?
  78. cambelt info
  79. Help C20let Engine Number
  80. Phase 2 Astra GSi Heated Seat Loom?
  81. Cav Turbo Gearbox problem
  82. creaking corsa clutch
  83. Should a x16xe ecu prime the fuel system on ignition
  84. mk3 Astra Clutch arm
  85. Gte wont start!
  86. what spec are people running on evo 5 chips?
  87. astra gsi chip help
  88. Corsa redtop drive shafts q
  89. garret t3
  90. taking inlet manifold off, help appreciated :)
  91. How to remove egr from a mantzel intake?
  92. 14nv Cam trigger setup
  93. c20xe hoses
  94. What does low fuel pressure do?
  95. 1.6 8v engine into a 1.4 spi astra
  96. Is the lack of CAT causing my misfire? (Astra GSI)
  97. corsa xe: oil sensor and lamba sensor?
  98. Calibra wont start
  99. changed the plugs & leads and still got a misfire!!!!!!!
  100. E16se loom - whats this plug for? (Pic)
  101. whistling intercooler?
  102. Cav/Cal Garrett Turbo downpipe !!
  103. Matheus428 Turbo conversion
  104. Can a C20LET be run on a coil pack?
  105. Sportex exhaust help :S
  106. help what redtop ecu is gq?
  107. FAO Matt,Chip Beardy,Jamie,Anyone with knowledge of cams
  108. differences in xe in astra and corsa?
  109. corsa c20xe
  110. C20XE Sump Gasket Leaking
  111. Can I use an aircon radiator for conventional cooling?
  112. C20let engine problem
  113. XE running 'flat'
  114. C20LET alternator question
  115. Bosch B775 ht leads
  116. x16xe conversion problems
  117. cam belt advice
  118. c20 let chips
  119. Coil pack reliability
  120. which exaust and wat power gains??
  121. Damaged Block on C20XE
  122. taking alternator off redtop ASAP
  123. fitting frontera cooler and apexi to cally turbo
  124. C20XE aircon pump..
  125. Corsa 2.0 Xe Engine Problems
  126. C20let boost dropping off
  127. c20xe engine mods ?
  128. Oil pressure switch......
  129. Recommended spark plug Gap?
  130. Fixing up a redtop...
  131. turbo brakes
  132. Engine Problems (C20XE) - Please help
  133. 1.4 16v nova conversion
  134. cam timing
  135. k16 recirculation valve question
  136. Help Need engine mount for corsa 2.5 v6
  137. corsa c sri 1.8 16v gear ratios????
  138. Throttle boddies on a C20LET
  139. Genral Q about injection
  140. LET Coolant Pipes
  141. Oil Leak Between Block and Head?
  142. Breather mod on Let. SBD way???
  143. What engine to turbocharge?
  144. C20LET Compression Test Results - WTF?!
  145. FAO Anyone running SARD fpr
  146. power mad!!!!!...what do i do next
  147. what flywheels better on xe?
  148. Engine Management HELP!!!!!
  149. Cam Box
  150. carbs or throttle bodies
  151. Fitting F20 speedo drive ring on to F28 - Why ?
  152. Nova XE coolant loss problem
  153. Intercooler fitment .
  154. Omega sump gasket replacement
  155. spring rates (on coilovers)
  156. Nova XE wiring..
  157. power gains for 2.0 16v c20ex engine
  158. Compensator Valves (Newbie)
  159. 14 spi engine management light problem high reving
  160. Zlet precat fitting? Early models - welding experts opinion
  161. kent cam bhp gains
  162. Hmmm, Just found a clutch plate....
  163. nova coilover assembly
  164. possibly burning oil..... whats the most likely cause?
  165. c20 let conversion
  166. dastek unichip remapping info please
  167. update of my turbo k16 problem *piccies added*
  168. z let oil pump on c let
  169. i have found a f16 box but is it the right one??
  170. Let in a corsa what fuel pump??
  171. EDS Phase 3,5 boostlevels in step 1-5?
  172. Vauxhall Astra 1.6 Sportshatch
  173. calibra sump advice...
  174. what is needed to turbo a seh
  175. working out fuel pressure
  176. intercooler for Corsa
  177. F20 Problems
  178. fitting F28 into nova
  179. flange - exhaust blowing
  180. Calibra turbo manual
  181. does anybody do rebuilds
  182. can anyone help will 16 astra eco sump fit seh?
  183. anyone kno if v6 alt fits onto redtop late?
  184. c20let smokes in leicester but not in norfolk :confused:
  185. did your let splutter with new bosch green injectors
  186. Corsa B C20LET Q's
  187. Exhaust making dodgy noises
  188. xe cam in turbo
  189. oil pressure switch question...
  190. c20seh cams
  191. Exhaust help
  192. turbo power ratings
  193. C20XE Overfueling
  194. bosch greens let did they work straight away or cause running problems
  195. bosch greens let bogs down onhigher boost
  196. C16 Xe Gsi Help
  197. Corsa LET conversion
  198. mk4 xe conversion
  199. Valve Depresion Tool - Camshaft Removal
  200. diffrnce in 2.0 in tank fuel pumps?
  201. x20xev with weber carbs
  202. improving a vectra phase one gsi msd...
  203. how to connect up a mbc controller
  204. How Can I Make My '96 1.2 Corsa 'b' go faster?!?
  205. gearbox needed
  206. E16SE into C14SE corsa B - Urgent help required
  207. tigra c20xe conversion questions
  208. Turbo Gaskets ?
  209. the rev count has stopped working after c20let conversion
  210. the range has stopped working in mymk 3 gsi
  211. Let tuning ideas please
  212. headgasket on X18XE
  213. corsa 1.2 16v t reg replacing head need help!!!!!!!!!!!
  214. Nova C20XE running issues!
  215. starter otor problem
  216. misfire on c20let running phase 2
  217. c20let problem
  218. valver
  219. Vernier cam timeing on Standard Cams
  220. xe problem sound familiar
  221. Wiring the round plug in the Astra GTE loom into a LET loom?
  222. Nova GSi T40 Carb Settings
  223. air filter or not?? on throttle bodies
  224. Unidentified part...possibly MAP sensor?
  225. Non vaux - Golf VR6 fuel pump...
  226. Fan Belt
  227. Fuel Leak (Vauxhall Corsa)
  228. F20 Trouble
  229. 2.0 XE ECU light not illuminating.
  230. Engine missing/being very jerky...
  231. HELP fitting chips to LET Motronic ECU
  232. xe gsi stalling problems
  233. C20let / Evo 8 Tubular header
  234. funny stuff in gearbox
  235. calibra turbo wheels from halfrauds
  236. Atb Lsd F28...
  237. head trouble
  238. bosch super 4/c20let?
  239. C20XE corsa
  240. Brake Fluid - is Dot 5.1 too good for a diesel?
  241. c20xe throttle body
  242. C20LET Help - Please Get Me To Billing!!
  243. Help!! Code 117 - AMAL valve shorting out but don't know where??
  244. C20XE exhaust conexion in a Corsa B
  245. c20xe and x20xev injectors
  246. pic request: x14xe, x16xe inlets
  247. anyone know a good recon turbo specialist
  248. Fuel pressure regulator noises...
  249. diesel engine swap
  250. Gearbox info
