Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. Oil for Carlton gsi 24v 3000
  2. Astra dti 1.7 turbo sounds like a dentists drill
  3. Exhaust Resonance
  4. Vauxhall engine blocks??
  5. v6 air filters
  6. S Reg Astra TD Engine code?
  7. XE/LET missing teeth position
  8. Anyone want to earn some money and beer? need someone to fit my gearbox?
  9. Corsa C20XE slight problem
  10. Air Filters and Exhausts...
  11. Exhaust sizes, back pressure and turbos
  12. fwd conversion kit,on a f28,info please
  13. More BHP?!?!?
  14. drive shaft problem still!
  15. Nova XE , welding seems , stupid question
  16. I need something fab'd - weld on velocity stacks / inlet trumpets (38mm ID at base)
  17. LET ICV/Knock sensor loom?
  18. xe cams in a let, how would it idle
  19. Head,block fluid tester
  20. What head gasket for 87.50mm xe pistons?
  21. let problem
  22. Replacing an F17 gearbox
  23. Frontera intercooler & z20let
  24. Replacing an F17 gearbox
  25. z14xe upgrade to z20xe
  26. Problem selecting gears!
  27. Do you trust you head gasket?
  28. could it be the head gasket
  29. Cam Technical Info
  30. pistons
  31. Hi RPM Turbo 8V!
  32. Fan belt Tension Pulley Mounting
  33. Who for crank regrinding?
  34. GTE engine help
  35. nova 2l 16v driveshafts came out!
  36. Best shocks + springs for astra 3 LET
  37. Info on 2.0 8v head
  38. engine temp?
  39. will an altinator off a corsa gsi 16v fit on a c20xe?
  40. F28 Electronic speedo - Cut wires... Help!
  41. seat belts
  42. 2.0 8 valve idle problem
  43. shopping 4 a new exhaust....?????
  44. shopping 4 a new exhaust....?????
  45. Air filter heat shield?......
  46. Power cap mod
  47. Engine identifcation help
  48. HID Headlight Installation
  49. Starter Motor
  50. V6 cavvy clutch!!!
  51. HELP!!! C20XE electrical problem
  52. Reconditioned/Remanufactured C20LET
  53. Diesel Wont Rev .please Help
  54. Aftermarket Fuel Pressure Regulator
  55. For Those Of You Who Think A Calibra Turbo Can't Launch Properly
  56. Identifiying Piper Cam..
  57. MVaux-turbo kits
  58. is this the tappets?
  59. exhaust recirculation
  60. xe problem rwd conv
  61. help please corsa gsi xe problem
  62. 2.0 redtop g/box onto a redtop 4X4 non turbo? will it go??
  63. Astra gsi engine question
  64. 2.5 v6 engine mods
  65. Nova/Corsa exhaust
  66. engine swap on nova question?
  67. 1600 NV pistons
  68. egr valve
  69. silicon hose kit for corsa xe
  70. Tuning the xe
  71. XE Corsa Carbs Or TBs
  72. c20xe crankshaft cap bolt torque settings ??
  73. Rocker cover to oil catch tank, Should you return it to the airbox or vent?
  74. Omega Irmscher spoiler brake light
  75. LET/XE oil level sump sensor question
  76. 1.8 Astra brake problems.
  77. engine conversion help + advice :)
  78. Testing a starter motor..?
  79. head gasket
  80. C20LET into an Astra mk3
  81. What turbo for my LET engine
  82. Random EML While Driving - Feels Like 50% Power
  83. Gearbox selector turret removal/refitting
  84. Vacum Pipe Came Off The Turbo Housing
  85. help me my car is broke!
  86. EGR valve on X18xe1 - problems
  87. Sensor on a X16XEL near the crank sensor
  88. chips - what does it do c20let
  89. torque settings for LET engine
  90. Does coil pack failure damage ecu?
  91. oil into water (C20 LET)
  92. Quick question, which oil for 41k zlet?
  93. f13cr clusters/cwp ratios/exhaust system/shafts
  94. what cars had a 2e3 carb or the weber equivalent
  95. let oil
  96. chipping my ecu
  97. Valve diameters ?
  98. help! any1 kno what the copper washer in c20xe headset is for?
  99. Help replacing crank shaft sensor on a LET
  100. Astra Mk4 - seat belt tensioner / air bag dash board light
  101. Corsa C C20LET F28 Conversion Info?
  102. [z20let]new turbo fitted now running high temp
  103. where can i get a limited slip diff for f16?
  104. Cav SRi to Turbo gear linkage problem
  105. timing belt 2ltr eco
  106. Urgent advice needed: X20XEV performance cams in Nubira (X20SED)
  107. engine out of top or bottom poll
  108. zlet oil filter thread size?
  109. engine removal, best way?
  110. xe plug gap?
  111. Post Engine Transplant Problems
  112. x14xe tubz
  113. cylinder head
  114. f16 on a c20xe
  115. Corsa linkage problem
  116. Chips installed, what now?
  117. mixture screw location on pierburg 2e carb ?
  118. Using existing FPR on C20lets ;) *maybe* to higher/lower ur pressure...
  119. will a dicky coolent sensor cause boost/misfire problems??
  120. copy mantzel powerbox
  121. xe corsa top hose
  122. idling problems on a 90 cavalier 1.8 peirburg carb
  123. symptoms of dirty/nackered injectors
  124. What should the normal oil pressure be?
  125. Viva / Magnum LSD axle options??
  126. 4x4 4wd ecu scheme c20let
  127. Help C20XE Runing Problem
  128. Fuel line question on Corsa
  129. C20XE Engine Management Light
  130. c20let problem - 4wd light on
  131. dump valve prob
  132. vectra clutch bleeding problems
  133. sheared bolt head. any advice or tips?
  134. mk4 astra gear problem - EPC
  135. How To Check A Diesel Pump On A Vectra
  136. lsd on seh?
  137. Does my fuel pump only prime if there's fuel in the tank?
  138. air con - how long does it last before it needs regassing?
  139. injector cleaners, which one to choose?
  140. Clutch change on C20LET with F28 FWD
  141. nova excessive negative camber on one wheel
  142. my rear diff 4x4 cally turbo
  143. X18XE1 Z18XE Crankshaft Speed sensor
  144. steel head gasket
  145. CORSA XE
  146. Oil Pressure test? (zlet)
  147. Fuel pressure running issues
  148. Corsa XE hub and cv problem ""HELP""
  149. Fuel lines to XE fuel rail
  150. c14se plug gap?
  151. Converting a Manifold??
  152. XE Timing Belt Slackness
  153. C16XE into Nova
  154. HELP with the ideal Xe exhaust
  155. corsa 1.4 8V and 1.4 16V...Can they be swapped
  156. Ideal exhaust bore size for X20XEV?
  157. courtenay v. stock cams - Turbo - details?
  158. Tigra 2.0xe with A/C?
  159. XE cream injectors
  160. Cts Been Through The Wash! Xe
  161. wierd C20LET boost problem
  162. gearbox question - what would happen if....
  163. This the adapter to fit my oil pressure gauge?
  164. corsa C20XE
  165. does a saloon exhaust system fit a hatch?
  166. Carb mounting
  167. best place of person to buy a set of new pistons
  168. viper induction kit on a c20xe???
  169. redtop/XE conrods questions - big end diameter? rod length? also rod experts please..
  170. crank sensor on x20xev.
  171. LET part name
  172. F28 torque settings?
  173. XE SFI box rubber thingy
  174. Gearbox Recommendation please
  175. Mk4 astra engine transplant...
  176. C20XE: error 94: Hall Effect Switch - High voltage
  177. running let with xe manifold
  178. vxr220 into Astra G mk4
  179. 1.2 spi has snapped rockers ::::000000
  180. 03 Astra Coupe Starter Motor Trouble
  181. astra gte c20xe,sump gasket leaking help?!
  182. astra radiator
  183. anybody had the z18xe 140 bhp remap?
  184. urgent help needed with c20xe please traction control!!
  185. carbs advice needed
  186. C16XE sump Q
  187. cam belt and water pump change....
  188. zafira oil change
  189. What intercooler for Phase 2
  190. Z20 LET missfiring, any ideas?
  191. Let fuel pump - opinions please
  192. Best carb for this...(Nova engine)
  193. shot peaning rods - wont it **** up the bearing surfaces?
  194. How big is an LET throttle body?
  195. Priming A New Turbo -- How???
  196. Gearbox change in MK3 Astra Turbo
  197. Hydraulic lifters in a zlet?
  198. fitting intercooler on a c20let with air con
  199. C20XE Oil Feed for Turbo
  200. XE fault codes
  201. titanium valve springs retainers
  202. Whistling inlet/throttle body
  203. Stud snapped off in head - how to remove?
  204. vectra engine v6 out
  205. Help installing eds chip
  206. Fuel lines are they the same?
  207. F28 ONTO XE (how ??????)
  208. Anyone who has done the 2.2 airbox mod on a zlet...
  209. tdc points of an astra sri 8v
  210. Nova gsi engine into 1.2i straight fit??
  211. Astra Mk3 1.6 fault
  212. Nova Spax coilovers
  213. Will an astra sport (1.6 16valve) oil cooler be a direct replacement for a LET one?
  214. uprated fuel pump
  215. overfueling ???
  216. let into astra gsi, project list of parts required?
  217. Air Con Clutch Problem. Astra Mk4
  218. which gear linkage set up to use on cavalier witha retro fit C20LET/F28
  219. Astra Chip - Anyone read German?? :)
  220. corsa c sri 1.8 16v performance
  221. HELP - Motronic chips... wich one is wich?
  222. corsa xe conversion
  223. xe idle problem
  224. EVO5 chips - fueling question
  225. let tight fit
  226. anyone ever weighed an f28 and transfer box?
  227. C20Let stock cams data?
  228. XE Manifold Help
  229. intercooler best one? buy from where?
  230. let overfuelling at 2.8 bar is 2.4 ok
  231. 1.6 8v astra g aircon ???
  232. Losing cam cover breather to turbo pipe - what about amal valve?
  233. Nova LET / F28 clutch slipping ?!?
  234. Throttle position sensor big block vaux's
  235. Info Needed v6 turbo?
  236. Nova XE problems still......
  237. Cracked Manifold
  238. Which precat replacement courtenay/regal/lmf? (astra g gsi)
  239. Air conditioning Low Pressure Port Location mk4 astra turbo
  240. bad running and strange rattle on let
  241. which exhaust for astra ?
  242. Alternator queries for 1.6 16V Mk III Astra
  243. c14se questions...
  244. Strange XE Problem
  245. How to tell if theres something major wrong with the head and not just the gasket??
  246. another LET problem-
  247. intercooler question
  248. Injector wiring?
  249. 1.5TD - need help (strange engine noise)
  250. Ive got purple injectors on my XE 'CONFUSED'
