- X16XE spark plugs - every 40 000 or 4 years?
- car juddering badly
- 2.0 diesel boost problems?
- smoking engine??
- Let Running Problems
- Adjusting Actuator ?
- c16xe engined kit car???
- Late Vauxhall ECU's.. Strangeness..
- engine oil for c20xe
- engine cooling fan wont cut in!
- clutch problems
- calibra turbo 4x4-compression figures
- calibra turbo 4x4-- not starting
- Blown engine, part 2
- XE into corsa 12v fuel pump wire where is it?
- on the LET manifold is there a reason for ...........
- Can I use Quicksteel (Metal Epoxy) on a split oil pipe on cav sri?
- Which oil in my let? I have 15w40 in, is that right?
- water pump probs on sri 130
- C20LET Code 116 - Boost preasure too high, What do i do??
- SBD throttle bodies prices, are they worth it???
- M.O.T and engine conversion
- Matheus group buy clutches - balanced?
- will unplugging tps cause any problems?
- XE Timing Advance
- c20let boost
- exhausts
- Help, engine mount issues - mk3 Astra Turbo
- Getting around immobilisers in engine swaps....
- Lambda / Oxygen sensor
- catch can problem?
- calibra ecotec probs
- when oil heats up does pressure rise or fall?
- 2 litre engine into corsa Gsi
- Engine problems
- 9 pin block connector for engine loom ?
- C20XE corsa
- x20xev cylinderheads please help
- XE and Ecotec inlet manifolds the same?
- pistons and pins
- XE Oil in water and head OK
- Valves, Where from and how much
- nova xe running crap!
- 1.6 cam in a 1.3??
- changing fuel filter on Corsa / Tigra
- breather on a c20xe camcover
- Wheres the Tophat pic gone all labelled up?
- Turbo Fueling / Management Simtec 56.5
- Champion GTE change head to coscast or not??
- Gearbox Slave Cylinders
- cavalier coilovers
- Help!! Air con relay location - Corsa B
- C20let nova
- Different Injector Colours
- need help on my engine again
- astra mk4 bonnet catch
- astra m4 de-cat
- throttle body mod to ecotec
- dbilas throttle bodies on a let
- 3.0 V6 Cams, Part numbers?
- warning light lights up when the engine is hot
- 1600 16v head
- ne1 who as done a c20xe into a corsa i need ur help pls!!!!!
- Car feels very underpowered :(
- Egr Problem Help
- standard vauxhall (non forged, non machined) pistons - will they take 200hp
- smallblock xe rods - will they take 200hp?
- ST200 X25XE help required!
- Engine Mount Q
- Blown engine, much help needed
- intercooler Repair
- 1.8 astra weird engine noise
- 99 Astra 1.6 16v. Cheap power upgrades ??
- another loom
- C20XE oe manifold
- let ecu chips
- mk4 astra 12mm camber suspension bolts ??
- Many problems in my Corsa B XE conversion
- C20XE only firing on no.1 cylinder
- corsa c 1.8 16v oil?
- Engine conversion diagram or help needed
- which injectors to use in an xe?
- 1.6 8v spi to 1.6 16v, whats needed?
- Cavalier 16v XE Rear Engine Hose
- 1600 turbo pistons
- turbo wanted!!
- new dump valve....wont idle right
- C20XE fault code 31 ......
- GSXR 750 injectors
- xe nova running problems.
- 2.0 16v ecotec oil pump same as 1.8 16v ecotec
- What mount for F28 into V-plate corsa?...HELP ME!
- How to recognize inlet/exhaust cam
- XE Loom to Nova Sr..
- Mk 4 GSI Turbo more power wanted, ideas??
- Performance Fuel Pumps
- SFi/ecotec pipe/powercap debate.
- 'Performance' Gaskets?
- cometic headgasket
- Timing belt on c20LET
- X16XE Exhaust manifold
- Engine problems C16XE
- Wtf? Whats going on with this XE Camcover?
- help with removing the oil cooler off a c20xe.
- xe exhaust manifold gasket help plz
- Cleaning head/block surface
- f28 question
- Let ecu plug diagram
- F20 exploded diagram?
- Fuelling/tuning????
- xe sump still leaking !!!!!!!!
- Nova LET, Boost or Clutch probs ?
- turbo conversion
- paper clip test not working
- Fault Codes?? Astra 1.6 16v
- Carburettor help........
- Engine balancing
- Adding Synthetic oil to normal mineral oil
- S144 Hybrid actuator question
- cam numbers
- corsa xe conversion wiring help needed
- C16XE Idle problems
- astra gsi mk3 f28 fitment
- **CHECK**crank sensor??????
- valve spring compressor
- Corsa sri 1.4 misfire...
- c20 let cavalier smokeing sometime
- C20XE... engine number code? What means mine?!
- let fault code 113
- Will air/fuel mix flow over a wooden surface
- let intoo a corsa help needed
- What Fuel Pressure for a Phase 1 LET
- Problems with C20XE Engine conversion
- C25XE - X25Xe
- More advice needed (RE: Nova engine)
- astra mk2 digi dash into mk1 nova xe
- Corsa b clutch peddle.
- Another ecotec fault code, just for good measure
- setting up the carbs on my xe
- C20 LET into corsa b
- ecotec code 73 (cav)
- F20 Gearbox - Difficult into second gear!
- Are all F23 gearbox's the same off Z20 LET's?
- Z20LET engine misfire and hesitation under high boost at high rpm
- Well, think I found that elusive 'hot oil' smell
- mk3 astra eco to redtop wiring?
- vx220 engine is hunting
- uprated driveshaft on nova snapped
- C20let head
- How to turn up fuel pressure on a let
- which rad for corsa xe
- xe/eco =?
- Turbo help
- Removing late C20let alternator
- coilovers and camber ....where can i get?
- No rev counter Mk3 astra LET
- cav gsi exhaust plz help
- Predictable ecotec.....EM light
- LET hose & rad question
- c16xe idle control valve
- oil light....stays on after start
- changing v6 tappets help
- EDS phase 2 battery issue
- astra gsi (red top) starting/running problems
- C20LET fan not working at low speed
- New Throttle Body
- V6 cam upgrades
- 1.8 vectra keeps cutting out
- Removing T/C throttle body help please
- locked transfer box! how can i tell if it is?
- C20XE and Corsa PAS HELP!!!
- egine advice pleaseeeee
- gearbox and shaft problem
- astra F turbo diesel possible fuel pump problems??
- oh crud, removed crankshaft pulley, not lined up
- Fe*king LET.... Again..
- gearbox identification
- Let Oxygen Sensor
- my XE dont like oil!!!
- 2.2dti vectra (03) timing belt
- Head Gasket
- Late Omega 2.2 (52 onwards) Engine Management
- c20let into corsa c
- Injector cleaning
- engine moutin kit 4 a nova needed
- what the best way to double pump the tank ??
- Pajero fuel filter , kinda urgent .
- Moving waterpump, need to change O-ring?
- Astra 1.7 dti intercooler upgrade
- LEESTURBO (cant find those 2 16mm bolts)?
- Calibra turbo, problem from cold
- urgent!! what coilovers do i buy??
- Where do i go from here!!! C20LET
- No oil pressure (LET)
- cleaning mating faces of head and block?
- X16XEL EGR Valve
- engine blown at Nurburg
- C20LET Cambelt lost tension
- Vectra X20XEV Engine loom plug wiring diagram needed
- nova gear linkage,easy one for ya
- Vectra clutch and knocking noise
- X20XEV won't start - injector voltage
- c20 let wont start.
- Exhaust technology - DTi
- how much coolant/anti freeze in a x16xe?
- c20XE CORSA PROBLEMS
- astra mk3 stuff on to a mk2 & diesel problems
- more power!!!!
- zlet not running properly
- Induction noise plz read ;)
- 3.0 MV6 Inlet Manifold number ??
- c20let smoking
- Fuel tank problems .
- Passed MOT - But Clunking Gearbox?
- fse power boost valve adjustments?
- astra 1.6 16v idleing/cutting out
- Nova - LET / F28 Clutch slipping ? why ?
- opening a f28 gen or pics / how to.
- have i just broke my gear box
- Z20LET help is this the ecu?
- XE Head to L850 (VX220???) Block
- how to install arp rod bolds??? info needed!
- fuel problems
- will an F28 mate to 2.0 8v?
- Girdle on the X20XEV
- Motronic v's Simtec ECU Pinouts
- can a coscast head have gm on the side of it?
- XE/LET air flow meter....
- xe conversion fuel pump problem
- rough z20let idle
- Misfiring, backfiring c20let. I'm bafled.
- C20let fault code No 24...
- C20LET corsa with high tickover?
- Let Wiring Help!!!!
- 250bhp let
- HELP PLEASE C20LET calibra 4X4 Cable connections
- LET limiting to 4000RPM
- What bolts? Gearbox to block
- need help with c20 xe idleing problems
- X18XE1 / Z18XE Oil filter Housing
- c20xe engine conversion.
- LET alternator wiring??
- Too much pressure in fuel tank.
- gsi cav exhaust help plz
- Accralitte pistons how much tolerance to overbore
- tigra 2.0 16v ecotec conversion help needed plz
- Torque setting for star shaped headbolts
- Astra td low pressure turbo
- Building a Z20LET
- 3" free flow exhaust + 4-2-1 + superchip = 30hp - eh?
