- 2 x let boost problems,advice needed
- Help, identify gearbox....
- will an xe die without its conrod oil sprays?
- astra x16xe-c20xe
- performance chips and cam advice on c20xe
- supercharging an C25XE, advise please...
- Which Cams are which.
- function of breather hose?
- priming engine/oil pump
- green injectors info
- Z20LET oil pressure readings?
- X reg 1.4 astra cutting out
- m-reg 1.4 L.S astra wit 2.0 8v cav lump no spark
- c20let conversion, need local mechanic asap!!
- drive shaft?
- quick question about gearbox fluid
- c16xe sump can i change it for a....
- f20 lsd
- oxygen sensor c20xe
- can i blank egr valve?????
- Technicall opinions please on this hybrid clutch..
- XE Still Overfuelling
- Oil Cooler
- C20xe Corsa, Engine Management Light On!!
- Crankshaft question on XEV
- Oil cooler pipe repair in the Derby Area
- snapped bolt on exhaust down pipe
- Cav Turbo Gearbox Change
- advice on fuel lines
- x18xe1 Turbo Pistons
- C20LET test parts help
- Vectra 1.8 16valve 96
- Active Exhausts
- what engine code do i have ???
- Acck! Adjusting Gears - followed guide but messed it up - as usual
- C20XE troubles.. HELP!
- fuel cell construction
- fitting an XE to a capri...
- Engine management V6 Vectra
- engine management problem on c20let
- 8v turbo - how to?
- C20XE Oil Hose Split
- Intercooler vs charge cooler
- helix paddle clutch on standard flywheel
- Anyone running a turbo'd C16se?
- Flywheel Chatter USA
- quick question on gearbox's
- just fitted a loom to a nova - some niggles though
- would 30 seconds of no oil pressure on tickover fook the crank and big end bearings?
- let-missfiring/splutterin wen boost comes on!
- corsa turbo conversion help
- Help Needed - Small Block Starters
- Corsa Sri 16v engine into Nova ! Help ?
- Engine codes
- Worth getting a lightened flywheel for a LET ?
- Cavalier fuel leak.
- Corsa engine code ????? help
- F28 Speedo issues
- Idle control valve or idle stepper motor?
- OK OK Phase 2 boost settings
- C20LET - turbo dead or alive
- astra 1.4 8v, wont start, ?
- turbo on c20xe or ecotec
- Fuel Computers....cav/cally
- c20let fueling / where to get webber fpr
- DIY Astra MK3 Camber adjustment
- changing vectra sri engine 1.8>2.0
- engine managment light wiring question
- Corsa C Engine Conversion,
- engine swamp
- Water pump .. How do u know its f***ed??
- Clutch removal on F18 box
- my new clutch doesnt fit my 20xe
- Setting the linkage on F28 in Mk3 astra
- Titanium Rods...how much would you pay?
- 16v headbolt
- 1.6 Civic not revving over 3k?!?
- breather mod???
- Astra 1.7 Turbo Diesel???????
- FAO Davey
- Oil pressure ok or abit high? c20let...
- nova gte gearbox problem/ linkage???
- cav gsi/turbo electric windows problem!
- Inlet manifold or Throttle bodies??
- C20XE Idles (just) But wont rev. WHY??
- ECU Remapping Question????
- standard let will it boost 10 psi
- who does corsa xe conversions?
- 440cc injectors from USA?
- MAP sensor on a LET
- nova xe to let
- Will 16V starter fit an 8V(2L)
- C20LET thermostat
- XE/LET FPR blanking plate
- engine recon..
- apexi boost by gear settings sorted
- Injector Ultransonic Cleaning
- X20XEV Head On X22XEV Block
- Induction Kits
- Turbo timers
- Head Gasket
- Live mapping a 3.0 V6
- what clutch do i need?
- please help turbo problem i could cry!!!
- Why would i get error 113 when Amal Valve is disconnected?
- Oil at spark plugs
- Clutch Slip when cold
- LET Automatic ?
- Fitting Chips 'C20LET' ???
- boost problem let
- What else shall i do to the XE?
- Penny valve questions... on c20let
- nova engine query!!
- xe starting problems
- Crank sensor help
- xe on 45's
- what do i need to cut of my new f20
- 1300 & 1600 cranks
- any idea why my car wont start.
- Crank pulley bolt size, is it E20?
- x18xe1 Ticking noise
- Question on cylinder head bolts...
- best Vectra Gsi Air Filter
- Astra c20 let overheating problems
- astra mk4 shifting linkage does it fit in mk2
- F20 box
- let-over fueling why? wots causing it?
- fuel lines
- m tech drive shafts for nova 16v???
- astra di/astra dti engine?
- C20Let into mk4 astra
- z20let sandwich plate progress...
- turbo?
- Nova XE gearlinkage problems
- f20 lsd help!!!
- C20XE Conversion Parts
- advice on engine conversion
- does astra gsi fuel tank fit astra van???
- red top flat spot??
- nova weber carb and head
- Lightened flywheels for XE, where from???
- ecu remapping
- LET into mk3astra Gsi,intercooler/eng mounts
- nova c20let mount! help!!!!!
- supercharged x20xev
- Smoking turbo again!!
- X16XE EGR valve problem keeps sticking open
- V6/Turbo Brakes
- c16xe engine loom into nova wires...some odd ones?
- Which radiator on a Corsa Let?
- corsa gsi
- Whate driveshafts on an xe nova??
- LET ECU and Tech 1 question
- is it worth getting a performance clutch
- Ecotec airflow meter
- c20xe running prob
- oil pressure on xe corsa
- boost valve
- C20XE wont start.
- Flywheel - heat cracks
- highest BHP an XE can handle?
- Astra GSi Turbo Smoking???
- astra 1.6 8v fan belt
- Turbokit C20LET C20XE Stage 3 Super Response vauxhall
- new 2ltr 16v nova conversion with no spark
- arp head studs
- 16xe manifolds onto x18xe1/z18xe head?
- Removing bottom pulley C20XE- Help??
- confusion then loss of power
- Do my spark plugs look ok?
- Oil leak from sump sensor
- what box on a z20let?
- cam with longer duration?
- Cavalier diesel digi-dash?
- injectors vid
- Plastic crankshaft sensor?
- f28 gearbox / L-S-D convertion
- Let Not manging Boost
- Corsa XE Inlet Manifold question (with Pic)
- Help xe plug holes filling up with coolent
- c20let oil pump
- 2.0 xe oil in water tank!
- gearboxes
- juddering problem on R reg. Astra 1.6 8v
- Engine mount/drive belt problems
- What Engine Oil For X16xel?
- WTF is going on with my TPS??????????
- Corsa LET, F20 to F28 - Worth it?
- Corsa 1.0 12v Conversion To A V6
- How to diagnose Dizzy Cap And Coil
- Mounting a 20XE/LET into a Corsa C??
- Bottom end rebuild? my 'no oil pressure' outcome...
- X18XE1 - Z18XE1 Misfire
- nova engine swap xe for let
- Anti Rollbars On Xe Nova Yes Or No
- gearing ????
- X16XE sparks plugs - have a look at this please - what do you think?
- X20XEV wiring questions
- 1.8 ecotec... My F18 blew up!
- xe fuel pressure reading
- oil pressure problem and tapping once warm
- new lifters in v6 still ticking help
- unichip price??
- c20let oil pressure problem
- Exhaust temp sensors
- Crankshaft
- Problems since my boost pipe blew off
- exhaust back box
- C20XE - what hoses do these connect to ?? help !
- Another Clet wiring question
- Finally got my breather system sorted from my 2.2 mod (56k ok)
- Throttle bodies for Z18XE
- 2ltr turbo conversion
- Cam Bearing Caps
- Corsa Gearbox !
- gearbox swap!
- LET head refitting
- 1600 turbo second opinion
- any 1 know where i can get a tps from? and how much?
- ECU & key chip
- few f28 gearbox questions!
- Adjust calibra 4x4 handbrake cable (osr)
- C20XE corsa clutch cable
- engine management light : Vectra GSI
- fitting a twin exit exhaust?
- Who makes stuff from Carbon ???
- ASTRA X16XEL Performance
- Z20LET oil pump on a C20LET block
- Corsa 2.0 Inlet Manifold removal help
- X16XEL teething problems
- turbo cams
- Cam lift/duration etc.
- What the hells just fell in to my downpipe ? (LET)
- f20 onto c20let
- nova fuel tank
- Safe rev limit for XE with 45's
- alternator belt pics?
- carbs filters?
- Corsa XE 1/4 mile times??
- I've just blown up my Corsa Let
- need to know what this connects to
- XE rods in 8v
- ecotec series con rod pillow blocks
- c20xe wont rev past 3500rpm
- superchip
- which air filter ?
- Astra 1.4 8v MPi Problems. Possibly Not Getting Fuel???
- LET into 7-type of thing?
- MK4 Astra SRi Engine Mod
- C20XE Ignition module???
