Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 [72] 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. ARGHHH! engine mount bolts!
  2. Turbo kit for a 1.8SEH 8v
  3. What parts r needed 2 run carbs on c20xe?
  4. Corsa C20XE Fuel Pump Voltage
  5. XE/LET double valve springs
  6. timing on late type c20xe enigne any hints
  7. C16Xe air flow meter
  8. info needed
  9. sump gasket cally turbo
  10. Let started, few questions
  11. turbo clocks into m3 cav
  12. Kangaroo gte Red top??
  13. Corsa 1.6 sport 1999 gearbox help
  14. fitting a C20 LET into a Mk4 Astra, Whats required
  15. Autosprint cams?
  16. intercooler
  17. More power out of my diesel
  18. Dump valve on Z20let
  19. nova let suspension
  20. ebay hydraulic c20xe lifters-any good
  21. garret gt3271 on alet help needed
  22. F28 Theory
  23. Engine Temperature Gauge
  24. let running rough inter.
  25. c20let calibra 4x4 problem
  26. RP Labs mapping software
  27. looking for a mantzel inlet manifold
  28. xe oil press releae valve
  29. is the running temp of calibra turbo right?
  30. F28 Advice needed please.
  31. std LET in 6th gear boosting 13psi...why?
  32. misfire problem with XE
  33. fuel pump groaning noise any ideas?
  34. C20LET - not sparking
  35. Hyrdro clutch in a mk2 cav
  36. quick question icv loom icv red plug or black?
  37. XE nova quickshift
  38. c20let corsa gsi
  39. oil pressure release valve sticking
  40. LET wire into mk4 astra diagnostic plug
  41. Corsa throttle body
  42. Sach clutches or LUX clutches?
  43. Alternator fouling throttle bodies
  44. ecotec brain problems HELP!!
  45. ecotec throttle body
  46. F28 into Astra GSI
  47. Torque Settings (LET)
  48. Engine swap or repair??
  49. LSD ????
  50. oil pressure/temp senders => what gauges?
  51. corsa b c20xe brake problem (spongy pedal)
  52. LET High Idling
  53. 20seh timing belt removal???
  54. Dastek Unichip - any good?
  55. Manta fuel and temp gauges not working!
  56. loom help!!
  57. F20 Problem, Jammed !!??
  58. driveshafts
  59. f16 gears into f20
  60. C16xe head z18xe bottom end?
  61. Fuel relay by-pass c20xe?
  62. nova radiator quick question
  63. Frontera 2.0 clutch, ideas on price please?
  64. Mk3 GSI Turbo Owners - Advice
  65. problem cav ecotec
  66. steering pump
  67. C20LET - Head gasket help
  68. zero compression c20let
  69. any info on cs10 courtenay heads and the eco
  70. How to clear ECU errors - Ecotec GSi
  71. 8v Engine
  72. F20 Vs F28 ?????
  73. Astra 1.8SXI 2 DOOR MK4 GEARBOX????
  74. astra 1.6 16v lossing oil
  75. 115 bhp 1.4. What mods next though?
  76. newbie's astra gsi c20let probs
  77. omega XEV
  78. 1.6 8V in To 1.6 16V
  79. f13 gearlinkage the same as f18?
  80. Bolt on turbo to 2l16v calibra?
  81. dump valve on Z20LET
  82. Spark Plug Heat Range
  83. Big end bearings C20Let
  84. v6 oil filter location
  85. location of crank sensor on xe
  86. C20let In To A Corsa
  87. Nova 20xe no spark! can anyone help?
  88. Calling People With Coilovers
  89. how do you get let dump valve to flutter
  90. nova ready for engine???
  91. cavalier x20xev into a vectra
  92. how many litres of oil in x25xe
  93. x14xe..cam belt covers!
  94. Header tank pressure cap
  95. Let Tank Vent/hot Start Valve
  96. fuel cell for nova - injection, where?
  97. SBD Titanium valve caps / springs
  98. C20LET Question
  99. Standard head gasket, thickness, x16xe
  100. Impressive Standard C20let 13.7 1/4 Mile
  101. c20xe running prob
  102. Pressure in cooling system
  103. Coscast head depth issues, any help appreciated!!
  104. My nova won't start
  105. Oil Pressure
  106. C20LET - Rad - standard intercooler
  107. Reputable turbo friendly garage needed (or some turbo advice)
  108. Can driving in too higher gear over time damage a diff?
  109. what is needed to fit an f28 to a c16xe in a corsa?
  110. what uis needed to fit an f28 to a c16xe in a corsa?
  111. Adjusting clutch cable
  112. c20let How much boost
  113. new oil pump, different tapets- still taps it knackers off
  114. ECU Information 4 Motronic
  115. LET inlet manifold breather question.
  116. head problem.
  117. Got fuel pump, spark but no injector pulse?
  118. Ford Sierra RS Cosworth 2wd T5 Gear Box...any good?
  119. ashley exhausts
  120. Anyone know what this engine is (bike)
  121. Urgent HELP required on x16xel engine
  122. Snapped stud in head,welding in situ - advice needed
  123. Thread stripped on my C20LET block
  124. Please Help Motronic 2.7. PICTURE IS HERE
  125. Engine swap
  126. GT series turbo
  127. Valver brakes are leakin
  128. oil filter help
  129. Corsa C Engine Fault?????
  130. Replacing tappets ?
  131. 20xe carb dizzy
  132. F15 gearbox oil level
  133. Dry tappets what to do befor putting it back together.
  134. ram air filter
  135. xe in sh*t
  136. fuel regulators
  137. Making a custom Loom
  138. C20LET and F20 gearbox?
  139. Ecotech 1800 16v cylinder head
  140. carbon fibre nova bonnet where?
  141. C20LET ECU unit
  142. Corsa B 1.4SRi Non-Start
  143. Magnecor Leads for C20LET Query
  144. fuel pressure on xe
  145. water pump probs on sri 130 in nova
  146. Xe- let crank in an ecotec block
  147. anyone got a pic of a fuel rail blanking plate?
  148. Oil pressure switch---corsa
  149. Oil light flashing when warm?
  150. Nova coilover advice
  151. EDS Phase 3.5 Wiring Help
  152. emissions test on XE
  153. dimension of 8v valves?
  154. LET Air Flow Meter Gen? (unplug = run great)
  155. 97 GSi Engine Management issue
  156. Injector cleaning...
  157. Bosch injector query - 440cc
  158. Astra mk3 C20let converstion
  159. Getting OBD software to work with the LET?
  160. Best oil for the f28
  161. Indicator Bulb Replacemnt Astra GSI Mk 4
  162. Diesel glow plugs problem
  163. Help corsa xe over heating prob !
  164. X20XEV - Z20LET Valves
  165. F23 gearbox - LSD installation question
  166. MkIV Astra Brakes - Question
  167. VW programmable wiper relay 357 955 531
  168. 1.8e engine? valves?
  169. Performance Manifold
  170. xe/let coil packs
  171. Front Mount Intercooler Nova
  172. Cally turbo failled mot on emssions
  173. engine code
  174. 8v Turbo Cylinder head pics.
  175. Immobiliser light came on
  176. f28 linkage in to a corsa help help
  177. c20xe rings
  178. Charlie18's C20LET conversion.
  179. calibra turbo problem :(
  180. Help needed please. Clutch kits
  181. camber help! URGENT
  182. wanted:pic of Astra mk3 GSI V-belt routing with PAS
  183. c20ne valves question
  184. xe prob
  185. x20xe into corsa gsi?
  186. nova xe springs
  187. best place for head work on an eco???
  188. engine worries
  189. Cav Ecotec - crank sensor playing up
  190. Are these turbo pistons
  191. Running LET ECU wires thru bulkhead NOVA
  192. f28 in to a corsa
  193. new pistons from vauxhall
  194. f28/f20 clutch/flywheel qs
  195. f28 fitment
  196. few vectra engine change questions?
  197. new oil pump- good pressure but taps like fook when warm
  198. let build list<> help suggestions please
  199. Gearbox probs
  200. c20xe into 93 corsa gsi
  201. how much power do veccy sports make
  202. LET owners who had crank sensor problems
  203. xe inlet cam on let
  204. Engine point: 1.6 8v wiht 1.2 dist. covers
  205. Is this a pot flywheel?
  206. Info needed on BERU XE leads
  207. bosch 440cc injector q's
  208. Misfire
  209. Strange LET Problem
  210. corsa fse boost valve
  211. corsa xe conversion, - help what bits do i need
  212. astra mk4 2.0l sri - bhp
  213. another let problem wooo
  214. Intercooler pipework on c20let
  215. has any1 else put a c20let into 8v calibra? if so plz help!
  216. Corsa turbo, What intercooler?
  217. Corsa C20XE power steering pum support
  218. C20XE clutch
  219. How do you set the fuel pressure on a sard fuel pressure regulator
  220. what cam? c16xe
  221. Nova 2ltr or turbo top rad hose
  222. will phase 3 eds work with a T34?
  223. How to remove the wastegate arm on c20let
  224. Corsa C20LET, Cooling problems
  225. Arrow steel rods
  226. let code 121 what does it mean
  227. X16XE, runs ok, then no start, the ok again (???)
  228. Air/Fuel Gauge + O2 Sensor Help
  229. F28 synchro problems!!!!!!
  230. F28 speedo problems!!!!
  231. exhaust rear section - what's easier?
  232. Tigra needs a tune up - what can i expect from a garage?
  233. 20xe loom problems
  234. A real engine management Head Scratcher.
  235. Gearbox oil leak
  236. Ecotec throttle bodies help
  237. Lambda sensor Weld in boss
  238. c20xe tps switch 2 different types?
  239. Regal Bhp increase figures??
  240. T34 turbo on a let
  241. URGENT URGENT - What chemical to remove the vx rust protection stuff on engine block?
  242. turbocharging a honda b16a
  243. c20let fault codes read-results
  244. "Spare" plug on Astra H 1.8
  245. EGR blanking plates
  246. ecu/chip problems on my let nova
  247. transfer box question
  248. astra 1.4
  249. 1.4 astra
  250. 1998 1.6 8V Engine To A 03 1.8 16v
